Home » Eclipse Projects » Plugin Development Environment (PDE) » [P2] Problem creating repository with .product when exporting for multiple platforms
| [P2] Problem creating repository with .product when exporting for multiple platforms [message #18926] |
Wed, 03 September 2008 07:54  |
[Sent to multiple newsgroups because I don't know which component owns
the export feature]
I'm not sure whether I'm doing something .product-Export from within
eclipse is not designed or there's a bug.
Let's start from the beginning:
I've setup a target with RCP-SDK, Delta-Pack, EMF, CDO, ... . Then I try
to export my .product for multiple platforms using the Wizard and Check
the "Generate metadata repository". Everything is fine until this point.
I get a content.xml and with filters for different platforms the only
problem is that filters for os-x tooling* are not added in the <unit
"at.bestsolution.soccer.app.product">
This is the original one:
-------------- >8 --------------
<unit id='at.bestsolution.soccer.app.product' version='1.0.0'>
<!-- obmitted to show the interesting things -->
<required namespace='org.eclipse.equinox.p2.iu'
name='toolingorg.eclipse.core.filesystem.macosx'
range='[1.0.0.v20080604-1400,1.0.0.v20080604-1400]'/>
name='toolingorg.eclipse.swt.win32.win32.x86'
range='[3.4.0.v3448f,3.4.0.v3448f]'/>
-------------- 8< --------------
This makes troubles when trying to install with the p2 agent poping up
errors. If I correct these problems manually changing it to something
like this:
range='[1.0.0.v20080604-1400,1.0.0.v20080604-1400]'>
<filter>
(& (osgi.os=macosx) (|(osgi.arch=x86) (osgi.arch=ppc)))
</filter>
</required>
range='[3.4.0.v3448f,3.4.0.v3448f]'>
<filter>
(& (osgi.ws=win32) (osgi.os=win32) (osgi.arch=x86))
</filter>
</required>
Is this now a bug in the metadata repository generator or am I expecting
too much from the whole repository?
Tom
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
| Re: [P2] Problem creating repository with .product when exporting for multiple platforms [message #19013 is a reply to message #18926] |
Wed, 03 September 2008 09:47   |
Ok. Some more information on this.
The plugins making problems are:
- org.eclipse.core.filesystem.*
- org.eclipse.ui.carbon.*
- org.eclipse.swt.*
But it works appropriately for (e.g.):
- org.eclipse.equinox.launcher.*
Comparing the Platform-Filter of the 2
org.eclipse.core.filesystem.macosx (NOT WORKING):
Eclipse-PlatformFilter: (& (osgi.ws=carbon) (osgi.os=macosx) (|(osgi.a
rch=x86)(osgi.arch=ppc)) )
org.eclipse.equinox.launcher.carbon.macosx (WORKING):
Eclipse-PlatformFilter: (& (osgi.os=macosx) (|(osgi.arch=x86) (osgi.ar
ch=ppc)))
Another difference between those two is that:
- org.eclipse.core.filesystem.macosx is packaged as a jar
- org.eclipse.equinox.launcher.carbon.macosx is a directory
Is it possible that the meta data generator has problems extracting
filter informations from bundles packaged as a jar?
Tom
> the export feature]
> like this:
> <filter>
> </filter>
> </required>
> <filter>
> </filter>
> </required>
> Tom
| Re: [P2] Problem creating repository with .product when exporting for multiple platforms [message #19483 is a reply to message #19013] |
Fri, 05 September 2008 11:29   |
So no one an idea?
Tom
> - org.eclipse.swt.*
> ch=ppc)))
> Tom
>> the export feature]
>> Hi,
>> like this:
>> <filter>
>> </filter>
>> </required>
>> <filter>
>> </filter>
>> </required>
>> Tom
| Re: [P2] Problem creating repository with .product when exporting for multiple platforms [message #19527 is a reply to message #19483] |
Fri, 05 September 2008 16:36   |
There is a bug here. A workaround would be to export to an archive
instead of a folder.
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=246430 for details.
-Andrew
Tom Schindl wrote:
> So no one an idea?
> Tom
>> - org.eclipse.swt.*
>> ch=ppc)))
>> Tom
>>> the export feature]
>>> Hi,
>>> like this:
>>> <filter>
>>> </filter>
>>> </required>
>>> <filter>
>>> </filter>
>>> </required>
>>> Tom
| Re: [P2] Problem creating repository with .product when exporting for multiple platforms [message #19572 is a reply to message #19527] |
Fri, 05 September 2008 18:47  |
Hi Andrew,
Thanks for the clarification and I don't missed anything.
Tom
> -Andrew
> Tom Schindl wrote:
>> So no one an idea?
>> Tom
>>> - org.eclipse.swt.*
>>> ch=ppc)))
>>> Tom
>>>> the export feature]
>>>> Hi,
>>>> try
>>>> point.
>>>> like this:
>>>> <filter>
>>>> </filter>
>>>> </required>
>>>> <filter>
>>>> </filter>
>>>> </required>
>>>> expecting
>>>> Tom
| Re: [P2] Problem creating repository with .product when exporting for multiple platforms [message #578399 is a reply to message #18926] |
- org.eclipse.swt.*
ch=ppc)))
Tom
> the export feature]
> like this:
> <filter>
> </filter>
> </required>
> <filter>
> </filter>
> </required>
> Tom
| Re: [P2] Problem creating repository with .product when exporting for multiple platforms [message #578567 is a reply to message #19013] |
So no one an idea?
Tom
> - org.eclipse.swt.*
> ch=ppc)))
> Tom
>> the export feature]
>> Hi,
>> like this:
>> <filter>
>> </filter>
>> </required>
>> <filter>
>> </filter>
>> </required>
>> Tom
| Re: [P2] Problem creating repository with .product when exporting for multiple platforms [message #578587 is a reply to message #19483] |
-Andrew
Tom Schindl wrote:
> So no one an idea?
> Tom
>> - org.eclipse.swt.*
>> ch=ppc)))
>> Tom
>>> the export feature]
>>> Hi,
>>> like this:
>>> <filter>
>>> </filter>
>>> </required>
>>> <filter>
>>> </filter>
>>> </required>
>>> Tom
| Re: [P2] Problem creating repository with .product when exporting for multiple platforms [message #578607 is a reply to message #19527] |
Hi Andrew,
Tom
> -Andrew
> Tom Schindl wrote:
>> So no one an idea?
>> Tom
>>> - org.eclipse.swt.*
>>> ch=ppc)))
>>> Tom
>>>> the export feature]
>>>> Hi,
>>>> try
>>>> point.
>>>> like this:
>>>> <filter>
>>>> </filter>
>>>> </required>
>>>> <filter>
>>>> </filter>
>>>> </required>
>>>> expecting
>>>> Tom
Current Time: Sat Nov 15 03:31:52 EST 2025
Powered by FUDForum. Page generated in 0.05200 seconds
