How to build Nebula projects from CVS [message #32014] |
Mon, 26 March 2007 10:10  |
Originally posted by: dfayerma.wyeth.com
--____MMSZIQEGSVWCVTVDSXEZ____
Content-Type: text/plain; charset=iso-8859-1
Content-Transfer-Encoding: quoted-printable
I'm trying to get the Nebula projects from CVS.
I checked out all projects under org.eclipse.swt.nebula. I also got the =
org.eclipse.jface from HEAD.
The problem is that I can not get most of the nebula projects to compile.
1. I see duplicated code between org.eclipse.nebula.widgets.* projects and =
the code inside the org.eclipse.swt.nebula.widgets project. I assume some =
of the the widgets are migrated to the org.eclipse.swt.nebula.widgets =
project?
2. org.eclipse.swt.nebula.nebface project does not compile because some of =
the required plugins are missing the source code directory and some are =
not in CVS at all.
Does anybody know how to get the full source code for nebula projects?
Content-Type: multipart/related; boundary="____ODEKGWBTQDJAVUNRIVTK____"
--____ODEKGWBTQDJAVUNRIVTK____
Content-Type: text/html; charset=windows-1252
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; charset=3Diso-8859-1"=
<META content=3D"MSHTML 6.00.2800.1589" name=3DGENERATOR></HEAD>
<BODY style=3D"MARGIN: 4px 4px 1px; FONT: 10pt Tahoma">
<DIV>I'm trying to get the Nebula projects from CVS.</DIV>
<DIV>I checked out all projects under org.eclipse.swt.nebula. I also got =
the org.eclipse.jface from HEAD.</DIV>
<DIV> </DIV>
<DIV>The problem is that I can not get most of the nebula projects to =
compile.</DIV>
<DIV> </DIV>
<DIV>1. I see duplicated code between org.eclipse.nebula.widgets.* =
projects and the code inside the org.eclipse.swt.nebula.widgets project. I =
assume some of the the widgets are migrated to the org.eclipse.swt.nebula.w=
idgets project?</DIV>
<DIV> </DIV>
<DIV>2. org.eclipse.swt.nebula.nebface project does not compile because =
some of the required plugins are missing the source code directory and =
some are not in CVS at all.</DIV>
<DIV> </DIV>
<DIV>Does anybody know how to get the full source code for nebula =
projects?</DIV>
<DIV> </DIV>
<DIV> </DIV></BODY></HTML>
--____ODEKGWBTQDJAVUNRIVTK____--
--____MMSZIQEGSVWCVTVDSXEZ____--
Re: How to build Nebula projects from CVS [message #32084 is a reply to message #32049] |
Mon, 26 March 2007 16:03   |
--____MQEFOCEJBEAXIIJQOPME____
Thanks, Chris,
Is there a place somewhere in CVS where I can find GridViewer code during =
this transition?
Dimitry.
>>> Chris Gross<chris.gross@us.ibm.com> 3/26/2007 1:00:35 PM >>>
Hi Dimitry,
We're going through a bit of a code reorganization. The=20
org.eclipse.nebula.widgets (and nebface) projects are going away. In=20
the future, all components will existing in their own project. That =
why=20
you see some duplication.
-Chris
the=20
> =20
compile.
> =20
> 1. I see duplicated code between org.eclipse.nebula.widgets.* projects=20=
assume=20
> some of the the widgets are migrated to the=20
> org.eclipse.swt.nebula.widgets project?
