Home » Eclipse Projects » DSDP - Target Management » How to use SDK to launch terminal window
How to use SDK to launch terminal window [message #30430] Sun, 14 December 2008 04:31 Go to next message
Can someone show me how to use RSE SDK to
launch the terminal window programmally?
I installed RSE 3.0.1
Can I use org.eclipse.rse.internal.services.terminals package?
How do I get ITerminalService handle from program?
Great thanks !
Wendy
Re: How to use SDK to launch terminal window [message #30537 is a reply to message #30430] Mon, 29 December 2008 20:53 Go to previous messageGo to next message
Hi Wendy,
If you use the RSE-Terminals integration, it should be possible
to send an Eclipse Command (the equivalent of a keystroke). The
corresponding handler is declared in
org.eclipse.rse.terminals.ui/plugin.xml
looking at the handler's code should help.
If you want to use the plain TM-Terminal, the code for opening
it programmatically is in the works but has not yet been
committed (it will be committed soon). For details, see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=185348
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Wendy Zheng wrote:
> Can someone show me how to use RSE SDK to launch the terminal window
> programmally? I installed RSE 3.0.1
> Great thanks !
> Wendy
Re: How to use SDK to launch terminal window [message #32170 is a reply to message #30537] Mon, 23 February 2009 02:23 Go to previous messageGo to next message
Hi Martin,
Do you have sample code to show how to use tm.terminal API (3.1M5 build)
to launch a terminal window?
I am trying to launch a terminal window for a emulation device (unix
process) in the remote host, to run CLI commands in terminal window.
Instead of launching terminal view tab through RSE, can I invoke
TM-terminal API directly here?
Great thanks.
Wendy
Re: How to use SDK to launch terminal window [message #32586 is a reply to message #32170] Mon, 02 March 2009 12:29 Go to previous message
Hi Wendy,
sorry but the code didn't make it into M5. For details, please see the
bug. When you create a bugzilla account, you can also register for CC
on the bug, so you'll get notified when anything changes.
Wendy Zheng wrote:
> Hi Martin,
> Great thanks.
> Regards,
> Wendy
Re: How to use SDK to launch terminal window [message #578256 is a reply to message #30430] Mon, 29 December 2008 20:53 Go to previous message
Hi Wendy,
Wendy Zheng wrote:
> Great thanks !
> Wendy
Re: How to use SDK to launch terminal window [message #579186 is a reply to message #30537] Mon, 23 February 2009 02:23 Go to previous message
Hi Martin,
Great thanks.
Wendy
Re: How to use SDK to launch terminal window [message #579416 is a reply to message #32170] Mon, 02 March 2009 12:29 Go to previous message
Hi Wendy,
Wendy Zheng wrote:
> Hi Martin,
> Great thanks.
> Regards,
> Wendy
Previous Topic:Locator is null when using the APIs to start up TCF
Next Topic:Announce: New TCF mailing list and phone conference
Current Time: Fri Jul 25 08:31:59 EDT 2025
Powered by FUDForum. Page generated in 0.05447 seconds
