Home » Eclipse Projects » Equinox » Starting additional OSGI bundle in the console
Starting additional OSGI bundle in the console [message #55432] Tue, 27 December 2005 08:18 Go to next message
Originally posted by: glenns.web.de
Goal and Background:
I am trying to run another bundle besides the actual core bundle (org.eclipse.osgi_3.2.0.jar) in the console.
Steps performed:
1. The documentation from the Equinox page "Coding bundles on the Slug" served as an example for me. I was able to start the runtime and display the bundle state. However, I had to copy the org.eclipse.osgi_3.2.0.jar into a new folder.
2. Prepared a JAR file to display Hello World similar to the one in the documentation.
Problem:
I can not install nor start a bundle. The command "install test.jar" ends up with unknown source. The bundle does not necessarily have to be the "helloWorld-bundle" any other bundle is also fine.
I know that I am probably one of the candidates for a step by step tutorial. Help would be very much appreciated.
Thanx Bob
Re: Starting additional OSGI bundle in the console [message #55511 is a reply to message #55432] Fri, 30 December 2005 14:18 Go to previous messageGo to next message
hello bob,
first of all: why did you hav to copy the org.eclipse.osgi_3.2.0.jar into a new folder?
For the installation of a new osgi-bundle use "install file:test.jar" for installing test.jar from the actual folder.
Please post, when you have further questions.
martin
Re: Starting additional OSGI bundle in the console [message #57717 is a reply to message #55511] Mon, 23 January 2006 23:23 Go to previous message
Originally posted by: jeff_nospam_mcaffer.ca.ibm.com
Note that you might want to use reference: URLs when installing to avoid the
copying of the bundle...
Jeff
"Martin Schikowski" <schikowski@gmx.de> wrote in message
news:1438365.1135970314851.JavaMail.root@cp1.javalobby.org...
> hello bob,
a new folder?
> martin
Previous Topic:Alternatives for deprecated IPluginDescriptor::getPluginClassLoader
Next Topic:plugins is not a valid directory when launching through Java Web Start
Current Time: Tue Sep 16 18:41:49 EDT 2025
Powered by FUDForum. Page generated in 0.03653 seconds
