xsd errors [message #30206] |
Thu, 25 September 2003 09:02  |
Originally posted by: dominic.nospam.com
Hi. I tried creating a simple xsd file in the eclipse editor. I selected
"Example Emf model creation wizards/XSD Model". However when i select
documentation or the definition tab i am getting an error stating that "The
source page has errors. Other pages cannot be used until these errors are
corrected". I did not add anything to the default created xsd file at all.
FYI this happens in both eclipse 3.0M3 and 2.1.0. both with
emf_1.1.1_20030819_0612SL and xsd_1.1.1_20030819_0612SL
Re: xsd errors [message #30282 is a reply to message #30206] |
Thu, 25 September 2003 10:27  |
Hi Dominic,
By default, Eclipse associates .xsd files with its Extension Point Schema
Editor, so that's they editor used to open them on creation. You'll have to
close the editor, right-click on the schema file in the Navigator, and
select Open With -> Sample XML Schema Editor.
You can change the default File Association in the Preferences dialog box.
Dave
Re: xsd errors [message #578461 is a reply to message #30206] |
Thu, 25 September 2003 10:22  |
--------------BD058AB2A93D8D30B2E3A6DD
Content-Type: text/plain; charset=us-ascii
Dominic,
You are using the Extension Point Schema Editor from the PDE rather than the
Sample XML Schema Editor from XSD. Using Window->Preferences, you can change
the default file association:
[Image]
Or you can use Open With to choose the one you want.
Content-Type: multipart/related;
boundary="------------5D0CFAA17FCA9953D5F1A91E"
--------------5D0CFAA17FCA9953D5F1A91E
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Dominic,
<p>You are using the Extension Point Schema Editor from the PDE rather
than the Sample XML Schema Editor from XSD. Using Window->Preferences,
you can change the default file association:
<blockquote><img SRC="cid:part1.3F72FA18.107A530E@ca.ibm.com" height=552 width=602></blockquote>
<br>
<p>dominic wrote:
<blockquote TYPE=CITE>Hi. I tried creating a simple xsd file in the eclipse
editor. I selected
<br>"Example Emf model creation wizards/XSD Model". However when i select
<br>documentation or the definition tab i am getting an error stating that
"The
<br>source page has errors. Other pages cannot be used until these errors
are
<br>corrected". I did not add anything to the default created xsd file
at all.
<br>FYI this happens in both eclipse 3.0M3 and 2.1.0. both with
<br>emf_1.1.1_20030819_0612SL and xsd_1.1.1_20030819_0612SL</blockquote>
</html>
Content-Type: image/jpeg
Content-ID: <part1.3F72FA18.107A530E@ca.ibm.com>
Content-Disposition: inline; filename="C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\nsmailOJ.jpeg"
/9j/4AAQSkZJRgABAQAAAQABAAD/2wBDACAWGBwYFCAcGhwkIiAmMFA0MCws MGJGSjpQdGZ6
eHJmcG6AkLicgIiuim5woNqirr7EztDOfJri8uDI8LjKzsb/2wBDASIkJDAq MF40NF7GhHCE
xsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbG xsbGxsb/wAAR
CAIoAloDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwCKS8uzdPFE5J8wqqhR/hSS Xl7ESGc5HUYX
j9KSN1S/lycOZGCH3oaSMD5lII6gj/69b2VhIal7fysBEzucZwqAn+VI9/fR uVkdlYdQyAH+
VPsZIlkuCxCo1uwAzjPsPepFu4ZLeZ3iiLRJGkSSckgHn0z+FKy7CZX/ALSu /wDnr/46P8Kk
mu7+AgSyBSRnbhcj6jt+NSO1uLJBHFE+YfmJkVWV+5wfmJ/HFTzS28l7dsfK kfagiOVAI4zy
QRn680adhFH+0bv/AJ6/+Oj/AAo/tG7/AOev/jo/wqeeSBbSVlggWRpcBQwY qCvUEe/4CppW
tPNRY4oTDvjIfzFGBxnjqe+c0adg1Kf9o3X/AD1/8dH+FH9o3X/PX/x0f4Vd Q2byAy+Thbll
GAB8mOM46jOOTUVuUHneeIDNtXywDGBjPP8As5+vNGnYNSv/AGhdf89f/HR/ hS/2hdf89f8A
x0f4VbiNsxn3xxQEtkMGSQLx0we2fT6dqyqaSfQNS1/aF1/z1/8AHR/hS/2h df8APX/x0f4V
VpaOVdhXZZ+33P8Az1/8dH+FL9vuf+ev/joqrS0cq7Bdln7fc/8APT/x0Uv2 65/56f8Ajoqr
S0cq7Bdln7dc/wDPT/x0Ufbrn/np/wCOiq9FHKuwXZZ+3XH/AD0/8dFH224/ 56f+Oiq9FHKu
wXZZ+23H/PT/AMdFH224/wCen/joqvS0cq7Bdlj7bcf89P0FH2y4/wCen6Cq 9LRyoLssfbLj
/np+go+2T/8APT9BUFFHKguyx9sn/v8A6Cj7XP8A3/0FQUUcqC7J/tc/9/8A QUv2uf8Av/oK
goosguyf7XP/AH/0FL9qm/v/AKCoKWiyC7JvtU39/wDQUv2qb+/+gqClpWQX ZN9qm/v/AKCl
+0zf3/0FQ0UWQXZN9pm/v/oKX7TL/f8A0FQ0UWQXZN9pl/v/AKCj7RL/AH/0 FRUtFkF2S/aJ
f736Cj7RL/e/QVFS0WQXZL9ol/vfoKPPk/vfoKipaLILsl8+T+9+go8+T+9+ lR0UWQXZL50n
979KPOk/vfpUdFFkF2SedJ/e/Sl86T+9+lR0tFkF2P8ANf8AvfpS+a/979Kj paLILsf5r+v6
Uvmv6/pUdLRZBdj/ADH9f0pfMf1plFFkF2P8xvWl8xvWmUUrILsfvb1o3t60 2losgux29vWj
e3rTaWiyC7Hbj60bj60lFFkF2O3H1o3GkoosguyRRlcliOcdKXA/vH/vmkzi LOCcE9PwpqMz
E5jkXAzllxWb3LWwxriKOKWWRyiRvtJ259P8ahTUrKR1RLglmIAHlnrSPn7P KQCcXIJCjJwC
hPFLPMsqKiJKT5iHmJh0YHqRSuOxYicSNIASAhxnHXp/jSh4irMJgQhIY8cY 655qO0+9c/75
/pVS5tZZrh5liUKpH7sn/X49cHH0z+NNsSRd81TKiIdwZd27tjiqUv8ArX/3 jVjJN6hIIJiP
B7ciq8v+tf8A3jQASaV5kkj+cBvYnGzpnt1ph0fPWfP1U/41qUUc7HYyjo2c fv8AGP8AY/8A
r0f2L/08f+Of/XrVoo55BZGV/Y3/AE8f+Of/AF6P7G/6b/8Ajn/161aKOeQu VGX/AGP/ANN/
/HP/AK9H9j/9N/8Axz/69alFHPIOVGX/AGP/ANN//HP/AK9L/ZH/AE3/APHP /r1p0Uc8g5UZ
n9kf9N//ABz/AOvR/ZH/AE3/APHP/r1p0Uc8g5UZn9k/9N//ABz/AOvS/wBk /wDTf/xz/wCv
WlRRzyDlRm/2T/03/wDHP/r0f2V/02/8d/8Ar1pUUc8g5UZ39lf9Nv8Ax3/6 9H9lf9Nv/Hf/
