Home » Language IDEs » AspectJ » How to add aspects to multiple eclipse plugin projects?
How to add aspects to multiple eclipse plugin projects? [message #35582] Mon, 10 May 2004 21:26 Go to next message
Originally posted by: Michael-Scharf.gmx.de
I want to "aspectize" multiple projects with AJDT/aspectj.
Suppose, I want to add a simple tracing aspect to all
public methods that are called "run".
public aspect TraceRun {
pointcut run(): execution(public * *.run(..));
before() : run() {
System.out.println("TRACE "+thisJoinPoint);
I want to add this aspect to the entire workbench or
at a set of projects. Ideally I would like to have
independent plugins/projects with aspects and "inject"
the code into my unmodified eclipse plugins. Is this
possible?
Here some concrete questions:
- Is aspectj supported for eclipse plugins or only for
stand alone applications?
- How to best add aspects to a a set of plugin projects?
- Can aspects cross project/plugin boundaries?
- Is there a better way than to copy the aspect into
each project?
<library name=" c:/eclipse/3.0M8/eclipse/plugins/org.aspectj.ajde_1.1.8/aspe ctjrt.jar ">
<export name="*"/>
</library>
- How to add the aspectjrt.jar to the projects?
- It is not clear to me where to put the lib for
plugin projects. I ended up adding the absolute
path "Runtime Library" into each plugin.xml
- How can I control adding the aspect (changes in the
.lst file seems to have no effect on plugins)
- Can I add the aspect without modifying existing projects?
Thanks for listening
Michael
Re: How to add aspects to multiple eclipse plugin projects? [message #35820 is a reply to message #35582] Wed, 19 May 2004 00:53 Go to previous messageGo to next message
I am also interested in a solution for this.
I would like to use a separate project for my aspects, and having the
aspects dynamically link to other projects that marks it as dependent.
"Michael Scharf" <Michael-Scharf@gmx.de> wrote in message
news:c7p9ob$3s3$1@eclipse.org...
> before() : run() {
> possible?
> each project?
> <library
> <export name="*"/>
> </library>
> Michael
Re: How to add aspects to multiple eclipse plugin projects? [message #38259 is a reply to message #35820] Wed, 14 July 2004 09:28 Go to previous messageGo to next message
Corville or Michael,
I am hoping that one of you can provide me with some guidance since it does
not appear that I am getting responses from my other postings. What I am
simply trying to do is develope a eclipse plugin project that adds some
debugging/tracing support to one or more of the org.eclipse.emf projects (or
any other org.eclipse plugin). The plugin containing my aspects depends
upon those org.eclipse projects. It compiles successfully and appears to
correctly modify the appropriate class files (I also see the aspect class
file within the output jar). I encounter problems when I try running my
application in the Eclipse runtime environment. When the pointcut is
encountered in the org.eclipse
code I get a java.lang.NoClassDefFoundError exception listing my aspect
class.
Do the aspects and the code containing the join points need to be in the
same Eclipse project? That would seem to severly limit the power of
cross-cutting multiple projects. How do Eclipse project dependencies and
project classloaders work with aspects and AJDT?
Any help you can provide would be greatly appreciated. Thanks
Dennis Fuglsang
"Corville Allen" <corville@us.ibm.com> wrote in message
news:c8eorl$9d4$1@eclipse.org...
> > Hi,
> > before() : run() {
> > possible?
> > each project?
> > <library
> > <export name="*"/>
> > </library>
> > Michael
Re: How to add aspects to multiple eclipse plugin projects? [message #38292 is a reply to message #38259] Wed, 14 July 2004 16:57 Go to previous messageGo to next message
Originally posted by: george_harley.ntlworld.com
Hi Dennis,
Does your plug-in have a dependency on the org.aspectj.ajde plug-in ? If
not, how are you adding the necessary aspectjrt.jar to your plug-in's
runtime classpath ?
George
> class.
> Dennis Fuglsang
>>>Hi,
>>>before() : run() {
>>>possible?
>>> each project?
