Home » Eclipse Projects » DTP » Connection Profiles
Connection Profiles [message #16329] Fri, 09 June 2006 10:53 Go to next message
i would like to use the created Connection Profiles in my Plugin.
How can I retrieve all Connection Profiles ?
Oliver
Re: Connection Profiles [message #16342 is a reply to message #16329] Fri, 09 June 2006 13:55 Go to previous messageGo to next message
Oliver,
Have a look at org.eclipse.datatools.connectivity.ProfileManager. The
methods you should look at are:
getProfiles() - returns all the profile defined in the workspace.
getProfilesByCategory() - returns all the profiles contained by the
specified category (not sure if this recurses through subcategories).
getProfileByName() - returns a profile with the specified name.
getProfileByInstanceID() - returns the profile with the specified ID.
getProfileByProviderID() - returns all the profiles of a specific type
(e.g. using
org.eclipse.datatools.connectivity.db.derby.embedded.connect ionProfile
would return all the Derby connection profiles;
org.eclipse.datatools.connectivity.db.generic.connectionProf ile would
return all the generic DB connection profiles).
Hope that helps.
Sincerely,
Rob Cernich
Re: Connection Profiles [message #16355 is a reply to message #16342] Fri, 09 June 2006 13:57 Go to previous message
Hi Rob,
great, that is what I am looking for.
Oliver
Rob Cernich schrieb:
> Oliver,
> (e.g. using
> Hope that helps.
> Sincerely,
> Rob Cernich
Re: Connection Profiles [message #579399 is a reply to message #16329] Fri, 09 June 2006 13:55 Go to previous message
Oliver,
(e.g. using
Hope that helps.
Sincerely,
Rob Cernich
Re: Connection Profiles [message #579419 is a reply to message #16342] Fri, 09 June 2006 13:57 Go to previous message
Hi Rob,
Oliver
> Oliver,
> (e.g. using
> Hope that helps.
> Sincerely,
> Rob Cernich
Previous Topic:Connection Profiles
Next Topic:Filtering mechanism
Current Time: Sun Oct 26 06:57:47 EDT 2025
Powered by FUDForum. Page generated in 0.03109 seconds
