Home » Eclipse Projects » Eclipse 4 » How to get a View dynamically
How to get a View dynamically [message #548904] Fri, 23 July 2010 09:03 Go to next message
I would need to get a view.
I know you can get the MPart from the EPartService but I can't figure out how to get to the view object.
-- artur
Re: How to get a View dynamically [message #548918 is a reply to message #548904] Fri, 23 July 2010 09:10 Go to previous messageGo to next message
What do you mean with View-Object. The POJO-Instance behind it? You get
this by calling MPart#getObject() (inherited from MContribution)
Tom
Am 23.07.10 15:03, schrieb Artur Kronenberg:
> -- artur
Re: How to get a View dynamically [message #548954 is a reply to message #548918] Fri, 23 July 2010 10:25 Go to previous messageGo to next message
Yes that was what I ment, the POJO that is implementing the view.
When is this object available? If I inject the EPartService into a method and try to get the Object, I get the MPart but the Object is null.
EDIT:
Never mind, I had another problem. Getting the view works just fine. Thanks!
[Updated on: Fri, 23 July 2010 10:32] by Moderator
Re: How to get a View dynamically [message #548965 is a reply to message #548954] Fri, 23 July 2010 10:38 Go to previous message
At the moment the MPart is created, at least that's what I'd expect.
Tom
Am 23.07.10 16:25, schrieb Artur Kronenberg:
Re: How to get a View dynamically [message #579340 is a reply to message #548918] Fri, 23 July 2010 10:25 Go to previous message
Re: How to get a View dynamically [message #579361 is a reply to message #548954] Fri, 23 July 2010 10:38 Go to previous message
Tom
Previous Topic:How to get a View dynamically
Next Topic:Enable/Disable ToolItem
Current Time: Tue Jul 22 23:04:00 EDT 2025
Powered by FUDForum. Page generated in 0.25695 seconds
