Re: Cannot uninstall IMP [message #516718 is a reply to message #511559] |
Wed, 24 February 2010 16:33   |
On 2/1/10 7:45 PM, Ken Walter wrote:
> Started from wrong place(IBM) from OOPSLA article. :blush: IMP has
> missing references and mismatched ones.
> Update from Eclipse.org refuses becauses of mismatches.
> Uninstall fails because it cannot find all the components. :( (Uninstall
> should remove what ever it finds).
> How to I uninstall IMP manually so I can start over?
What version of Eclipse are you using? What version of IMP?
I've seen strange behavior from the p2-enabled versions of Eclipse 3.4 in
which all sorts of problems cropped up after installing IMP (e.g., unable
to install new features, unable to update IMP features, unable to uninstall,
etc.). I've also had some problems in 3.5, but generally that version is
much better behaved.
To be honest, I don't spend much time uninstalling IMP :-), so I don't
have much direct experience to offer here.
If you give some more particulars about what you attempted, perhaps I can
shed some more light on the matter.
-- Bob
Robert M. Fuhrer
Research Staff Member
Programming Technologies Dept.
IBM T.J. Watson Research Center
IDE Meta-tooling Platform Project Lead (http://www.eclipse.org/imp)
X10: Productive High-Performance Parallel Programming (http://x10.sf.net)
Re: Cannot uninstall IMP [message #516948 is a reply to message #516718] |
Thu, 25 February 2010 10:09   |
Gave up waiting and deleted Eclipse and reinstalled yesterday.
Below is the current installation.
Tried to install IMP from Eclipse.org and got the following error messages which are meaningless to me.
!SESSION 2008-04-28 13:13:43.640 -----------------------------------------------
eclipse.buildId=M20071023-1652
java.version=1.6.0_03
Command-line arguments: -os win32 -ws win32 -arch x86 -clean
!ENTRY org.eclipse.update.configurator 2008-04-28 13:13:44.781
!MESSAGE Unable to find feature.xml in directory: E:\Development\Eclipse\features\EclipseJDE_1.0.0.10.jar
!SESSION 2010-02-24 21:37:36.000 -----------------------------------------------
eclipse.buildId=M20090917-0800
java.version=1.6.0_18
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.java.product
!ENTRY org.eclipse.ecf.provider.filetransfer 4 1001 2010-02-24 21:45:38.890
!MESSAGE Transfer Exception
!STACK 0
java.net.SocketTimeoutException: Read timed out
at java.net.SocketInputStream.socketRead0(Native Method)
at java.net.SocketInputStream.read(Unknown Source)
at java.io.BufferedInputStream.read1(Unknown Source)
at java.io.BufferedInputStream.read(Unknown Source)
at org.apache.commons.httpclient.ContentLengthInputStream.read( ContentLengthInputStream.java:170)
at java.io.FilterInputStream.read(Unknown Source)
at org.apache.commons.httpclient.AutoCloseInputStream.read(Auto CloseInputStream.java:108)
at org.apache.commons.httpclient.AutoCloseInputStream.read(Auto CloseInputStream.java:127)
at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetri eveFileTransfer$1.performFileTransfer(AbstractRetrieveFileTr ansfer.java:140)
at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransfe rJob.java:73)
!SESSION 2010-02-24 22:06:29.093 -----------------------------------------------
!ENTRY org.eclipse.equinox.p2.engine 4 4 2010-02-24 22:22:52.656
!MESSAGE An error occurred while installing the items
!SUBENTRY 1 org.eclipse.equinox.p2.engine 4 0 2010-02-24 22:22:52.656
!MESSAGE session context was:(profile=epp.package.java, phase=org.eclipse.equinox.internal.provisional.p2.engine.pha ses.Install, operand=null --> [R]org.eclipse.imp.doc 0.1.17.v201001291500, action=org.eclipse.equinox.internal.p2.touchpoint.eclipse.ac tions.InstallBundleAction).
!MESSAGE No matching artifact found for: osgi.bundle,org.eclipse.imp.doc,0.1.17.v201001291500.
