Home » Archived » Swordfish » Can't build checkout?
Can't build checkout? [message #577454] Sun, 14 March 2010 10:04 Go to next message
I got the trunk of swordfish and tried to built it. According the readme.txt I changed the settings in the launcher.properties. However the build of third.parties already didnt work. Any ideas?
Here are the last lines of building:
[java] [get] To: /Users/hans-jurgenschumacher/Development/Projekte/OpenSource /swordfish/trunk/org.eclipse.swordfish/rt/org.eclipse.swordf ish.build/tmp/plugins/javax.activation_1.1.0.v200906290531.j ar
[java] [get] Error getting http://sop-bp02.servicebackbone.org:8088/tools/orbit/downloa ds/drops/R20100114021427/bundles/javax.activation_1.1.0.v200 906290531.jar to /Users/hans-jurgenschumacher/Development/Projekte/OpenSource /swordfish/trunk/org.eclipse.swordfish/rt/org.eclipse.swordf ish.build/tmp/plugins/javax.activation_1.1.0.v200906290531.j ar
[java]
[java] BUILD FAILED
[java] /Users/hans-jurgenschumacher/Development/Projekte/OpenSource /swordfish/trunk/org.eclipse.swordfish/rt/org.eclipse.swordf ish.build/tmp/eclipse/plugins/org.eclipse.pde.build_3.5.2.R3 5x_20100114/scripts/build.xml:34: The following error occurred while executing this line:
[java] /Users/hans-jurgenschumacher/Development/Projekte/OpenSource /swordfish/trunk/org.eclipse.swordfish/rt/org.eclipse.swordf ish.build/tmp/eclipse/plugins/org.eclipse.pde.build_3.5.2.R3 5x_20100114/scripts/build.xml:78: The following error occurred while executing this line:
[java] /Users/hans-jurgenschumacher/Development/Projekte/OpenSource /swordfish/trunk/org.eclipse.swordfish/rt/org.eclipse.swordf ish.build/tmp/eclipse/plugins/org.eclipse.pde.build_3.5.2.R3 5x_20100114/templates/headless-build/customTargets.xml:12: The following error occurred while executing this line:
[java] /Users/hans-jurgenschumacher/Development/Projekte/OpenSource /swordfish/trunk/org.eclipse.swordfish/rt/org.eclipse.swordf ish.build/tmp/eclipse/plugins/org.eclipse.pde.build_3.5.2.R3 5x_20100114/templates/headless-build/allElements.xml:16: The following error occurred while executing this line:
[java] /Users/hans-jurgenschumacher/Development/Projekte/OpenSource /swordfish/trunk/org.eclipse.swordfish/rt/org.eclipse.swordf ish.build/tmp/eclipse/plugins/org.eclipse.pde.build_3.5.2.R3 5x_20100114/scripts/genericTargets.xml:59: The following error occurred while executing this line:
[java] /Users/hans-jurgenschumacher/Development/Projekte/OpenSource /swordfish/trunk/org.eclipse.swordfish/rt/org.eclipse.swordf ish.build/tmp/fetch_org.eclipse.swordfish.third-parties.feat ure.xml:10: The following error occurred while executing this line:
[java] /Users/hans-jurgenschumacher/Development/Projekte/OpenSource /swordfish/trunk/org.eclipse.swordfish/rt/org.eclipse.swordf ish.build/tmp/fetch_org.eclipse.swordfish.third-parties.feat ure.xml:63: java.net.ConnectException: Operation timed out
Thx,
Juergen
Re: Can't build checkout? [message #577505 is a reply to message #577454] Mon, 15 March 2010 03:08 Go to previous messageGo to next message
Hi Juergen,
as we had lots of timeouts getting orbit bundles from the Eclipse servers in the past, we mirror them locally.
Please replace "sop-bp02.servicebackbone.org:8088" with "download.eclipse.org" to get the orbit stuff from Eclipse.
Cheers
Juergen
Re: Can't build checkout? [message #577557 is a reply to message #577505] Mon, 15 March 2010 16:38 Go to previous messageGo to next message
Hi Jürgen,
Thx. It works now. Maybe you should consider to change the files in the trunk. It would be easier for newbies ;)
juergen
Re: Can't build checkout? [message #577600 is a reply to message #577557] Tue, 16 March 2010 04:49 Go to previous message
In fact it would be easier for us as well ...
I'll check how we could use the Eclipse site by default, but switch to our internal mirror for our continuous build.
Previous Topic:Can't build checkout?
Next Topic:SCA in Swordfish
Current Time: Sat Jul 26 06:52:25 EDT 2025
Powered by FUDForum. Page generated in 0.06756 seconds
