| Build state machine has not been initialized [message #577850] |
Sat, 17 October 2009 06:45  |
Hi All,
I was using MTJ dsdp-mtj-runtime-incubation-1.0M7 and all was working fine,
I udpdated to the last version of MTJ 1.0.1 and now I'm not able to build all all of my J2ME applications.
I'm blocked now with all of my projects and I'm very irritated:
Please, help me!
The error is:
Errors during build.
Errors running builder 'Preprocessor Builder' on project 'miabo'.
Build state machine has not been initialized.
Errors running builder 'Preverification Builder' on project 'miabo'.
In the error log I see:
!ENTRY org.eclipse.mtj.core 4 0 2009-10-17 12:42:06.286
!MESSAGE Build state machine has not been initialized.
!STACK 1
org.eclipse.core.runtime.CoreException: Build state machine has not been initialized.
at org.eclipse.mtj.internal.core.build.BuildStateMachine.change State(Unknown Source)
at org.eclipse.mtj.internal.core.build.MTJCompilationParticipan t.aboutToBuild(Unknown Source)
at org.eclipse.jdt.internal.core.builder.JavaBuilder.initialize Builder(JavaBuilder.java:583)
at org.eclipse.jdt.internal.core.builder.JavaBuilder.clean(Java Builder.java:286)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildMan ager.java:635)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:170)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:201)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:253)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:256)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:218)
at org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:360)
at org.eclipse.core.internal.resources.Project.internalBuild(Pr oject.java:516)
at org.eclipse.core.internal.resources.Project.build(Project.ja va:94)
at org.eclipse.ui.internal.ide.dialogs.CleanDialog.doClean(Clea nDialog.java:305)
at org.eclipse.ui.internal.ide.dialogs.CleanDialog$1.runInWorks pace(CleanDialog.java:147)
at org.eclipse.core.internal.resources.InternalWorkspaceJob.run (InternalWorkspaceJob.java:38)
!SUBENTRY 1 org.eclipse.mtj.core 4 999 2009-10-17 12:42:06.286
!ENTRY org.eclipse.core.resources 4 2 2009-10-17 12:42:06.879
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.core.resources".
!STACK 1
at org.eclipse.mtj.internal.core.build.MTJIncrementalProjectBui lder.onStateEnter(Unknown Source)
at org.eclipse.mtj.internal.core.build.MTJIncrementalProjectBui lder.build(Unknown Source)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildMan ager.java:633)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop (BuildManager.java:309)
at org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:341)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBu ildJob.java:140)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJ ob.java:238)
!SUBENTRY 1 org.eclipse.mtj.core 4 999 2009-10-17 12:42:06.879
!STACK 1
!ENTRY org.eclipse.mtj.core 4 0 2009-10-17 12:42:06.879
!STACK 1
at org.eclipse.jdt.internal.core.builder.JavaBuilder.build(Java Builder.java:167)
!ENTRY org.eclipse.mtj.core 4 0 2009-10-17 12:42:08.020
!STACK 1
at org.eclipse.mtj.internal.core.build.MTJCompilationParticipan t.buildFinished(Unknown Source)
at org.eclipse.jdt.internal.core.builder.JavaBuilder.build(Java Builder.java:233)
!SUBENTRY 1 org.eclipse.mtj.core 4 999 2009-10-17 12:42:08.020
!ENTRY org.eclipse.core.resources 4 2 2009-10-17 12:42:08.020
!STACK 1
!ENTRY org.eclipse.core.resources 4 75 2009-10-17 12:42:08.067
!MESSAGE Errors during build.
!SUBENTRY 1 org.eclipse.mtj.core 2 75 2009-10-17 12:42:08.067
!MESSAGE Errors running builder 'Preprocessor Builder' on project 'miabo'.
!SUBENTRY 1 org.eclipse.mtj.core 4 999 2009-10-17 12:42:08.067
!MESSAGE Errors running builder 'Preverification Builder' on project 'miabo'.
| Re: Build state machine has not been initialized [message #579814 is a reply to message #577850] |
Thu, 18 March 2010 06:34   |
Hello, I have the same issue, suddenly one day, I'm not able to create the midlet packages. (I am working on Ubuntu 9.10, with Eclipse Galileo, jdk6) To reproduce the poblem I have created a new workspace, set the device configuration to WTK 2.5.2_01, then a new midlet project, then a new midlet (splash screen from templates). Initially it compiled, the package was created and it ran on the emulator. Then I restarted eclipse with the same workspace, made a modification to the source (modified a comment) and tried to recreate the package. And voila !
Build state machine has not been initialized !
This is a piece of the .log file from the workspace:
!SESSION 2010-03-18 11:21:21.808 -----------------------------------------------
eclipse.buildId=
java.version=1.6.0_14
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=it_IT
Framework arguments: -product org.eclipse.epp.package.jee.product -showlocation
Command-line arguments: -os linux -ws gtk -arch x86 -product org.eclipse.epp.package.jee.product -clean -showlocation
!ENTRY org.eclipse.core.resources 4 2 2010-03-18 11:23:24.249
!STACK 1
at org.eclipse.core.internal.events.BuildManager$2.run(BuildMan ager.java:627)
at org.eclipse.core.internal.resources.Project$1.run(Project.ja va:523)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1800)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1782)
at org.eclipse.core.internal.resources.Project.internalBuild(Pr oject.java:502)
at org.eclipse.mtj.internal.core.project.midp.MidletSuiteProjec t.createPackage(Unknown Source)
at org.eclipse.mtj.internal.ui.actions.packaging.AbstractCreate PackageAction.createPackageForProject(Unknown Source)
at org.eclipse.mtj.internal.ui.actions.packaging.AbstractCreate PackageAction.access$0(Unknown Source)
at org.eclipse.mtj.internal.ui.actions.packaging.AbstractCreate PackageAction$1.run(Unknown Source)
at org.eclipse.mtj.internal.ui.actions.packaging.AbstractCreate PackageAction.doPackageCreation(Unknown Source)
at org.eclipse.mtj.internal.ui.actions.packaging.AbstractCreate PackageAction.run(Unknown Source)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:251)
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1176)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3493)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3112)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
!SUBENTRY 1 org.eclipse.mtj.core 4 999 2010-03-18 11:23:24.251
Any solutions?
| Re: Build state machine has not been initialized [message #579898 is a reply to message #579814] |
Mon, 22 March 2010 15:20  |
Originally posted by: krischik.users.sourceforge.net
Am 18.03.2010, 11:34 Uhr, schrieb Mario Balaban <extremepredator@mail.ru>:
> voila ! Build state machine has not been initialized !
This is a painful and persisted one.
> Any solutions?
I for one changed to Maven based builds in the end and I never looked
back. The Maven plugin for Java ME works great - I can even build on Mac
OS X.
Martin
Martin Krischik
FUDForum. Page generated in 0.05114 seconds
