Can't build checkout? [message #577454] |
Sun, 14 March 2010 10:04  |
I got the trunk of swordfish and tried to built it. According the readme.txt I changed the settings in the launcher.properties. However the build of third.parties already didnt work. Any ideas?
Here are the last lines of building:
[java] [get] To: /Users/hans-jurgenschumacher/Development/Projekte/OpenSource /swordfish/trunk/org.eclipse.swordfish/rt/org.eclipse.swordf ish.build/tmp/plugins/javax.activation_1.1.0.v200906290531.j ar
[java] [get] Error getting http://sop-bp02.servicebackbone.org:8088/tools/orbit/downloa ds/drops/R20100114021427/bundles/javax.activation_1.1.0.v200 906290531.jar to /Users/hans-jurgenschumacher/Development/Projekte/OpenSource /swordfish/trunk/org.eclipse.swordfish/rt/org.eclipse.swordf ish.build/tmp/plugins/javax.activation_1.1.0.v200906290531.j ar
[java]
[java] BUILD FAILED
[java] /Users/hans-jurgenschumacher/Development/Projekte/OpenSource /swordfish/trunk/org.eclipse.swordfish/rt/org.eclipse.swordf ish.build/tmp/eclipse/plugins/org.eclipse.pde.build_3.5.2.R3 5x_20100114/scripts/build.xml:34: The following error occurred while executing this line:
[java] /Users/hans-jurgenschumacher/Development/Projekte/OpenSource /swordfish/trunk/org.eclipse.swordfish/rt/org.eclipse.swordf ish.build/tmp/eclipse/plugins/org.eclipse.pde.build_3.5.2.R3 5x_20100114/scripts/build.xml:78: The following error occurred while executing this line:
[java] /Users/hans-jurgenschumacher/Development/Projekte/OpenSource /swordfish/trunk/org.eclipse.swordfish/rt/org.eclipse.swordf ish.build/tmp/eclipse/plugins/org.eclipse.pde.build_3.5.2.R3 5x_20100114/templates/headless-build/customTargets.xml:12: The following error occurred while executing this line:
[java] /Users/hans-jurgenschumacher/Development/Projekte/OpenSource /swordfish/trunk/org.eclipse.swordfish/rt/org.eclipse.swordf ish.build/tmp/eclipse/plugins/org.eclipse.pde.build_3.5.2.R3 5x_20100114/templates/headless-build/allElements.xml:16: The following error occurred while executing this line:
[java] /Users/hans-jurgenschumacher/Development/Projekte/OpenSource /swordfish/trunk/org.eclipse.swordfish/rt/org.eclipse.swordf ish.build/tmp/eclipse/plugins/org.eclipse.pde.build_3.5.2.R3 5x_20100114/scripts/genericTargets.xml:59: The following error occurred while executing this line:
[java] /Users/hans-jurgenschumacher/Development/Projekte/OpenSource /swordfish/trunk/org.eclipse.swordfish/rt/org.eclipse.swordf ish.build/tmp/fetch_org.eclipse.swordfish.third-parties.feat ure.xml:10: The following error occurred while executing this line:
[java] /Users/hans-jurgenschumacher/Development/Projekte/OpenSource /swordfish/trunk/org.eclipse.swordfish/rt/org.eclipse.swordf ish.build/tmp/fetch_org.eclipse.swordfish.third-parties.feat ure.xml:63: java.net.ConnectException: Operation timed out
Thx,
Juergen
FUDForum. Page generated in 0.03357 seconds
