Home » Eclipse Projects » Eclipse 4 » Menu Contributions
icon5.gif  Menu Contributions [message #534370] Tue, 18 May 2010 17:18 Go to next message
currently I'm trying to contribute to menus.
This is, having a "main menu" contribution in Application.e4xmi
I'd like to contribute via ModelComponent in some plug-ins.
This seems to be not possible, yet.
Am I right or did I miss something?
Secondly, I'm trying to hook a "main menu" contribution to only a special perspective, this is in Perspective1 I don't want to have a "main menu".
The only way is to make it invisible?
Thirdly, in eclipse 3.x it was easily possible to use the org.eclipse.ui.menus extension to define menuContributions, which could be accessed via a service.
How is this to be designed to work in e4, since a menu might not be tied to a declared ui element/container?
Didn't find anything on these topics on bugzilla.
Sebastian
PS: Anyway, while watching e4 evolve (and adopting my e4 app to it a lot of times Smile, I'd like to say thanks to all the committers and people working on it that hard.
It's really a pleasure to watch things evolving and getting better or more easy to handle.
So again, thank you all indeed, for all the efforts made and time spent.
Re: Menu Contributions [message #534375 is a reply to message #534370] Tue, 18 May 2010 17:47 Go to previous messageGo to next message
Am 18.05.10 23:18, schrieb Sebastian:
> Hello,
Contributing to the main menu is possible your parent is the main menu
id and you simple contribute a Menu there.
Or did I get your request wrong?
> "main menu".
I'm not sure about this but I guess we have no story for this yet.
Not sure what you are referring here. Please note that in e4 you can
always register a Event-handler like described in "Dynamically extending
the workbench model" where you get notified when the model is about to
be renderered and can adjust all things you want to adjust.
The same is true for perspective switches, .... .
Tom
Re: Menu Contributions [message #534535 is a reply to message #534370] Wed, 19 May 2010 08:59 Go to previous messageGo to next message
Sebastian wrote:
> Hello,
As Tom mentioned, this is possible today (or it should be).
> "main menu".
A visible expression can be attached to MenuItems and Menus (or it will
be, once I implement it :-) It's not there yet.
The same pattern that org.eclipse.ui.menus has will be available for
ModelComponents (parentId?before/after=siblingId). It's not there yet,
but I'm working on it.
I'm not sure what you are asking. The main menu and view menu are
rendered by the main rendering engine. There will be a service that
provide an equivalent function to partSite.registerContextMenu(*).
Later,
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Menu Contributions [message #534544 is a reply to message #534535] Wed, 19 May 2010 09:46 Go to previous messageGo to next message
Had a closer look on this today.
The Workbench Model Editor isn't supporting this feature for Model Component, yet - at least as of I20100514-0830.
So I give the XML way another try Smile
>be, once I implement it Smile It's not there yet.
Great.
This is awesome.
This is exactly what I mean. And, from my point of view, a very utilizing API.
Sebastian
Re: Menu Contributions [message #534551 is a reply to message #534544] Wed, 19 May 2010 09:58 Go to previous messageGo to next message
Which editor are you talking about? Mine (the none visual one) does have
the feature of creating a main menu by using the Context-Menu on the
Window entry in the tree.
Tom
Am 19.05.10 15:46, schrieb Sebastian:
> So I give the XML way another try :)
>> will be, once I implement it :) It's not there yet.
> Great.
>> yet, but I'm working on it.
> This is awesome.
> utilizing API.
> Sebastian
Re: Menu Contributions [message #534554 is a reply to message #534551] Wed, 19 May 2010 10:14 Go to previous messageGo to next message
Hi Tom,
Yep, I'm talking on the non-visual one:
http://www4.pic-upload.de/19.05.10/hc6x7vgzjjlk.png
Button "Add..." doesn't work and context is not available
Sebastian
Re: Menu Contributions [message #534567 is a reply to message #534554] Wed, 19 May 2010 10:56 Go to previous messageGo to next message
--------------010204050804020600000309
Content-Type: text/plain; charset=UTF-8
Not sure which add you are referring too but because the Main-Menu is
not part of the children-feature I had to find another way to define it
(I'll probably add button also to set it some where in the form)
Here's a screenshot which shows that you can set a main-menu on a window.
Tom
Am 19.05.10 16:14, schrieb Sebastian:
> Hi Tom,
> Sebastian
Content-Type: image/tiff;
name="screen.tiff"
filename="screen.tiff"
TU0AKgAF4nKAONyOh/gCDQeEQmFQuGAAAw2IRGJROKRWLReDw+MQaNRuPRyE x2IyKMSSESaR
x+VQyHxqUQyCwuYw6VzWFS2KS+bTadTuJT2fT+gw2gSeDzOPTqi0OGv+lxOn 0qVAGSVWV0iF
TONViKVyP0CvTWwxux0yPWWNyaUP+0WaMgC2xOsVK3Qunzm4RW4yCLTi6ymQ zu726x4OoTS3
YOqRXDUm03XGz6O3u/5Wg1ahZXF0aISLKZmE5+8W/LYzESqy1iuS+6ZrA2e7 aXDQXMU2DaK8
yCtXyT4u/S6j0iY2zc6/Y7WZwXiUfO4nT12L1LWXbIxm/V++4/S8aa2Dtx/c XKzeGZeWxRC9
+Tn9y9efbaTQ8rzUPq+v0cWJZ/1a7v0P9vmzjQtirL8LI7qbv60zHNO4TKtU iMHpK+0EPWtT
roQrz5QxAUCqJAMBr+7ypwSnkPtvDbmQw+sKNQwDsow4a8sm0ESRq+EbP/Ds Jxs5r2w5AD7x
4o0VthBTgQhGjsNI8i2yImCmLDJzwR03kcos1cTRPHr3xbJidtFK0syoy8UR BJ8WyBFMaw1I
UuSCyLcQjBiQs3Mc3TEkc5OKtUkKYtb3zC6CnTbO8z0JNToUPRE7N5RVFxGh yXJwkkNOItjk
0ZGFEw88U10ci84owYhjGe2jdy0jNB04oivSlJT7lqWZZAATRMEsABWliWoA AJXq/qQpdXOO
nrFNbFljsCAK9sVCUh0lScBOU5c1SlC9XyS3tH1QziXrilDIpxNlG0Mmiiqf VsdzMw8b3Gjl
A1XKqUofU91ULZt1SPD86pYm9rW+w7VLamN9x/cS+LDgc9z7hcEPDg1gTS9i 4SjUE8OzdD7v
THzEXndbbt3Nkj3pfjSWNH7zqXYGO0gt9g3SlaRX/Bd2p1kdULBleT046duo 46afz5kjqX/h
