Home » Archived » Service Component Architecture (SCA) Tools » SCADomain.newInstance stops after loading contribution
SCADomain.newInstance stops after loading contribution [message #577867] Thu, 02 September 2010 13:17 Go to next message
I'm trying to deploy a web service with TUSCANY and SCA. I got it once, but now I'm trying again and it won't work.
Composite file as follows:
> <sca:composite xmlns:sca="http://www.osoa.org/xmlns/sca/1.0" name="TMBrowser" targetNamespace="http://eclipse.org/tmbrowser.deploy/src/TMBrowser">
> <sca:component name="TMBrowserComponent">
> <sca:implementation.java class="tmbrowser.impl.TMBrowserServiceImpl"/>
> <sca:service name="TMBrowserService">
> <sca:interface.java interface="tmbrowser.api.TMBrowserService"/>
> <sca:binding.ws uri="http://localhost:8080/TMBrowser"/>
> </sca:service>
> </sca:component>
> </sca:composite>
Running it as Java application prints:
> 02.09.2010 18:59:43 org.apache.tuscany.sca.node.impl.NodeImpl <init>
> INFO: Creating node: TMBrowser.composite
> 02.09.2010 18:59:45 org.apache.tuscany.sca.node.impl.NodeImpl configureNode
> INFO: Loading contribution: file:/D:/Projekte/TM/dev/source/projects/tmbrowser.deploy/bi n/
> Exception in thread "main" java.lang.NullPointerException
> at tmbrowser.deploy.TMBrowserDeployment.main(TMBrowserDeploymen t.java:29)
Line 29 is the line with "scaDomain.close();", whole file is copied from SCA tutorials.
> try {
> scaDomain = SCADomain.newInstance( "TMBrowser.composite" );
> char c;
> while(( c = (char) System.in.read()) != 'q' ) {
> System.out.println( c );
> } catch (IOException e) {
> e.printStackTrace();
> } finally {
> scaDomain.close();
That's it. And I really don't know where to look for any log files.
JRE1.6 & TUSCANY1.6 user library are in the build path.
I'd be glad if anyone could help. Why wouldn't there be any error message? SCA normally seems not to be so silent...
Thanks in advance,
Frieder.
Re: SCADomain.newInstance stops after loading contribution [message #577882 is a reply to message #577867] Mon, 13 September 2010 11:51 Go to previous messageGo to next message
try to put this instruction "scaDomain.close()" inside the block try catch .
Re: SCADomain.newInstance stops after loading contribution [message #577915 is a reply to message #577867] Mon, 13 September 2010 12:16 Go to previous messageGo to next message
Thank you for your answer.
This surely would solve the problem of the NPE... but this has not been the point, since it is totally unclear why SCADomain.newInstance returns null.
However, I reset the whole project and it worked. I yet don't know what has been the problem...
Re: SCADomain.newInstance stops after loading contribution [message #577972 is a reply to message #577915] Wed, 15 September 2010 05:48 Go to previous message
> null.
For the NPE, just initialize the domain to null and test it before
closing it (in the finally block).
Why domain.newInstance would return null?
I can't remember what represents the parameter of newInstance.
Is it the composite name, or the relative location of the composite in
the class path?
In this last case,
would mean that the composite is right under your "bin" directory.
Is your project built automatically? See the manu "Project > Build
automatically...".
Vincent.
Previous Topic:SCADomain.newInstance stops after loading contribution
Next Topic:Fwd: New article "SCA revisited: Helios and Eclipse SCA tools"
Current Time: Sat Jul 26 10:41:14 EDT 2025
Powered by FUDForum. Page generated in 0.04541 seconds
