how to delete remote working folder ... [message #31229] |
Mon, 19 January 2009 10:08  |
Hi all,
I have created my service and subsystem ...
on the top of that I have created my own view to display IHostFile ...
when I edit the file the remote object file are downloaded from the server
in the local machine
what can I do to remove the REMOTE SYSTEM TEMP FILES local folder once the
IDE is shutdown?
I have tried with ... but still no luck ...
ISystemRegistry systemRegistry = RSECorePlugin.getTheSystemRegistry();
subSystem.getParentRemoteFileSubSystemConfiguration().delete SubSystem(subSystem);
subSystem.disconnect();
systemRegistry.deleteHost(connection);
systemRegistry.deleteSubSystem(subSystem);
Kar
Re: how to delete remote working folder ... [message #31499 is a reply to message #31430] |
Fri, 23 January 2009 07:32  |
Thanks a lot for your help
"Martin Oberhuber" <martin.oberhuber@windriver.com> wrote in message
news:4979942C.6060906@windriver.com...
> Window > Preferences > Remote Systems > File Cache
> press button "Clear Cached Files"
> I'm sure you can find the code which does that, to also
> call it programmatically if you want.
> When you select any folder, the right-click > Synchronize Cache
> function is also related.
> Cheers,
> Martin Oberhuber, Senior Member of Technical Staff, Wind River
> Target Management Project Lead, DSDP PMC Member
> http://www.eclipse.org/dsdp/tm
> Kar wrote:
>> Hi all,
>> server in the local machine
>> the IDE is shutdown?
>> Thanks
>> Kar
Re: how to delete remote working folder ... [message #578800 is a reply to message #31229] |
Fri, 23 January 2009 04:55  |
Kar wrote:
> Hi all,
> Thanks
> Kar
Re: how to delete remote working folder ... [message #578835 is a reply to message #31430] |
> Cheers,
> Kar wrote:
>> Hi all,
>> Thanks
>> Kar
FUDForum. Page generated in 0.04961 seconds
