Home » General (non-technical) » Jobs and employment » Project Leader - EXTOL Software Development
Project Leader - EXTOL Software Development [message #579273] Thu, 04 February 2010 13:44 Go to next message
EXTOL
Project Leader Position
Job Description
Kristin Zhivago
January 14, 2010
____________________________________________________________ _______________
Project Leader - Software Development
COMPANY
EXTOL provides data integration solutions to businesses of all sizes. EXTOL International helps lean organizations implement and manage complex, heterogeneous trading partner connections and data integration at a fraction of the time, cost, and effort required by other solutions.
As multi-enterprise integration experts, EXTOL specializes in helping companies with short transaction cycles (CPG, Grocery); fast turnaround requirements (Insurance, MRO); and high transaction volumes with supply chain integration needs (Logistics, Manufacturing, Distribution). Our solutions boost processing efficiency, integrate natively with applications and data, reduce errors, and lower end-to-end processing costs.
EXTOL is a privately held, self-funded software and services company. The culture is professional, collaborative, and supportive. Unsurpassed customer service is our trademark, thanks to our highly knowledgeable and helpful staff.
At EXTOL, we place a premium on highly skilled technical people, since they play a key role in the success of our company. We reward excellence and provide the working environment and tools to make it possible. Our development team is viewed as a strategic investment in the future, and as such are a critical part of our company.
EXTOL is located in Pottsville, PA. You will be working on location.
POSITION
You will serve as project leader for the development effort of the next version of EXTOL Business Integrator (EBI 3). EBI 3 is major step forward in the evolution of our successful Integration platform, and is being built afresh using cutting-edge and modular technology both on the client (RCP), and server (OSGi/ESB) side. You will be able to employ your extensive experience leading and managing development projects to help the development team define and execute their individual and collective assignments. You will assist in the development effort as needed, but your main responsibility will be to make sure that the project stays on track - in terms of completion and quality.
RESPONSIBILITIES
Understand the architecture of the new system being developed and the roles and abilities of each member of the team.
Break the project into modules that can be implemented, managed, and tracked.
Develop and execute a development plan, including modules, responsibilities, schedules, goals, and the tools that will be used to track progress.
Collaborate with other team members to finalize the plan and evolve it when necessary.
Execute on the plan, holding regular progress meetings in which every team member understands the status of each aspect of the project and what must be done going forward.
Identify and resolve any impediments to progress, doing whatever is necessary, individually and in collaboration with team members, to eliminate the impediment and enable that aspect of the project to proceed.
Contribute technically, as needed, to the development effort.
REQUIRED
The best candidate for this position will have a strong technical background and dedication to customer satisfaction.
5 - 7 years as a project leader in a software product development environment, with a track record of using the Eclipse platform to build robust commercial applications, from initial delivery to subsequent follow-up releases.
Astute command of the Eclipse development environment (e.g. SWT/JFace, Workbench, Resource model, Builder framework, Debugger framework, Jobs API, Help framework)
Understanding of Eclipse Modeling (e.g. EMF, Model transformation [XPand, ATL, QVT])
Working experience with Java, XML, and JDBC.
Strong research skills, with the ability to research available options and then cohesively present considerations, tradeoffs, and recommendations.
Professional and thorough communication skills - written and verbal
Organized, detailed, strong worth ethic
Team player - lead by example, willing to pitch in as needed, mentor and be mentored
Practical approach to problem-solving
PREFERRED:
Experience using Eclipse Graphical Modeling Framework (GMF), and Graphical Editing Framework (GEF)
Knowledge of OSGi architecture and ESB technology
A working understanding of popular provisioning systems (e.g. P2) in the Eclipse/OSGi environment
Experience in distributed and redundant system architecture and design
Practical experience using established relational database systems (e.g. DB2, Oracle)
SALARY: $90,000 - $120,000 annually, commensurate with experience
CONTACT: Please send a cover letter and a resume to Kristin Zhivago at mailto:kristinzhivago@extol.com
http://www.extol.com/documents/EXTOL%20Project%20Leader%20Po sition.pdf
Note: EXTOL will have five (5) members of the Development Team at EclipseCon in late March; please introduce yourself and get to know the team and our exciting project!
Re: Project Leader - EXTOL Software Development [message #583931 is a reply to message #579273] Fri, 25 June 2010 10:35 Go to previous message
This position has been filled.
Previous Topic:Project Leader - EXTOL Software Development
Next Topic:Montreal Developer Available with Eclipse Plugin Development Experience (can work online)
Current Time: Sat Aug 30 19:50:02 EDT 2025
Powered by FUDForum. Page generated in 0.03651 seconds
