Home » Archived » DSDP - Mobile Tools for Java (MTJ) » Breakpoints ignored in "dollared" classes
Breakpoints ignored in "dollared" classes [message #576869] Fri, 28 August 2009 08:28 Go to next message
Hi, I am on a project that need to debug. I have several breakpoints and they work fine, but some of them are just ignored. I have been looking if I could find any difference between a breakpoint and another.
I have found that the breakpoint that works, the specified class is this kind, as an example:
pkg1.pkg2.classA
but the breakpoints ignored are of this kind:
pkg1.pkg3.classB$classB
That is, the classes with $ seem to fail.
Anyone has had this same problem? Is there anything I can do?
Thank you.
David Lucena.
Re: Breakpoints ignored in "dollared" classes [message #576881 is a reply to message #576869] Fri, 28 August 2009 08:38 Go to previous messageGo to next message
If you are using jdk 1.6.0_14 or 1.6.0_15:
http://bugs.sun.com/bugdatabase/view_bug.do?bug_id=6862295
I suggest to update to http://java.sun.com/javase/6/webnotes/6u16.html
Re: Breakpoints ignored in "dollared" classes [message #576893 is a reply to message #576881] Fri, 28 August 2009 08:51 Go to previous messageGo to next message
I also read some people had problems with some previous releases, but mine is already 16.
Re: Breakpoints ignored in "dollared" classes [message #576906 is a reply to message #576893] Fri, 28 August 2009 09:31 Go to previous message
I guess this is a JDT error.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=279390
Previous Topic:Breakpoints ignored in "dollared" classes
Next Topic:Problem with svn and jmunit exclusions
Current Time: Fri Jul 18 10:12:01 EDT 2025
Powered by FUDForum. Page generated in 0.06035 seconds
