Home » Archived » Eclipse Communications Framework (ECF) » Initial setup problems
Initial setup problems [message #579245] Thu, 20 January 2005 14:25 Go to next message
Hello All!
I am just getting started evaluating ECF and have done the initial
checkout of code. When I run the JUnit test suite I get this error on the
testCreateSharedObject test. Sure enough
org.eclipse.ecf.provider.generic.Client does not exist in my source tree.
Running AllTest produces errors for all tests of a similiar nature. I
used the PSF file to import the source into 3.1M4 today. Are there
additional resources required?
TIA,
Ken Gilmer
org.eclipse.ecf.core.SharedObjectContainerInstantiationExcep tion:
SharedObjectContainerDescription named
'org.eclipse.ecf.provider.generic.Client' not found
at
org.eclipse.ecf.core.SharedObjectContainerFactory.getDescrip tionByName(SharedObjectContainerFactory.java:131)
at
org.eclipse.ecf.core.SharedObjectContainerFactory.makeShared ObjectContainer(SharedObjectContainerFactory.java:217)
at
org.eclipse.ecf.test.CreateSharedObjectTest.testCreateShared Object(CreateSharedObjectTest.java:36)
at
at
at java.lang.reflect.Method.invoke(Method.java:324)
at junit.framework.TestCase.runTest(TestCase.java:154)
at junit.framework.TestCase.runBare(TestCase.java:127)
at junit.framework.TestResult$1.protect(TestResult.java:106)
at junit.framework.TestResult.runProtected(TestResult.java:124)
at junit.framework.TestResult.run(TestResult.java:109)
at junit.framework.TestCase.run(TestCase.java:118)
at junit.framework.TestSuite.runTest(TestSuite.java:208)
at junit.framework.TestSuite.run(TestSuite.java:203)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:474)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:342)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main( RemoteTestRunner.java:194)
Re: Initial setup problems [message #579269 is a reply to message #579245] Thu, 20 January 2005 17:38 Go to previous messageGo to next message
Hi Ken/all,
Ken Gilmer wrote:
> Hello All!
> the testCreateSharedObject test. Sure enough
> tree. Running AllTest produces errors for all tests of a similiar
> nature. I used the PSF file to import the source into 3.1M4 today. Are
> there additional resources required?
I think that the problem is just that you need to run these tests via
the Eclipse 'JUnit Plugin-Test' from the Run/Debug rather than the plain
'ol 'JUnit Test'. This just runs the JUnit tests with a different
(eclipse runtime) context.
The reason for this is that the JUnit Plugin-Test creates a whole new
workspace, and initializes all the plugins in that workspace. The ECF
SharedObjectContainerFactory is initialized by the OSGI plugin loading
process (since other plugins implement the containerFactory extension
point), and so it doesn't get initialized when run as a simple JUnit test.
If this doesn't help please let all know.
Scott
> TIA,
> Ken Gilmer
> at
> at
> at
> at
> at
> at
> at
> at
Re: Initial setup problems [message #579300 is a reply to message #579269] Thu, 20 January 2005 18:12 Go to previous messageGo to next message
Hey Scott,
Thanks for your help. Yeah, I tried that as well. When I run the
"JUnit Plug-in Test" on AllTests.java, I get the following console output.
I am using OS X.
ken
"Error: " java.lang.IllegalArgumentException: No ClassLoader found for
testplugin: org.eclipse.ecf.test
Unhandled Exception
Reason:
Unable to execute early startup code for an extension
Bad extension specification
Reason:
startup class must implement org.eclipse.ui.IStartup
Unhandled Exception
Reason:
Reason:
Unhandled Exception
Reason:
Reason:
Unhandled Exception
Reason:
Reason:
Unhandled Exception
Reason:
Reason:
Unhandled Exception
Reason:
Reason:
Unhandled Exception
Reason:
Reason:
Unhandled Exception
Reason:
Reason:
Unhandled Exception
Reason:
Reason:
Reason:
Reason:
Scott Lewis wrote:
> Hi Ken/all,
> Ken Gilmer wrote:
>> Hello All!
