Home » Modeling » Epsilon » Java via Epsilon Tools
Java via Epsilon Tools [message #482096] Tue, 25 August 2009 07:23 Go to next message
Originally posted by: d.clowes.lboro.ac.uk
Hi All,
I'm trying to execute some regular expression searches in a
transformation. The Java I need to execute uses the
Java.utils.regex.Pattern and Java.utils.regex.Matcher. Dimtitris kindly
pointed me to the Epsilon Tools documentation and I can follow the JFrame
example. However from what I can tell there is no default constructor for
Pattern, which is what I believe to be causing me the problems.
Pattern is typically called in Java by:
Pattern p = Pattern.compile('regex Srring');
I have tried:
# var pattern : new Native('java.util.regex.Pattern') :=
pattern.compile('Section ((\\d)[(\\.\\d)]*)');
Pattern.compile('Section ((\\d)[(\\.\\d)]*)');
java.util.regex.Pattern.compile('Section ((\\d)[(\\.\\d)]*)');
# var pattern : new Native('java.util.regex.Pattern');
All of which result in an EXCEPTION: Internal error:
java.lang.InstantiationException: java.util.regex.Pattern
Has anyone any suggestions to try.
Many thanks,
Darren
Re: Java via Epsilon Tools [message #482108 is a reply to message #482096] Tue, 25 August 2009 07:53 Go to previous messageGo to next message
Hi Darren,
Since Pattern doesn't provide an accessible constructor - only the
static "compile" method, you should create your own tool that wraps
Pattern (using Java) and then call it from Epsilon.
Having said this, calling static methods seems like a useful feature
that should be supported natively by Epsilon. Would you mind opening an
enhancement request in the bugzilla for this?
Dimitris
Darren Clowes wrote:
> Hi All,
> JFrame example. However from what I can tell there is no default
> constructor for Pattern, which is what I believe to be causing me the
> problems.
> I have tried:
> Many thanks,
> Darren
Re: Java via Epsilon Tools [message #482114 is a reply to message #482108] Tue, 25 August 2009 08:22 Go to previous messageGo to next message
Hi Darren,
If you are using Epsilon from source, please update and then you can
simply write the following:
var pattern = Native('java.util.regex.Pattern').compile('\\d');
var matcher = pattern.matcher('Some text and 1 digit');
while (matcher.find()) {
matcher.start().println();
matcher.group().println();
matcher.end().println();
The change will appear in 0.8.7 - which should be released within the
next couple of days. I'll also update the EGL/Tomcat integration shortly.
Dimitris
Dimitris Kolovos wrote:
> Hi Darren,
> Cheers,
> Dimitris
>> Hi All,
>> kindly pointed me to the Epsilon Tools documentation and I can follow
>> the JFrame example. However from what I can tell there is no default
>> problems.
>> I have tried:
>> Many thanks,
>> Darren
Re: Java via Epsilon Tools [message #482121 is a reply to message #482108] Tue, 25 August 2009 08:47 Go to previous messageGo to next message
I think I created that correctly you should find the request available at:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=287549
Darren.
Re: Java via Epsilon Tools [message #482131 is a reply to message #482121] Tue, 25 August 2009 09:12 Go to previous message
Thanks Darren. For some reason I didn't receive a notification from the
bugzilla and opened this
https://bugs.eclipse.org/bugs/show_bug.cgi?id=287548
I've marked the one as a duplicate of the other so that's fine now.
Dimitris
> Darren.
Re: Java via Epsilon Tools [message #579507 is a reply to message #482096] Tue, 25 August 2009 07:53 Go to previous message
Hi Darren,
Dimitris
> Hi All,
> problems.
> I have tried:
> Many thanks,
> Darren
Re: Java via Epsilon Tools [message #579520 is a reply to message #482108] Tue, 25 August 2009 08:22 Go to previous message
Hi Darren,
Dimitris
> Hi Darren,
> Cheers,
> Dimitris
>> Hi All,
>> problems.
>> I have tried:
>> Many thanks,
>> Darren
Re: Java via Epsilon Tools [message #579537 is a reply to message #482108] Tue, 25 August 2009 08:47 Go to previous message
Darren.
Re: Java via Epsilon Tools [message #579554 is a reply to message #482121] Tue, 25 August 2009 09:12 Go to previous message
Dimitris
> Darren.
Previous Topic:Java via Epsilon Tools
Next Topic:EGL + Tomcat? (egl.servlet)
Current Time: Wed Jul 23 19:12:56 EDT 2025
Powered by FUDForum. Page generated in 0.04962 seconds
