Home » Eclipse Projects » DSDP - Target Management » Programatically creating a telnet connection?
Re: Programatically creating a telnet connection? [message #34836 is a reply to message #34767] |
Wed, 29 April 2009 10:21   |
Hello John,
Right now there is no official API for programmatically creating a
connection. You can do it today through internal non-API with this snippet:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=185348#c16
https://bugs.eclipse.org/bugs/show_bug.cgi?id=185348#c19
With respect to version numbering, the bundle versions are almost always
different than the product versions since they evolve based on different
rules ("technical versions" vs. "market version").
http://wiki.eclipse.org/Version_Numbering
In short, a bundle version is only incremented if that bundle changes.
The version of the entire TM/RSE product, however, is incremented on
every release. That's why after some time, the versions differ.
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
John Moule wrote:
> I'd like to programmatically create a telnet session, supplying the host
> and port as parameters, which opens in a Terminal view.
> I've read a previous post (sorry couldn't figure how to reply to that
> thread):
> Programatically creating a connection?
> http://dev.eclipse.org/newslists/news.eclipse.dsdp.tm/msg002 29.html
> and followed the bug:
> Need API to programmatically open the terminal for a specified connection
> I've downloaded TM-terminal-3.0.3.zip and studied the
> org.eclipse.tm.terminal, but am now totally confused as to the API I
> should use to proceed.
> Please can anyone provide a short snippet of how I could get started
> with this.
> Also I'm confused about the version numbering of org.eclipse.tm.terminal
> - as I said I downloaded (from
> http://download.eclipse.org/dsdp/tm/downloads/drops/R-3.0.3- 200902181300/)
> TM-terminal-3.0.3.zip, but this expands to plugins with versions
> starting "2" (eg: org.eclipse.tm.terminal_2.0.3.v200902181600.jar).
> Any help gratefully received.
> Cheers john
Re: Programatically creating a telnet connection? [message #34900 is a reply to message #34836] |
Fri, 01 May 2009 08:27   |
Hi Martin,
thanks for your reply.
I've adapted the code snippet to my needs, simply replacing Ssh with
Telnet, thus:
* Adapted from the following bug:
* [terminal][api] Need API to programmatically open the terminal for a
* https://bugs.eclipse.org/bugs/show_bug.cgi?id=185348#c16
private void startTelnetSession(String host, String networkPort) {
ITerminalConnector conn =
TerminalConnectorExtension.makeTerminalConnector(
"org.eclipse.tm.internal.terminal.telnet.TelnetConnector");
if(conn != null) {
//force instantiating the real connector
conn.makeSettingsPage();
TelnetConnector telnetc =
(TelnetConnector)conn.getAdapter(TelnetConnector.class);
if (telnetc != null) {
TelnetSettings settings = (TelnetSettings)
telnetc.getTelnetSettings();
settings.setHost(host);
settings.setNetworkPort(networkPort);
terminal.setConnector(conn);
conn.connect();
... but get compilation errors on the last two lines. I've a couple of
questions:
1) what is the definition of terminal?
2) In my ITerminalConnector
(org.eclipse.tm.terminal_2.0.3.v200902181600.jar) connect has a different
defintion:
void connect(ITerminalControl control);
Thanks for any help.
cheers john
Martin Oberhuber wrote:
> Hello John,
> Cheers,
> John Moule wrote:
>> Hi,
>> thread):
>> with this.
>> Cheers john
Re: Programatically creating a telnet connection? [message #34964 is a reply to message #34900] |
Tue, 12 May 2009 13:36  |
Hi John,
the definition of "terminal" comes from this code:
which is referenced here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=185348#c4
instead of conn.connect() I think you need
terminal.connectTerminal();
John Moule wrote:
> Hi Martin,
> Telnet, thus:
> if(conn != null) {
> conn.connect();
> questions:
> different defintion:
> cheers john
>> Hello John,
>> snippet:
>> always different than the product versions since they evolve based on
>> different rules ("technical versions" vs. "market version").
>> Cheers,
>> John Moule wrote:
>>> Hi,
>>> host and port as parameters, which opens in a Terminal view.
>>> thread):
>>> connection
>>> with this.
>>> org.eclipse.tm.terminal - as I said I downloaded (from
>>> Cheers john
Re: Programatically creating a telnet connection? [message #580577 is a reply to message #34767] |
Hello John,
John Moule wrote:
> thread):
> with this.
> Cheers john
Re: Programatically creating a telnet connection? [message #580617 is a reply to message #34836] |
Hi Martin,
Telnet, thus:
if(conn != null) {
conn.connect();
questions:
defintion:
cheers john
> Hello John,
> Cheers,
> John Moule wrote:
>> Hi,
>> thread):
>> with this.
>> Cheers john
Re: Programatically creating a telnet connection? [message #580654 is a reply to message #34900] |
Hi John,
John Moule wrote:
> Hi Martin,
> Telnet, thus:
> if(conn != null) {
> conn.connect();
> questions:
> cheers john
>> Hello John,
>> snippet:
>> Cheers,
>> John Moule wrote:
>>> Hi,
>>> thread):
>>> connection
>>> with this.
>>> Cheers john
Current Time: Wed Jul 23 07:39:23 EDT 2025
Powered by FUDForum. Page generated in 0.31186 seconds
