Home » Eclipse Projects » DTP » problem creating driver definitions
problem creating driver definitions [message #17368] Mon, 26 June 2006 15:22 Go to next message
When I select Preferences -> Connectivity -> Driver definitions, I'm
able to add a driver definition for DB2 where I specify the paths to
the necessary jar files. Now, when I go to create a new database
connection, I am not able to select the driver definition I created.
Does the new database connection wizzard not look at the list of
available driver definitions?
Bryan
Re: problem creating driver definitions [message #17387 is a reply to message #17368] Mon, 26 June 2006 16:11 Go to previous messageGo to next message
> Bryan
Bryan,
Which build of DTP are you using? (Look in eclipse\features folder for
org.eclipse.datatools features.) When you try to create a new connection
profile, are you choosing the "SQL Model (generic)" one?
John Graham
Eclipse Data Tools Platform PMC Chair
Re: problem creating driver definitions [message #17897 is a reply to message #17387] Tue, 27 June 2006 13:31 Go to previous messageGo to next message
John,
I'm using DTP 0.9.0.200606161 which was pulled from the Callisto site
yesterday from the update manager.
Here are the exact steps I'm trying:
Preferences -> Connectivity -> Driver Definitions
Select Database -> DB2 UDB -> V8.1
Click Add...
Expand Database -> DB2 UDB -> V8.1
Select IBM DB2 Universal as the template
Use the default driver name "IBM DB2 Universal"
Click ok
Add the db2jcc.jar and db2jcc_license_cu.jar
Click ok
Click ok to dismiss the preferences
In the Database Explorer view, click New Connection...
Expand DB2 UDB and select V8.1
The JDBC Driver selector will only let you select "Other" - I was
expecting to be able to select "IBM DB2 Universal" - the one I set up
above.
Bryan
>> Bryan
> Bryan,
> connection profile, are you choosing the "SQL Model (generic)" one?
> Regards,
> John Graham
Re: problem creating driver definitions [message #17921 is a reply to message #17897] Tue, 27 June 2006 16:30 Go to previous messageGo to next message
Bryan,
It looks like you might be confusing the WTP Database Explorer with the
Data Source Explorer from DTP (which is understandable since they are
very similar). "New Connection..." is an action on the Database
Explorer. The equivalent action on the Data Source Explorer is "New
Connection Profile". The WTP Database Explorer doesn't know about the
Driver Definitions in the Preferences.
Brian Payton
SQL Tools Development
IBM Silicon Valley Lab
Bryan Hunt wrote:
> John,
> Click Add...
> Click ok
> Click ok
> above.
> Bryan
>>> created. Does the new database connection wizzard not look at the
>>> list of available driver definitions?
>>> Bryan
>> Bryan,
>> for org.eclipse.datatools features.) When you try to create a new
>> Regards,
>> John Graham
Re: problem creating driver definitions [message #17934 is a reply to message #17921] Tue, 27 June 2006 17:07 Go to previous message
Brian,
That is my problem. Will there be a merger / hostile takeover of these
two explorers in the future?
Bryan
On 2006-06-27 15:30:23 -0500, Brian Payton <bpayton@us.ibm.com> said:
> Bryan,
> Brian Payton
> Bryan Hunt wrote:
>> John,
>> Click Add...
>> Click ok
>> Click ok
>> above.
>> Bryan
>>>> Bryan
>>> Bryan,
>>> Regards,
>>> John Graham
Re: problem creating driver definitions [message #579902 is a reply to message #17368] Mon, 26 June 2006 16:11 Go to previous message
> Bryan
Bryan,
John Graham
Re: problem creating driver definitions [message #580032 is a reply to message #17387] Tue, 27 June 2006 13:31 Go to previous message
John,
Click Add...
Click ok
Click ok
above.
Bryan
>> Bryan
> Bryan,
> Regards,
> John Graham
Re: problem creating driver definitions [message #580061 is a reply to message #17897] Tue, 27 June 2006 16:30 Go to previous message
Bryan,
Brian Payton
Bryan Hunt wrote:
> John,
> Click Add...
> Click ok
> Click ok
> above.
> Bryan
>>> Bryan
>> Bryan,
>> Regards,
>> John Graham
Re: problem creating driver definitions [message #580073 is a reply to message #17921] Tue, 27 June 2006 17:07 Go to previous message
Brian,
Bryan
> Bryan,
> Brian Payton
> Bryan Hunt wrote:
>> John,
>> Click Add...
>> Click ok
>> Click ok
>> above.
>> Bryan
>>>> Bryan
>>> Bryan,
>>> Regards,
>>> John Graham
Previous Topic:New ODA plugin - cannot find dataSet element
Next Topic:Database connections not persisted
Current Time: Fri Jul 18 04:07:40 EDT 2025
Powered by FUDForum. Page generated in 0.53056 seconds