AK9aNFHPIOVGd/Zf/Tb/AMd/+vS/2X/02/8AHf8A69aFFHPIOVGf/Zn/AE2/ 8d/+vR/Zn/Tb
/wAd/wDr1oUUc8g5UUP7M/6bf+O//Xo/s3/pt/47/wDXq/RRzyDlRQ/s3/pr /wCO/wD16P7N
/wCmv/jv/wBer9FHPIOVFH+zv+mv/jv/ANej+zv+mv8A47/9er1FHPIOVFH+ z/8Apr/47/8A
Xpf7P/6a/wDjv/16u0Uc8g5UUv7P/wCmv/jv/wBej7B/01/8d/8Ar1doo52H Kin9g/6a/wDj
tH2D/pp/47VyijnYcqKf2H/pp/47R9h/6af+O1coo52HKip9h/6af+O0fYv+ mn/jtW6KOdhy
oqfYv+mn/jtL9j/6afpVqijnYcqKv2P/AKafpR9j/wCmn6Vaoo52HKit9k/2 /wBKPsn+3+lW
aKOdhyorfZP9v9KX7L/t/pViijmYcqK/2X/b/Sj7N/t/pViijmYcqK/2b/b/ AEpfs3+3+lT0
UczDlRB9n/2/0o+z/wC1+lT0UczDlRD9n/2v0o8j/a/SpqKOZhyoh8j/AGv0 pfI/2v0qWijm
YcqIvJ/2v0o8n/a/SpaKOZhyoi8n/a/Sl8r/AGv0qSijmYcqI/K9/wBKPL9/ 0qSijmYcqGeX
70eX70+ijmYcqGbPel2e9Ooo5mHKhuz3o2+9Ooo5mHKiKSBJSN+446YYimfY 4fRv++j/AI1Y
opXY7Ff7HFjGGx1++f8AGj7HD6N/30f8asUUXCxCLaMIUG4KTk/Mef1pv2OH 0b/vo/41Yoou
wsRR20cT7lBzjHJJqnL/AK1/941o1nS/61/940XA0ahht47i7nEoJ2hcYYj1 9KmpLP8A4/Ln
6J/WkAn2Wyyf3chwccbzTksbR13KjY93Yf1oIbJ/fXEWGbhIwQeTzypqeAHZ nLDLMcEY7mmB
WFrYnbgN8zlB87ckZyOvsacllZyKWRWIBK/fbqDg9/UUya1m86R4ydqnzI1B wC2Rke33Tz/0
0Pvlktm6psEfnN5QRJOBsfnL8nIySDkZPFAEr2dojxqY3zI20YduuCfX2oSz tHeRRG+Y22nL
t1wD6+9RmykKrtyjmd3Z85IU78d+nzDgY6noeaals/nsfsYicyoVkBXCqAoI BznBwR079qAL
P9nWv9xv++2/xo/s61/uN/323+NUo9PkCbXR2JKCTcU2yYdSTwMtwDy3PPua ma1KTNm2EtsG
OyEbcDITkAkAchvz96AJIrO0lQssbgBmXl26gkHv7U/+zrX+43/fbf41HDam OSORYlVzPIZG
GMlDuxk9+q8f4VeoAq/2da/3G/77b/Gj+zrX+43/AH23+NWqKAKv9nWv9xv+ +2/xo/s61/uN
/wB9t/jVqigCr/Z1r/cb/vtv8aP7Otf7jf8Afbf41aooAq/2da/3G/77b/Gj +zrX+43/AH23
+NWqKAKv9nWv9xv++2/xo/s61/uN/wB9t/jVqigCqYkhUJGMKCe+fSm4BKg8 jcP51JN1/H+g
qMfeX/eH86Qyz5Uf/PNfyprCBXVGEYZ87VOMnHXFZ11B5+uhcRHFtn97HvH3 vTIqn50gvw6I
rPHPc7FCYyQgx06/zpiN/wAqP/nmv5UeVH/zzX8qz9KuJ52BluYZVaIMUDgu rfQAYHPTmqN1
PJ9vlvxG5jtplj3/AC8KMhxjPOS3/wCqgDe8qP8A55r+VHlR/wDPNfyrLF7c DUZomkQgByhV
lKKAP4+Nw9znrUMWoXJtstI4Imjjkl+RlVT1IIGPzzjIoA2vKj/55r+VHlR/ 881/KshL64Zo
lkn2QNPIn2jCjKgfLyRt5Oe3ahrtori82vuBMKrKoUdR95mwePfB68UAa/lR /wDPNfyo8qP/
AJ5r+VYKXMlxcWsk84RYppo/PUrjG0Y5Ixz9Oalju5VuGQyLBC13KryhVGMA YGSMc+/JxQBs
+VH/AM81/Kjyo/8Anmv5ViR317KgLStGVs2mwEHzEMQDyO4xUqahcPe2wdgY 5VQ7IWXKkjJ3
KQTj8sCgDW8qP/nmv5UeVH/zzX8qfRQAzyo/+ea/lR5Uf/PNfyp9FADPKj/5 5r+VHlR/881/
Kn0UAM8qP/nmv5UeVH/zzX8qfRQAzyo/+ea/lR5Uf/PNfyp9FADPKj/55r+V HlR/881/Kn0U
AM8qP/nmv5UeVH/zzX8qfRQAzyo/+ea/lR5Uf/PNfyp9FADPKj/55r+VHlR/ 881/Kn0UAM8q
P/nmv5UeVH/zzX8qfRQAzyo/+ea/lR5Uf/PNfyp9FADPKj/55r+VHlR/881/ Kn0UAM8qP/nm
v5UeVH/zzX8qfSUAN8uP/nmv5Ck8uP8A55L/AN8078DSY46GgBuxP+eS/lRs T/nkv5U4j2P+
f8ikx/sn86YCbE/54r+X/wBak2r/AM8V/KlI/wBk0m3/AGTQINq/88B+VG1f +eA/KjH+w1Jt
/wBlqAF2r/zwX8qTC/8APBfy/wDrUbf9lqNv+w1ABhf+eA/L/wCtTJAAFIjC nPp7Gnbf9hv8
/hTXGFHykfN3+hoYxtZ0v+tf/eNaNZ0v+tf/AHjUgaNJZ/8AH5c/RP60tJZ/ 8flz9E/rQBbb
7yfX+hp1Nb7yfX+hp1MApqZKLnrjnNOqONTsX5iOBxge3t/nNABPPHbQtLM2 1F6nGfapKq3E
U8k1v5TKojyxd13c4wBgEdifyqgttJuaBoA8yQLHHKAo2YZwrcnI4weM0AbN FZKW7yrJ9ni8
qTzJsz8DdkuAMjnqR1Hb6U5bR1gkVYZBG5XdGwiycZ5CgbeuOT2HsKANSis2 0tZkLyMmJFj2
xeYRgHc+MheOhHTsSBUcNixmVWgb7OHVikgjxna4JwvHdff8qANais+G3ZJl Mtv5qgkR/dPl
fOxB5PHBXp6ewo061kgk3OJA2zDsSmHbjngZPfluefc0AaFFFFABRRRQAUUU UAFFFFAFebr+
P9BUY+8vBOCDx9akm6/j/QVHSGWfMX0b/vk0eYvo3/fJqtRQIs+Yvo3/AHya PMX0b/vk1Woo
As+Yvo3/AHyaPMX0b/vk1WooAs+Yvo3/AHyaPMX0b/vk1WooAs+Yvo3/AHya PMX0b/vk1Woo
As+Yvo3/AHyaPMX0b/vk1WooAs+Yvo//AHwf8KQup7P/AN8n/Cq9FFwLBdfR /wDvg/4Ublz0
f/vk/wCFV6KdwJ9y+j/98n/CjK+j/wDfJ/wqCii4E2V9G/75P+FHy+jf98n/ AAqGii4WJfl9
H/75P+FHy+j/APfJ/wAKioouFiX5fRvyP+FJhfR/yP8AhUdFFwsSYX0f8j/h TXA2jAbr3B9D
7U2ii4WCs6X/AFr/AO8a0azpf9a/+8aQGjSWf/H5c/RP60tJZ/8AH5c/RP60 AW2+8n1/oadT
W+8n1/oadTAKbHxGo6cCnVHGp2L8xHA4wPb2/wA5oAWWVIl3OTycAAEkn2A5 NLG4kQMoYA/3
lKn8jUMqOsscyKZCishUYBOcc84Hb26/hVe5hlnLP9nbc8e2MsVzC2T83Xjq vIyeKANCist7
F9shWFd7CZgRjO8tlDn1xnB7UQROWZ7eBUkWWUmVsAPywAODk846+n0oA1KK yYbF/OVTDIsA
dWKvsH8Lg8Jx3Ue/0p4ha2uJbqVZDsLuzjZhl5wOm48Y4PHHsKALQvoNxBLg gnPyEgAMVySO
AMqetTyOsUbSOcKgLE+gFUYrF+I5XYRi3jiYJjD43ZHIz37Y61Fc2c808hVC rSB1ZxsCFSpC
8/eP8Oc8Z/CgDVpkMgmhjlUEK6hhnrgiqiQATxubL93gBEwn7ognJxnjOR0z 0osrU2/2bbEs
f7jEu3Ay/wAuM46/xc0AXqKKKACiiigAooooArzdfx/oKq3juluTGSG3KPlx nlgOM8Vam6/j
/QVC6K4wwyMg/iDkUhlJ5ZU8tGMwLMD85XON6D+H6n9amtbo3Df6plUruVsH p75AGee2e9TP
CkjKzrkr059wf5gUkcEcTZQEHGBkk4HoPQfSgCGKeQLukUFDKyBgeQNxAyMe uB+OaT7YxDOs
QMap5hJfkrk4IGPQZ7dale3VkdVJUSH5hkkEZ547Z56etD2ySTtI5JBULtBI HBPXnnr3oAiF
6TI4EMjIpYZVSSSM+2O3r6VLDM0qg7UPzYba+dvHfIHOeMe9L9nj3FsHJz0Y 4GepA7H3HrSr
BGu3AOVbcCSSc4xknvxQBJRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRR
RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAVnS/6
1/8AeNaNZ0v+tf8A3jQI0aSz/wCPy5+if1paSz/4/Ln6J/WgC233k+v9DTqa 33k+v9DTqYDH
kVCAc5PQBSf5U2KRSFTkMF6FSP6Cm3AO9cNInykbkXJHI9j6VDZRPFHDGzyM UjwSVwB93gcD
jg+9AFia4jhZVfeWYEgKjMcDGeg9xSvMqRLIQ2GKgcYPzEAcH61Wu4maeF/L mlVUZT5cmw5J
XHcehqOaB5Jt7WxZ2ljdZDtzGoK5HXPZumRzQBejlSXdsJ+UgEEEEHAPf2Ip 9ZUFlJHAVaAG
RljJYbeVAQMmffafbnrUsFoftSSND5cK7ikeR8n3MDAOOqsf160AaFFU9Pha HzN0ewHGGcL5
jHnJYqcH69ev1NygAooooAKKKKACiiigAooooAKKKKAK83X8f6Cqt2xS1kZS QQOCKtTdfx/o
