Home » Eclipse Projects » Mylyn » Default Eclipse 3.3/Europa redistribution and org.eclipse.mylyn.team.ui
Default Eclipse 3.3/Europa redistribution and org.eclipse.mylyn.team.ui [message #23036] Mon, 20 August 2007 07:53 Go to next message
Hello there,
I've noticed that Mylyn redistribution in eclipse-java-europa-win32.zip
lacks some features that are required for Subclipse Mylyn integration.
Namely org.eclipse.mylyn.team.ui plugin. Is it bug or there are some
reasons not to include this plugin in redistribution?
Ref.: http://svn.haxx.se/subusers/archive-2007-08/0057.shtml
"Re: [Subclipse-users] Problem installing 1.2.3 Mylyn integration on Europa"
--t.
Re: Default Eclipse 3.3/Europa redistribution and org.eclipse.mylyn.team.ui [message #23905 is a reply to message #23036] Mon, 27 August 2007 02:13 Go to previous messageGo to next message
Originally posted by: beatmik.acm.org
The problem is that the current Team plug-in needs to be coupled to the
Team/CVS, which is not distributed with eclipse-java-europa. We hope to
resolve this early on in the Mylyn 3.0 cycle:
191793: [api] remove coupling from to ..mylyn.team.ui to
org.eclipse.team.cvs
https://bugs.eclipse.org/bugs/show_bug.cgi?id=191793
I added a FAQ entry describing what's redistributed and how to get the
missing pieces:
http://wiki.eclipse.org/Mylyn_FAQ#What_version_of_Mylyn_is_d istributed_with_the_Eclipse_downloads.3F
Mik
techtonik wrote:
> Hello there,
> Europa"
> --t.
Re: Default Eclipse 3.3/Europa redistribution and org.eclipse.mylyn.team.ui [message #24121 is a reply to message #23905] Mon, 27 August 2007 09:32 Go to previous messageGo to next message
Originally posted by: markphip.GoogleMail.com
In article <fatq2s$dam$1@build.eclipse.org> Mik
> the Team/CVS, which is not distributed with eclipse-java-europa. We
> hope to resolve this early on in the Mylyn 3.0 cycle:
> the missing pieces:
Mik,
Correct me if I am wrong, but when I look at your feature:
< http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.mylyn/o rg.eclipse
mylyn.pde-feature/feature.xml?revision=1.23&root=Tools_P roject&view=ma
rkup&pathrev=R_2_0_0>
I think this is the one that includes the Team stuff. There is no
<requires>for CVS, but there is for PDE. This is what seems to be the
problem
as a lot of people do not have PDE installed but most probably do have
CVS.
Mark
I'm trying a new usenet client for Mac, Nemo OS X.
You can download it at http://www.malcom-mac.com/nemo
Re: Default Eclipse 3.3/Europa redistribution and org.eclipse.mylyn.team.ui [message #26066 is a reply to message #24121] Thu, 06 September 2007 18:06 Go to previous message
That's correct, the ..mylyn.pde-feature is the bridge to the Eclipse
SDK, even though it is not properly named (we got the repackaging
request from EPP too late in the 2.0 process to rename this feature).
What we need is a separate feature for just the Mylyn team stuff. The
challenge that we are always faced with is that we don't want to force
users to select from a dozen different features because that adds a lot
of complexity to the install. So we break up features as lazily as
possible, and have already had confusion from breaking up IDE and SDK.
However, I could see making the following changes, along the lines of
your suggestion and to more closely line up the Mylyn Bridge features
with the EPP packages:
1) IDE: same as current, core IDE stuff, can be redistributed by CDT
2) JDT: same as current, coupled to JDT
3) PDE: just the PDE stuff
4) Team: team+CVS
This unfortunately still leaves the Ant bridge stuff out, because Ant UI
is coupled to JDT and so it cannot be added to (1) or (4). Depending on
EPP packaging, it may be possible to add it to (2), if not it's not that
bad for it to be available in (3) only, because what's more important is
that more people have access to the Team stuff.
I'd like to consider making this change for 2.1, so please post any
opinions or needs on the bug I just created. I'll Cc the EPP folks as well.
202547: improve packaging of Mylyn features
https://bugs.eclipse.org/bugs/show_bug.cgi?id=202547
Mik
> problem
> CVS.
> Mark
Re: Default Eclipse 3.3/Europa redistribution and org.eclipse.mylyn.team.ui [message #578369 is a reply to message #23036] Mon, 27 August 2007 02:13 Go to previous message
missing pieces:
Mik
techtonik wrote:
> Hello there,
> Europa"
> --t.
Re: Default Eclipse 3.3/Europa redistribution and org.eclipse.mylyn.team.ui [message #578444 is a reply to message #23905] Mon, 27 August 2007 09:32 Go to previous message
> the missing pieces:
Mik,
problem
CVS.
Mark
Re: Default Eclipse 3.3/Europa redistribution and org.eclipse.mylyn.team.ui [message #579905 is a reply to message #24121] Thu, 06 September 2007 18:06 Go to previous message
4) Team: team+CVS
Mik
> problem
> CVS.
> Mark
Previous Topic:Removing a Task Repository
Next Topic:Background Task Synchronization
Current Time: Sat Nov 01 01:06:39 EDT 2025
Powered by FUDForum. Page generated in 0.05251 seconds
