Home » Archived » GMT (Generative Modeling Technologies) » [OAW] dynamic evaluation of templates
[OAW] dynamic evaluation of templates [message #376862] Tue, 17 April 2007 07:21 Go to next message
I want to save my templates in a database, so I can only access them as
a string. All parameters (e.g. metamodel, model, ...) for the template
will also be provided from the memory. Is it possible to
programmatically expand such a template with OAW?
Thanks in advance.
Markus Herrmannsdörfer
Re: [OAW] dynamic evaluation of templates [message #376871 is a reply to message #376862] Sun, 22 April 2007 16:40 Go to previous message
this is not supported out of the box. however you could provide a
respective implementation of a resourceloader (in the workflow project),
which loads the inputstreams from the db (the default one uses a
classloader)
hope that helps,
Sven
Markus Herrmannsdoerfer wrote:
> Thanks in advance.
Re: [OAW] dynamic evaluation of templates [message #580393 is a reply to message #376862] Sun, 22 April 2007 16:40 Go to previous message
classloader)
hope that helps,
Sven
> Thanks in advance.
Previous Topic:[TCS]User issues
Next Topic:[OAW] import of an ecore MM in XPAND template
Current Time: Wed Jul 23 19:04:38 EDT 2025
Powered by FUDForum. Page generated in 0.03262 seconds
