Home » Archived » Eclipse Communications Framework (ECF) » org.eclipse.ecf.example.collab problems
org.eclipse.ecf.example.collab problems [message #579454] |
Tue, 08 February 2005 17:36  |
I was trying out the sample ECF app in org.eclipse.ecf.example.collab
and ran into a two problems - the first I was able to resolve.
Background: I obtained the code via CVS, ran server and 2 clients using
a single WinXP machine using localhost and JDK 5.0, and used the sample
launch configurations (ECF Collab Server, Client 1, and Client 2) as
suggested in http://www.eclipse.org/ecf/downloads.html :
a) localhost:3282/server vs localhost:3282//server
I run Client 1, and use "ECF/Join Test Collaboraton (localhost)".
Then I run Client 2 and use the menu, "ECF/Join Test Collaboration
(localhost)", it logs me on with same userid as Client 1.
So I quit and restarted Client 2, but used "ECF/Join Client
Collaboration..." instead, bringing up the dialog. I change the
nickname and hit "Finish".
I get "Could not connect to group 'ecftcp://localhost:3282/server'. I
also see a stacktrace:
java.io.InvalidObjectException: Container for target /server not found!
at
org.eclipse.ecf.provider.generic.TCPServerSOContainerGroup.h andleAccept(TCPServerSOContainerGroup.java:104)
at org.eclipse.ecf.provider.comm.tcp.Server$2.run(Server.java:7 9)
at java.lang.Thread.run(Thread.java:595)
I notice that "//server" is showing up in the console for the server and
client 1. So I change the Group ID, which was
'ecftcp://localhost:3282/server' to 'ecftcp://localhost:3282//server'
(extra slash).
Now the joinGroup call appears to be successful. There must be a typo
somewhere with an extra slash.
b) ClassNotFoundException: RemoteSharedObjectMsgEvent
Upon connecting 2 clients, immediately I get
trace)org.eclipse.ecf.provider(container)[02/08/05;17:23:40: 435]sendcontainermessage:ContainerMessage[GUID[ST4iAanAkSXKQ rEwKeexHHoKmrY-];null;2;SharedObjectMessage[StringID[chat];R emoteSharedObjectMsgEvent[StringID[chat];null;SharedObjectMs g[null:handleNotifyUserAdded(Li-Te
Cheng)]]]]:GUID[ST4iAanAkSXKQrEwKeexHHoKmrY-]
(trace)org.eclipse.ecf.provider(connection)[02/08/05;17:23:4 0:435]send:localhost:3282:AsynchMessage[[B@1b68d78]
(trace)org.eclipse.ecf.provider(connection)[02/08/05;17:23:4 0:515]recv:localhost:3282:AsynchMessage[[B@105562b]
(trace)org.eclipse.ecf.provider(container)[02/08/05;17:23:40 :525]class
not found for message:GUID[ST4iAanAkSXKQrEwKeexHHoKmrY-]
java.lang.ClassNotFoundException:
org.eclipse.ecf.example.collab.share.RemoteSharedObjectMsgEv ent
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:404)
at
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:93)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319 )
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:242)
at java.io.ObjectInputStream.resolveClass(ObjectInputStream.jav a:574)
at java.io.ObjectInputStream.readNonProxyDesc(ObjectInputStream .java:1538)
at java.io.ObjectInputStream.readClassDesc(ObjectInputStream.ja va:1460)
at
java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStre am.java:1693)
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java :1299)
at java.io.ObjectInputStream.defaultReadFields(ObjectInputStrea m.java:1912)
at java.io.ObjectInputStream.readSerialData(ObjectInputStream.j ava:1836)
at
java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStre am.java:1713)
at
at java.io.ObjectInputStream.readObject(ObjectInputStream.java: 339)
at
org.eclipse.ecf.provider.generic.SOContainer.getObjectFromBy tes(SOContainer.java:579)
at
org.eclipse.ecf.provider.generic.SOContainer.processAsynch(S OContainer.java:938)
at
org.eclipse.ecf.provider.generic.SOContainer$MessageReceiver .handleAsynchEvent(SOContainer.java:195)
at org.eclipse.ecf.provider.comm.tcp.Client.handleRcv(Client.ja va:419)
at org.eclipse.ecf.provider.comm.tcp.Client.access$4(Client.jav a:404)
at org.eclipse.ecf.provider.comm.tcp.Client$4.run(Client.java:3 78)
I continue seeing the same error whenever I try typing in the team chat
area, etc. Whenever I type in client 1, client 2 generates the above
stacktrace, and vice versa (typing in client 2 triggers the stacktrace
in client 1).
It looks like a classloader problem with RemoteSharedObjectMsgEvent,
which is defined in the org.eclipse.ecf.example.collab plugin, whereas
the rest of the ECF Event classes are found in the org.eclipse.ecf plugin.