>>> <library
>>> <export name="*"/>
>>> </library>
>>>Michael
Re: How to add aspects to multiple eclipse plugin projects? [message #38358 is a reply to message #38292] Thu, 15 July 2004 10:06 Go to previous messageGo to next message
Thank you for your reply George,
The plugin project containing the aspects, call it "dev", is an AspectJ
project so that build path has a reference to the aspectjrt.jar. The
project I am trying to pointcut, org.eclipse.emf.ecore, I have added
org.aspectj.ajde as a project dependency. Still when I launch my
application, contained in a plugin project called "test", I encounter a
java.lang.NoClassDefFoundError exception when the pointcut is encountered in
the org.eclipse.emf.ecore plugin. Do I only need aspectjrt.jar in the
runtime classpath of the plugins that were modified? Any suggestions?
Thanks in advance,
Dennis Fuglsang
"George Harley" <george_harley@ntlworld.com> wrote in message
news:cd46ll$cnk$1@eclipse.org...
> Hi Dennis,
> runtime classpath ?
> Best regards,
> George
does
am
(or
to
class
my
> > class.
and
> > Dennis Fuglsang
> >>>Hi,
> >>>before() : run() {
> >>>possible?
> >>> each project?
> >>> <library
> >>> <export name="*"/>
> >>> </library>
> >>>Michael
Re: How to add aspects to multiple eclipse plugin projects? [message #38525 is a reply to message #38358] Thu, 15 July 2004 19:46 Go to previous messageGo to next message
Hi Dennis,
So, if I understand correctly, your setup is as follows...
1. Plug-in project called "dev". Has AspectJ nature, contains aspects.
2. Plug-in project org.eclipse.emf.core. Does this have an AspectJ
nature ? Does it contain any aspect code ? Have you woven in your
aspects (from "dev") ? Did you carry out binary weaving against any jars
in this project or are you building against its source ?
3. Plug-in project called "test". Does this have an AspectJ nature ? Is
it just ordinary Java calling into your org.eclipse.emf.core plug-in ?
Assuming the above summary is correct (?), how have you configured the
dependencies between these different plug-ins ? Where are your compiled
aspects at runtime and where are the classes that you have woven into ?
I would really like to help you out here but until I get a better
understanding of the topography of your workbench then I am of limited
use (even more than usual!). If you want to mail me off-group with more
details on your projects then I will see what I can do. What you are
trying to do *should* be possible...
George
> Thanks in advance,
> Dennis Fuglsang
>>Hi Dennis,
>>runtime classpath ?
>>Best regards,
>>George
> does
> am
> (or
> to
> class
> my
>>>class.
> and
>>>Dennis Fuglsang
>>>>>Hi,
>>>>>before() : run() {
>>>>>possible?
>>>>> each project?
>>>>> <library
>>>>> <export name="*"/>
>>>>> </library>
>>>>>Michael
Re: How to add aspects to multiple eclipse plugin projects? [message #39100 is a reply to message #38525] Thu, 22 July 2004 15:59 Go to previous message
George,
Thank you for your responses and your offer to work with me offline. I have
solved my mysterious NoClassDefFoundError. The plugin.xml for the project
we were "aspectizing" contained a package prefix declaration that defines
the list of package prefixes for the runtime library. The problem was that
the list of package prefixes did not include the package for the aspect I
was weaving into the project. In other words, even though my output jar
from the AspectJ compiler included my aspect class the classloader for that
plugin could not find it because it was not in the "org.eclipse.emf.core*"
package. I had looked at the plugin.xml numerous times but for some reason
I was discounted the <packages prefixes> as a problem.
<requires>
<import plugin="org.apache.xerces"/>
<import plugin="org.eclipse.core.resources"/>
<import plugin="org.eclipse.emf.common" export="true"/>
<import plugin="org.aspectj.ajde"/>
</requires>
<runtime>
<library name="runtime/ecore_AOP.jar">
<export name="*"/>
</library>
<library name="runtime/ecore.jar">
<export name="*"/>
<packages prefixes="org.eclipse.emf.ecore"/> <<<<<<============ this
was my problem
</library>
</runtime>
Once I removed the package prefix list in my plugin.xml the aspects started
working. Yaaaahoooo!
