| Home » Archived » XML Schema Definition (XSD) » Suitability of XSD for particular task
 Goto Forum:|
| Suitability of XSD for particular task [message #57698] | Mon, 14 February 2005 17:03  |  |
| Eclipse User  |  |  |  |  | Greetings XSD'ers.
 I have started experimenting with XSD enthusiastically a few days ago,
 being convinced that it was the right tool for the task I would like to
 outline. A few days later (today) I am not so sure anymore. Before
 forgetting about XSD and implementing the below task 'by hand' (querying
 DOMs directly), please take a look at what I am trying to achieve and be
 so kind to share your thoughts with me as to the suitability of XSD for
 this.
 THE TASK
 (+) We want to parse WSDL files and specifically (surprise) query the XML
 Schemas which may be defined in the <wsdl:types> section. [Given that XSD
 imports are present in the files, xSD does a great job here.]
 (+) From this data, we want to generate a model that is to be displayed in
 a tree viewer. We will display a set of <message>s (parsed by a separate
 piece of code). Expanding these nodes, we want to display any XSD types
 referenced from within the <message> and in turn the types defining these
 types. We need a way of differentiating between complex and any of the XSD
 simple types.
 (+) Furthermore, a type X may reference an element or a type Y in another
 (imported) schema. In the tree viewer we want these types (Y, Z, etc.) to
 appear as children of X.
 (+) Alternatively, a type X may have a complex type definition which
 contains an element whose type definition specifies a type in a separate
 schema.
 I cannot see a straightforward way to achieve; at least XSD doesn't seem
 to buy me that much in comparion to generating DOMs of the involved
 schemas and turning this information into the desired model
 representation.
 Please share your wisdom and let me know what you think. Can you see how
 to achieve this task with XSD having a serious advantage over a
 custom-built piece of code. Let me know if this needs any further
 clarification.
 Many thanks,
 -- Bruno
| Re: Suitability of XSD for particular task [message #57722 is a reply to message #57698] | Tue, 15 February 2005 06:28   |  |
| Eclipse User  |  |  |  |  | Originally posted by: merks.ca.ibm.com
 Bruno,
 It sounds like XSD will help significantly by loading imported and
 included schemas properly and automatically, by providing name lookup to
 find the things you are searching for, and by providing a structured
 model for analyzing complex content.  I would imagine that you would use
 XSD to load the .wsdl giving you access to all the embedded schemas in
 the resource's getContents as well as access to any imported or included
 schema via additional resources in the resource set.  Given these, and a
 type name/namespace you want to lookup, you'd iterate over the schemas
 in the wsdl resource and do resolveTypeDefinition(namespace, name) until
 one returns an XSDTypeDefinition with a non-null getSchema, i.e., one
 that's properly resolved rather than an unattached placeholder.  You'd
 be able to check instanceof
 XSDComplexTypeDefinition/XSDSimpleTypeDefinition. For a complex type,
 you could walk its particles and its attribute uses to determine what
 other types it references.
 If you don't use XSD, you'll need to do an awful lot yourself.  It's not
 so easy to figure out which schemas to import or include (or to handle
 the circularity in these) nor is it so easy to resolve names which
 you'll need to do for all kinds of things such as dealing with things
 like elements reference, attribute references, model group definition
 references, base types, and so on.  I would expect that doing this with
 custom code would only be feasible if you can make many simplifying
 assumptions about the complexity of the schemas you will need to handle.
 Bruno Wassermann wrote:
 > Greetings XSD'ers.
 > to outline. A few days later (today) I am not so sure anymore. Before
 > (querying DOMs directly), please take a look at what I am trying to
 > achieve and be so kind to share your thoughts with me as to the
 > suitability of XSD for this.
 > THE TASK
 > XML Schemas which may be defined in the <wsdl:types> section. [Given
 > that XSD imports are present in the files, xSD does a great job here.]
 > displayed in a tree viewer. We will display a set of <message>s
 > (parsed by a separate piece of code). Expanding these nodes, we want
 > to display any XSD types referenced from within the <message> and in
 > turn the types defining these types. We need a way of differentiating
 > between complex and any of the XSD simple types.
 > another (imported) schema. In the tree viewer we want these types (Y,
 > Z, etc.) to appear as children of X.
 > separate schema.
 > seem to buy me that much in comparion to generating DOMs of the
 > involved schemas and turning this information into the desired model
 > representation.
 > how to achieve this task with XSD having a serious advantage over a
 > clarification.
 > Many thanks,
 > -- Bruno
| Re: Suitability of XSD for particular task [message #57747 is a reply to message #57722] | Tue, 15 February 2005 12:28   |  |
| Eclipse User  |  |  |  |  | Thank you for your reply, Ed.