KqXv/HnL9KQyZ7JURmNxcEAZ4Yf4VG1vsXc8l2F453Kf5VLeRNcSLGjBSo3E kZHPt+FFnGEW
W3kw+0gnI4wfb8KYgFirAEXU5B5BDD/Cj7AP+fm4/wC+h/hUZjuGtoxasEAk OR7eZ6cds9+n
HfixcPJBYPJ96RI8n5vQc84/pQBH9gH/AD83H/fQ/wAKPsA/5+bj/vof4U2f UfJeQeXvVQ21
hnkhSSM4x2I4J+nXCXlzP9mnVIwjrCXYmTBUHOMYByeD/iaAH/YB/wA/Nx/3 0P8ACj7AP+fm
4/76H+FIL8mVwLeRkUsMqrEkrnPbHYgc+n4LHeSS7VjjiaQ7jgSnAAxnPy5B +YcYoAPsA/5+
bj/vof4UfYB/z83H/fQ/wq5RQBT+wD/n5uP++h/hR9gH/Pzcf99D/CrlFAFP 7AP+fm4/76H+
FH2Af8/Nx/30P8KuUUAU/sA/5+bj/vof4UfYB/z83H/fQ/wq5RQBT+wD/n5u P++h/hR9gH/P
zcf99D/CrlFAFP7AP+fm4/76H+FH2Af8/Nx/30P8KuUUAU/sA/5+bj/vof4U fYB/z83H/fQ/
wq5RQBT+wD/n5uP++h/hR9gH/Pzcf99D/CrlFAFP7AP+fm4/76H+FH2Af8/N x/30P8KuUUAU
/sA/5+bj/vof4UfYB/z83H/fQ/wq5RQBT+wD/n5uP++h/hR9gH/Pzcf99D/C rlFAFP7AP+fm
4/76H+FH2Af8/Nx/30P8KuUUAU/sA/5+bj/vof4UfYB/z83H/fQ/wq5RQBT+ wD/n5uP++h/h
R9gH/Pzcf99D/CrlFAFP7AP+fm4/76H+FMez2n/j5nx9R/hV+oLjO07QCcDA Jx60AVPsw/5+
bj9KLXO2YFmbbJtBY84xUNpHfJO5uXieNznCk/L9OOlTWvS4/wCu39KQFgnC rgDp6Um4+35C
hui/T+tJQMXcfb8hRuPt+QpKzI5pEJuFgfdOrEE4O8gZTgHP3QRQBqeZ8xXK 5AyRgUCTcMqV
IzjgCswSgXDlLrehCB5cr8g+c9cY646+tWLF18kKH3lmkYH+8A55447igC3u Pt+Qo3H2/IVG
kyPs2tneu9eOo4/xFPoAXcfb8hUM0jefAoOASc4GM8Gpagm/4+bf6t/KgCes 6X/Wv/vGtGs6
X/Wv/vGgRo0ln/x+XP0T+tLSWf8Ax+XP0T+tAFtvvJ9f6GnU1vvJ9f6GnUwC mx8RqOnAp1Rx
qdi/MRwOMD29v85oASa4jhZVfeWYEgKjMcDGeg9xUisGUMM4IzyMH8qp3cTN PC/lzSqqMp8u
TYckrjuPQ04xu9wsvkkJkFkLDJbs2Ony/r/wFcgFmN1ljWRDlXAYH1Bp1ZP2 FhbwR+QwWMFX
VBGd7YHz4bjseTzzUgsWMcgkTezSRcs27KjZu6/7pzwM4+lAGlUYmUmXhv3R w3Gc8A8Y69ao
zWj4eMQ5t/M3KiKhI+VegbgDO7PfP41Pp0U0UTeeDvYqSScknYoP6g0ATQXE dwGMe/CnB3Iy
8/iPapaotbv9nVXi8xRO7vHwd6ktjrx3B59PWoWtJSjAw7iyEQnI/cHcxB68 YBX7ufu+woA0
YpBKhZQQAzLz6gkH+VPrNW1lE6MYtxEjHMgVkUF2ORzkNjHT2z7aVABRRRQA UUUUAFFFFAFe
br+P9BVS9/485fpVubr+P9BVS9/485fpSGW7hPmEgmERxtJI4NRxQqxYi6LS NyShHT6c1PMQ
rRFiAAxJJ7fKapzO8k103mEeQFaPAHGRk07dRF6KMRRhASeScnryc0ye3WZJ R90yoEZuvy8/
4mmXj3KBPsyBssN2fTcPr2z29+3LppnhsmmZTvVNzAAcHHPGf0zQAj2VvIxL qxzn5d7BeQQe
M47n86dPaxXGfMDcjadrlcj0ODz3/Oo5L+KO4aEqxcAkBSpLcZwADnp6gU57 yJEkcfMqBSWD
KAc9BkkD0P4j1oAd9li3lsMCc9HIAJ6kDPB68jnk0n2SHaBhwQc7hIwY/Vs5 PQd+w9KfBMlx
CssZyrf04NSUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUU AFFFFABRRRQA
UUUUAFFFFABRRRQAVWuYDK4PmyIMdFIGf0qzUcn3v8/5/wA/mAVPsf8A08T/ APfQ/wAP8/zd
HCII3AZm3MGJbGelT/5/z/n/AOu1/un8P60gK8tzDGQryKGA5HpTPtlv/wA9 Vqxt4BLAZo2j
+8P1oGV/tlv/AM9Vo+2W/wDz1WrG0f3h+tG0f3h+tAFf7Zb/APPVaPtlv/z1 WrG0f3h+tG0f
3h+tAFf7Zb/89Vo+2W//AD1WrG0f3h+tG0f3h+tAFf7Zb/8APVajaeKW6gEb hsE5x9DVzaP7
w/Wmu6oyKTkucDH0zQAtZ0v+tf8A3jWjWdL/AK1/940CNGks/wDj8ufon9aW ks/+Py5+if1o
Att95Pr/AENOprfeT6/0NOpgFNj4jUdOBTqjjU7F+YjgcYHt7f5zQBBc3Qgl CEtkjICoW6Yz
0HvTVuy0ioC2WUtyuOmPX/eFR3UBkvELF9qowLBipydvpj0NVJbWUyybAdp7 7gSR+745652s
OfxpAafmv/e/SmRXfm7/AC3zsYo3HQiqsEckNrII0O7kojleuOmBgDmovss0 a7CxkQxKn7tQ
p+U8dTg5yc/SgZpea/8Ae/SjzX/vfpWatvIHhJhQFe21diDJPAzkN9Mj+dIt tJsAEW0qoEpy
P3xypP1yA3XH3vrQI0vOfcRk5Az0pDckMy7jlVDEBc8c/wCBrPeBju2W+yJl UFAEzwWPA6dS
D/8AXqMWsnkyboSztEyITtynLY+mQQOKBmt5r/3v0o81/wC9+lZk1tI6yBYv 3h8zMmR84IbC
569168cfSnTWuGYRwny8KQiBdpb5s5BwCOn6elAGrC7Nncc4qWq1kpWIKwUE KAQvQfT2qzTE
FFFFABRRRQBXm6/j/QVUvf8Ajzl+lW5uv4/0FVL3/jzl+lIZdulJj3fJhclt 5wMYIOfzqmkW
2N4IRbKZMggSknPPt7H8jVy4RZPLRxkF/wChqnKqMbxNnESgryepBPr/AJwP QYrWwjSqC5gM
0UyqxzKnl4J4Uc5IHrz+OBTby4ktwhjiMm5gDjtlgPp39f0zh8k/l2hncYwm 4jB4/TP6UgGi
0UTK4kk2q5cR8bQTnJ6Z7nvQLONYwqFkKuXVlxkHkemOhx9MU5LqKSQopbOS uShAJHUAkYPQ
9PSk+1w7ScuCDjaY2DH6LjJ6Ht2PpQA+CIQRbAzNyWLNjJJJJ6fWpKri9tyo bc2DnPyN8uCR
83Hy8g9cdDVigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKA
CiiigAooooAKKKKACo5Pvf5/z/n85Kjk+9/n/P8An8wBv+f8/wCf/rtf7p/D +tO/z/n/AD/9
dr/dP4f1pAMbov0/rSUrdF+n9aSgZDLLIsqRxorFlLfM23GMex9aBdRFEckg Oob7pO0HucdP
xontY7h1MqhlCsu0j1xz7dP1qKWy81wztG7bdpLxhjgE4x2B5+ntQBL9rhyR uPBIJ2nHHBOc
dB3PQUNdQqW3MQFBydpxx1wehPXj2NRtZ7kZfM+8si9P75z+lPW3KyKS4KK7 Oo285Oc5OenJ
7elAD3njjYqxO4AHABJOc9AOvQ/lTkdZFDKcg1WNinkiMbTtfcN67h0wARnn AwPwzViGMRRB
Bjj+6uB+AoAfUE3/AB82/wBW/lU9QTf8fNv9W/lQBPWdL/rX/wB41o1nS/61 /wDeNAjRpLP/
AI/Ln6J/WlpLP/j8ufon9aALbfeT6/0NOprfeT6/0NOpgFNj4jUdOBTqjjU7 F+YjgcYHt7f5
zQAyeSGJ1Egcs4JAVGY4GM9B7inqkbKGCnBGecg/lUM1sZbmEsX2JG4LK5U5 JXHQj0NRPbOL
jiIs29CkxIJRBtyuSd3OG/769zQBadYo1DPwCQvfqTgfqad5Sf3f1rNGnstv bosCDES+cox8
7BkOD6nhvz96njgYXyyLBtUAZMiqdg24whByPcdOuPcAt+Un939aPKT+7+tP ooAZ5Sf3f1o8
pP7v60+igBnlJ/d/Wjyk/u/rT6KAGqir90YzTqKKACiiigAooooArzdfx/oK qXv/AB5y/Src
3X8f6Cql7/x5y/SkMuXSF0UBC4ycqDjggj+tVY7STLIPNRXH7xnZWJHYfzq3 cBP3fmY2bud3
ToaqB96tNCqwtGm/AGdwPY9PSq1sI0ar3cUksE6Kc+ZHsVcYwTkE5/EflRd3 a2oTcrMWIHyj
PcDoOe/9O4qTz4xAJnZUQgHLMMDPv0pAVY7OV1Ilk2KJJGQIMMNxYA7s+jZ6 elM+wPAWmiEf
mAqVSKIKMjcOQW54Y9x0FXVnhbO2WM4xnDDv0/PtRJPDECZJY0AO0lmAwcZx +VAFFNNLqHmE
XmNndviDYBZm+Xng/N7jp176VQPdRrcRwB0aR2wVDDKjaTnH4frU9ABRRRQA UUUUAFFFFABR
RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFRy fe/z/n/P5yVH
IQG5Pb/P+f8AJAG/5/z/AJ/+u1/un8P60uR6j/P+f892swIbBBwQDz060gIJ FmZvklVVAwBs
z/WmeXcf8/C/9+//AK9T0UDIPLuP+fhf+/f/ANejy7j/AJ+F/wC/f/16nooA g8u4/wCfhf8A
