Home » Archived » Service Oriented Architecture Tools Platform (STP) » Re: [stp-newsgroup] xalan dependency
Re: [stp-newsgroup] xalan dependency [message #374027] |
Wed, 05 July 2006 12:09  |
This is a multipart message in MIME format.
--=_alternative 0058CE50852571A2_=
Content-Type: text/plain; charset="US-ASCII"
Hi David,
Yes, the dependency on org.apache.xml.utils.QName is needed. I am not
sure what this class was introduced but it is part of Xalan 2.7.0 which
is included in the supported JRE's (1.4.2 or later). What JRE have you
installed?
Sebastian Carbajales
David Black <david.black@capeclear.com>
Sent by: stp-newsgroup-bounces@eclipse.org
07/03/2006 03:12 AM
Please respond to
"Gateway between eclipse.stp and stp-newsgroup"
<stp-newsgroup@eclipse.org>
To
cc
Subject
(apologies if anyone has already received this via the mailing lists, its
not clear to be whether those lists are currently in use)
I've just grabbed the latest stp code from dev.eclipse.org:/cvsroot/stp,
loaded the various projects into Eclipse 3.2 (callisto rc7). I'm seeing
a few build errors, including:
org.apache.xml.utils.QName cannot be resolved to a type
in the org.eclipse.stp.core.saf.ui plugin. Is this supposed to be in
there?
If so, which version of xalan is being used, am I missing a plugin?
thanks
David Black
Cape Clear Software
_______________________________________________
stp-newsgroup mailing list
https://dev.eclipse.org/mailman/listinfo/stp-newsgroup
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Hi David,</font>
<br>
<br><font size=2 face="sans-serif">Yes, the dependency on </font><tt><font size=2>org.apache.xml.utils.QName</font></tt><font size=2 face="sans-serif">
is needed. I am not sure what this class was introduced but it is
part of Xalan 2.7.0 which is included in the supported JRE's (1.4.2
or later). What JRE have you installed? </font>
<br><font size=2 face="sans-serif"><br>
Regards,<br>
<br>
Sebastian Carbajales</font>
<br>
<br>
<br>
<br>
<table width=100%>
<tr valign=top>
<td width=40%><font size=1 face="sans-serif"><b>David Black <david.black@capeclear.com></b>
</font>
<br><font size=1 face="sans-serif">Sent by: stp-newsgroup-bounces@eclipse.org</font>
<p><font size=1 face="sans-serif">07/03/2006 03:12 AM</font>
<table border>
<tr valign=top>
<td bgcolor=white>
<div align=center><font size=1 face="sans-serif">Please respond to<br>
"Gateway between eclipse.stp and stp-newsgroup" <stp-newsgroup@eclipse.org></font></div></table>
<br>
<td width=59%>
<table width=100%>
<tr valign=top>
<td>
<div align=right><font size=1 face="sans-serif">To</font></div>
<td><font size=1 face="sans-serif">stp-newsgroup@eclipse.org</font>
<tr valign=top>
<td>
<div align=right><font size=1 face="sans-serif">cc</font></div>
<td>
<tr valign=top>
<td>
<div align=right><font size=1 face="sans-serif">Subject</font></div>
<td><font size=1 face="sans-serif">[stp-newsgroup] xalan dependency</font></table>
<br>
<table>
<tr valign=top>
<td>
<td></table>
<br></table>
<br>
<br>
<br><tt><font size=2>Hi,<br>
<br>
<br>
not clear to be whether those lists are currently in use)<br>
<br>
<br>
seeing <br>
a few build errors, including:<br>
<br>
org.apache.xml.utils.QName cannot be resolved to a type<br>
<br>
in the org.eclipse.stp.core.saf.ui plugin. Is this supposed to be in there?
<br>
If so, which version of xalan is being used, am I missing a plugin?<br>
<br>
thanks<br>
<br>
---------------------------------------<br>
David Black<br>
Cape Clear Software<br>
<br>
<br>
_______________________________________________<br>
stp-newsgroup mailing list<br>
stp-newsgroup@eclipse.org<br>
https://dev.eclipse.org/mailman/listinfo/stp-newsgroup<br>
</font></tt>
<br>
--=_alternative 0058CE50852571A2_=--
Re: [stp-newsgroup] xalan dependency [message #374028 is a reply to message #374027] |
Wed, 05 July 2006 12:46  |
Hi Sebastian,
Thanks for the reply.
In JDK/JRE 1.4.2 xalan is included in the rt.jar. I am actually using 1.5
(precisely: 1.5.0_06) to run Eclipse and compile against (but with 1.4 compliance
level), and there it is not included in rt.jar. A quick look through other
jars and I don't see it. Hmm, has it been moved/removed in 1.5 ?
regards
David
> Hi David,
> not sure what this class was introduced but it is part of Xalan 2.7.0
> which is included in the supported JRE's (1.4.2 or later). What JRE
> have you installed?
> Regards,
> 07/03/2006 03:12 AM
> Please respond to
> To
> cc
> Subject
> its not clear to be whether those lists are currently in use)
> dev.eclipse.org:/cvsroot/stp, loaded the various projects into
> Eclipse 3.2 (callisto rc7). I'm seeing a few build errors, including:
> there? If so, which version of xalan is being used, am I missing a
> plugin?
> thanks
> David Black
> Cape Clear Software
Re: [stp-newsgroup] xalan dependency [message #580894 is a reply to message #374027] |
Hi Sebastian,
regards
David
> Hi David,
> have you installed?
> Regards,
> 07/03/2006 03:12 AM
> Please respond to
> To
> cc
> Subject
> plugin?
> thanks
> David Black
> Cape Clear Software
Current Time: Sun Jul 27 06:42:19 EDT 2025
Powered by FUDForum. Page generated in 0.23999 seconds