FuZuxDiZrSNkX6u6W1C+s4QM0dMxdDq1xnjyqNrF9+sPoNlXbHbKYJbCzXzM uq5NmWK4ywFi
Xk7GTPyuDgaVNNv7RM1pyGmCuUtrrrJAloBAGAAB8KAABAFSh/Nufx+gAf3I LzGKaN2zaHgF
Ca2cdNmDS3l8EMHBts3hlq+ZjC2vZ/wejaFRrfXY2+2PYjuy9desr9fsSg3f hmIw6tDKYFLV
Mc/NTk7/qtt034CjZtpkueLAk3K3aLg7TMae4SvG9Z1DdMer8dtauny5uj3y 05z8lO/Lr3mt
1DnLfA8vh8FOmWb7FUUe72bM3SllPqcozxxX7reY4uNC7dmfLlgauM+Q/h/u ORO8d9rl38st
Sc/5T5jGYvPdg9J7TzXQNiKKf96LP1zr2Li/d2KaGpmmaDB1QDuoOMbgK+5i xV4SPxSm/Y47
cYROcPiyVihzSrHVVVB5A8LkKpBTnCB98OnRE3eiuR0sMW2nQiSgqHUWYet8 SLFImTRSktZi
rD6NSPnvr2Py/R4zdI5PBdCtuMRhIqRLjdHk2SDmdMYekl5jyMTUnuJlAViE F3RSEi0pCEsd
FmwtiAlAk6eoaLuhisQlzmyqObQxBNibnlLLTkBBV87untIZO+pdHZd3fv1W UmBLBBhgjDGY
bRJ61n0raRWsIhYfw+h6AAMMYQwQAAkBKCQAAmxOiiYnK9iSKJfRBZe1yIa6 ZrL8bCx508iz
4KTN9OErMo5TRXao71a6yZryKldNyB0dYRy7lRDiaMO5URtNzNNE0aI6mGJM jkpUHyWUCZ27
k+zBITvhlPI967oXqRkbhEU5jw3cF6YNAOXzOTZv1eY9CU8EH/r6nQiY8k/5 6oCUpF6bTX5I
TVntS856fF6HDbmoyXEiZzzqnyuYokM5+0EaOvNVr3J0G0p80Na8eqUS8m7F s7aD6azbPtGZ
2EbZs0hp4dJEDPacr4Ms7I9EYJ61HKPVeR9HKYTvq8zOgz8aTPna4vl2puVl oNrEo9CxLTFu
LAI4cAdfXFycIO5MgrkB+OSH9YeViJ6pHWdu2OCKBVlv7nTUyk8Jmy0CgZK1 pdPZ9oecyxKf
9EZ3z4oK/pkqJZKoEbJPVpLfmFR2eXFCi0pkyvigNROOK5GKxwKEeFIjw5VF yrefhwEqa1Hv
qvPOFluoaxkjS+xs8hlVsghWmCP1CnnIAb1UZA5mIczSuySGO9IYpt1LHKo0 TqkJtbp7Y+9z
8pyykcqlSMTeUBy6rRGkrss0/WdhgTmitkkdJRv9Dx+TI6gNMuxHN3a9yYVc q/WmlTbZX0Jt
jb11GCLWTxLFemta7LlswXTHe/VbT+P/MKr8+EKLeS4io2JU61kIyFXjGOhs XLmXmQCpXDts
KW3biniBwMvqz28svdSRjJ8G5BhEuKaD78iSYjwlafSU8p4UjXgFTNDzUWNP wn+a9i6nZYpH
HuSKd5LGEzBlFA95yFD6HyPkAA0hpDRAANkbA1wADfG8N0AA6x1DqUiQ8CgF QLAABCCIEYAA
TgoBQAAFoLgXgAAKAYA2BIMnBUCla4dT4BMbP7eVPq9BfjAGTjB8ZUbUNWKY M8ZwzQAB2DqH
KBolNcAABMCgFllcd3nn5OfAeI7+XgyfsTJMIcBLQcZXpjq0r5shbldOfDUq uxUrnsjN53yg
T+h3XPOCSWpYnqbdBwdPIEpZwW651eKMH5LQMnrHOymx22Pa9/MTE7tGhwHh atmWztYU3go0
/U7racB3ThVK8K2lN33LiLh5mdWcOzPA+jzB+K6iUQ9dp29dC0stEti/XHX0 Wrp7iszu655w
rR063g1voxohm9a2q+I+VNfT4VXA9057WtgTJ7MSlVvasydjGddOmaVThuy0 1ZjV3sQs1ebV
UbuYb7dDXuvYAq+gDr/X6vqGB+uR7DYdydir6b6oMvtrNdqO48spzF0VWnY1 WgXRGXVpoF7u
3ozw6mWqRrhQ42jfsqFQzwS0ymNXVSAACBAB/wODQaCweFQp/w2CQOEwd/Qe CxGLRCIxSFxu
GQ+NRyEQcAyCSQaRyCMySHSWPxyKx6BQmXyGNyeBzaYTeSgGcSyQzOcxCSym UT6fT2jSwAzK
kS6kwuT0Snx2pUmqwur0WaRCmzqvUmmz2T12hWUASOyT+p2es0+o0G1Ru2zW kWiFWORWecWO
yS+VzGYSmZQKu3ioUed1SfXPCVzESCeSasSwYj0UWuQKdPq8AFgwlGzZiBM5 jNin0C75Kv4e
W1qMQVfsFeABcLpaABrNdqAB4b0ABDgAAVCkWAAjkYlgAgj8iWcBSO2zaC2L J4zRaqkqpVqY
AFYqlqOWmO9fV0rx4CNvx+vwAMtmMkAMhksQANhstcAONyOIAPR6Hmg4GAYB oAA6DgPAAFAT
hUAAcBuHYABqGYbgAAgBgG1rrIJDTXOwxrJLI8SIrCm7IuolaqqI6inNS8kQ NDFx/vE1i4Q6
9ChrzFkcpbGbJx1GyWQ5FsdxdH7AMEhEhLlGsfRw67IsmuyTKQi6Krm60eyC py/rlJUYSUrq
ry468xS1JciRjIs1RG08mTdIclpTLKgy8wc1JUpaKTmoyGzrJ8jvOsCVJIt6 t0DN9BS21s7y
KnDGGuaxqgAYhhGCABpGiaAAQvDABU8AFPAEiiHH7UoAVKfoABcF4YAAHYeh /BIVQY1DCSpM
qrSKqUNGiZ5nAAXpdF0ABwG8byDhAEQRAAIYjCMAAXhiGLzz3JsaUMoclKyX hfGNOU/xuvdG
XGg5YlgVwAFUVJTgAQpDEKAAWhdaZ5noesgKnarILPRF9RLDzHxXa6FlcVpV AAcRxHCAAoig
KoABAEAQgAfmKvaZZkQrC4ABsGwcvC8ieLRE1+ShJKgT6tcpXIqGTJqtcNX9 b84ZLgAAEYSB
EgAJQjiY4QUhXG9CZZfmBxfbNbX3pTy3wx2XIEcxznMABRFOUAADSMY1AAB4 HAho0PSox+wN
UwyvMKw+XJsuy+LynqZxGmTBTGoqq0K0U55TpemXFDcboyokZKnK+mTPM2x6 KnUe7hbFFw+w
B0HSc9NgDUQKAoC1QafJzzLvf3E6Hw9sL7fhaFrdB+H2fQACgKAsLdNGj8dH K0r3xfQZAu8V
ZVa3e6FfnBbSqE2bdvbU9rmjxeVsiheWyG0Zfl8ROj43oxhoUOS8hWonGABQ FGSwADUM47AA
CIHgjonFZb6vC2vlebZqk3tb3vPQsbKWSKbKy/RhHqIWWK1Zo7l+DuH7P4eY QIVYsjuD7H46
sLIUgwPqRJAN3C1iskOS830niolQqbAEARUAAkME2H9CcAEJz2D/hQQ0iao0 iNmSS40xLIXm
w2eM/Aurm2SGrLq48kTAi9Oxfk9Z+L62iufSm4h+77lCEZdu9RR0QHHJ2eA7 9Q7oIMp0JpC8
oUXitkXJi3QszLk7P0LKVc6BTkZv7NcdI6yu0muMdmYmAERktJId/AJprvma FzeQ9d+ZMYlL
UUPG5XJi0jRojq2J+q+VCN9I+VlESdylvELg3duqfHZw6eOi12xoi2x6UMQm H7ZU0pQe0lgx
znXcxUKeDMICDFGCMEMJIAAdA9BuXGMsYakk4uwic2eLEgiBDpHUOgAAeg+h zAANMag0SOKc
VOqYjYLQWAvXaIQRgAALgWAwjyAKiVGBICUD4AAWQsBeAAF8LwZIiJGdhEou ySB6n/AAKcVQ
owACtFewcdo7R2PqIMBMCYFAABTCgFadIVguAAAWAsBjfoiN6oJEiJ0lZYKg X4c9WxPR/Nym
LIOBMFHRPMjuS5wk8nDQWTvGiUlL4mUunGRhRcVqTvZkUUdPZ02StmlUa+FN Qm8JCTqilwZI
R1DtHUAACoE3MzCIMPgfI+AADhHEN8AAGwNAbogApAiZFEUtnkScdQ6x0sUd TVsDIHI61jUa
rdNMck0w1pzJx9RUpNUkSaOkdMyoSKiAkBECamwBqijJSwkAtxcG3ai1M44S KtgcA6aIdg7B
1sIHGfyg1hQPgeBAm1xrYk7ObINSEgonxPicIOGAMAY4RqiGwNg/AxhjH0BK CUEwAAeA9nRR
dGrfY+ECGaMsZQABdi6FwACgVA5qGYZSyKaqqaD0IWbZIGYNQa1wKwn5zlZC QD6vEAASAjJu
jAF6bMgwCQFAKIOPcew9iDhACGEMAAbw6B0AAAYAwBzyMzj6kyxJohdC8GHg N9sF7gElF0Lk
W4ABJCSEgzUFgLQWgACEEK+wWJ1QpPWAAS4mBNAAFMKWfjKVZtBCcE80AOwe A8K+zGnbRzpO
8cSHUOgbwAK+GYU8JoTwpX3DgHWeJ5SyB2DrLwZgzLjiKEVhMGoNAcH9nwE0 JwRQAAIAQAk2
gtxfnoMKtWULay8v9SbIGsTAcFM2hlW9fYdw9ByUmMUYRLMtAIWALkYbiQeB BQoH0PIgAABI
CMEog4Owgg2AAH8PYggABGCJZKcmk5jZrgNJbBUug4AAGEMVSxJc7qTFyMc0 Q1TdTtDQF0AA
shUi1AABoDAGgAC/GGL4AAdQ+TOGOLwZYAAC6/pRS1fUPZiMDfydhkZIw4B4 a2M4aOPRaCpF
6+YCL6W6DXGybsK4YQngAGSL2aQBwDZ4b/RRxKY3gw0c6nnWYwzZhzl3t4X0 0tfgFjGRosUO
zJF+ishrf1F3tPQiXAWOkdJFDCGJrYTwn3wjfHAN2tR7L+b2E0JYUoAATAlM vdw6Mp9LTFbV
SeYuACQB/EDkSqg9wACIEOJVIEktLmYiE2E0QdA7hoAAMMYe071gJy4BkDFb gsBWgmFEJwV8
i1JiyQ/NoABUCpE+94UQlzaC117mSGvHpIWmTRSkwEBZITDeceUJYUgdM7CO aANj5COBlDZ0
gc45xyAAFmK0YpHBci7FkAATQnxIgAFcKbaYdg+tbHwPflQkhGNXrJcORhCx qDWV+FwMQTQA
C3FexkDQGbK9cexEyT3H6eSuip1hIiI+wSGwXjRURdhVCxn4HsQmmxXCiNmC sFALn/Q2kKoo
kAaQ6TsHrfFqglhWofgKJ8U3VBECR0ENsZVAz0YIJh6kgwcA+hmAAPfw4ABM iLxPaLS0FYiN
vnEaGmNSEp752S5pTqnyEUhQ2ROF29yXvLi2uBoj+yxyYcKimiGb4MMOo88+ QiSekbQ7HAMp
oiC96b4gvAALo9I2E3Ozc66/UvAjWRqlMiau6LioozMqGPOSrA2hm9EpgScQ 46ahglccA6Wr
oKFBcu5Am5m6UJbBClEUZA0TWo2+qXwZkiOxmmCkS5ELYJQkcKOp8/1AXAUW 1Aspm98j8Rsr
1AOniXE5hBsvAIYd2AACcHMvsGqH0GmJYBWAMwuFmA22m4E0qUG92MMxk9GI 0MYBuCG90RiI
cCQCK0MGKGQz2HeHeHc18AKAMNEGQGAGlCjDiKsX0mQcmDSDYDCAAHOHQcmB eVYAADcDazkB
YBWOKAIAKhEdSPYGoGqN2EkEmEcAAGiUyAAAwAy1kEwEo6iAsnAS+pKu+jwS KCcCgOa3Ev8C
cCayCC8C6tg/EKMYEjcZW/aZSNqFmAAEmEtFSoC+kIGQuVEB8B8CCAAB0ByQ gBAA+tCAcAaA