--Dennis Fuglsang
news:cd74tl$49m$1@eclipse.org...
> Hi Dennis,
> Best regards,
> George
encountered in
> > Thanks in advance,
> > Dennis Fuglsang
> >>Hi Dennis,
> >>runtime classpath ?
> >>Best regards,
> >>George
> > does
> > am
projects
> > (or
depends
> > to
> > class
> > my
> >>>class.
the
> > and
> >>>Dennis Fuglsang
> >>>>>Hi,
> >>>>>before() : run() {
> >>>>>possible?
> >>>>> each project?
> >>>>> <library
> >>>>> <export name="*"/>
> >>>>> </library>
> >>>>>Michael
Re: How to add aspects to multiple eclipse plugin projects? [message #579685 is a reply to message #35582] Wed, 19 May 2004 00:53 Go to previous message
> before() : run() {
> possible?
> each project?
> <library
> <export name="*"/>
> </library>
> Michael
Re: How to add aspects to multiple eclipse plugin projects? [message #581326 is a reply to message #35820] Wed, 14 July 2004 09:28 Go to previous message
class.
Dennis Fuglsang
> > Hi,
> > before() : run() {
> > possible?
> > each project?
> > <library
> > <export name="*"/>
> > </library>
> > Michael
Re: How to add aspects to multiple eclipse plugin projects? [message #581345 is a reply to message #38259] Wed, 14 July 2004 16:57 Go to previous message
Hi Dennis,
runtime classpath ?
George
> class.
> Dennis Fuglsang
>>>Hi,
>>>before() : run() {
>>>possible?
>>> each project?
>>> <library
>>> <export name="*"/>
>>> </library>
>>>Michael
Re: How to add aspects to multiple eclipse plugin projects? [message #581388 is a reply to message #38292] Thu, 15 July 2004 10:06 Go to previous message
Thanks in advance,
Dennis Fuglsang
> Hi Dennis,
> runtime classpath ?
> Best regards,
> George
does
am
(or
to
class
my
> > class.
and
> > Dennis Fuglsang
> >>>Hi,
> >>>before() : run() {
> >>>possible?
> >>> each project?
> >>> <library
> >>> <export name="*"/>
> >>> </library>
> >>>Michael
Re: How to add aspects to multiple eclipse plugin projects? [message #581521 is a reply to message #38358] Thu, 15 July 2004 19:46 Go to previous message
Hi Dennis,
George
> Thanks in advance,
> Dennis Fuglsang
>>Hi Dennis,
>>runtime classpath ?
>>Best regards,
>>George
> does
> am
> (or
> to
> class
> my
>>>class.
> and
>>>Dennis Fuglsang
>>>>>Hi,
>>>>>before() : run() {
>>>>>possible?
>>>>> each project?
>>>>> <library
>>>>> <export name="*"/>
>>>>> </library>
>>>>>Michael
Re: How to add aspects to multiple eclipse plugin projects? [message #582037 is a reply to message #38525] Thu, 22 July 2004 15:59 Go to previous message
George,
<requires>
</requires>
<runtime>
<export name="*"/>
</library>
<export name="*"/>
was my problem
</library>
</runtime>
--Dennis Fuglsang
> Hi Dennis,
> Best regards,
> George
encountered in
> > Thanks in advance,
> > Dennis Fuglsang
> >>Hi Dennis,
> >>runtime classpath ?
> >>Best regards,
> >>George
> > does
> > am
projects
> > (or
depends
> > to
> > class
> > my
> >>>class.
the
> > and
> >>>Dennis Fuglsang
> >>>>>Hi,
> >>>>>before() : run() {
> >>>>>possible?
> >>>>> each project?
> >>>>> <library
> >>>>> <export name="*"/>
> >>>>> </library>
> >>>>>Michael
Previous Topic:Feedback on AJDT 1.1.11
Next Topic:Feedback on AJDT 1.1.11
Current Time: Sat Jul 26 19:26:23 EDT 2025
Powered by FUDForum. Page generated in 0.66226 seconds
