Home » Eclipse Projects » Eclipse 4 » integer databinding: thousands separator
integer databinding: thousands separator [message #579984] Wed, 04 August 2010 09:24 Go to next message
I'm still working with XWT and this time I got the following problem ;)
An example:
I have a person pojo, that has an age attribute, which is an integer. Now when it comes to databinding, I bind that attribute to a text field via XWT, which works fine :)
But if the person's age is greater than 999, there is added a thousands separator automatically: If the int value is 123456, the text field has the text "123.456". How can I disable this behavior? Is is actually wanted?
Thanks in advance
Best Regards
Moritz
PS: Somebody could help me with my CSS problem post please? It is a feature, that I would really like to include.
Re: integer databinding: thousands separator [message #580008 is a reply to message #579984] Wed, 04 August 2010 18:38 Go to previous messageGo to next message
Please fill a bug!
Best regards
Yves YANG
"Mo P." <moritzpavlik@gmx.de> wrote in message
news:i3bplo$j5j$1@build.eclipse.org...
> Hello,
> An example:
> wanted?
> Thanks in advance
> Best Regards
> Moritz
Re: integer databinding: thousands separator [message #580027 is a reply to message #579984] Thu, 05 August 2010 02:11 Go to previous messageGo to next message
Thank you very much for your fast replies!
I filed a bug for that problem:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=321816
Re: integer databinding: thousands separator [message #580051 is a reply to message #580027] Thu, 05 August 2010 05:35 Go to previous message
Thanks. here is my respons I replied on the bug:
You can disable it by overriding the default convertor. There are two
solutions:
1. Override the system default convertor
XWT.registerConvertor(IConvertor)
2. set up a local convertor in the binding
text="{binding path=age,convertor=MyIntConvertor}"
The MyIntConvertor must implement IValueConvertor
Best regards
Yves YANG
news:i3dknb$q40$1@build.eclipse.org...
Previous Topic:integer databinding: thousands separator
Next Topic:[Announce] Eclipse 4.0 Webinar - Aug. 26
Current Time: Wed Jul 23 23:34:00 EDT 2025
Powered by FUDForum. Page generated in 1.06933 seconds