cIOHkHmQAHCHCq0GKGM7uGEGGGAumIOoMoQDYDQ03DyOSp2pwhwyMeAIcEkE uEavuDUv0ZPE
kck1e1iIO9ac0JGo86YQ2IK/kX64CJYHgHiHeawDktgP0YW9XFyIWAiAgfSF aFEwev5EIpG6
WSaHEHIYWA8A4A+PKHQHUcmH2dUAAA4A0QQulJWH6H8VTHSq02qAkfMAhKMl KpqHaHcoGpCI
m8QvkA+A4tDJCXIuGqJFxFtJAS0TnIguklUIS/ohSg0IGDODigmF6GCWGDuD eD4AADKC8a3C
MI2GuG0GsAACaCwywBqBiQoFME6XQIMDiDya2+45UEwEe6iS4SEGQGW7uFSF e4uGWGcPgsGs
KFiFMFyMevEdWD0ECmcF5LWN+Aea/EmamCmCe6QEKD8EUwCIiE6FEEyZuEkE MJYCSCM8sEaE
MEoKEHaHeoGCSCgCA4iAAAOAOzwsHKMDCC6DKAACqCkCy3M6ZCBChBSKQDcD m5xEmHLGMIWC
oCg6QCsCoPBKsOqZhK4kaJSFQFU4uGMGQ7ur8mUiXLgDGDSOUCCOaR+SEEME S0dFJEQDuDqD
2VUBcVaMwF8F+NmE4E6EwAAB/GyAADODMDXO9C5JYI4hOImC8C9OkIMFAFCO 4hIQwGAF+2mE
6E6xHGwViDKDNPvPSiOKAGytoAAFiYKABD/ECg+INJwH3HkVQIOmomo3qIkh QAiAksKCaCiN
ABMBQBTPRBnShK2I4EkEam6F2FwuWB8CBOIDaDe02YjKqIGHBTIAAEiEgEeU mGCUsCKCQslO
zINK4+pClA+JKFuFyGAjU9WjuX0EqEmwmF3UCtiaTBZPoxiJWKjKCawDUl4C MCO0lToX3Ac9
EI2D2Dyv0yWuOBiBkBmQKA6QQReVWWmVhG0rs9KJoDyDyDiYuyayeAABmBku 3M6AAFIFK6iA
JE+nbGIIfCUozDZACgRQxOtGOleK2TmZGrqZAD4D+DuuYoEAAD4D20Ed+OeJ G6ArcJsE+FEt
YCCB8CEAABCBABGIOB8CIY+0Y0cCICCyxCoRc+sUbWJVMIGDyD+yIHYHasyE AD2EClgg7J0A
usqMwGsGyUkDCDSC+AAFgFPGcAyAuAyqvJeNoF6weDKC6DPUHNOXSFeFSAAD MDA5wAUvZA7X
kbbUlUMbKbYL0VEDoD6DaAAF8GCF2ABPBOkEADyEO3vQ0PqG2UkCsC+CcAAG OF2U1JSjTTqi
4Q6SyJsHAHGq0FwF2NuDMC/QrR3DhZOjWZQcCLWE+FGxGBeBcBkAABiBeBpC fXdJWYBJ8iSj
cL/bbbQHw+6YcvsB6B5OID6D0EGU3FAuQF2FsQSBMwuAwAu1lbNB6o2T3DWs U0rB2I2EGEKD
wABbg5UEIEIlxPMelXhCxFuI4DyD4DYAAHcHcHaAADwDu0EGmGkGe8AFeFQA AG2G4GyaoE6F
g4wBJSfCqTajOd6OgKQNyU0GgGgPgC2Cy5wfilDB1AKIG7jO6FUFaFDY6DJV WAUAQvdcNesi
bBXCCdkECEOv0HKHNO6E2EndatOhQB8COwuXsQAGCFzDHHEAeIOEKEWDyAAv Yy4DkDYD8AAF
4GBGcPWVSCQCGNAVq8eJU/8IE1MU0C8DHaAdOGMABWvUpV+3YdA9Sc+h/WPA XLpCDXfRhUkM
iHSHWmUCaCynQXqHkn6FFZkBSBKaDXkMQgOrwI4DaDyDEAAviXuE6ElY4gQ/ aFEFUxGEOEeD
+AAGyGQsy+mzNbdWCI4DmEBPu+4vkEsEReek2cK3Sp9BqdxV63UhmkRDbH85 DLA4+g1iWic5
JC0ky5A6TZPjBcObARWLC9C7Ah261g6iK2K3wgGh5glAmercTH9SlAqhoeU3 +zKixgoK+h4q
CMCIctRkaZQLMjFV5BLgKknkFg9cKbpiwUAlG/zi2oxVOxsRRPOMYW0WrT0w CZLksRjUmi4u
9SmjtAsVwlQTUg4/HBNkxCWTcihbRV+jKhzes5DCJK1ToBMHBYeHICUtYJKA 4FsngG2BCcm5
pcLC2lBlBWHjzKwI2B0CKWmMwBgBiVaDKDKngwzW+GkGnDGYaNBSIMwGMF9d Ucfm2f9eSaES
yZSvxYuGaGc166GPBQED0YoH2ILJwPYC2C+CoAAFKFCFZEEhEAGAKJGEUEZZ w6e4vVgu2EgE
bNmc3Xbjdj06So0I4CiCkWeFGFFdaDcDea2wyCOAAC6C3EjGNCpGQ/KcrOKE QEXX4FsFw72J
eAooOAADZUY0eCMskAYAWQJf+mqIrIoJuo9GsQqQsP6HrhQFyuUAAEoEslxX vGoIECVNyAAD
uDnLfVwhEPHa07CidFEXaEW0EF1YmAAGMF6V+IMGQGU7uDkDzZcC4CvYQDQD JZcAIhIc0gRk
nTnUjAYIGEoE3TSFeFmFWAADmDgfKsOQxjTZGYGVKPYEGEO0EDoDhWaCqCYP BlIv+IUEmE3F
SBkBeu2B0BsB6AAG6G+G2AADgDy5wAmAkoQPUPZYyF6Fi1II2FcFmYOEkE0m 6BSBMaCHIHKP
4BuBo7OD4DpbzBkI2EwE+lwHMHRO6ANEGmWDlX4g+qoqsDEDWdeEiEPQcEgE xNdLjQqBCA/X
Gp7mJCeIcBGBrcJkyKM+hO6jwlYcTWrACJfIpkeIiDWDsngF4F/M2BgBaWmF SE8FiJYEgEuE
WxAE8EmY4QmaoExskIMFwF9GcYqPYCYCNgGI8SUFCFQtYrOmUHHueABuce6F cFHb9C0DkD1c
/JqamFIE7daoiomqwq1xjO6BkBbbLvsIEFCFOtYFoFvdpHs02I2AsAqnCBQB IOKMAHsHwXuG
aGiPgB/bq19VyEiErFSFKFQn4F+Fu1JndmrgnB4IUFaFjdaHiHkHgIOHeHhI 0GYGauPOOzwB
8B4ViKkBiBdU6Bh0SiCcHsS9VCLH6IeGUPevIEmm6Ab0zZmCm6QukGSGU1IQ c7OOXP0gwSEE
UEaXgGoGpDGxxcgBYmyoqIW4c4hUzXABDXGBoBm0UmFnpkIMnZ0DCDCoeIME 6E8n5RG5yGEy
+E8E6E2AAB8B/OIDCDHOdv4KdVmFOxMPqUhqnrQIHR7UHOQzwQt2+IKPUVSq qqtZ1zgIFSBS
aMuCuC21VaLi7lZlUVqGnFXWgDsfL2iViEKEQEQP68QAAvFR8IM4mAAAY58m WDvWaGGGEzqE
IETNcBbEspM/RSjjSKAJtygF73vAhj8LWGiGkU0EEEBf0hIhFX8tMeoVGILw HVhbCD4D9iIH
yH14Ro/ApbPFzkSAAD6D2fKGaGY16D2D7X5UcCSfkJPrb5wdXbTjYIMD2D1U wyY5WERtYBiu
2ulZCv8IivgqthecRlcffrWJy2Hev7USKD+EFfo8Q5UEaEVw2JLKCVS56zwd VR9KAVSJsCAC
MxgD8D00ECECBP0g2Tg3Ts1WL8XkQIW0bWb7hGeEWfCJLs46VLtLwDGDXEiF cFLdoAwAtYfS
Hu/ciHuHyJ1zAx6DaDpPuFuFcNmAgAbfhgrWFiZ9rau//UIp/IfsKDsD8l4G GGNHjSAFaFLb
8BWBSwv70AA1NDHZ88sGIFzdU3E3sosjEMHlMLT53GqsO18AMhE8P6hlYbNk nKUcPOEnQDPs
EdYCYYekAQ69Rl+NZCvbWQyf4euKIG0G2PwIAZDQWAAoU8qgAIhAJwBDYaBQ KAwA/H4/QA/o
xDo1G45HQDHYbH4+/5DDpJJZBKZLH4bJ5RGpdMI3LI7LkKhj0AHw+XwAEGgU fKqFGpFQ6NK5
pQqLQ5jDj2fjcAH0+XyAEejU4AAHWwAzGYxgAajaXwAdzmgAATyaVwAAgDIr eALfSQA/7tdb
vdpJe43d77cZABAJEgGBAEAJ4+7li6JdIdjqHjrpk46zWcyAAazgXgAuVoyg ADweEcfHJjkJ
VgJBkNRj6TdFquFYAEMiz8AGEuGmAMEBAA3W+2gAWDASou/oslUcogANxqPZ QUiyQQAdDgfQ
AOxuQgBEIljH2+otTZNKvJR5rHWs2GgADAZSiAFkq2GAAyGA5jPR+5XM6IkL zv+9DJNSxbWP
Iyj+QVBaPI+Ng6rICQJgmABaFwV4AFMTZZAAFASBYozUNa/S6o4pcSwC9KVD ePYyAAex7nqA
BNkeU7SsAj7DlGViskSSC0GuYx1PKux/LxIyWpal0TwE6pBDWAB7nwe4AEoQ 5PSS1MUpTBEB
NYmUSpBFIAy2vjVybG80vQvyPL6lMRvK/bztalkRTW/0TKVM8DJexk6tK1yZ pZJc/QbEk2zh
Q08UTBjX0PNqjwJPLJpo08US5ME9pnLdMMWk6Ty+kKWLckQBMOua+n8kiMSM jFVrvI0zLxLM
w0ulzz1lBia1zN83V1ONftNNFa0zXk2V280SzpR7/T+/lbzdW6YqbTlhpM1t qpqyFQTFPs8V
1bJ/0dYSmRVYFk3REL/U409s00yM90ZAFfxTTlt2YxlqWJYL93Hb1CwVMdO3 NPKGhQbr8l8H
IzqMIRjkyABsBIcmC3vctG3PSGNUBWkFB4JAZ10HeRgADQNAyACbkMABoGgZ 4ACiKApO6iFd
GGXZmY5XlM0BJmB3wjhiGMYAAD0Po6AAF4XBhGZMlAxB7sVY6Gi+Ma2FATpU pmw4AAQBIDAA
MgzLIaRpvaQxBka7IdB9XyhYFjtFKbnyOEqSyghaFumB8HrqCkKokgAVBSww dR2HOAAvi+LU
Zk0UiEhCEaj6nM6aUYpa4j+QI8AAXxgl0jYuC0zg1jSNrugJsDEoufsjHQdP EG4bptgAdx3n
cjYJAiCQABIEYTAADAL5QAQBo+A4DgKAB9n6fQAEqS5JgAUhSuYjQgh+IYAE EPhD328l3QKk
B7HrGQ/EKPIAGUZjMI0YZdGWjYCgMiRYlsVoAEORRCgAMQvBmf6FyADljVJK UyvJ8KjyWE7J
6FMLhxgwBeDGAALwWQxJxfAr1eShy6DmHQOUAASwphFemJxrQIgOvATEtVFI sBav4GUM8Y4A
BEB/KCeEfgAAlBWCAZkMwbwABUCgQQkA+R7GKI0NcbQ1XEhqCsZ0WAwXggVA wXItwAB+j8SM
PsfJ4yhDrHWOloohA5kFEwKgAAgREB7AAEMHoSAAA2BmDkAAgBEOcCGEAIgA Afg5hIOweEYg
whqcYKYTKGAGgMAaiFMq+1urlBMDcDq/JKFDGyMccSd11KCJetJWRfA3B4YY NUa5ux0DqHQA
AXosBivBeGSmHZ3CqE9A4BsDwABQCWjQRoAhESNj8H3DlOR5H5m+AC1wRYkX vDEGPFIVYoBZ
lGHO7AAARwpNtFWKMWIAATgjBUXgkiplSkNIokiTRGxRioSwMkZZYBMCSE+l xVREx+kWI0qQ
rRhosT1VmAAdLhwABGCYD8gomo0AwBcDJXsCW3SVbiQ0AwB5jRXI0NkbY2QA B8D+HYACEwKA
AEwJMrJIJgEWIpPZfi03xUOWI5RaywhSCnFCAAXQvBbgACaEsKAAAtBYC6rW Xphx9vMeWPqJ