 As I said before, I agree that XSD is doing a great job wrt loading schemas
 and resolving imports. It is the transformation of the model XSD provides
 you with into a 'more semantic' model of the schemas based on certain
 requirements (i.e. hide some information from the user - if you don't just
 want to display a tree representation of whatever has been parsed (cf.
 XSDEditor)). But I think that is a difficulty introduced by the application
 itself rather than the XSD API :-(
 Out of interest, how do you think XSD compares to Sun's XSOM? Have you
 looked at XSOM (https://xsom.dev.java.net/). Looks like XSD provides a bit
 more functionality (e.g. resolve references / types, load schemas from WSDL
 files). It would be interesting to know which implementation has a larger
 user group and whether or not the use cases for which these two
 implementations are used are the same or not.
 -- Bruno
 "Ed Merks" <merks@ca.ibm.com> wrote in message
 news:cusmbt$cqq$1@www.eclipse.org...
 > Bruno,
 > > Greetings XSD'ers.
 > > THE TASK
 > > separate schema.
 > > representation.
 > > clarification.
 > > Many thanks,
 > > -- Bruno
| Re: Suitability of XSD for particular task [message #57772 is a reply to message #57747] | Tue, 15 February 2005 13:07  |  |
 --------------050406000303060802080102
 Bruno,
 I haven't seen this before, and I'm surprised to see this effort by Sun
 given that DOM PSVI includes a complete model already.  I think this was
 developed primarily to support implementing JAXB.  I doubt it's well
 used (and I'm not sure if it is supported should you find problems).
 XSD is used heavily at IBM, e.g., WSAD and RAD.
 >Regards,
 >-- Bruno
 >>Bruno,
 >>>Greetings XSD'ers.
 >>>THE TASK
 >>>separate schema.
 >>>representation.
 >>>clarification.
 >>>Many thanks,
 >>>-- Bruno
 Content-Type: text/html; charset=ISO-8859-1
 <html>
 <head>
 </head>
 Bruno,<br>
 <br>
 was developed primarily to support implementing JAXB.  I doubt it's
 well used (and I'm not sure if it is supported should you find
 problems).  XSD is used heavily at IBM, e.g., WSAD and RAD.<br>
 <br>
 <br>
 <blockquote cite="midcutbfc$mvc$1@www.eclipse.org" type="cite">
 <pre wrap="">Thank you for your reply, Ed.
 looked at XSOM (<a class="moz-txt-link-freetext" href="https://xsom.dev.java.net/">https://xsom.dev.java.net/</a>). Looks like XSD provides a bit
 -- Bruno
 "Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> wrote in message
 <a class="moz-txt-link-freetext" href="news:cusmbt$cqq$1@www.eclipse.org">news:cusmbt$cqq$1@www.eclipse.org</a>....
 </pre>
 <blockquote type="cite">
 <pre wrap="">Bruno,
 </pre>
 <pre wrap="">Greetings XSD'ers.
 THE TASK
 separate schema.
 representation.
 clarification.
 Many thanks,
 -- Bruno
 </pre>
 </blockquote>
 </blockquote>
 <pre wrap=""><!---->
 </pre>
 </blockquote>
 <br>
 </body>
 </html>
 --------------050406000303060802080102--
| Re: Suitability of XSD for particular task [message #593999 is a reply to message #57698] | Tue, 15 February 2005 06:28  |  |
| Eclipse User  |  |  |  |  | Bruno,
 > Greetings XSD'ers.
 > THE TASK
 > separate schema.
 > representation.
 > clarification.
 > Many thanks,
 > -- Bruno
| Re: Suitability of XSD for particular task [message #594014 is a reply to message #57722] | Tue, 15 February 2005 12:28  |  |
 -- Bruno
 > Bruno,
 > > Greetings XSD'ers.
 > > THE TASK
 > > separate schema.
 > > representation.
 > > clarification.
 > > Many thanks,
 > > -- Bruno
| Re: Suitability of XSD for particular task [message #594033 is a reply to message #57747] | Tue, 15 February 2005 13:07  |  |
| Eclipse User  |  |  |  |  | This is a multi-part message in MIME format. --------------050406000303060802080102
 Bruno,
 >Regards,
 >-- Bruno
 >>Bruno,
 >>>Greetings XSD'ers.
 >>>THE TASK
 >>>separate schema.
 >>>representation.
 >>>clarification.
 >>>Many thanks,
 >>>-- Bruno
 <html>
 <head>
 </head>
 Bruno,<br>
 <br>
 <br>
 <br>
 -- Bruno
 </pre>
 <pre wrap="">Bruno,
 </pre>
 THE TASK
 separate schema.
 representation.
 clarification.
 Many thanks,
 -- Bruno
 </pre>
 </blockquote>
 </blockquote>
 </pre>
 </blockquote>
 <br>
 </body>
 </html>
 Current Time: Thu Oct 30 21:34:44 EDT 2025
 Powered by FUDForum . Page generated in 0.04004 seconds |