Any thoughts?
Li-Te
Re: org.eclipse.ecf.example.collab problems [message #579473 is a reply to message #579454] |
Tue, 08 February 2005 19:24   |
Hi Li-Te,
Thanks for the info...couple of comments and questions below:
Li-Te wrote:
<stuff deleted>
OK...I did find a typo and fixed in the source/config files. Thanks.
Getting an update for the org.eclipse.ecf.example.collab and
org.eclipse.ecf.provider plugins will get you the fixed code.
<stack trace deleted>
There's a feature of OSGI that we are depending upon here...and that's
provided via the 'DynamicImport-Package' property in the
org.eclipse.ecf.provider plugin. In the manifest.mf file in the
org.eclipse.ecf.provider plugin is a line that looks like this:
DynamicImport-Package: *
The OSGI-spec'd behavior for this is that any classes exposed by other
plugins (via the Export-Package: property in manifest.mf) should be
seen/loaded by the plugin declaring the DynamicImport-Package wildcard
as above. So in the manifest.mf for the org.eclipse.ecf.example.collab
plugin should be:
Export-Package: org.eclipse.ecf.example.collab.share,
org.eclipse.ecf.example.collab.share.url,
org.eclipse.ecf.example.collab.share.io
(on one line)
And this *should* allow the org.eclipse.ecf.provider plugin classloader
(the one doing the object deserialization) to find the
org.eclipse.ecf.example.collab.share.RemoteSharedObjectMsgEv ent class,
load it, and deserialize the stream.
This is working fine for my/our tests...I'm currently at a loss as to
why it would not be working for you. Can you make sure that the
respective manifest.mf files have the lines above in them (they do in
the checkedin versions...I just checked now).
Then, assuming they are there in your copies...what platform are you
running on and what version of Eclipse are you using? Is there a chance
that the OSGI behavior for classloading is not working right on that
platform/version?
I will also attempt to reproduce on my machine given a whole new
installation/etc. I would appreciate any further assistance you can
give on this, as it's obviously important to make sure that this
mechanism works as expected until ECF puts something else in place (i.e.
to allow plugins to register their packages with providers rather than
using DynamicImport-Package.
Scott
> Any thoughts?
> Li-Te
Re: org.eclipse.ecf.example.collab problems [message #579489 is a reply to message #579473] |
Wed, 09 February 2005 14:33   |
Hi Scott,
Ok - it was indeed a problem with the MANIFEST.MF file. I refreshed it
and the example app works fine now.
Li-Te
Scott Lewis wrote:
> Hi Li-Te,
> Li-Te wrote:
>> Hi,
> <stuff deleted>
>> plugin.
> plugin should be:
> (on one line)
> platform/version?
> Scott
>> Any thoughts?
>> Thanks,
>> Li-Te
Re: org.eclipse.ecf.example.collab problems [message #580871 is a reply to message #579489] |
Tue, 12 April 2005 06:12   |
Hi, Scott and Li-Te
I have the same "class not found" problem while MANIFEST.MF file is correct.
I checked the run configuration, in class path page, I found
org.eclipse.ecf.example.collab was not in the user entry.
I solved it by adding that project.
My enviorment:
Win2000 Sp4,
Eclispe SDK 3.1M6,
emf-sdo-xsd-SDK-I200504070700.zip
org.eclipse.ecf-1.0.0.M1.zip
Best Regards!
Simon
"Li-Te" <li-te_cheng@us.ibm.com> wrote in message
news:420A65A6.8090807@us.ibm.com...
> Hi Scott,
> Li-Te
> Scott Lewis wrote:
> > Hi Li-Te,
> > Li-Te wrote:
> >> Hi,
> > <stuff deleted>
> >> plugin.
> > plugin should be:
> > (on one line)
> > platform/version?
> > Thanks,
> > Scott
> >> Any thoughts?
> >> Thanks,
> >> Li-Te
Re: org.eclipse.ecf.example.collab problems [message #580907 is a reply to message #580871] |
Sat, 16 April 2005 18:14  |
Hi Simon,
Yes...thanks for the fix!
Scott
Simon Li wrote:
> Hi, Scott and Li-Te
> My enviorment:
> Win2000 Sp4,
> Eclispe SDK 3.1M6,
> Best Regards!
> Simon
>>Hi Scott,
>>Thanks,
>>Li-Te
>>Scott Lewis wrote:
>>>Hi Li-Te,
>>>Li-Te wrote:
>>>>Hi,
>>><stuff deleted>
>>>>plugin.
>>>plugin should be:
>>>(on one line)
>>>platform/version?
>>>Thanks,
>>>Scott
>>>>Any thoughts?
>>>>Thanks,
>>>>Li-Te
Current Time: Wed Jul 23 12:53:24 EDT 2025
Powered by FUDForum. Page generated in 0.09099 seconds