Db6XEqEYI97w1Bqm7DoHJzgLAVguYyt4vhWyJS9IkchI0wIcrVUSuE9CrGwh kM4RoTQnGn1a
AAMMYcUhPieKyD0H1BAwBhgnSylaXSNjRGgM4AApxSCja6AgBBG6hmKl68oB gCwGHHSNPWlB
Da3KmMOPQeo9CJ1DZo8ojQ97RHDC5T8FwMQYrkXSwFBanBSihaeKwVLWhSio a0AoBwDpwIhL
iPYeQ8gABbCwWwKgVi2BacUv+hrBbVr1r4RwWQtRdKyTtc9SKg0tidE4xAXV 3S2lcLeRJVCm
10EuAHFe85hxTCmFKRMfxH1XXWUi0BfpDg/h9c4M0Zr8Q7B4D4ACu53F3kdH gO8eEuBPiaAA
NIaR7R4jxwOBcDDKAwhhYYDYGwOAAB9D4HUAF+n4iGEMIwAAMgYg0Re+QAAc g5unAQ8gAAkB
ICXI2JESOJBsDYGsAANIaHTi/GAL0AAxhjjENCA4B4AAyhlDTHEGsdCQCyFm hgZIySwDVGsN
QAADgGyLB8D47gZSBEpyJkZ6lMxyjlHGfYDAGgABhDAi4HANwdKIr4iNeUGx ACDv/aIewABE
iGEcroMwaQwv9PeAAHOdD9BDCTQQPgeA/gAexgIhw7dMAAEYJARWC2zAAAvh IAAcA2xlBeCw
F98k+IKLonMoQfRBk5z8AARwhhIq6HYO0dkNBHP8lJloDwHJbhKCOEvTQkhF gAFYKNDAGALR
VGaM9nIkRMFBE8JWmY5BzQgDqH0OQABzjoHMAAD4HQPlaMKAAT4ljmFbN8f+ Dak0+qhYAUhU
8x90ESDuICIDwoqi5ptuQDwIAACxFULknQ9yqjQGiy8KoXdjG5GaAAA0vQAD kHKOEAAoxUzx
GkNU9o8x6DzwADqHoagyFRAVyuGgjxCUdQk2EL+TZOsRG0NcAAihIP8EuI9L A0xrDRAAJES2
yRPiXFMbwwSWRijIGEAATInxKz+jCdkG50GT5uHEOSTIgg9veI0MEYovzOi8 FsADoHQgJgSo
+E4JTMwoBNCqRsOoe3TvrhmBLmMibdBo5SADOZ0FVEWE70cAAuBdTRVUkYKI Ti2BeC2i5OSY
YCqI8rzVY6n0ktzIc+XkgTgpncC+F2AAXfIznIbrodemud4LGlYLULKA4yhA AC4FlqS5EfHM
ObNYphU0zqd0IenIwAA8B1QTv3KgFALI2JcTetx9fRABVSqwnxRYKCcEwKYA AqhTcYPDCAAB
LbVAAM4aD8fh8kPvm4SIjxOgAAYAy3QhhExsHx/eIIUwtozE49IdQdKVIJ4K CJ4LILDQ4pJS
yl5Xpji65RilQAAPwQAOIxAnjQAQ4TA/R16EAK4LSOAOgOI7DuIggMIMr7YM 4MqIAZQZaVrg
AWhDIT6bbvQCp2odwdoqwSZlbaIZK74iQGwGjOoNoNQO7+D+QjYXIXaaIWoW 5/ASQR5p5bwZ
QZTIwSwTRtQc4c5igGYGIG4AAPIO5/jLgCCTjtAaiwQTBGgAAbgbijB5AA4A AHoHh7QKwKgz
gOiUTcAc6EAD4DwETfKXATibatylcQcBkQrebeQjQcoc7jQKILCPYTwS42YF gFRpgWYW4VYA
AXYX4WoAAa4bDLQLYK6CYMALbJodIdRxAJ4K6ggX4W5l4BIBD5gSYTARMCgq oOgN424jQSUW
gqQqiNoIJwMKjEh17cYKgKILiCgLRhiRwdYdhIYQgRRzipxl4D0PgAAJgJL7 YRQRw24WAVJo
h4Q/ImgZ4aJ+ISgTMWo4A4QC4CxlCIUZIKoKKn4jQPQQB04GIF4GwAAKwKIz gwAZAZY+oSAS
plYQIPTEgFAEwFYjYToUTqY3o9wLQNEQjOy5hNB8Ly4hyswSwTptQWIW42Yf 4jIK4KQzgMoL
x04vpUAj4WgXIVwAASYTTToWYVTsgHYIyqwUaQ5DoEZECh4uLeMQxb5i5n4h wOIPiABGBGQT
IRq9pQooow4UoVr94RQSQQQAAagYbcYjQ5CHISQTkWoWAWwhCswLIKQMAAAN AL4qJJoOwQh0
7+5KgSQQgrIlwRoSx/gfIqY5oGYHYAAS4T4oKU5xAI4ILYwPANwtAAxmrAby a5cBaDEoZPUB
S+ht5fBbiR61pRUipgBbZqY1jPApTy5RyAheJE0jRQMyo/syKBUi5jBdQyRL c1LVZjkjRcRI
iq4/hMhLTVk0Ax8lghqzDdAw4AQwa75rkjZ1qLCogioiyrwi5WBYAvxaCT5T CskosyCrAoyh
jVTzTVs3JniDI8038RBBsoRYpaJjLzSR01opgkZeE9o1c2c7qlk3BZ8zc7Bc EobzhM09Ex09
0QxOA1BdxnZBa6rzcy8zRjBf01ZBM3S+dBZEoKocQ4wa4fKJgkAXgHjQ4oYI gYieIkAFIA8h
gVoEDs5uM+s3ZEzV0/j1AlAH4JULiljLDLQatG5mBmSz5XQYAXEHcos+Eoko U+5ZISQSzEgV
4WA2YTASwrIFAEoFq3YkAMIMxxgTwTTpJRbfCiw3YNANKCZmIKgAANoNZpFC RnlFc1STYhzA
xIdLyCYNgNbb4SQSbZIQYQTToQQQi/4QoQYRB3oEib6LKYU7JAqDYygj5wyE DQrQ4PYPTSYI
QIB7QeoeRKixY+QWpDAWIWcmAcAcIb5XQEAD4EItIJpmbtw+IiA3wBYBoBRz oYIXYAAQgQ0r
ATQSxLAC4CbNxYSFkoQmkZxIYPYQSjgbSi4lIYAW4zBz1WLUKKoGwGoGqXAU j94S4TTqYUQT
KNADoDjc9XxyZjcyoaga4aQsIOSCamQ2YfgfJIz0iJ5flJ6b75561BAkgY4Z g+oOwPsCYXQW
BogfQfCHIB4B0MQmBAJbIMYN0ZIPQOY24EYD4hgYwZQ+oOgPx04Y4XY9of6e 0B4kCOxzgAaX
wPwOplckahhXiU7cYQYRa/4SoRaeIR4S9P4HIGkv74azgZYaAzBo4QaLCLSK wj4PwQ7DwIQH
gIwAAIAHZ7S5RedCE+VBQjYFIHTc7VShwawYtUBWtAk7hN02ifpYQN4PTJtZ rZUb7FcIS4IK
osgjQbAbbnAMINgLKHQIoJgAAbwcIbwAATwSdLIhwRwSsWr6IqoPEEE/FNAj QScpoAAYjpwA
AVITybYoYUVxzdQUgTY3AWwzCLScxZBTIWIWsmAW4XcFwTASBLA84UoVSeIZ IZiGYSQRTBS1
c14lJCybYQ4RkrFHozAAri1Bs9ilKvlAwjQ4AbiNIQy/5CZCgRwRDqah4jrL A3YVrgzi4cjN
bldVwFQFJEALIKyn6RKRZJMFQzAWAWZ/EOCHsWABIAAWwzyfaHIJ4Jg+LOcv 4UQUieIZwaJn
IEwEghgLgLIzgCgCcGdkwAF8Z/AWAWUmAFAE4FIAAOIN7D0xhsB8LB4eIAAV QVhGwbAbLHYe
Qea4ACoCgC0fgKoghpS1IRwSEWtG7LQOIODDwawayJgYwZDIyWqSYKgKQtgE AEFUgjQZYZYz
FTZDAGQGTFAKQKFMRGDP4QwRErAAyiIAFOKIAUIg1uob4boAAGgGkfYKoKgt gBIBV9IjQqZ5
x6g5gZ4Z7iYBOMCEIJgJoAAUWKojQTATRLCtwYoYjp4UAT794HiuxxIMCvdr Jc0/4jxfQhoV
4VohGNLiYiB5VS6Y4w63K3SyifYi2SojS84wk46tweQeK4BJMiNS4GAGZkIK AKdMVw12MzeV
WVQRQQlngaQaNcgVQWAWAqT6RBh5BsAKsAT2ppQAAOwPi/9rZelQuY4owV4W QW82aSlrszol
QPIOxpDrbNZ4q8TfBfgt4w+NcNzYIDaOoQZlcvZ5xOFFUixAZBYQIP4nIZwZ pnIMYMsimLbD
QjV3Z5QCwCwC4jb+4noNYNCC6MBIYDYDg/IJIJNugcIcFUAHIHIHiOLRgP4P y/K/ZlMaIAAG
AGDFDz0fgK4J6w99IVoVkFwkoPwPyjgyxnOHdUgvRKIe7P4dWmLimKAVQVKb eJ5sAYAYIXzn
OV9QAEoAAK4K1uIdGoojYKgKduIjQZDKyNLrzcgD7ggJwJqnYVQVaNGgTdQT i9rf1A65VFuQ
o9AQQQo25KRKgQ4QbEi+ohoI4Jg6maS/4IAHx7QmigQ6gPQO47AIAHo7iswM oNTQ4E4EwhgM
RqrgoWmW4WgWqaIVBHaw6xLyhXRZ2aC1RdQQAQqNmT+CoPoOwtDmoCA0VHel oMQNQsmNdVwO
INrb9S4RwSTEgbZ2eCwUA2cdqKoYoZLIwPRzaVQWSKR1oiwXMVoAARoSLZIR 4RLW7LqRYEgE
J4BHJZuys1FAZSEoJPwmk4pUw3hmoPIQAOCbgE4FBpIFzVIM4NaCYSYR5iDt xmYrw0D/TYwY
AWx+Lip5VcQ9oZIZosDSuXB5wNYOJhgO1sAAAIoIKOAWoXabYS4TgSmAgUym 54rd4lgR4SjT
qzS4AP0L9xQZCKQPIP6MoX4WgsEiKJTHYNAN6C4JgJQJxxILiC4aYadcgRgS NP9baW4TISMJ
4hwV0moAENrwAHDOoXIXSm4ToULBQWQVVWOMNVwcAcmLANQNyCYKAJ1MWuR7 R4WcCx63QTwU
MDDsTIWvA278GCtPS/4PIOoQI7IHKgky2QZgSApbBMJXFNBVASEHA+QWkmAJ QJCnYNKH4ADl
b5gkCswMgNNuOwWBmwoMrgtThCoWybYVIUZDixFV0TzLQZYZyGeuQ7ioZ5wN oOMigOYN59II
nAojY2o249aJlgTJILAKz/ewUhgCgCWEWv8ZIerFQPgPUrBk2cAbQbQbBpIF 7DWnDQARQ7Ab
IbLnGa77gKr77ApGYTfBiwpDnLFNd2Uyki+sJzSMsvYnoQ4QgSw/QT4UPcQU YUrBQToTJrQE
qb1o4IxplUVUgFrVAAAJOtr2oFjFEkYhqCRmZ+Z5QNQM+70vYquOgSQAGNcW QR6mYjWZRG3c
9ywVwVWngksNXYJ0xxgOoOQ7AFaqqGgRXNI++cAPgPNP4jR2SjDJiJ5vh7Wf 8Cb6J5wdsGoA
AFIFDVPIRDCpZ/gSARrBTvgAAEpD82u6Zfuyal5Zae684AHPiOgLoLJFwLQK iC5Hw24CwCuf
Y9Y3a843wQ4QPBgXHBDZQWJx4ToS0kQu4QAQxpEuSGgQN5ghwQAQ5pGDTLTd w4YKozj8B3AS
wTIoIVoUzsj9a3YLoMnFbld9IOYOCNlS4RYRzl4bYbjnAVoU+nnawbgbyjFK g+IJwJZmYLIK
8tIYjsYAHIrGgMwMO7wKwKYzgSwTbToayUp54Rxx4mjnQ24VwWSNANgM7DwL wK/RYjUZB7QP
YOtngGoGEv5Ql5s8zehX41oS4TzQYXgYKm4QAPR7z8Ad4AAPYQKMoQQPTQdp CPZJPmb1YKoM
JwIRgQvBgGYFrOoG4Iohncp/AE9QKDTVlplAGZAkAgBzP5oADsdzsAB/OiIA AAAMNh8PiAAW
q7VwAT6mTIAaDAcMNkCUTiLAC7YK1ACBPUMeDwdwAPKBOYAQx7R4AII7IsOk B4QxvAD4fD3A
CQQSakENPCFoDUa7RAAUCYWABYKhcADUa1QUqrUMwNyAABWJxbpNniVntVrA D/tlvtsTt1wu