> =20
some=20
some=20
> =20
> =20
Content-Type: multipart/related; boundary="____RHOYVVMRKUMJCRCYIZGH____"
--____RHOYVVMRKUMJCRCYIZGH____
<HTML><HEAD>
<DIV>Thanks, Chris,</DIV>
<DIV>Is there a place somewhere in CVS where I can find GridViewer code =
during this transition?</DIV>
<DIV> </DIV>
<DIV>Dimitry.<BR><BR>>>> Chris Gross<chris.gross@us.ibm.com>=
3/26/2007 1:00:35 PM >>><BR></DIV>
<DIV style=3D"COLOR: #000000">Hi Dimitry,<BR><BR>We're going through a bit =
of a code reorganization. The <BR>org.eclipse.nebula.widgets (and =
nebface) projects are going away. In <BR>the future, all components =
will existing in their own project. That why <BR>you see some =
duplication.<BR><BR>Regards,<BR>-Chris<BR><BR>Dimitry Fayerman wrote:<BR>&g=
t; I'm trying to get the Nebula projects from CVS.<BR>> I checked out =
all projects under org.eclipse.swt.nebula. I also got the <BR>> =
org.eclipse.jface from HEAD.<BR>> <BR>> The problem is that I =
can not get most of the nebula projects to compile.<BR>> <BR>> =
1. I see duplicated code between org.eclipse.nebula.widgets.* projects =
<BR>> and the code inside the org.eclipse.swt.nebula.widgets project. I =
assume <BR>> some of the the widgets are migrated to the <BR>> =
org.eclipse.swt.nebula.widgets project?<BR>> <BR>> 2. =
org.eclipse.swt.nebula.nebface project does not compile because some =
<BR>> of the required plugins are missing the source code directory and =
some <BR>> are not in CVS at all.<BR>> <BR>> Does anybody =
know how to get the full source code for nebula projects?<BR>> =
<BR>> <BR><BR><BR></DIV></BODY></HTML>
--____RHOYVVMRKUMJCRCYIZGH____--
--____MQEFOCEJBEAXIIJQOPME____--
Re: How to build Nebula projects from CVS [message #32330 is a reply to message #32260] |
Wed, 28 March 2007 16:17  |
done!
Tom Schindl wrote:
> Just one minor thing would you mind updateing the JavaDoc and add me as
> a contributor in the GriViewer-classes? GridEditor is missing the
> Copyright completely.
> Tom
> Chris Gross schrieb:
>> The new Grid and GridViewer plugins are now in a useable state. You
>> can download them from the Nebula site:
>> http://www.eclipse.org/nebula/widgets/grid/grid.php
>> -Chris
>>> Thanks, Chris,
>>> Dimitry.
>>> Hi Dimitry,
>>> the future, all components will existing in their own project. That why
>>> Regards,
>>> -Chris
>>> got the
>>> to compile.
>>> projects
>>> assume
>>> because some
>>> some
>>> projects?
Re: How to build Nebula projects from CVS [message #580365 is a reply to message #32014] |
Mon, 26 March 2007 13:00  |
Hi Dimitry,
-Chris
> and the code inside the org.eclipse.swt.nebula.widgets project. I assume
> of the required plugins are missing the source code directory and some
Re: How to build Nebula projects from CVS [message #580394 is a reply to message #32049] |
Thanks, Chris,
this transition?
Dimitry.
Hi Dimitry,
why=20
-Chris
the=20
> =20
compile.
> =20
assume=20
> =20
some=20
some=20
> =20
> =20
<HTML><HEAD>
<DIV> </DIV>
Re: How to build Nebula projects from CVS [message #580471 is a reply to message #32084] |
Wed, 28 March 2007 15:10  |
The new Grid and GridViewer plugins are now in a useable state. You can
-Chris
> Thanks, Chris,
> Dimitry.
> Hi Dimitry,
> Regards,
> -Chris
Re: How to build Nebula projects from CVS [message #580536 is a reply to message #32190] |
Wed, 28 March 2007 15:17  |
Tom
> -Chris
>> Thanks, Chris,
>> Dimitry.
>> Hi Dimitry,
>> Regards,
>> -Chris
>> the
>> compile.
>> projects
>> assume
>> because some
>> projects?
Re: How to build Nebula projects from CVS [message #580596 is a reply to message #32260] |
done!
Tom Schindl wrote:
> Tom
>> -Chris
>>> Thanks, Chris,
>>> Dimitry.
>>> Hi Dimitry,
>>> Regards,
>>> -Chris
>>> got the
>>> to compile.
>>> projects
>>> assume
>>> because some
>>> some
>>> projects?
FUDForum. Page generated in 0.24704 seconds