> Scott
>> TIA,
>> Ken Gilmer
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
Re: Initial setup problems [message #579325 is a reply to message #579300] Thu, 20 January 2005 18:26 Go to previous messageGo to next message
Hi Ken,
This smells like something wrong with the Mac OS X impl of the JUnit
Plugin Test (perhaps specific to 3.1M4). Obviously, this is not what I
see running the 3.1M4 on win2k or winxp.
Bad extension specification...hmmm...I'll see if I can figure out what's
going on...maybe this is something wrong with the extension
loading/handling. Please let everyone know if you find something about
this issue on Eclipse.org.
Scott
Ken Gilmer wrote:
> Hey Scott,
> output. I am using OS X.
> Thanks
> ken
> Unhandled Exception
> Reason:
> Reason:
> Unhandled Exception
> Reason:
> Reason:
> Unhandled Exception
> Reason:
> Reason:
> Unhandled Exception
> Reason:
> Reason:
> Unhandled Exception
> Reason:
> Reason:
> Unhandled Exception
> Reason:
> Reason:
> Unhandled Exception
> Reason:
> Reason:
> Unhandled Exception
> Reason:
> Reason:
> Unhandled Exception
> Reason:
> Reason:
> Reason:
> Reason:
> Scott Lewis wrote:
>> Hi Ken/all,
>> Ken Gilmer wrote:
>>> Hello All!
>>> on the testCreateSharedObject test. Sure enough
>>> Are there additional resources required?
>> plain 'ol 'JUnit Test'. This just runs the JUnit tests with a
>> different (eclipse runtime) context.
>> test.
>> Scott
>>> TIA,
>>> Ken Gilmer
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
Re: Initial setup problems [message #579343 is a reply to message #579300] Fri, 21 January 2005 05:23 Go to previous message
ken, scott,
the reason for this behaviour is (without looking at the code),
that the test plugin declares an extension for the org.eclipse.ui.startup
extension point. this extension will start/initialize the plugin even
if it is not used at once. a class is specified there that implements
the IStartup interface.
most probably the name of the plugin class is given there,
but the class does NOT implement the IStartup interface.
when the eclipse ui plugin reads its extensions, it tries to
instantiate the plugin class, cast it to IStartup - and fails!
failing during startup means, that the plugin classloader is NOT
initialized! subsequent calls into the plugin's code will end
in NoClassLoaderFound or ClassNotFound exceptions.
you should implement IStartup (due to a bug in the eclipse startup
sequence preferably NOT the plugin class) and leave the earlyStartup()
method EMPTY! initialization code should go into start(...) or startup(...),
the presence of IStartup/earlyStartup() is enough to make the normal
plugin startup happen (with calls to start(...) and startup(...)).
hope this helps ;-)
cheers
/eike
Ken Gilmer wrote:
> Hey Scott,
> Thanks
> ken
> Unhandled Exception
> Reason:
> Reason:
> Unhandled Exception
> Reason:
> Reason:
> Unhandled Exception
> Reason:
> Reason:
> Unhandled Exception
> Reason:
> Reason:
> Unhandled Exception
> Reason:
> Reason:
> Unhandled Exception
> Reason:
> Reason:
> Unhandled Exception
> Reason:
> Reason:
> Unhandled Exception
> Reason:
> Reason:
> Unhandled Exception
> Reason:
> Reason:
> Reason:
> Reason:
> Scott Lewis wrote:
>> Hi Ken/all,
>> Ken Gilmer wrote:
>>> Hello All!
>> test.
>> Scott
>>> TIA,
>>> Ken Gilmer
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
Previous Topic:ANNOUNCEMENT - Security "Work Area" in Equinox/Eclipse
Next Topic:Group discovery
Current Time: Wed Jul 23 04:21:48 EDT 2025
Powered by FUDForum. Page generated in 0.08658 seconds