kgtNqu9outvt15vF8htzvcgf9+v1xieGw9swUTuGHxd2AOGpMRiWLu+XteTn mPztviOVumRu
10ueZz+Dzd/yWg1OpzWEwNrxuqwGvvG12kO0+lhoCAUPAfDAAEAwE4oHAoAA YEAdnfr7foAf
b5ffU6wAfr86b9f9uf3fxHjt3lwm62vmuvp226x2yxm22+4+VJ92C8Vn92I/ ey2rSJ4vMBPk
9T4PG+0DwSz0DNMvT4wW3a2tDBr6rYvz+rUxq0ww2bOw5BEKwo/UQtUvL/sq yMAQAvbxQ/Cz
3rhAr6QZBUHs7FcbwhGzWMxFi4hea4RAAcQtI2pIPFMM4AFwISzLqJBfFLIc irPJElGmFRuw
JEjfReusJxo/rdIkIQmh1Li1mqapqAAaprGqAAoigKLigKA0ZroXpamM1kYx KwaJPYpI0DaM
AAG2bhtAAXRbGC5gAuXDq1jGNAugAThMFJGC1PCfgACMJIfgAEoSBKABLkoU EKwxHDRr2AoC
uQeJ5HaAAxjKL4AHkeR4gABIEgUABFkSRwABSFAWKCfB9PrFzX1avQDOOAAB AItzguee56Hy
ABommZyikmkhxHGj62WkA4AA6DgOrOcZyHGAB9H1bi2A8DoPgAOA2DqAAXha GNfAXdNOgAfx
9oefZ909A9BQyyiziIJYdzQhpfFpPhGkqhheF8XQAEiRRL1GEwSAAJYoiMAA vi2MYACuKMnS
7PuK2ghpfmKXYAEEQ4+gAXhZmIABZFqi5JExYuKiiJwqAAN4zX62xZlyi5IE qRgAF6WRigAM
A1C1k4iicAAqigLMMxBAx/bWAAdCOGAAF8WRjgABQEgYABVFhKRYFsVgAB2G wfAAV5alXXwE
WCOw3D4AAeBzUSkjINyzBcFm4G0bZsgAaatgAFQT2SlREgACwKAvDsZIc4IA DaOwyAAGoYhy
ABgGJnRBDyRQAD6Qw7IwSpTIafwBLeThSkqoJ7qINoyJnTbIrm9FoQwFYeyF ivsroaZhG5PD
ZzFGrV0kyrajiPg1gAEQPhGABvnEbwAJaeAAE6SVNKSkSbnad5118sAADmXN ibEiKMs4exCB
0AAPcoYABHCEEomhhz+gADGGQMMAAphOEXLqIsSQhQADOGiMwAAdw3uNFIKo r47SDuABw4MM
DLTmHEMEMsZwyAADMGeMkAAaQxFAPcKYrwABTirgMEwJAUFjAnBWAAHoOggE OMgWooQ+IAjc
GwAAZo0BltxGAx8NQZw2uABuqI76HHpPaWcaphxSRvDge8IMRAfgAATAkBRY QhhJIRJANQao
0gACMEiIcAABwDgIAAEwJTY1EObGmNSQAFwLAYAAIQP7uwCSZAAMIYovyMCi E2AADgGwPAAH
dC0CwFnUDhHCOAACdk7glBGqZWavR4DxfoPQeg8wABSCeFUAATQlBPS2W4dI 6x0AAD2H4O7B
m2AaAyBtroXnYAjBEyZ1Q+ZtTKD878d48B3gAAwBeSgPwfRRHKOYcgAAYgvB mv4F4MiiiSJI
m5Ni918jxn03VuwABzDnHOv4FzcA2hsDih0YgxVHChFEJ5xwPAesrC8y4ew9 h6tODg+mTJyA
KAUAqAABFIQADoHTQF5ZRAxBiDKAAHIOWKFJE4pgAAyRkw4AiBECQAAjhHCR BUY6fBxjiXMS
ASolxOQzeKMYYsGBRChE+4CiAAAuheDCfVmx7SziTEisWcE4TJkPm0twBYC2 8KwOWdxTx2zp
l1Oac85xyGFHXHqPUelIKRNrH8AAB9NwABrDfQd8j2o+I1UCiOwwjxEukGeM 9cAoBTioikgO
wKGTxBgCyFgAAMAYzyDiHeZqzbJ2CS2jsAArRYC1QKhtmbNT5WqLgGwNZBB5 DzrqcB4pk3iv
fLYrE5ADAGgNeHXkE4J1TBmDUGxGZ7kLoBjW+NVyXyJCDEA40ZwzoSF1A8B5 fIkRKFILSK8V
zhxQigqOBxdgABRikFSAAfh3KkAAm0ddeazBAiAD1CG6wABBiDdIC+eIAK50 XCyFmJVIQEgA
FWKoWRZxACADzFq/NOwkgAD4HoP97L2gAC8GBsA46ggAEKIN3d/mAitFcKoj AoJQhBCAEMAA
dg633kNIgwpbh8D2isUkNwcCCDdG694Rsgp2AwneK4WDhxKCUEjRIMTLwqtg U2baq6X2aFwE
KIfC4xhjtcAOAZdJbA/B8EFkOd5SZFhEAAHgOoewAA+B6EEs+Z805rAAEDN4 ABijHaEIIQ2F
xXirwWA0BgDjtHbAAEgJpOw+B4wuDwHVETRZUqtaIvRDxAs9AAMMYowi9iKE GI0AANAYg1AA
MoZkOA8CAd+KATQon1PsLONwb42wABiDQoYU4n8UAXAq6gY4y0+B7EDg8XQs BfSvVgAAaTng
3h1uQLQVYuAAAOAcA87TC7nKAQchaKaEzOGJADbc4GyE7h7EFQe4YKQACHEK 1gJrKQADXGuN
Z2ouW6byiyVcJYABfi0hwc45ZzSHgEAKc8fY+jr7fDoH0oAEAHARhLCeBY+R 7SJCsyoQofXd
g3BqmfhB1wphc32IJ3tmQVg0ABr+DAehAL9F4LFoVG2diJca52QAtRWsfHyP dblbQACWE5Hs
Zoz4SCWEcJ0s8h07lJH5thhZ1whhMB5usQKxQbg0TPJk54TAqYuDMGN9Mwgp TOrzNpZgUArs
qDUGgoATgltNOCQ8PIfqD5dkQHoO2Y7SZSyie89NzY0t1AXIgUQpJQibE6JZ 0uvQACA40ACa
ypik55UcIIQuDxXisFztMBYEDtD+WYEcJjgw+h5hBo6KPWpXrTH4PphhnA8h 9DhXqvYAA6Bw
zYWkRAjRAkcGiM0AApBPuHAUApvF7TpjBGHscQAhMHh5DvhcI4RQm+frycPg x0i2niEUIzC4
yhlt0E2JpKU5JpD+H6dMIwRwcAADcG2ZoRwjTE0in/KSPWKiCEIv0cg5V4gj PqAABkILnOBq
FwAogngrGnA1r7m1i3AhAkJ5AkvRAABHhGPFPkHlFuBdBdhbM0uGH6hMHhGS omjCiGhnBnoc
A4A6ElBHBFpQl/p3hYhaL1hSBSqjhVBTmdDQhDBEr7h2B2h1AABKhJCvjtq8 hehgCUBDBEGf
BcBZhlFqNxhCBDg8N+BgmPlGE+MugFrIlqCJL2q8hpBqISA2g4smhahYmuAH gHPPQMrDO+ts
jQkTkwP6kdDHA/BCKDwMhDhABJmVgzk6A3g1HfhqhrpABWBXhTgABYhUhgCa BGM2AKgKiqFc
IgCQL+HfoqsQA/o9ikxMwBBkmhBQhOBWgAANAMF2h+v0InAiAWvbA3sLokGm hjhlNOM1klBR
hPBXgAASAQgVEJCGhtBuE2AwAyApsEBSmdJJJpBBhDl+hoBpoSBbw1F5B8FP OCDnhCBEwrBh
hiJPBZBVmhBnhom6A5A8ElBcBXwogEgEMDgpAtghHPlkFlIrBHBDCkBuhvlF Azg3mwBdhZIu
nirckSDYopkaP7CJL5gAAigogbF9A1nfgqgnCsNwiHg3g8KVgEADsDhCA9Cb jZg7hALkAJqO
gAA9A4hCL2PtAdgkomhPhKHDgTARxgLAw6sqrdQ7KsQ4DOg6hAH0nbBeDijm i9xVq8vtoche
nvOEFmAggnrOA1pmgrgnFLSLHWg8GXAEgDlghDg9sli0iVqDihCiBHBAhMEO ywgAI3nvBUhO
hYjmABOAgBniyomXSBpAg/nkw7LXD6D8k0CHj0LnydNtLlu+jxSDkRLBjfLm jWrVkQkVQ5Ga
NvkUDPjUHxjISbkXkVTJtskKlWrJEvNJCITITMTFSeGKjew7kGC+kui0y5ni uCDkACgEE7gD
AEk7gBlpjEPWlPB9OeF5B7lmGFFPP0K8jwjwEDDzD8DaDGo2zTI+LCkfTUDH D9kxlVo+D7j7
rQm0O+TQIpTpEwyEPtznTVE/HxEHFAzUzEjAzMtKEdjSTGEXTGFJS+D1zntt u9jZzNzNP7T1
z7NtTHLAz5Tzzyi9zODXEuvAjHspi1hrhsk2AtB9E6BcgkJgAUgMsXBrhzhe i90L0M0NqdBc
HDhTADiLnQFkz8TTEPzPlXDDzyD4C/GECiBvhvn4hwBxJXB0B0KAyFi6g/BA s2Byp0iUhABB
pRANAOCzlpE7gMAMAMgAAQAPgQPIARmTABB/Mvw7T5zKEQhPhRCNwZiLxNik qxwughggmVA0
gzA3C3vRFRE5QFAwJqJCpDi0HWAkgmFRLftCBUhTMFzTkI0GUDD5FYDkBphq lwA3qMq+g0ox
grgrCsHll6z/u+TRUAQpHim1jphchdhbgABJhLliqwnEJEAxAwqVghAgsXAQ gQnsLlCG0aH4
hfhgNjhOhPCkIGIrMul0g2g0g5KdAiKerbJnEMS/TQjBvqHBmKheBZIMAEAF jlmmAlGTgkGx
gwguKVg5g9oxgLPGA6g2s2TB0A1LDQT6iGhaBdxeBMBOHkhaBWUOBMBPI9hV BWxF1Li1AyAw
klAtAolcjbBShWqnrTMUBXBR1PAuAzxkL2lPBUBOS3zzDdBuBvFFAwA2Gzhi BbhnzxgABMhQ
w/14oIg6g3MHgtgrlLBUhWnhBNhQyzhchWNOVhgpAvMJpagABKBGCkAQAQAQ s0g/CZxUUknF
mfHUi4Stk7hnhoPgAWAVgXAAR+qqg0gxrkBjhkk+SZgUCcAeM0KvgABbmtHC NoAABNBHNXDE
j5zzDBkMAEAMq8gTW3T3E0BtW5IFhzLSI0AA0trSA6A/U2UokhAUAS2sNUoF WXRHgJI7gAAo
Atqeg9g6sLhgxvoAhunN2xivikg+HfCgudlhBBI90XD1j+hLBOslhixRPghN HDi6yRPZhoBp
FwF70pgtAqisBxv/AABQBSKjgkAiAmAAA6g3r7jzRsjmDnL4TgkahrBspABh XIhlhmwo0HE4
AVR6BKBHKjyN0sj3hmhooug+hBQrIWCEAhAgM0A7A4s2AIgHqc1xTt2iLn28 j51zI3ktRtix
AJ37gABFBCBIERjaxnGfBwqhGuguqqgiQIShnig5g8PZp0p1gugsqqgfgex5 BiBjlHBQBRuk
KbuIBDhCHdgIAHvPAyNbgAJdK60zidgylKKZvwwKhImsHLAXv3A1Hn0CHyr3 hthvNaBIhJli
sA2N4DAjmyAprMDgCHhbhdCUBXhYG/gLpyJAhFX+TilqABmEuEDqNsLuNQBr E3gAW3ATplA9
I6Jbn6A3g3qNJNBJhJCN2uBjBjKmBRqngdgdqIguguFDKKuKg5A5oxiksBiz AlgmPqhbhbiU
BShSoDAbAbP2gw1TgAJ9Jwg8A8IFDZhFBFFixJiqP0jpgxgyV/CQBJhKikPs OU43r0BRFVY5
qIgtgu5P17o2TwCGhCBBMLzXwvY8gAAJX8B/jwsMTiRWDuK1iQDnDnjgK3JN SrB3B2lavilg
ozr2P0yTg/verQLRUtjzQnhZ3bhPKHGeCGATLhkSBtBsIsg/A9MHgwAwsmtE Pqm020320U54