v3/9ejy7j/n4X/v3/wDXqeigCDy7j/n4X/v3/wDXo8u4/wCfhf8Av3/9ep6K AIPLuP8An4X/
AL9//XoEMplR5Jg2wkgBMdsetT0UAFZ0v+tf/eNaNZ0v+tf/AHjQI0aSz/4/ Ln6J/WlpLP8A
4/Ln6J/WgC233k+v9DTqa33k+v8AQ06mAU2PiNR04FOqONTsX5iOBxge3t/n NACvLGjbXYKd
pbnpgYyc/iKcrBlDDOCM8jB/KqlzbySXMEi8+UrH5jwxyuAfyJ9iAfaomtpH vhMySAllZTlM
IABlSeW7HgcHPuaANGis1bfzIZAPMdI8xRCPAO0NyOeD0C89QvvVy0Ro7ZFd I4yM/LGuAOfT
/PNAE1FFFABRRRQAUUUUAFFFFABRRRQAUUUUAV5uv4/0FVL3/jzl+lW5uv4/ 0FVL3/jzl+lI
ZNdWQklEybi5IyABxx/+rvUMCTGKcGF9zxhBwBzg+v17VduGKKuGKjJyRjpg nvx2qFrh0xIr
GRACXUlcgevFVd2sTZXLbKGGGAIyDyO46VDcRyS/KCgQNGw65yGyf0AxS3N1 FaqrTNtDEAE9
OoHX8c/QH0qVWDKGGcEZ5GD+VIZTFpIDn923EoIbJGHcHp34zx/+uka0mCRr EVV03Ks28ggH
GSVwQxPfPXGeM8XqKAKa28yzRjEflJK8m7cdx3buMY/2vXtVyimu6xqGc4BI X8ScD9TQA6ik
DAkgZ4OORS0AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAU
UUUAFFFFABUMxIzg46f1qaoZ/wDD+tAEW9v7x/OobXpcf9dv6VLUNr0uP+u3 9KQyaiiigAoo
ooAKKKKACiiigAooooAKzpf9a/8AvGtGs6X/AFr/AO8aBGjSWf8Ax+XP0T+t LSWf/H5c/RP6
0AW2+8n1/oadTW+8n1/oadTAKbHxGo6cCnVHGp2L8xHA4wPb2/zmgBxdRIsZ PzMCwHsMZ/mK
SaQQwySsCVRSxx1wBUEwkS5hkWJ5QsbqdpUHJK+pHoap3drcSyyskTb3DqWX YFZSpCjP3j/D
14z+FAGtTBIDM0WDuVQx9MEn/A1nSWjuD5du0MOVzCoTLYDZOOV7r1/u+wqx YwPDIxYMFMag
biCR8znHHAwCOnHYUATQXUVxjyy3I3DchXI9Rkc9vzqas1YLiWyhh2NA8MeA zMOW2FRjBPrn
P+Q2OzZF4gkMW8FoX8sbuGH3VwvUqeT29hkA1KKzzbsZgVt9pLoyP8v7pBty nXI6NwOOfrTP
sbLYW8JhLAKDIFCM2/AH8fGOo/LHFAGgJUJYAklGCtgE4Jx/iKfWXDaSqgMk O6ZjEzS5BOBs
3AnOf4SfSkFlIyIhgAwFExO3Ex3qS3vwG688+5oA1aKzJrN8sscAZA5MSEKY gCq8lScjnd05
6+vOnQAUUUUAFFFFAFebr+P9BVS9/wCPOX6Vbm6/j/QVUvf+POX6Uhly6ZVV CzBBuI3Ht8pq
tLNF9nlAuFclCAMn+pNXJnZAu3HJwcgnsT0H0qJ7h4trON0ZzuIjIK0xE0kU cuN6glSCD3GC
D/MD8qq34xbGLyAYg0QAGMN84+XH5fnVqSWOLG9gCxAA7nJA/mR+dL5ibA+9 drYw2eDnpQBR
gtD9qSRofLhXcUjyPk+5gYBx1Vj+vWq8tu0cCb7fpsWX7v79t6c9eejfex97 61sUisHUMpDK
RkEHgigDLks3fB8l1g3MVgURkrwuOGyvUMeP73uaf9hYxTeYnmOXjPzNu3Ko TI59dp9M8ZrS
ooAypbN3csYXEJbIiURkj5EA4b5eMMP5cVNDbSJdxsULbVAaSXaxGFx8rdev XI556d79FABR
RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAVDP/
AIf1qaoZ/wDD+tAENQ2vS4/67f0qaobXpcf9dv6Uhk1FFFABRRRQAUUUUAFF FFABRRRQAVnS
/wCtf/eNaNZ0v+tf/eNAjRpLP/j8ufon9aWks/8Aj8ufon9aALbfeT6/0NOp rfeT6/0NOpgF
Nj4jUdOBTqjjU7F+YjgcYHt7f5zQA4uokWMn5mBYD2GM/wAxSqwYZGepHIxV aYSJcwyLE8oW
N1O0qDklfUj0NVTYuRdO0KmQo3kscZDb5CMHt1WgDRikEqFlBADMvPqCQf5U +sx7SfypBgsZ
HboRlV3liBnjDD174zx0EtCipvtnlhBb9y2wkE7cHHCjo3T19zQBc+1xCCKY 7wsoG0BSxORn
oM9qljdZEDocg1TW2lNrYx5aNosbyuMr8hHfI6nFRTWcjRxI6O6oW3BNh3sS Dvw3A/i9xnA4
oA06KzGtJy52A+Z5W3zpSGKnZgbWHzDnrkep47uWB0mWaK2MUaMD5I2gk4cE gA4/iXv2+lAG
jRWZFZzN9ocoY5HRhGS33WLSHPBPOGHPufeia08xY9lo8USlt0SrFkk4w2Dl exHrQBp0VQht
pEu42KFtqgNJLtYjC4+VuvXrkc89O9+gAooooAKKKKAK83X8f6Cql7/x5y/S rc3X8f6Cql7/
AMecv0pDLlyMhBxySOen3TUEqhLablOUPQj+gFWZ8EKpjWTc2MN06E1XcW8L os9vAgboRg/0
HrTJsT3NrFdKqzLuCkEA9OoPT8MfQn1qK7XfAYVSQhDGxIJyQG5wepIA+vSr TMFGWIAyBye5
6UtAymN3nJs8/wAj5d2c5zxjrzj198f7VO01PKs44yJAyAK4fPDADOM9vpxV qigAooooAKKK
KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigA
qGf/AA/rU1Qz/wCH9aAIahtelx/12/pU1Q2vS4/67f0pDJqKKKACiiigAooo oAKKKKACiiig
ArOl/wBa/wDvGtGs6X/Wv/vGgRo0ln/x+XP0T+tLSWf/AB+XP0T+tAFtvvJ9 f6GnU1vvJ9f6
GnUwCmx8RqOnAp1Rxqdi/MRwOMD29v8AOaAHF1Eixk/MwLAewxn+Yp1VZhIl zDIsTyhY3U7S
oOSV9SPQ1XktZmZxGmyYmQmfIG4ENtGRzxle38PsKANKojcRhZmbKrCfnJH+ yG/kapzW++FU
SyMcW4lo1SLdnAwecrjr79KIre4/s25jkUmaRMDLAkny1HX6g0AXnlRHVCTu YZAAJ4yB/UUr
OqMiscFztX3OCf5A1RnsmE8TQiRgMbi8hbHzoe59AfyqJLNtoL2oeNXDFXVP Mk+Vh8xBweWB
ycd/xANWisu4tJXWVUh/enzMy5H7xSG2rnOeMr14+X2FTT26iVIYvlEqFZB1 ygOSc/iR6/Pn
tQBeooooAKKKKACiiigAooooArzdfx/oKqXv/HnL9Ktzdfx/oKqXv/HnL9KQ y5dO0ao6oXIb
hR34NUBM4WYcyCYEsB/BxjP8uvpV68kWJEZi4O7gpjI4PrxjGaqRPbvI0W+a Jps53BRuPp7d
/wAc9wRTsIt3dot0E3MylSD8px3B6jnt/XsKHdIYTEsuxokXnbn2HAHOcYwP wxxVK91n7JdP
B5G/bjnfjORn0qD/AISH/p1/8if/AFqrlYroszXM4XeJSjpFJI8eBgMu3Cnj OOevfORxipYJ
H/tAxO2/yw4DFRuPEZ7D/aPT2qj/AMJD/wBOv/kT/wCtR/wkP/Tr/wCRP/rU ckgujcorD/4S
H/p1/wDIn/1qP+Eh/wCnX/yJ/wDWo5JBdG5RWH/wkP8A06/+RP8A61H/AAkP /Tr/AORP/rUc
kgujcorD/wCEh/6df/In/wBaj/hIf+nX/wAif/Wo5JBdG5RVTTrz7dA0vl7M NtxnPYf41bqW
rDCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKhn/wAP61NU
M/8Ah/WgCGobXpcf9dv6VNUNr0uP+u39KQyaiiigAooooAKKKKACiiigAooo oAKzpf8AWv8A
7xrRrOl/1r/7xoEaNJZ/8flz9E/rS0ln/wAflz9E/rQBbb7yfX+hp1Nb7yfX +hp1MApsfEaj
pwKdUcanYvzEcDjA9vb/ADmgBJriOFlV95ZgSAqMxwMZ6D3FSKwdQykMpGQQ eCKrTQSSXMLL
K6BY3Bdduckr6g+h/Kq/2FkvFKrJtUr5bArhFAAxkjd2PA4Ofc0AaVFZZsmW zto1h3yKnzK+
1k3YAy2TnjsR0HtxTUt3lWT7PF5UnmTZn4G7JcAZHPUjqO30oA1qYJUJYAkl GCtgE4Jx/iKz
o7NkXiCQxbwWhfyxu4YfdXC9Sp5Pb2GXm1IdylsFLvG4YbRtUFMr17bSeOKA NGis57KUwugJ
xGAkQGM7Mgkc8dAF5/u+5qM2biFVWF2+YlY5RGUXIA+ZRgDv93PUnvigDVoo ooAKKKKACiii
gAooooArzdfx/oKqXv8Ax5y/Src3X8f6Cql7/wAecv0pDJ9T/wBVH/10z+h/ z/UdRhLGimRQ
qnYpAYdR7EevfP16Y+Xd1FotsUcnm5Zsr5fXIH+ff05qvJZ2aHy5LtgTxtLL 6fTjoPyHoK0T
siWUb+dINVuS8YfcuBnt8mPr39f6Yzwokm3FH2OxA2gZz7cYPUccfhWvfaTP eXb3EUkWx8EZ
J9B7VCNEvQMCaIAZ4DN34ParTViWmVUtojM0RLNIMBVDBfMJ7gkEY6Yz16+1 KEjignQBjJ5K
