Home » Eclipse Projects » DSDP - Target Management » How to specify the parent directory in SystemRemoteFileDialog
How to specify the parent directory in SystemRemoteFileDialog [message #30287] Wed, 10 December 2008 02:37 Go to next message
The default searching directories are "My Home" and "Root" in
SystemRemoteFileDialog.
Is there anyway to enable the textfield in the dialog to let user specify
where to browse from?
Or should I construct other kind of dialog which may have more flexible UI
for file browsing in the remote host?
Great thanks for advice.
Wendy
Re: How to specify the parent directory in SystemRemoteFileDialog [message #30570 is a reply to message #30287] Mon, 29 December 2008 21:01 Go to previous messageGo to next message
Hi Wendy,
SystemRemoteResourceDialog#setPreselection() is what you want.
For details, see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=174944
as well as the EclipseCon 2008 Tutorial code from
http://www.eclipsecon.org/2008/?page=sub/&id=38
(click on the "Presentation" link on top to get the ZIP
file which includes the sample code).
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Wendy Zheng wrote:
> Wendy
Re: How to specify the parent directory in SystemRemoteFileDialog [message #31354 is a reply to message #30570] Wed, 21 January 2009 19:35 Go to previous messageGo to next message
Thank you, Martin.
SystemRemoteResourceDialog#setPreselection() works in function.
It is quite slow. Is that because we have mounted file system
and the API is doing some searching?
But it works. Thanks.
Wendy
Re: How to specify the parent directory in SystemRemoteFileDialog [message #31375 is a reply to message #31354] Fri, 23 January 2009 04:53 Go to previous message
Hi Wendy,
in order to set the preselection properly, the code must
list the directories of all parent folders of your selected
folder. This may take some time.
Please file a bug if you believe this doesn't explain the
slowness sufficiently.
Wendy Zheng wrote:
> Thank you, Martin.
> Regards,
> Wendy
Re: How to specify the parent directory in SystemRemoteFileDialog [message #578276 is a reply to message #30287] Mon, 29 December 2008 21:01 Go to previous message
Hi Wendy,
For details, see
Wendy Zheng wrote:
> Wendy
Re: How to specify the parent directory in SystemRemoteFileDialog [message #578769 is a reply to message #30570] Wed, 21 January 2009 19:35 Go to previous message
Thank you, Martin.
Wendy
Re: How to specify the parent directory in SystemRemoteFileDialog [message #578785 is a reply to message #31354] Fri, 23 January 2009 04:53 Go to previous message
Hi Wendy,
Wendy Zheng wrote:
> Thank you, Martin.
> Regards,
> Wendy
Previous Topic:Eclipse PDT + RSE (FTP)
Next Topic:Eclipse PDT + RSE (FTP)
Current Time: Fri Jul 25 19:45:28 EDT 2025
Powered by FUDForum. Page generated in 0.04025 seconds