ESDBC016BZT1VXzH1BD6v3g1AAB5raYqDnrcTOgBS5gAAGaEgALfrgZnmFFm JUo8A4A4mo24
VyX2Z4i3sQo6LGPgAsgtFLAaAayHik3sJxUkDSqtGsBgBf0OApAppgAuAusm jRDIhBhBLqL8
hAtLqBGAqKqLgtAtxkKQpEBUBThYCzhBBB6coSBDhDCSAVAUxX2uBLhMI9hb hcCUAqAqLMY7
KqpTiEA1A1qVnluKqOqPgmAlpia0mxl0NCjpgqyp5fAAAcAbuspNB3h3iXp7 NDgj1pg1g0vZ
6MVj0C7Ci4QesxiWpwg9A8Whi16EtrK3izt3mVA7A6L7gegdooik7KIS7Ls2 7NAABUBWHhBT
BToDaoomi2BrBrk4AygxElO3IlLWEvVBToi6r+MLxNhKBHmRjDqLCiOmlPBV hYL1hPBRqjuc
PN4qyCRhBuHNg1A5CCINLIVunUBkBmG6A+BBr7hcBWmdOZNlioA5A8vZhX0/ aFtBzBT+VKjS
i0jY2zLcjONwzYNkg+oE4vXAvG77gAXahvnHAfgbgAAsgrgvAAAkwAgsAvpi OXmuJMlI5eAA
Jjpkhghi0OB0h1B0s8BktOAWAVWmg9A5ML2uHewrStMDg8A5I6cKpPZRX+BW BSBaGDRVwBBl
mhNzHfhchXlHOZAyA2lLFSYwITHGm0WVvFRohoQhhFikD7CJQx8klvckiDH/ BahcS3hBg+iG
AcgbNICeApAtKegxgwA0gAAlP5izhxByJXAxg0mwATb9FflgikqABygAZMoH BFSzzpydXPzr
i9lgE7hshthrneA/nf7FCaBBibgV6pbRIhhShTlVaoxX7VhrhpgAbXn0gnOu Czh1h18NNNJP
dPcNBjBkoMcPWmg7cVDPhFBH0jB8l6CEvTGDVjIMoVXbpQAAU+8ZQ2OIZ3C9 BGSyl5ODneA9
pCDuK8tvgrgsMJgw8x6+v6dfjXGIP759xPhCpmhoPfxegR4wLzJSggAfs0Ac HBIFh7FuYjSG
AlOUBCBAmsAkgjGxjBODjrhOhPnkhPhRikBbBXtOHVizlliiAnApIog2g1F+ pFGmhZnDPghT
qHBUhSNpCJgzg2LMK6JeJoF2ikh7B7qLnM9CBTBRQPAKnT2neKm6oABIhGqn j8v8FvISA5A6
gzAAMjxHgHAGtrNJzHtKzOi/74CQBXhaHhBPBRSzhUBQVPOuOphbhXk+XkpA A4A6qVhWhS0O
A1A4isA9g7SVAYAW6SCQBCBFwrRN8sX+CkhC+xL4dYhCA/Ml4pjOmmKI7X02 AmgkwFbRqHBN
hPo9hdBZyBFqjxhshtE2FCGzhUBRPNpJANAAAyA1RkARAQmTXGnSEHBdhfS3 hCuaeaBT+bQ2
KdAn8BJLI9gMAKpKA7A+8yBBg/Gseo+Zm/E+BThWKnhwBxnvJundkFEVv8Vx kH0DrV0bn4gs
AyN9gUATImgFm7izhyBziPteUnhNBHnhBeBg1PBEhIixBKhGqHACABJECkgv A0olBBA9NQAX
gVp3gJAIgJ6M7CbDNKO8oxoGOKhPhL17S9gABQhSpQhFhICAIUAMldNcAOBx N0AFUxkoACkT
CsAAsFAwAReLuNzOIABgKhgAJ1IKkAAGMHxEnMAPh8vgAIw/JWMReUSp8y2X n+ZP9/zOLqBV
JgAJ9TpsAMBXMoAAIAgKfU+oT6e1GqVOTTOp1StVetV2uRev1STVmngGyViu 2mL2eMWGfW62
2Cu1a4VC4XeZ1+r24A3qS1G+2W82/ASazXG7X/EWKoVm61u84+1W3A5PH36S 2y2ZPOV/N4u1
6HFaO+yYBgOnAQCgQAAYEgbWgkDgACAYCgCez1+Pl9gB8vZ8gB9cAAPt9PwA P7lcmecmMc3c
c/o5uz1PrXPOVirdjs1Ht9HOd+1dTpU/od60eC/5/GWHK5D0+X5eTNd3u+e6 5L0fLAaL9Oyz
7/vMqr7MbAr9qlAzEvssieswwcFv0w0Bv4+6vQguDcwStMNPs/69sI70QMm9 kBLUq48GuOAA
F4fBcAAWwmilA4ACUWZXAAIgECQABEhSR65RpDcQyEsEHvi0UkvAtwjikH8i qeaxrGqABqym
AAoCeKIAALLsaFwWBgyDCjsyPCqogUBbZj0Pw7AAYhimGnwaBmGqXkUSIAHu ergqiep7HoAB
DESQQAGgaRmpeRBJoeFKJHieR4gALAtieAAUBOFIAEeRhLyGrT2Sg+EEmwbJ rAAQ5EkCAB4n
ieAAAYBgGgAMQvjMAAhiEI1PyRUdRQWqhvHAbYADkOw3AAGYZBoAA/j5VdYg clbiH03kiJmA
wDtuBDZAAeZ6nkABAkGP4AGaZxmAARxFEkAARA+ErusPXlfIwI4oCDURcleY Dkn8foAC6Mwr
yxGSFieLQADyQKVAsCwL2KNI7wvITDRMqJcF8WYAEwTqZFeUsXk+UyhFOVRS 1EMQvDKAAsik
L8lK0VRZFIABWlgVQAFUTxZYCNAqp8URLlXGhwnGbwAC4M+gGGW1EvAVJY5q UBTE4ABdleYQ
AH6feAAEAinB2I4Z3UQpLWSF87DIN4uAAFoWBfiI8OSfqemWaJjAAPRAjqAB blXrQBKZEjTb
AABLk7doMcWABemAXQADgNO+lKVRQgAIogCSAAcBoHUYF7npal0WIAEsRJO1 BIVQrEqYFA4k
wTdlX/aG12wAHoceAQoq/WQ72jQjsQEVhAD4QgAMelAAIQmh3Yo14mFYUBaA A2jvW5dlhORG
koRAAG2bps8ORpPp8P5Ebme58JcRRASBDkCKiS5P0YY5kmIABQkwkj1KgPoh k3C9F+Ltvwrx
egAAoBICpS3BOHE6owTgoRMgAY0Mc1oBzZsxLSAQAgAzaGrAAAODoABtDcGw QtSrAQsBhAAG
kMobSqQcg8AkBYCAADiHGOEAAnBQCab8LgWgABSieaIBoDAGzwvxPGYt1iUB vjhIUIYRaqwJ
gSAmqgQQjiqHKH8AANYcQyNbH6wAPweVCgcA2B4nwpxVijAAL8YMBwgg+CGp MKwXQADFGQ1o
UQpBPAACYEoJwAAnhMRmconohxFqFHAOEb6ihIAAAaAwB4ABxjlI4IQQ65QV gpBYAANwayVQ
aiURc1RrB6LgAAJsT0PhqDUGmcwnoQwghFAAFYKgWShihKMMkZcFgjhGc2FA JwVDuEYEmJVI
A1hrpUDmHFNwJASAmNEGkNkYSZiVEnD4phThjDIfwKMUgoAAA7B0D1pIWmYD 2HwPYAAcw6LI
gwbMS4lmrPrJcNAaAzgACaE2p4GYM1mBjDGGcAA2RskGEiJGLSsSLCLEXJGL h0wABsDXQYmY
kRJqeNPB4ZAxxigAFIKNy4Ogdg8AAFoLceHgPwNAWcP4ew8qwVibg5o9acAA Aqw4AA/B9nIj
GwAm5wSeRdJm4IpwBlswhNObSDgAB1jrHVTQixMx6VXWaIUQyNDzv9NAmeY5 UR6DyXCGYMUL
AXAvbiHIPDc0um3PcaIfVcwACNESIcAA0xpDSn6J6P4CwHLSlLS5XqwC1meY pV4qIqBViwib
S0tJ+h/mPFSKkUwAKPjIS5UopdTTSwMKcAepYCQFAJi2csflPlpzuC6GAMAA ASgmBOaOyBbi
2JmROYQQ4hBAAAGeM9RM8G5g9B+vkqRPR90/J8JARwiY8pxluFdhIVgrBbO6 IUQgfrfXAAAI
AQFWwWgtBgAAew9h6sBC60ABF6wACmFKjgmYhBCB9AAM67l3qtguvET4TgnG zi2FvEEJ4TkZ
hfC/GGDsHh8j6HuAASYk5IjDGImInhPXZWzESIhIC/2ABWCwFCMTAAmBLkHY FaVn6kAAjQB1
zgN3nIeRoxda5jxECLEGSse+DRBiBuchMmdEx/D/qMRgKAU3Nh0DncMHSTyZ hPyMAAOuSQAA
9yWAAVIrBTs2FezkPIdQ9pGJ8acp0RokAVAoBZ1WM0IKixkT6KShcc4NEKH/ HpjaugAjYzUV
4tEcCsFEK+mxZxtDdG09UOgagACjE3ZcC2ZyBjNs0H4QgfAAC1FWi+DhrBpj Wr4HQPYcgACs
FHoCSdgjImJXmmVa+YExlyL2VwpxTSnUdWaIdiYIwRLxDqHEPRrTbKbEnc4S 4mhKAAD4HZQo
gRD5fFwK1MVbwADBGJAcQ4j1ChTCc0AGQMFmCmFWzUCgEwKAADwG/ShWRjDM TkIcRghAACrF
A6UQwjre64XiF4LE2CMDJGZSEPohG5i3FYL+p0HteBrxUBvFgcw1tzKiJsUZ QhpDTGeAASQi
ihYVR6I/dw1xtKnCeEtGamFNBwDtwgQQfK8OdpQTMKYXQlvIC9QYJIRZBmKH GOQcAAAyBrjw
GMMFBgQghBIT5wRJgFJpAACcEhEj0FcMc7Qx7v6wlPlPGIlwWQupbBuDVz4b w2Nzyu5cVgrh
UMKDtdqz5M8xAAAyBjFmjSQDDGKv0RgkN3BQCbMYGQMVmWMZqBPcWUA4aUJn 3cgRNyXB8Dvj
czdjBRAAFEKV8oqRSsbAWrIzq6u8ErfWwoPG7iohaC4EwAAYAv0GCNzZAuPs YnvV+IURFMzj
D6XUIuCY/cgnFH0b04zuyrzdAAEkJwNwAB+D1VsIoRPTHgjGcgTooSZdlyyK 0U0BLaEXuT7Y
KAVghAADMGRZATglhWAALQW4rb2ioj+KYUQti4zWl0BcC5IAnBMmMZEpwAgB kmBUBQBiAAtE
hsDMDWYIAsI+AAt4Ty1czWIwGmGouCDuDQAA7MgOAaAakqYqXkMILw1Y1aKo G6HAhODIDUl0
DeDWpm/QFYJCEtBYxyUCCUCkpQDQDERWE2FCUYFuFgbyg6NgJmEMEY16JYJc ECD2i0Jm3ZCG
8/CNCQKgCgCwSeDKDChgCWCOaAFGFQKEZusuFgFSwoLYGyG2GoAADUbYvaFA /gAuAsA0AADC
DOxAv0BkAADiDY7UKg2kcgECgAZ0FGFyp0AoJADsD4oMBEBAmoAiAgiuHWHa HQoqDMb6CQCi
c+EeEOh8EoE0EWpSCsteB8BylssQMsP7AcsMQKHAHGIUC2DMxADQDGWQBIBE moqOcGIoVmBY
BNDmESEkXKFk/SRoCwCkC8eqDKTcQO9gK2seVEDyEKDevIHuncEgEKKMLSFW ZoAAEiEuEUjy
FuljFOIUCyDKkGDTFctgBEtnFmJNFqAABcBOWYK4D+EWb6HuJwEWD4UYKzHh HkJwEVHsQMFE
FYKME0+kTeFk4q7WQtGMO9GSLsza1Wd6MgRKsGsUQ5Iatw1Usk+zAbAcK5GO MUrjItI61OMv
IyLFJCQXIWQ+MHIaSC9cSKRBIeXqRIMsVCLCLOQnI4MC7ahkS4W0S4AQNgAG AMNYpsp6OOOF
HmOEHw9sH4H0YA90i6yCd+KzKmOmPqV6zvIlImNC1S+zIWQQtpK8P8QUMFKJ ImQaLQOoPEsi
MK1WP66oSGPodWQYshJktyiSKkxk6mLqOvBAiXL7KzKwPIq+xjK1LbJYQvIx L9KvMPJUsRMD
AcOqV5JbLsK3JWcIOeQEEiGkIMKiHwHmHeIGADBYHKAPD+Fq2wLUCWFaZ6A2 HyCOAABuH+mM