MW3cclDjGPf1q2uj36oUW4QKRggO2CPTp7n86P7Hv/K8r7Qnl/3N7Y/LFF13 Cxj0Vq/2Bdf8
9IfzP+FH9gXX/PSH8z/hT5kKzMqitX+wLr/npD+Z/wAKP7Auv+ekP5n/AAo5 kFmZVFav9gXX
/PSH8z/hR/YF1/z0h/M/4UcyCzLvh7/jxf8A66n+QrVqlpVpJZWzRylSS5b5 T7D/AAq7WMty
1sFFFFIYUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUU AFQz/wCH9amq
Gf8Aw/rQBDUNr0uP+u39KmqG16XH/Xb+lIZNRRRQAUUUUAFFFFABRRRQAUUU UAFZ0v8ArX/3
jWjWdL/rX/3jQI0aSz/4/Ln6J/WlpLP/AI/Ln6J/WgC233k+v9DTqa33k+v9 DTqYBTY+I1HT
gU6o41OxfmI4HGB7e3+c0AEs6Q437iT0CqWP5CnqwZQwzgjPIwfyqvdICEzD NKRn5o3CEfjk
df6VVW0nN0kk295MofMUoFGAMjJG4ZIPA4Oe2TQBp0yaQQwySsCVRSxx1wBW X9jnaU5jdd5B
lKlFUnepyNvPQNgnn8amuLUkXKLbB2dCsLjbhBsxt5ORznpxz9aANGiq8EAg uJPLjWOEouAo
AG7LZ4+mKsUAFFFFABRRRQAUUUUAFFFFABRRRQBXm6/j/QVUvf8Ajzl+lW5u v4/0FVL3/jzl
+lIZYvFhmlhgldwznhVPXHPP/fP1/WqE0c09x5sKyujvkEFRj5e/p/8Aqq9d WttJPHLMUGDk
q+MPwR39M1LaQxwxDYwcnq/rV3tsCdiu0F2tnbxwyYZAofdj1X0x0Ge/TjnO RbzIkAO3fIAM
jd19ecD+n4VJUbwRuWLLneArc9QCSB+pqRFeS+KxpIsahJOVeRiq7eMEnBxn PAP8+KbJPNLN
D5YVIzK6BixJJCuOV9Mj17CrDWsT9Q2CSSochTnrkZwfp9fU017K3kYl1Y5z 8u9gvIIPGcdz
+dAEH2qSBNwLzo7BYmYcscEk/KPu4HHH6YNSxXUkzKqQ7SAGfzCVwCSOBjn7 p647fg/7JFtK
kyHJzkysSD7HOR17UotYgUKhlK91cjPOeeeec9c9T60AVzqDBEcwZEoDRhX5 ILKOcgYPzD1+
tO+2uLnyfIY4Kq5UMcEgHg7cYGR1I78esos4F6IeoIBYkLgggDngZA4HoKc1 vE0vmFTuyDjc
cEjoSOhPTn2HpQBLRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUU
UAFFFFABRRRQAVDP/h/Wpqhn/wAP60AQ1Da9Lj/rt/Spqhtelx/12/pSGTUU UUAFFFFABRRR
QAUUUUAFFFFABWdL/rX/AN41o1nS/wCtf/eNAjRpLP8A4/Ln6J/WlpLP/j8u fon9aALbfeT6
/wBDTqa33k+v9DTqYBTY+I1HTgU6mKm0ABjgdsD29v8AOaAElnSHG/cSegVS x/IUscqS7thP
ykAgggg4B7+xFQ3SAhMwzSkZ+aNwhH45HX+lV1tplWYvEkk8irulAXkbVDLz 34JGRjpmgDRp
sbrLGsiHKuAwPqDWdZ2brcKZI3ESFygcqMZ2Y4XjqGP69adbQParAVtjmNGj cJtBYnb83Ucf
L359qANGisezt2B2fZ8TRvEDN8vygImVznPTI445rYoAKKKKACiiigAooooA KKKKACiiigCv
N1/H+gqpe/8AHnL9Ktzdfx/oKqXv/HnL9KQy3c/fXHXacc47r7j+dUnu3t3n 2eXu+YlDkk/J
u3demeOPzrSeOOTHmIrY6bhmqssUwLALIY/NBCxvtOzYBgcjHzVcbdSSSeeS O6iRI3kVkclV
25yCuDyR6n86VbyJ4zIm4qHRM467tuD/AOPCmrbSPHAzzSRzJHtYrtOc4z1B 7ij7DGNojeRI
wVYoMEErjHUZ/hHftUjIra+aQN8rysxBVVAU7diEnk+rep61LFcldOgnkDSM 6JkLjJLYHsOp
pI7BIlHlSyIwGAwwTjaoxyMfwiiSyP2dYopXG0RqMnoFbORx1/wFADlvVaVY vKkEhJBXA+XG
OpBx0YH/AOvxTTfoEDeVJhwDH0/eAkDI54+8OuOtSRWqxy+bvd5MHLNj5s7f Qf7IqGSwzGqx
yvlCoTOP3ahlJA45+6Ouen1oAWXUoYgBIrK+SCjMoIwAepOOhHfv9aR9QDRs 1vG77WQZxgEM
V6ZI5w3+PbMn2MA71mkEuTmQbcnOO2Mfwr27fWnfZY9ki5f52DZJyQQAAef9 0HnNAEMmoxwl
hKCG3YCkqpHyqTyWwfvDv/LNSw3kc8uyEM4wCXGAFyMjIJz09v60n2MBzIs0 iyk8uNuTwoPb
HO0HpTvsq+ekrO7eWPkDYO3jHXGT+JoAnooooAKKKKACiiigAooooAKKKKAC iiigAooooAKK
KKACiiigAooooAKKKKACiiigAqGf/D+tTVDP/h/WgCGobXpcf9dv6VNUNr0u P+u39KQyaiii
gAooooAKKKKACiiigAooooAKzpf9a/8AvGtGs6X/AFr/AO8aBGjSWf8Ax+XP 0T+tLSWf/H5c
/RP60ATtKhYYDHaxzhCfUelSIwddy9PcYqjLE7yRESzR+XIzELHn+9yPlPPI 9sVbgB2Zywyz
HBGO5pgL58f2j7Pu/e7N+3HbOM053WNQznAJC/iTgfqao/Z7rzvO3R/8fG/y 9vOPuZzn+7z0
61ENPZbe3RYEGIl85Rj52DIcH1PDfn70AatFNjAEagJsAAwvHy+3FOoAKKKK ACiiigAooooA
KKKKACiiigAooooAKKKKAK83X8f6Cql7/wAecv0q3N1/H+gqpe/8ecv0pDLO oTGO3dFHzvG2
0npkdvr/AIGq1n/pEAjdFSfltyqMoA3AOMYP5dDUupRu6fukkd9hOAzBcDtj pk5/n6VX05JY
gu63mHBKDcVAAOOVzjPQ/n6UxFlbxkaFZctuV8lIyxJVgBwM+pqwLmEqWDgq GVcjkZOMf+hD
86gS3n/dyIyxOu8FXXdwzA9iPSkFgY1WOKUCIMjEMuWJXb3yP7o7etACw36u rM/qNojVmJBR
WzjGf4uuB2qWG4DWUVxLhdyKzEDgZH8qggsHtwpimXeo25ZMjG1QeMj+4D17 1NFbyRQLEs3C
xqgO3pjqfxH5Y70AK95AjbWc9SMhSQMYyc4xgZ5NIlyJLhET7pRi2VIYEFeM Hp97+VRvY7oz
GJMIIniQbfuhsY+uMf56mRLXbeNcb87s/Lj1CD/2T9aALFFFFABRRRQAUUUU AFFFFABRRRQA
UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAVDP/AIf1qaoZ /wDD+tAENQ2v
S4/67f0qaobXpcf9dv6Uhk1FFFABRRRQAUUUUAFFFFABRRRQAVnS/wCtf/eN aNZ0v+tf/eNA
jRpLP/j8ufon9aWks/8Aj8ufon9aALbfeT6/0NOpjjJXtz1A6cH2pdpzncfp x/n/APVTAjS6
ikkKKWzkrkoQCR1AJGD0PT0p08ywRNI4YhQSdoz0BP8ASs5rOaRZYxG6MzSn e75Qht2MDJwe
R2Hf8S8guLp5HW3dMptAZlyTskHYnuwoA0nkCPGpBzI20Y9cE/0pstxFC212 IOMnCkhR6kjo
Pc+hqotuwvI3Nvl1ldmn+XlSGwM5zxkDp2qfEsE0pSIyiVgwIYAKcAc57cdR nvx6gFmmJIHe
RQDmNtpz64B/rVCOwaKCVdu9gUAOfvooTcMds7SPfjPFRNZOxYi2eOEuSIVE ZP3UAODleze/
PuaANeiqllbGF5XkBLkqAxbcSNig8/Uegzge1W6ACiiigAooooAKKKKACiii gAooooArzdfx
/oKqXv8Ax5y/Src3X8f6Cql7/wAecv0pDLdxsEitIu4BW4xnnIquXMUokRRG OAyqpKkZ5OeO
n0/rVi6ilkKeUUGOu76g/wBKoR2tw7SpgrnhmJ4bk+3Pbt27U7aXEaE9yIZo YvkDSk43ttGA
R09TyOKeJ4W8zEsZ8v7+GHy/X06U0xMbmKUkELGyntkkr/gaqQ2EsUe1SAyJ sVvNclhkZ6/c
zjtnGeOnIBa+2Qb4lEqESg7GDDBIIGAfXmpPOjwp8xMOMr8w5HHT8x+YqnbW k0M/nEJksQVM
rNhSE53EZJ+Xp79aYbGZ1hicRGOFAmdxO8BkPIxxwp4560AXhPCXRBLGWcbl XcMsPUetP3AM
FyNxGQM8kf5Iqm9mzXbScFHdXJMjDBAHG0cH7vU+vtUk8ElxGEfyxhic4J4z wMe46/iO+QAP
N3bDObiLgBj844Bxg/qPzp0UvmPMuMeW+3Oevyg/1qBbaQziVtg/feYQCTge Xtx09aXT7Z7W
Eo5Uk7fu+yKv8waALVFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABR
RRQAUUUUAFFFFABUM/8Ah/Wpqhn/AMP60AQ1Da9Lj/rt/Spqhtelx/12/pSG TUUUUAFFFFAB
RRRQAUUUUAFFFFABWdL/AK1/941o1nS/61/940CNGks/+Py5+if1paSz/wCP y5+if1oAnaVC
wwGO1jnCE+o9KkRg67l6e4xVGWJ3kiIlmj8uRmIWPP8Ae5Hynnke2KtwA7M5 YZZjgjHc0wES
6ikkKKWzkrkoQCR1AJGD0PT0p8sgiQMwJBZV49SQB/OqiRSshgaJkAnMnmEj BHmbhjBzzx1x