!STACK 0
java.lang.IllegalArgumentException: No matching artifact found for: osgi.bundle,org.eclipse.imp.doc,0.1.17.v201001291500.
at org.eclipse.equinox.internal.p2.touchpoint.eclipse.actions.I nstallBundleAction.installBundle(InstallBundleAction.java:62 )
at org.eclipse.equinox.internal.p2.touchpoint.eclipse.actions.I nstallBundleAction.execute(InstallBundleAction.java:29)
at org.eclipse.equinox.internal.p2.engine.ParameterizedProvisio ningAction.execute(ParameterizedProvisioningAction.java:35)
at org.eclipse.equinox.internal.provisional.p2.engine.Phase.mai nPerform(Phase.java:129)
at org.eclipse.equinox.internal.provisional.p2.engine.Phase.per form(Phase.java:72)
at org.eclipse.equinox.internal.provisional.p2.engine.PhaseSet. perform(PhaseSet.java:44)
at org.eclipse.equinox.internal.provisional.p2.engine.Engine.pe rform(Engine.java:54)
at org.eclipse.equinox.internal.provisional.p2.ui.operations.Pr ovisioningUtil.performProvisioningPlan(ProvisioningUtil.java :389)
at org.eclipse.equinox.internal.provisional.p2.ui.operations.Pr ofileModificationOperation.doExecute(ProfileModificationOper ation.java:61)
at org.eclipse.equinox.internal.provisional.p2.ui.operations.Pr ovisioningOperation.execute(ProvisioningOperation.java:37)
at org.eclipse.equinox.internal.provisional.p2.ui.ProvisioningO perationRunner$1.run(ProvisioningOperationRunner.java:94)
CURRENT INSTALLATION:
Dynamic Languages Toolkit - Mylyn Integration 1.0.0.v20090610-1638-1--7w311_17261119
Eclipse Communication Framework SDK 3.0.1.v20090916-2238
Eclipse CVS Client 1.1.101.R35x_v20090811-7E79FEd9KKF5H2YDWFLLBL01A16
Eclipse IDE for Java Developers 1.2.1.20090918-0703
Eclipse Java Development Tools 3.5.1.r351_v20090810-0600-7r88FEoFI0WTo6Az-1qFRHm37ChJ
Eclipse Platform 3.5.1.M20090917-0800
Eclipse Platform SDK 3.5.1.M20090917-0800
Eclipse SDK 3.5.1.M20090917-0800
Eclipse XML Editors and Tools 3.1.1.v200907161031-7H6FM_DxtkM-7aeTHKEBbQqcZOZ2
Graphical Editing Framework Draw2d 3.5.2.v20100111-1352-4417w311A223702A19
Graphical Editing Framework Draw2d SDK 3.5.2.v20100111-1352-7A7E38yD6E88B9I5AELD4H8D8x42
Graphical Editing Framework Draw2d Source Feature 3.5.2.v20100111-1352-4417w311A223702A19
Graphical Editing Framework GEF 3.5.2.v20100111-1352-777928194B66D5D476C33B2A
Graphical Editing Framework GEF All-In-One SDK 3.5.2.v20100111-1352-787A47PpPBNpsWlH3EdWS1fY14Gn
Graphical Editing Framework GEF Examples 3.5.1.v20090813-1341-7P7c1EVVFGMFsTX7Tcko
Graphical Editing Framework GEF SDK 3.5.2.v20100111-1352-7G7O5A5WNXWQF_OVSWjaZLTWkNKY
Graphical Editing Framework GEF Source Feature 3.5.2.v20100111-1352-777928194B66D5D476C33B2A
Graphical Editing Framework Zest Visualization Toolkit 1.1.2.v20100111-1352-6618yD6DH8G6N59OM53B2A
Graphical Editing Framework Zest Visualization Toolkit SDK 1.1.2.v20100111-1352-6658CNDT4R8WTQUMhLVdgPbPObOX
Graphical Editing Framework Zest Visualization Toolkit Source Feature 1.1.2.v20100111-1352-6618yD6DH8G6N59OM53B2A
Mylyn Bridge: C/C++ Development 5.2.2.v20100222-0100-e3x
Mylyn Bridge: Eclipse IDE 3.3.2.v20100222-0100-e3x
Mylyn Bridge: Java Development 3.3.2.v20100222-0100-e3x
Mylyn Bridge: Plug-in Development 3.3.2.v20100222-0100-e3x
Mylyn Connector: Bugzilla 3.3.2.v20100222-0100-e3x
Mylyn Task List (Required) 3.3.2.v20100222-0100-e3x
Mylyn Task-Focused Interface (Recommended) 3.3.2.v20100222-0100-e3x
Mylyn WikiText 1.2.1.v20100222-0100-e3x
Subversive SVN Integration for the Mylyn Project (Optional) (Incubation) 0.7.8.I20090904-1300
Subversive SVN Team Provider (Incubation) 0.7.8.I20090904-1300
Re: Cannot uninstall IMP [message #577409 is a reply to message #516718] |
!STACK 0
!STACK 0
FUDForum. Page generated in 0.08108 seconds