AQAaAiKoDgBgBRLosTMGiZKylIIuCUCq++SgqCSqGtDIoQfECcCcUsQm0ytA LUFqFcF86rMN
JJLCs+ACAKi6CqCuxA1oFKFGZyLMNY40Xq4m4qGeGiUSC+C6jCGSGUpCEGEK u0CwUoaSCyDF
N/MLN2KiGyG0IMEOEQt6EWEUSADoDsDiAAEoEkU8DiDkhgC0CyZgloV2sKMY rBIdP6M4vWNg
HeHiHY7cAxDaHqHmwarmN6GEGIX6GIGMTEHIHKHIJ8jQA4nKByB8AAB+B4Xy qUNusAtMHOHO
HMAAAiAe3GHyHu9tQxK2smpaCgCyIcJm+ejEyGK0FsFYgOEcErG0GAGGgOFI E6yyACH8NYDC
DUusDJDe+GeY1ari1UxgQGGUGgpCD8EGy+z8Y2GcGoGWUEEUUKSgCaCUUsDW DG1BL2KeF4GI
FuXUElE0FoFQgIDmD8hgC+C4hZNyTsXoMAKdR0CY+MFiFKgIAcAaWkGO3UAA DsD/QWF8Fggs
NWNuJmCiC8R4Dm7CAAB4BuSeEGEavouSN6ECDwucJmG2G+hODEDUYSGCFqUT IOdYJMGgGon4
saZrQISACuDCkGFUE6Z6GIGWTEGcGgUSDXBsJCZILWi6DIC20RP9SYK0AaA8 NYdlFlXaO6ds
0KHkHDSWoozSOlLDMqLQDuEE1ABAA8eODSDCWQDxYGAApwvOBSBOIkHsT2ne 4aU2EtG0fA0K
EqEWasJmECEVCWJck2EbOATJK2PkEyFA2KGQGWbyE+EqsuLSEoE4SAF8GCF4 AAZA/gomJmGk
Gs4qDSDgjCFSFAFgAAA2A0xZMjQ4K6AGAKg8DcDoVvRSAAEqEcKMQEJM/4Kc fUvOCSCiCI5k
oMC2juSJaZLHA4PHWeK0kaaQEQEaxuAkisAAznE0Kip+N6DcDnApKIEAD4q2 AwAsJAJnNWZy
F2F4ReB4B3RyC2CuZgGMGSTkFGFKnICQCMIckKRnCTbihuHC52t4uciq3GHE HIh0EPT+AABU
BUk+DaDQRXbYNCPYxStIhssYyywAiCViVmEQEKEYJCh6u2USCUCS9MCW+JU2 myEukiGuGwVO
DYDURWUwBUpsYADackJ8EnGwL+KcGQGSpCFIFK8iB0B0pRQmjwxyncDqDvQW qUNgEaEYUYMU
n0USE6E6h8BkBkbIDCDCZYGumadMEsUYArgIAAD6D9UAOeyElAlCJ8EeEgJk 7aGSGQbyFLPE
ABfIecCwCybbbVLnJkEED+voAXhIJ8quUCApgKp8OQ969sWqOCtSOQJnOgqU Nnfcg+NYHYqi
qphMqwD4EE9FaashL5LINFiIvWhsFkFa/UpIcuBKBOmoCrg2UvdWJ9ecVOFU FOyyG4duJmDs
D0pmBYBhADZPjLXrLqLUFMFQFdiJFHjciVMsLUkcIUnEZqIqIsNsNgxSJKza yEN0jGN8Hwwb
hIAUAACoCtAOYfjPJJjfkYKoruUKGgGen4DeDiDoAABynO82FgFcZyFQFOZq A8A8BAAAEWEa
XbJHCSEMt6t+USD80kbcBabivMvOC+DACwABiQ0SFEaJCAEPlYu4D/lgbebi JnQSWQHAHAke
DSDShgVzNe7YNQVhhLbclADe0QziTuTyBEBE6KDi4YAAHDc+/ADJAoCmCk/M RDOMfXSXGTJS
pbMnIyEUEYq2fUwapi9FMSJnnQ5imeYmB3RwJ9n4AADoDjn+B1RyGWGYs0k0 VWEYw0AABYBW
BcQNOMH6H4d3N7JjIYZjnjg+EOEa3dmy5Sq3TeMWGwG2VODkDyRWE8Es8iAw /qJ8GeGkn4D3
WCAAFAEyZq0agWGUGcGSu7PqAAFkFSFqS4qe02liDsD7kuFME67PESAkq9Mm zbo8P7niPfJu
LA1igaEFZCAABCA+BEhaDKRWxSyCOQCoC09MqGAAHYHaHW0qFVOq2gDKDcjw ToBtDoDTkvV+
1q16NsNmDqDcpmx+H+YACkC2CaAAC9P0h2FEKEE8EuZqAuAoAyJ8GSGabyD+ EK16FoFVZzOg
FWFiyyFwF3qOE6EojcJmnw2MEITdhiAAEgEObOaM52DODghZaugmk7ooJaOC COCiCAXE+SAA
Bsc8J8CuDAUtschZCsxBsOYACgCuR4kCxADVtyQSNyKmuThkQBjNL/OuLXLC dY6OAAEEEMbm
HoHmUCESEKXaGU36AAEGEM0oEYESJlmJoqH4i7OMDWDehYoDr2DcDS1Bu9vQ EO0pjyWLsKJ8
EcEkrxrcD0eFLKJns0bzPo0omey+CAB9bFK+L+EgEkq3CI3IDrgSKeC4C+Ut PcZYCICJsZkb
a1nfLXOwLYERH4N8JuWaD7d+NxI/MOJMRkecy6UKCCB+R4NConS9D+UGu0Es Ei8jYLrIKyGm
Gq4qDwD4hgEIEDZKBiBe+MFqFwRwFPaKpEE+Y2LkEYEeXLAgGgiEFCY2/4g9 I0OKuU40EWEe
u0GJRYysFIReAStJA+THyun4DqDy0QFO/fSLEVQziLvGMhA8LixlU6CaCmnR bm3GBqBmBweq
DObms+DADQRmvKvOjQjUEcEOKNKiJ8ESEc0pxMD+Dzx+Ix1f1iJwjLd+LgCk C0++6ADYRqCM
RmGsGxzgDeDoDG8lW4I6AuiQJmvss0DwD64Qj8iDARswEEEOJUhwh0v9BYLg EqE1G0FudI/O
FapCLMJMFcFoZqFwF0Y3VIkqC2hWbQByYUEB2CiMjUFo2aAAFmFUTEW0tN0m sJIP0hIzKxFI
a2H8OR2H3uCg/Kee17IUN0a6AAIqNmALJ6KiHmHmXCB4CLACFPaMAABIA+tm T3X3FLkd4Ro3
xCKeD2ENQXfSrqEGgmLSFaFosuEkExE0GGFrzg90OQCGCi+MCiCY/MDoDWy+ x8OuJ6a5SsXE
EabmfWwaEQD3AYIwEB6o88wa2X60LkJ6DwEKRWHKHOHG0SEo/VN/X/5ZQ1Mp ITIbLUOi6mpa
QD5dg95cMPFDI+LuL5TdpMLf8B0p0fvFJf5dK8RHA4MlLzL7JX8FiH7yKqQc L+MrJuMCxSNO
cKg86uhEKcOhouOQH2WtKYqA914Yi6OhKoSSQ1LTMWO5MEQNFD8qSgLJFC9a PT7wPV4UP4Ob
9lkb8m+yPzZN9b91iEVFjbxt+QzXLP8MQKibxrLfkXMUPj+BJdeTLJ4K1ROs Owsetw6h+9Lv
0jo1LZMpdiPiQm6iIuEWGXzgE4DllwKiHUHSHSR6GIq2E+G+U8FmIAWCUAIJ BCaqFsADCITS
ADuPD0AAsFwvBYtBDIjlQADqNhfF5BIZFI5CAYJJpJKYu/5HLJETSuRJVIzG ZDGADxOQADwg
DwA/aAAHo83oADWazYAFyulzI5RF1kq15IZdKKfMwBV4LLq3IgDWgGBAEAHQ 6nGAHw+HyABA
HxKAH4+35WJVKHzdwAej6cgA2242gAmUungAGQuHZnXIJiqdWgA/65T8jIJN WlhUQAO80AA6
HBAACyWikAE6m1IAHg8XaADIZTAAEejUsAA+Hs/k6xjsXuotjLpWZCBgOBgA +30+wA53Q5wA
iEYgwA3W829/FxGIreeDmfMKGA0AAL4QA+ny+pTLN9wJR6erBAyHQtF3n8wA eT4dgAyGUx5G
tFUXYAGia5nAADgNg2woKg4ABPlIToAFOVZRgAVhTFiAAEgIBaCt49rgNzD6 VoKc52HI1g1C
8ABHEMSoABCEIPgAKIsiZDyQB0G4dgAPY5uhDqQGyb5qgAOI7DaABSE0VcCg +DKsn+AYAHqe
R7va3w4D4ho0jANwABOEgUpOlgkCqIIADeM46AAJAhxqbRumwAAzjiL4AFkU 8AAaBYHQCaxm
pwQA5wYSqNguCoMAATBPkkABvnEbgAESP9GMU3ynqIeQADoPykkmRZNAAAwC AQ1g3i2ABNEc
UQAFoXRXgAA9YzWIMakGRw+gAIwgCQAAbhjHSLMlG0bN8GwkBdYdkvaZJbmg rr2K7DjGWgkk
fvqQk1BA2wADMLw1gAYBiqmPxDIiCYIgmABBj6RAABYE6PkiTJGAAbhvMASZ E1AixBEW7i1H
wABDD4RbH2HaBNFC2ZkGWYzSEm06VGCYxegAPhBjwABVE/C4MgxJyuFyXpag AQ5GugXZZmIA
ACLDEVoWskQ2DoMoAAHlxIkUS7FpKyiCqAuYoCygYjCGJIADaM44Ja88RWVp 6RnAcRv0iRxC
AACQJXSQg/ESxqCEAQruHSdR0AALgsTrHAeouR183q6YACqKYsgAIAeCEABj mUYskFOUAACO
IqBicJYoIuRRHEKABwnEcIAEEPpDAACYJAoABxnJx5EEbxYVBSFajDMN9o4P pwAHUdh08gQo
/4MlhGEOSIAF+YWKlsW5ZgADGPryO4/Z8kZLExRhrmwa6jDTLoThPMLIH9M4 4jUi5IkfFqvr
GZJlYcUpTQmHQcx0LAri4AB7nueyHDzQVYgOABFkUSGDIIaJowITxPE2AAZB kGYABfC+Tcfk
AyOB1aWP6BAABCiGYKAuBwABwDgaoJAR7BSLCMEeJNmzNwADKGSfwU4pUJg5 B0DoAAVgsKna
g6YkQhBAvAAZDEi49IaAAAoBUCpcICHGPMXctcAy5kWAJENWCsgCgGOJEMAg AB2DrHWACGID
IZw1D0IAQLPDEvzhXFkkhXFzgQAAKkUwpgACjFCKEi7N0okWH8UE3pKQvhiJ uEIIoRUPLTjf
CtaxuGnCjFMKtakW1gyCK0P4uIABFPwAAA4BxPgEAJASyyIhJyslfMeZAmbQ AAD5LUUIeamR
9j7LWHEOh+AESni2zFEJdS6CLEQ4saA0ECA6B22wDwHkYyUIs+1wISAlloHw +kNQaCblpYC/
wGgAAihGaOO8d47gAAXImAAFYK1kCIEQIIAEsUCB8D5NoFgLFkD2nIAAMQYg tAAlOqQUIoBU
kXEOIiK83AAAjBGCQ0AWAugAGaM0ZYABcC5ZJLwTonEJxDOILoXRCYaDzXdN aXQhhDxXh8ok
wYAAIgQAiAAZwzp/iHES1cBtIwABDCEEYAAKXQAAHIOMcRJyTBPCaFGQSHC6 EsQ6VZnxJiuC
MEcIeYCVQ+B6m1HskIVQsBOSIHAOoAAdA4bYRapFSg5VMqdVCSSUQ2JoABSN PgXgtmvBOCUF
AAGyOrkvNEC6iGmNfJTKpap1REuKAAPKT4AA5huPwVo9ZBAHyNZYAVKIVQuG jBqDMGwAAtWE
cYOIcAABSiqQmOMcpZxPiWjQBUCh8RljPGUAAQIh3XCwFM7qJRaB9JVCuF8K oAA2BmSOEUIK
vCLm8McpaVcupB27trTaShXynmVACWMQgjFcS3M+GILgaJKlaGmNZAgcA7PT IsLEVAulQniD
mHspJPYwPSPw3tvoohUGEA2BlBdohGlduAbAS7BXasVOvPgSAiDZj9H49Aiw yxnDIAAIAQ4e
wACxFOU2045BzOPDOG8MQAAVAoBY/sF8yW9srAVhcAECHoCKEE/Idg7onhgD ROkNoaA4gABq
DEG6dhbKvFWLAjYbGlAACSEQJpFxBCKO5e0PIchAM2iJe0VArY0GXFaAANAZ Eug3BuDwuEoQ