/jVWwlWIhopJG+TzASmJSGUk8deh5Y559zQBsUVnxQywzCZLdhH8wWFSoKA7 PfHVSeD3+tVR
EIvs8M0StcZhKHKlkUbQR1z1DHgY5+tAG1RRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQBX
m6/j/QVUvf8Ajzl+lW5uv4/0FVL3/jzl+lIZflLZjVWK7mwSMehP9KilaWAh wWlQAlwccD9P
eor1JI385ZT14XJ64+v9Kq+ZuWQ+ZwSTlnGDgDoO5z/nim9rhY1JJQkiRhWZ n5wMcAYyefqP
epKqfZi1zbtKqyiNH+ZhnDZXB578Gq/2NlsLeEwlgFBkChGbfgD+PjHUflji gRp0VjFCjQx3
EYkumaFlYsrMoG3d3z1DHjjn61LBYvEkW2FVZEh5GBht37z8xjPrQBqU0uok WMn5mBYD2GM/
zFZUenyBNro7ElBJuKbZMOpJ4GW4B5bnn3NTrabLwP8AZ1aFHIjUAfJkJ8wH bkN055oA0KKq
zpLMq7Y9kgLfNvxhc9Mjn5hj6deoFQCyDT72tkCNKMqQv3PLAwfYMBx7ZoAv JIHeRQDmNtpz
64B/rT6qadFNFE3ng72KkknJJ2KD+oNW6ACiiigAooooAKKKKACiiigAoooo AKKKKACiiigA
ooooAKKKKACiiigAooooAKKKKACql3cRRMFkkCkgEA/jVuo5Pvf5/wA/5/MA ofbLf/nqtFmw
dJ2U5Bl4P4Vd/wA/5/z/APXa/wB0/h/WkBHRRRQMKKKKACiiigAooooAKKKK ACs6X/Wv/vGt
Gs6X/Wv/ALxoEaNJZ/8AH5c/RP60tJZ/8flz9E/rQBO0qFhgMdrHOEJ9R6VI jB13L09xiqMs
TvJERLNH5cjMQsef73I+U88j2xVuAHZnLDLMcEY7mmAvnx7N+75d+zOO+7bj 86WWQRIGYEgs
q8epIA/nVL7E3l7sSeZ9o348w7ceZnOM46c//XqGGxmQDKybwU3sSgDkOpJ4 GT0PLc8+5oA1
qKzdKixHbyJB5K+QA54HmE7cHg89D19frWlQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUU
UAV5uv4/0FVL3/jzl+lW5uv4/wBBVS9/485fpSGXp2KhPn2Ank8dME/0qFpn UebGzyxrneCA
CP5VFqAmG5mYeR/dDYPT6f1quJAfMwuWyeenG0d/6VTWlyb62Nimq6uzqpyU O1vY4B/kRVG4
JE9ulw0xBjckQl+Tlcfd+pplsZ4ZjJcrJgjD7VLZbZHzgfRuelIZp0isHUMp DKRkEHgislWl
WKEzm4E26ELy+MHbndjjOd3Xn9KfbJcCASuZ/NDxDDM3QhN3HTu3P1oA1KKq zvI6qYVlWTLD
GMcA4J54+n4ds1AInefg3HltKF5dx8nlg+vHzDr17UAX1dXZ1U5KHa3scA/y Ip1U9N80xyPO
rB3Ksdwxk+Wmf1zVygAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooA
KKKKACiiigAooooAKilODyf0+tS1BcAMpBzggDg49aAE3j1P5f8A16ijlMol yAAkm0fl/wDX
qpaWckE7vJcyyrn5FZjwPf1P+fpNa9Lj/rt/SkBNRRRQMKKKKACiiigAoooo AKKKKACs6X/W
v/vGtGs6X/Wv/vGgRo0ln/x+XP0T+tLSWf8Ax+XP0T+tAE7SoWGAx2sc4Qn1 HpUiMHXcvT3G
KoyxO8kREs0flyMxCx5/vcj5TzyPbFW4AdmcsMsxwRjuaYCxzpK8iJuzGdrZ UjB/HrUlZ7W7
TXLebb5i+0b/AJ9pBHl7c4z6gfmKatrKJoj5W7Y5xvCsiLvJGOcg4xjHHQdu ADQjdZY1kQ5V
wGB9QajW5RrloAG3LnJ7cBT/AOzD9ao/Y2Wzhg+zfKn3wixkswAG4buMHnrz 0qI29wkLmZTu
ki8rcWB+ZliUZ/EH8qANKO7hktmnBIRVDNkcqNob+RFT1RnilK3cSxM32jO1 wRhcoF5yc9uw
NV0t3lWT7PF5UnmTZn4G7JcAZHPUjqO30oA0xIDM0WDuVQx9MEn/AANKHUyN GD8ygMR7HOP5
Gs02zEzeXZ+VE4QMgWPLYLHIGSvUr17ZpIrOYIxMZErRMkUjFcxcvjp04Yfd 9KANWiqen25g
8z5JEVsYV9g555wgx6c9eParlABRRRQAUUUUAFFFFABRRRQBXm6/j/QVBLGJ YzGxIDdSKnm6
/j/QVHSGTGXIwf8A0H/69NR0jXaiqq+gXH9ajooES+YCwbA3AYB28gfn7Cl8 73/T/wCvUNFA
x58syiUxoZFGA5QZA+tP873/AE/+vUNFAE3ne/6f/Xo873/T/wCvUNFAE3ne /wCn/wBejzvf
9P8A69Q0UATed7/p/wDXo873/T/69Q0UATed7/p/9ejzvf8AT/69Q0UATed7 /p/9ejzvf9P/
AK9Q0UATed7/AKf/AF6PO9/0/wDr1DRQBN53v+n/ANejzvf9P/r1DRQBN53v +n/16PO9/wBP
/r1DRQBN53v+n/16PO9/0/8Ar1DRQBN53v8Ap/8AXo873/T/AOvUNFAE3ne/ 6f8A16PO9/0/
+vUNFAE3ne/6f/Xo873/AE/+vUNFAE3ne/6f/Xo873/T/wCvUNFAE3ne/wCn /wBejzvf9P8A
69Q0UATed7/p/wDXo873/T/69Q0UATed7/p/9eoJ085gfOlTA6IABS0UAQ/Z h/z83H6VJFEs
KMqs7Fm3Etj0p1FABRRRQAUUUUAFFFFABRRRQAUUUUAFZ0v+tf8A3jWjWdL/ AK1/940CNGks
/wDj8ufon9aWks/+Py5+if1oAnaVCwwGO1jnCE+o9KkRg67l6e4xVGWJ3kiI lmj8uRmIWPP9
7kfKeeR7Yq3ADszlhlmOCMdzTAUToZzD8wfG7lSARx0PQ9RUlUrhJppSywlQ qMnz7TvBK5wM
kdAeuOo96hhtZ44mMQeNw5VNwTIRgoPA+UYI3e+PegDTorNmtZBcReVEwEZR UZNmAgIyCT83
97pxjHvWlQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAV5uv4/0FR1JN 1/H+gqOkMKKa
jrIoZGDKehU5FOoAKKKQMCSAQSDg+1AC0UgYEkAgkHB9qWgAopqOsiK6HKsA Qfah3WNGdzhV
BJPtQA6imq6sSFYEjqAenb+h/KnUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUU AFFFFABRRRQA
UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAVnS/61/9
41o1nS/61/8AeNAjRpLP/j8ufon9aWks/wDj8ufon9aAJ2lQsMBjtY5whPqP SpEYOu5enuMV
Rlid5IiJZo/LkZiFjz/e5Hynnke2KtwA7M5YZZjgjHc0wI3voFWQ5c+WGz8h AJXOQCeCeD+V
WaznspHtJwzOzkymOMlcAsWwfyPc96SWC4ZRDGjKRJK4l3AKNwfHfPVh2oA0 qjjnSV5ETdmM
7WypGD+PWqFksc00zWoNtHtQZiCEEgtnpkdx79Ke1u01y3m2+YvtG/59pBHl 7c4z6gfmKALs
sqQxl5CQoIHAJOScDgURSpKu5CeDggggg+4PIqq0Mq2OwRlmWYMqAj7okyAO 33ajubaW4JlK
OqkqGiG0sVG71yvVhx7Z68UAaNMmkEMMkrAlUUscdcAVSFm/lRoNwWQeXKGI J2ZJA4wBxlcD
pu9hUMtjMzXBCyGRxJhsoFYEHaM43HqODxx7CgDWorJvLd1guGMWGAlZ5uPn UhsL68ZXg8fL
9KkFmJJkP2RY7feCYmC4yFfLYBI7qPXj2oA0qKyTZTmJFKNt2RmVV2ku+G3c HgnJUkn09RTv
sDeVKfKzIIAISxUsrZcjBHTGV6cDt0oA0kdZFLIcgEr+IOD+op1VrOHyWmBi CszsxkGPnBYk
e/AOOas0AFFFFABRRRQBXm6/j/QVVu/M+zOIgd7DaCDjGeM/hnP4Vam6/j/Q VE7qilmOAOpp
DKBWWNZEKeWm4MqxbiCMH5cqARyM5Hr+at5+87FkMnl/KCzYjO31Pyvz+P8A Sx9st/8AnqtH
2y3/AOeq0AVzuz8nn/Z8jdnfu6NnGfm67en+NEnmEMo81Y94KsQ5IG1cDAIP r+I9asfbLf8A
56rR9st/+eq0AVEWbypGPmLPIEYnDYxhQ3A4zweOvpT0DhV81p2hy3Kq4OeM dy2Pvdf8Ksfb
Lf8A56rR9st/+eq0CICso0+2VdyYVRJhSSBt9Bg9cdKimWQ2zrL575iIj2qw yeeoGe2373+N
XPtlv/z1Wj7Zb/8APVaBlYJMJJXxJ5pVhEecZDPjPboRjP4UoV3lRYmnWAsM liwP3Wz15x93
+nNWPtlv/wA9Vo+2W/8Az1WgCH599xnzmG1vmXcpHoADwT6Ef/ru1B9st/8A nqtH2y3/AOeq
0AT0VB9st/8AnqtH2y3/AOeq0AT0VB9st/8AnqtH2y3/AOeq0AT0VB9st/8A nqtH2y3/AOeq
0AT0VB9st/8AnqtH2y3/AOeq0AT0VB9st/8AnqtSRSJKpaNtwBwSKAH0Uu04 zx+dG0+35igB
