Home » Eclipse Projects » JavaServer Faces » run "WTP JSF Tools Tutorial" with requested resource is not available
run "WTP JSF Tools Tutorial" with requested resource is not available [message #470816] Wed, 21 December 2005 00:45 Go to next message
Originally posted by: bolixie.gmail.com
I create the FirstJsfApp under the direction in "WTP Tutorials -
JavaServer Faces Tools(Milestone1) Tutorial"
but when i run the login.jsp tomcat reports bellow
type Status report
message /FirstJSFApp/login.faces
description The requested resource (/FirstJSFApp/login.faces) is not
available.
Apache Tomcat/5.5.9
plz tell me what is wrong with me?
my eclipse version is 3.1.1;wtp jsf tool version is 1
Re: run "WTP JSF Tools Tutorial" with requested resource is not available [message #470819 is a reply to message #470816] Wed, 21 December 2005 02:19 Go to previous messageGo to next message
bolixie 写道:
> type Status report
> available.
> Apache Tomcat/5.5.9
the problem is trouble shooted.But i dont know how could it workes fine
after restart eclipse several times. :(
Re: run "WTP JSF Tools Tutorial" with requested resource is not available [message #470827 is a reply to message #470819] Wed, 21 December 2005 15:50 Go to previous messageGo to next message
Next time check the server view before restarting Eclipse. The Tomcat
server may need to be restarted after a change to the application and the
view will display that status.
Gerry Kessler
WTP JSF Tools Team
"bolixie" <bolixie@gmail.com> wrote in message
news:doavl4$tlv$1@utils.eclipse.org...
> bolixie ??:
>> type Status report
>> available.
>> Apache Tomcat/5.5.9
Re: run "WTP JSF Tools Tutorial" with requested resource is not available [message #470828 is a reply to message #470827] Wed, 21 December 2005 16:43 Go to previous messageGo to next message
Just performed a test using TC 5.5.12 + WTP10RC5 on Windows 2K.
It seems to work fine.
If you perform a "Run on Server" on the login.jsp while TC is started,
you could restart TC as Gerry points out here.
You might also try perform "Run on Server" again but need to close the web browser
first.
Justin
> Regards,
> Gerry Kessler
> WTP JSF Tools Team
>>bolixie ??:
>>>type Status report
>>>available.
>>>Apache Tomcat/5.5.9
Re: run "WTP JSF Tools Tutorial" with requested resource is not available [message #470831 is a reply to message #470828] Thu, 22 December 2005 02:07 Go to previous message
Justin Chen
> web browser
> first.
> Justin
>> Tomcat server may need to be restarted after a change to the
>> application and the view will display that status.
>> Regards,
>> Gerry Kessler
>> WTP JSF Tools Team
>>> bolixie ??:
>>>> type Status report
>>>> available.
>>>> Apache Tomcat/5.5.9
>>> fine after restart eclipse several times. :(
Thanks for Gerry Kessler and Justin Chen! TC 5.5.12 did work fine.So
give advice to fellows uese wtp should use TC 5.5.12 first!!! :)
Re: run "WTP JSF Tools Tutorial" with requested resource is not available [message #580364 is a reply to message #470816] Wed, 21 December 2005 02:19 Go to previous message
bolixie 写道:
> type Status report
> available.
> Apache Tomcat/5.5.9
Re: run "WTP JSF Tools Tutorial" with requested resource is not available [message #580463 is a reply to message #470819] Wed, 21 December 2005 15:50 Go to previous message
Gerry Kessler
WTP JSF Tools Team
> bolixie ??:
>> type Status report
>> available.
>> Apache Tomcat/5.5.9
Re: run "WTP JSF Tools Tutorial" with requested resource is not available [message #580474 is a reply to message #470827] Wed, 21 December 2005 16:43 Go to previous message
first.
Justin
> Regards,
> Gerry Kessler
> WTP JSF Tools Team
>>bolixie ??:
>>>type Status report
>>>available.
>>>Apache Tomcat/5.5.9
Re: run "WTP JSF Tools Tutorial" with requested resource is not available [message #580530 is a reply to message #470828] Thu, 22 December 2005 02:07 Go to previous message
Justin Chen
> web browser
> first.
> Justin
>> Regards,
>> Gerry Kessler
>> WTP JSF Tools Team
>>> bolixie ??:
>>>> type Status report
>>>> available.
>>>> Apache Tomcat/5.5.9
Previous Topic:Milestone 1 build + Tutorial posted..
Next Topic:Comments on wtp-jsf-I200512161901 release
Current Time: Sun Jul 27 03:59:59 EDT 2025
Powered by FUDForum. Page generated in 0.27919 seconds