KKXafb8xRtPt+YoASil2n2/MUbT7fmKAEopdp9vzFG0+35igBKKXafb8xTWI QqGIyxwBnrQA
tZ0v+tf/AHjWjWdL/rX/AN40CNGks/8Aj8ufon9aWks/+Py5+if1oAnaVCww GO1jnCE+o9Kk
Rg67l6e4xVGWJ3kiIlmj8uRmIWPP97kfKeeR7Yq3ADszlhlmOCMdzTARbqJp zCPM3jrmNgO/
fGOxqaqs0MryXJjO0yQKiNnGG+b/ABFVVtHWCRVhkEbld0bCLJxnkKBt645P YewoA1KKyYrG
UrmSHJGxV37chfMYkccD5COBxjitC0Ro4djDGHbaPRdx2/pigCaiiigAoooo AKKKKACiiigA
ooooAKKKKACiiigCvN1/H+gqpe/8ecv0q3N1/H+gqpe/8ecv0pDL8rMCgQgF mxkjPYn+lVRf
rvHziRMZJVGGB6j1HuP8KsykB4iTgb//AGU1nhXjinUKY4fLPyGQMN3+z7Y+ naq6CNKWaOFd
0siRqTjLMAM05WDqGUhlIyCDwRVe72BkctMjgEBooy5xxkHgjsPyqrI90ZoW ZXjkBjDKquyk
Ejccg7R1I5BPGc9KQGnTXdY1DOcAkL+JOB+prNgS4RIjmfcEhJ3Mx5ZsPnPt 27deKjg3y29u
Y/PcERtKX3HLb0ORu9t3Tj9KANimGaNV3NIgXJGSwxkZz+WD+VUtOFwJMzSS E7P3gKMAG47k
49fujH6Uy6jZorgrC5V1kVFAJKtg5bH+1/n7xoAvtPCoUtLGA4LKSw5AGSR+ FSVk31k6xkor
PjesagZ2qY349uTj6Ba0C8VxbyblkMZBVgUZSRjnjGfyoAdFPDPnyZY5Mddj A4pyurs6qclD
tb2OAf5EVQLytwWuHtww3MUKP0bIAABxnZ0Hc9s0LEyvLNEJgTNGFyW5XCAk g9eM8nn8qANG
isiNLoph5JizFBKArrg71zgk+m77uB+lSgXEYOBKwYSK2SxwA4Cn1+7k8cnH rzQBoswRSzEK
oGSSeAKZFPDPnyZY5MddjA4qigmfTLxG8x+GWPKMCRsHZsnqTT2ctEo33ToH /eExsjbcHGMA
Hrjp/KgC2k8TnCyLnJXGcHIJHT/gJ/I1JWNHE5ZS63AgRy38YYAtLz/ezyue /PNS3H2jbL5f
n+f+83Y3bduG247Z+505/WgDTZgilmIVQMkk8AU0yosauxIViAMgg5JwOPxq C7Ty7EgszKpV
pCxzldwLZ/DPH4YqC6VmnIcTFvOjMe0Nt2grnOOOu7rz+lAF+R1jQu5wBSqw ZQwzgjPIwfyr
ISK5kj2yvKxJTzF2OuG3rnBJ/wB77uB+lT3HnJdRiPzFCsigYdwy5GSTnaOp 6jPGfSgC+7rG
oZzgEhfxJwP1NJ5sZKAMD5gyhHRu/BrNJmdbWMrMWjVBLlWxuDx856Ho3P1p 8KeXY20QEgmE
iLh88MMbsE9tobpx1x1oA0qKKKACiiigAooooAKKKKACiiigAooooAKKKKAC oZ/8P61NUM/+
H9aAIm6L9P60lK3Rfp/WkpDCoo51kmeMAgr3PRvXHrjoalqh9gkMagzksyur 5Ax8w5xwP4sG
gCwt3CzyYkj2IqkvvGOSeP0/WnwSieLzFxjcwBBznBIz+lQGGdp/PKxhl27V Dkg4DDk44+96
dqlt0ljUB9mCXZsEnktkY/M0ATUUxPN+Tfs+78+M/e46e3X9KfQAVBN/x82/ 1b+VT1BN/wAf
Nv8AVv5UAT1nS/61/wDeNaNZ0v8ArX/3jQI0aSz/AOPy5+if1paSz/4/Ln6J /WgC7RRRTAKK
KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooArzdfx/oKqXv/Hn L9Ktzdfx/oKq
Xv8Ax5y/SkMu3A3BE2o25sfOuR0Jqs3kxkExQSRjO4xx/d+vWlu3uVmUIn7s NwwGT057/XtU
NuQba5wcgQAfo1VbS5N9bGpRWdqQjN1b+a9uq7H5nUMucr7jmpRKBMiRSqID t5VRhemFB6c/
5+8uEMuUiqEUKoCqBgADgCsiOaWGzto0uVUBMOzuq7GAX5M7T6ngjPHWp0mu PmleU5WWNDGF
AX5gmeo3fxHvQBo0Vkfa5ioZWE8qsSNu14yfLc4UgZ7Dg8/nzKJpHmSKG7aS NnA85dhOdrkr
nGP4V7Z5oA0qKz52abTsOFkPnhMNwGxKBz9cc8UmGtSqSSpaROWb5CNqEbQF BYY5+Y9P65AN
Gisu2kuJ7jY0jQFgXcIig52R8HIP941JpshlkkkeTa8oWTyuMEFE+Yd+uR1x QBoUm4BguRuI
yBnkj/JFZkjJDcSPb+Rcz/OQAu6RDgnkg5xn5cYHUD6vUCa6h8q9eTCSfvF2 E9U46YoA0aKy
oby5lmiJeNNwQiPPLAgEkLgk9TzkDjnoaWC4uNkTtMz5SFyCq872wRwO2OP1 zQBqUVn2d28t
4UMisrIz7CwLR4I4IAGOvQ56fnBA0cbXEiG1e5VpiiBB5u7c3fOTx7dKANbc CxXI3AZIzyB/
kGhVCKFUBVAwABwBWJcsJJJlhn+1bowuflY52S8DA/8Ar81aluWRT5d3v2x7 oj8p89sn5enP
QDC4PNAGlRVezaR1keSTd+8dVGMYAYj8f/1fjYoAKTaCwbA3AYBxyB/kCloo AKKKKACiiigA
ooooAKKKKACiiigAooooAKKKKACoZ/8AD+tTVDP/AIf1oAqyNOWAjWPaB/Ex z/KmZuv7sP8A
30f8Ks8AD5Qcik3D+6P1pDK+br+7D/30f8KM3X92H/vo/wCFWNw/uj9aNw/u j9aAK+br+7D/
AN9H/CjN1/dh/wC+j/hVjcP7o/WjcP7o/WgCvm6/uw/99H/CjN1/dh/76P8A hVjcP7o/WjcP
7o/WgCvm6/uw/wDfR/wpAk7zRvIIwEJPyk+mPSrO4f3R+tRSyETQooADE5/I 0ASVnS/61/8A
eNaNZ0v+tf8A3jQI0aSz/wCPy5+if1paSz/4/Ln6J/WgC7RRRTAKKKKACiii gAooooAKKKKA
CiiigAooooAKKKKACiiigAooooArzdfx/oKqXv8Ax5y/Src3X8f6Cql7/wAe cv0pDNFkVxh1
DDryM1EtpboCBEpB9ef51PRTEFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUU
AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFQz/wCH9amq Gf8Aw/rQBE3R
fp/Wkod1UKGYA47n3NN82P8Avr+dIYj/AH+VZgFJwpx6e9BLdFw21QScjBP5 j0pfNj/vp6dR
Sb4sg5j46ZxQAFmAJypwGPTsDilO/PBXJLADHpnv+FIZIyOXTpjqPrS+bHuL bk3HqeM0CE3M
cFR1OBnr0ye9OGdozjPsaaZIiMFkI9CRS+bH/fTjsCKBjqgm/wCPm3+rfyqX zY/76/nUMrK1
zb7WB5bofY0AWKzpf9a/+8a0azpf9a/+8aBGjSWf/H5c/RP60tJZ/wDH5c/R P60AXaKKKYBR
RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAFebr+P9BVS9/48 5fpVubr+P9BV
S9/485fpSGadFFFMQUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFF
FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAVDP/h/Wpqhn/wAP60AV 2t43O5o4yT3I
GaT7JD/zxi/IVI3Rfp/WkpDGfZIf+eMX5Cj7JD/zxi/IU4nA6E8gYFJuAzu+ XHXJoAT7JD/z
xi/IUfZIf+eMX5ClDguFBXpnk9fpShlPRge3BoAb9kh/54xfkKPskP8Azxi/ IUpkAJyQBxzn
6/4U6gBn2SH/AJ4xfkKTyoYnXCRqxOFwBnpUlQTf8fNv9W/lQBPWdL/rX/3j WjWdL/rX/wB4
0CNGks/+Py5+if1paSz/AOPy5+if1oAu0UUUwCiiigAooooAKKKKACiiigAo oooAKKKKACii
igAooooAKKKKAK83X8f6Cql7/wAecv0q3N1/H+gqpe/8ecv0pDNOiiimIKKK KACiiigAoooo
AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACi
iigAooooAKhn/wAP61NUM/8Ah/WgCJui/T+tJUcjTlgI1j2gfxMc/wAqZm6/ uw/99H/CkMmI
JxjGQQefY0hQ9SQWyDgEgcZ79e9RZuv7sP8A30f8KM3X92H/AL6P+FAEwBUN tIBYAcZPr69e
tIFIO7jPAALE9iOpHvUWbr+7D/30f8KM3X92H/vo/wCFAiVVK4IKlh7n/a9v 9qnHr1zUGbr+
7D/30f8ACjN1/dh/76P+FAyeoJv+Pm3+rfyozdf3Yf8Avo/4UgSd5o3kEYCE n5SfTHpQBYrO
l/1r/wC8a0azpf8AWv8A7xoEaNJZ/wDH5c/RP60tJZ/8flz9E/rQBdooopgF FFFABRRRQAUU
UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAV5uv4/wBBVS9/485fpVubr+P9 BVS9/wCPOX6U
hmnRRRTEFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUA
FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFQz/AOH9amqGf/D+tAENFFFIYUUU UAFFFFABRRRQ
AUUUUAFZ0v8ArX/3jWjWdL/rX/3jQI0aSz/4/Ln6J/WlpLP/AI/Ln6J/WgC7 RRRTAKKKKACi
iigAooooAKKKKACiiigAooooAKKKKACiiigAooooArzdfx/oKqXv/HnL9Ktz dfx/oKqXv/Hn
L9KQzTooopiCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKK
KKACiiigAooooAKKKKACiiigAooooAKKKKACoZ/8P61NUM/+H9aAIaKKKQwo oooAKKKKACii
igAooooAKzpf9a/+8a0azpf9a/8AvGgRo0se2N2dQdz4yc+lJSYPZwPbbn+t AyXzj7/mP8KP
OPv+Y/wqLDf89B/3x/8AXow3/PQf98f/AF6BEvnH3/Mf4Uecff8AMf4VFhv+ eg/74/8Ar0Yb
/noP++P/AK9AEvnH3/Mf4Uecff8AMf4VFhv+eg/74/8Ar0Yb/noP++P/AK9A EvnH3/Mf4Uec
ff8AMf4VFhv+eg/74/8Ar0Yb/noP++P/AK9AEvnH3/Mf4Uecff8AMf4VFhv+ eg/74/8Ar0Yb
ff8AMf4VFhv+eg/74/8Ar0Yb/noP++P/AK9AD3bdUbosiFHBKnqAcUuG/wCe g/74/wDr0Yb/
AJ6D/vj/AOvQMl84+/5j/Cjzj7/mP8Kiw3/PQf8AfH/16MN/z0H/AHx/9egR L5x9/wAx/hR5
x9/zH+FRYb/noP8Avj/69GG/56D/AL4/+vQBL5x9/wAx/hR5x9/zH+FRYb/n oP8Avj/69GG/
56D/AL4/+vQBL5x9/wAx/hR5x9/zH+FRYb/noP8Avj/69GG/56D/AL4/+vQB L5x9/wAx/hR5
56D/AL4/+vQBL5x9/wAx/hR5x9/zH+FRYb/noP8Avj/69GG/56D/AL4/+vQB L5x9/wAx/hSM
+4d6jw3/AD0H/fH/ANejDf8APQf98f8A16Bi0UmG/wCeg/74/wDr0Yb/AJ6D /vj/AOvQAtFJ
hv8AnoP++P8A69GG/wCeg/74/wDr0ALRSYb/AJ6D/vj/AOvRhv8AnoP++P8A 69AC0UmG/wCe
g/74/wDr0Yb/AJ6D/vj/AOvQAtFJhv8AnoP++P8A69GD3cH224/rQAtZ0v8A rX/3jWjWdL/r
X/3jQI0aKKKBhRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAF
FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRR
QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BWdL/rX/AN41
o1nS/wCtf/eNAjRp3ygDIJz702lbov0/rQMMr6H86Mr6H86SqksskVxJhi4C x7UOAMsxHXGe
1AFzK+h/OjK+h/OqZvGA/wBUNxO1Rv4yGCnPHHJ//VThcyM/lLEvmgnIL/Lw AeuP9odvWgC1
lfQ/nRlfQ/nVE3jyxF4Y8ANGAWPXdtOO/Zv89ri52jcADjkA5oAdlfQ/nRlf Q/nSUUAMlkCy
xIq/fJySfQVKANuSCefWq03/AB82/wBW/lVg/cH1P9KADK+h/OjK+h/OkqpK 0rXhjRpQgRT8
mzjJPJ3fTtQBcyvofzoyvofzqtLctGJf3eTGpc/NxjnH54/Q+2UNzIr+U0S+ aSMAP8vIJ64/
2T29KALWV9D+dGV9D+dUZLxzFNsj2tHGzFs8AjcPx5WraFio3gK3cKcj88Cg B+V9D+dGV9D+
dJRQAyeQRqu1eWcLyfU0+oLv7sX/AF1X+dT0AFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFF
FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAEEZnlUuJY1 G5gB5RPAYjru
HpTtlx/z3j/78n/4qi2/1H/A5P8A0NqloAi2XH/PeP8A78n/AOKo2XH/AD3j /wC/J/8Aiqlo
oAi2XH/PeP8A78n/AOKo2XH/AD3j/wC/J/8AiqhWWTyY7kuSJCv7vAwAxA4P XIz/AD6dlsZn
uIEldv4QCuOScDJP9PY578AEuy4/57x/9+T/APFUbLj/AJ7x/wDfk/8AxVS0 UARbLj/nvH/3
5P8A8VUUc0v2427sjAR7shCvOR7n1q1VJf8AkMt/1xP8xQBf+UAZBOfekyvo fzobov0/rSUA
LlfQ/nRlfQ/nSVXhZnjS5eYqrLvKcbQMeuM/rQBZyvofzoyvofzqkt67MIxC BIWAwxZRggnu
uf4T2qSO4aV9qRjK/fy2Mckccc/dPp2oAs5X0P50ZX0P51n/AGxpkUrG6KzI VbBHBZeDkDse
2e9X6AFyvofzqOWQLLEir98nJJ9BT6gm/wCPm3+rfyoAnrOl/wBa/wDvGtGs 6X/Wv/vGgRo0
rdF+n9aSopLeORtzhif94/40DJaia3jaQyEEscZ+Y44ORx06037HB/db/vs/ 40fY4P7rf99n
/GgAltI5EAGVIbOQT3YMfzIpfs0W0DDAg53ByG/POew/IelJ9jg/ut/32f8A Gj7HB/db/vs/
40AP8iIIyBAFYgkDjoABj06Dp6UGCMqwIJDIEbJPI5/xNM+xwf3W/wC+z/jR 9jg/ut/32f8A
GgCUIocuB8xABPsM/wCJp1QfY4P7rf8AfZ/xo+xwf3W/77P+NABN/wAfNv8A Vv5VYP3B9T/S
oUtokcOqnI6ZYmlkhSUguGOOmGIoAkqKS3jkfed4bGMq7Lx+B9zTfscH91v+ +z/jR9jg/ut/
32f8aAFltkkjdR8rOGG7vyMfj249h6Cj7NFtIwxJOdxclvzznufzPrSfY4P7 rf8AfZ/xo+xw
f3W/77P+NAD1giUMAgwy7TnnI56/mfzpViRCpGSVBALMScHr1+gqP7HB/db/ AL7P+NH2OD+6
3/fZ/wAaAJEhRNm1cbF2Lz0HH+Ap9QfY4P7rf99n/Gj7HB/db/vs/wCNABd/ di/66r/Op6hF
pCGBCnIOR8x/xqagAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKK
KKACiiigAooooAKKKKACiiigAooooAgt3VYcMwB3ydT/ALbVL5sf99fzqu2n WruzNGcsST87
Dk/jSf2Zaf8APNv+/jf40AWfNj/vr+dHmx/31/Oq39mWn/PNv+/jf40f2Zaf 882/7+N/jQBI
Ft1k3hlznON/APqB0B/xNKggj27GUbVCD5uw6VF/Zlp/zzb/AL+N/jR/Zlp/ zzb/AL+N/jQB
Z82P++v50ebH/fX86rf2Zaf882/7+N/jR/Zlp/zzb/v43+NAFnzY/wC+v51T Qg6wxBBHknp9
RT/7MtP+ebf9/G/xqSCzgt33xIQ2MZLE8fiaALDdF+n9aSopLeORtzhif94/ 4037HB/db/vs
/wCNAE9RfZ49xbB5zldx2nPX5elN+xwf3W/77P8AjR9jg/ut/wB9n/GgBUto kcOAxYHOWct2
I7n3P50v2eMMGAKkEnhiM8559eSevrTfscH91v8Avs/40fY4P7rf99n/ABoA UWsI/hPUYBYn
GDnj0GQOB6VNUH2OD+63/fZ/xo+xwf3W/wC+z/jQBPUE3/Hzb/Vv5UfY4P7r f99n/GnJbRI4
dVOR0yxNAEtZ0v8ArX/3jWjWdL/rX/3jQIv+bH/fX86PNj/vr+dFFAB5sf8A fX86PNj/AL6/
nRRQAebH/fX86PNj/vr+dFFAB5sf99fzo82P++v50UUAHmx/31/OjzY/76/n RRQAebH/AH1/
OjzY/wC+v50UUAHmx/31/OjzY/76/nRRQAebH/fX86PNj/vr+dFFAB5sf99f zo82P++v50UU
AHmx/wB9fzo82P8Avr+dFFAB5sf99fzo82P++v50UUAHmx/31/OjzY/76/nR RQAebH/fX86P
Nj/vr+dFFAB5sf8AfX86PNj/AL6/nRRQAebH/fX86PNj/vr+dFFAB5sf99fz o82P++v50UUA
Hmx/31/OjzY/76/nRRQAebH/AH1/OjzY/wC+v50UUAHmx/31/OjzY/76/nRR QAebH/fX86PN
j/vr+dFFAB5sf99fzo82P++v50UUAHmx/wB9fzo82P8Avr+dFFAB5sf99fzo 82P++v50UUAH
mx/31/OjzY/76/nRRQAebH/fX86PNj/vr+dFFAB5sf8AfX86PNj/AL6/nRRQ AebH/fX86PNj
/vr+dFFAB5sf99fzo82P++v50UUAHmx/31/OjzY/76/nRRQAebH/AH1/OjzY /wC+v50UUAHm
x/31/OjzY/76/nRRQAebH/fX86PNj/vr+dFFAB5sf99fzo82P++v50UUAHmx /wB9fzo82P8A
vr+dFFAB5sf99fzo82P++v50UUAHmx/31/OjzY/76/nRRQAebH/fX86PNj/v r+dFFAB5sf8A
fX86z5DmVyOmTRRTA//Z
--------------5D0CFAA17FCA9953D5F1A91E--
--------------BD058AB2A93D8D30B2E3A6DD--
Re: xsd errors [message #578480 is a reply to message #30206] |
Hi Dominic,
Dave
FUDForum. Page generated in 0.03684 seconds