ADmHOiYEgIwTxapqTOnixCCDeG+dQco5izg4Btk48IBV6jdGyTgPjpAshXn2 FMKE6SwljDWG
4MNXQGk+rAzUE4JkwtkbNWkiiTg8h9dIA8njSA0pqGSw2yAqBPgAA1egAAhB AQWIKJESgii0
ScJwHN10eYNljDQGxOp4TiB4Do65dDlxsDYSGCI7EUAGANAAJESa7S7sBDqH TH7PgvhgcOF0
LrNQiBDl+iC3mzLd1wJmIkRbwDylrD6HrT1fLfbbCgFUH5HNRAAB6DomRkpM GQLmGAMoVKHg
wnMF4hp5TzCbE8ozKRZxMiVFLhm/QtxciwAAKgVcaBQid4BJTKVjw0hsRSFA JwWAABQCaFYn
YDwJAAy8YADwHQQxFVJZQboAA1BtTqE0JQU3/hd3iPhKo3hwKQBkDCxJan0h WC2rwNgaT8BH
xssNYW0NtU7t7tu3oAiUB6ECl0ZYzb/B6DrNpu9tCCiPEs1ffwspzBfIaFgK WeT0iLEg64tS
VQ+h308RbsHYh89k7MSMKoXY7BiC89MJARaaEsegFEK4QAAA2Bpk4LgWQzQQ HDyGPwmXMDks
eKETiFwLAVScNUbCBA6B3uYG0NTGQjhDxuNAaQzNciVcWEUIZAwvhauocAcQ 5FIBlDW3WSAC
gACvFOxXo0SxXi032JoT0GuY2JEQIAShjx/U4Z6V63RdDKtNN/JYAE7vECtu smcNDGQeg4bz
KE82CKXpfBUdUeo9iihMCwD4AAmxIinAACQEOV0bFXMcAGQPRIth8EQmoe8w X3iANmV4lAVw
Wr9QSYTK9YYAWRP5D4T4VBnYVj6YOQNAPIAAHz7A4rKAcYcyl4FIEp0IiwQY R4iLsZgQPAR7
HED6DoZw/gvZyZXwHAAAYoZQYJdQR47gNYMhpYJoIblBYQkT+bLStrUit5ZT 5Zp4q6TCVUHo
6raD5UJT5JnroL5K4T48Jq2zZ75Bay9sJL5C3IpxD0IcJj45H7oDoampH5Ss La9i3K9rowsc
NQlAATowAEN4ysOB+YoAfon6/LDIoIfr4qS7vB0sMx17LB0qLAl0JCtJ04kD 40LUQkID+kQc
RyVkRQqkSkRsQY9A3yQMK75RD628SsRLc7LKLkH8RkSDZolUQ75kJsU0KjLA 9iPkUUT4rg9I
9L+ET8UkVcU8XMJ8SI3UQ0UyuMR5K0YEIT5sUp4MWMDoYIYYAALAKY0YlQeQ dqJ4VQbJRgYo
dpwAiwHYCY14KwE5LoBwCaHIlTIYVwAAPoICqMIjZ0LgrBag9B4IJ4LII6mr hw0Yy8c6QQWI
VIpsMcYiXSoxaKvsIcUwBIBR9y9oewepKoZQZi/wF4FoGKIp90M50qioSQSh goYwZBlYIAH5
MwO4Op4DlgtcYYf7+Mf8S0HwiwnjXA8g8x84tYMYMxU4QjHJSIRY6AMgMTwY GIF4GsCqIMTk
SUXESEJgrQaIaZAgQIQpXEN4sYKYKLdiZBEIZwZ5P4VgVwVTfglgP6ogAEiI GSLEsiLsIMXU
WCvsM5m4sYBYB6SIRoSBgoWYWzrAiwWQVAppPb2S/EO6PyNAUbSQAAOANgvg JAISX440O5ZK
VSnImYAQAokwLIMTlAJoJIJ4AALYKo14CwDTi5p44wuYdgc4d46oege4eI0A MLlEnR2YFQE4
FsPS/SLYXIYAWifkrAvIODUYlAawbYaRM4O56a84xAcodBEwP4PA6AHgGxMw f8PoAiwRRIUC
DQUwVRVZAwDzfkO4SQRQTCjAB0cguhcg/ALQKyfYFIEhZAyAlgY4ZsGIXAXY hLC72QNwM5QQ
e8hhpAPIM4AD3pCYBIAz2UVkssHjLIHIJUicZKLYYwWsBEUL48eMWI3QPYQw /AD4Doz4MoLp
6YfQfhgIJIKgIaRawAWIUwW82QAASQTYRxuA6gSQQ5nYiwQgRp4D/JgIQgPR r1AwrCIAuAfo
5AUAU4TgAC/gZIAEjR/QsYsaJA4hYIsYAAKQLiX62Ro4NAMIpId4eM0oQIRL AQDCtYhwOB4E
9jjDl7whqgIQH6OwkQeIeQeCRYBpPi/YZ9I4PIP5QQNIMpI4KgJ7iAp41NOA dwdwdhFwEAEY
n6/BjQV4jYTYUBnYRIQa9YGwGQHMldAtA0VNBYi4cIcZqjsCoACRdC0APioF TAgoZoaKz4UA
URB9URdIKQJ61ococpExkQhKSCSIQYP5dplrNBhhhwUwVBVYIwIhXgJgJJw5 ngRgSCoAcSly
/4PZq5rJdKyil4Ran6lIFD79PRI5njaEujrAeoeoooEoEjK4BKVAXwYIqYbA bZONcwExpANT
E584esdAQLAQ8gtYFFbbcQHb81N01ICkcYAAEwEzK4TATT4YbAbJ5ANIM5I7 P6stMqUgpIiw
R4RiDS9rR6/wU4VA04HIHCEwK4KqdL/JKoPIPaptJpSIRFFoiwaQaRZwT4UF IgGIGMsbYzPK
9oSgSh+QbobpSFailIFR0LWJ5AdqJpxFZiDZKIZYZS/wVCEIAAHCEhuSFFTc RQ3inAlwQyFz
WyKQiyGgoqG6HIuIuYtJKtH1HyISIi06U6SM6KJaJqJ6KKKYooO4Pp4CFlCS mwrVv0d8JYkw
CwChy4dQdJ1YYAX4XwAAbVhoi9hDK4IAIJvIc4c4cw+oO4/AkQLoMDPIIIIg mVrUVBg0HY9U
QS3QxgUIUYVNrtU4usgTnwmadZvQY0ZgZYZhP6rxUI4aSsNi4cPy2qS1MqNs O9lAAAeIeNOC
w8iYHIHjvkO0lh08L8i160TogoRgRRyYaIaAZ46oCF8NJAS1IiNQ5IcxEwSI SC9YcIcKx4iz
M4AFz5moIAIAmR+Bq6egPQPbH4FiiCch9IMgMh8t2p/CMgiwRQRV/KWQAF0S lAYwYxvqcle7
RSMAPIPA7gEIECfD4p6AWgWjgAWQWbgA+ZTK9qlT74KIKDdgGAF5/16V2oYJ 20/wT9Il5VOA
iyBxDYIV0Js6sMYsXRqDoIxwRwSBrx85KoPYPDYJYMXwi4K4LSmgOANxNQHJ HOJ4LeKQN5NR
HDJy9oe4fNe6RKoAaYak4FuLUo1gMDwYHoHbb8Y798XL+l6ogjsBdsjhvo34 QgPqoAFqiAYQ
Y4X70J2aAY5C+bd7Bt/giITgSrSYCtgoZgZ6f4QYRKK4VoUjgAAqIkOSyAVY 076TI4BYBRDY
UATBiMlSVkx2IK3kgqSq3ySwQ4RzH4zoz4LwLAm91Q8GTRgQRp1y+IAAVwUo hIAyI4AAagbB
Z1UAAAdyZ4AAGIF0sYJgJSpQQb4IAAJoI8zA1whoiwaobM4APAP6poOINZQQ IQHylEJqztI4
QQRBXAV4UtFCIZKK04Z4aj0AV4WTI+TTNAJ4JimgYgYwYQAAcrKa0APCoEth BgU5/QWAWcc7
5YKwKLiEhle4WoXM24PoOyK4GAFssYa4bYah96+oAAex9AAAOQNgO7FAGUFo AoA6JYUAUlIg
VwWMrgAYARKL4oljMiEwOINsCI9uJ0R2OgmYaoa4aJkoRR1zXtEgnweAeE0r ZJXgNwNaps0O
Vx8wfChwREnQAGMupNdKSOnJKIMgMJ6YHxvAAAa+b4AEuJdqZyaAF+aAAAJY JTG4QyeQAAJQ
JCpQMgMAhoSQSxempoOoOJXAr0OAeYetOAQYQp4AbVd9pwAAnqjYQ0DyGwCo ioSYSrT2poOg
OVvi3oMAMblALoLYm6kwgcYL98Xl2MswrtbDH9fZHYPBdsZCQYp4KYLBvIOZ LAzIHNEcQqmA
gh1JEwQQQzAQdAdFzN6Q69eQPgPKbSv6HNMs+JC4VRCU/wTbI4p9uZAIaaf4 RoR5yeqCaGYg
4gnijYRIQo2d8Li48Np4ZhlaDBxeCd35/YGMoIPoPJr2TgUoVB/QVoV6d+UR DdVpC+VcdyPa
nUJ0KUU4rTF6NATwUU74UO7giQCg74iwXQXzrCDKoASIRZ/QEwEjCI9IRoSS K5gBHYOtUwgv
FPFbUFlfF4kBtJXgMDlRwIIkzD5x2ohISASRdouQ5DKrK4MYMB6bQ50gT4TR V6zRRCJCJYXA
XjgAS4TMEjDSHQ5GvkzANYMxNSBA9Yk2hQK4L0etfp0IQAPC9ceJqQ6gNIN6 fen5jMw6mmIO
VUSW1z+SN6Pg9glCI4sZhL4YVQVyMl80556AHYHDvgPYORq434ej8QAAJ4LR M3LA04EYED90
s+OXTz5NTQ6oP4RY/Gkx9Opb4YlQV4Wyd4SlFgAAXwWCz4iwAYAwkwTU6iMP Q2yfRIAAHgHB
MwPwORyZD4QoSBf7UAQgO5elGfY6swdY5mnCJYbIbga2rRKoKbiZIgM+lYfo fU2cSfUPB8RM
JMWEduVEXsXBDseHTuOMd12e3F1ER8LGVeVsRj50LkVve3dEovduJt6fT7/3 d/fi392EYXgk
gG4d65EK9r5ffDba4I9bc6TCBETDvHiZnlv0WkQkX5aEQMSMUHeO2CFkZCTH fslfjcSqPEQM
TXf0omXPkEWfcSLflMLPkXg3nEVCuEWstHcm1kW/TsTMQHk6O/hcYwymovcn dkgJqCPEKUJE
Vq3j+cW10ggoPQWohIMG0g6saQdRKSu+HNOSRYCY+I34UAUBB4Q2aVS+3EpG OA6vj43YkFKW
1aLfHLBoUAUYwiQXQwhMiynHh8o0VXdcXwlmthIYQFHI7o74JwJg0YGIGCZL RQn15U1IZ4aD
0AWIWkc6lql4D4EAz4SwShUB9A5BZMQ+ofeAlIMwNKfenBKIo5LptauoeQov o8IMI8SfkveI
rWUaSIbYbxOJ3hRFwoiou48wi1lodZ1QsgdJswEr9uks/VMo3/lvCHmxS0OA CIChPnvLSYT9
VoAAWGYQi4Z4aRP9LpXAMoMU/sZydIeYeNe/T0xvhPPJaqSwXAYB3XvIwggB JIhMAACgwAhE
IAMJhkNh0PiERAAPCAQACbUCXABhLhkABQJBViUjkgGA4FACNSqIABDHpIAA qE4rAAEAgDAA
HBQGADfcDeAAcDQcAD/fsLfT7fkRnQHAFJfAAdrtdlBDYeAD3er5AD+fr+kg ApT7ADsd7oAA
dDQgAD9fb9hoFAs4AoGAlFhL5er6ACLSiFABYKhatIYENFf7/sMIxWKxcRx0 QhcIHZNGmPzG
ZsLDWTJhuRiWNkeTzWkhJ9RB4AAfDtsMZbNAAAOTbLfawABAHBGrDOHhiUTq QADcbzbACQQq
VhqFR6AAD4fNRQR4Q940OghyVTqRACtWKpsIe1oAT6VUuMhWTc7rcoAN52Nc 1Ad3d7wdwAFo
sF4AQZ96q5qcyJVleU4AFgWhWAAUpOlahrSEU5AAGKZBhgABcLqkdyqigJgp AANw0jksR9KW
hhrGyar3DsNKJgcix/RgrJ8HsAAvi2MIAC8LAxKepKHscybsR/ICFuwxx/oW 2b0SEhkmIY0y
HHEcZwAARhIkSAAJS0ABADywDQgAkyUGAYZfQMWZXAAe01tlNoQhCEQADALw xyyCAKKLGJkm
YY4AFMVJRgAIwhpgJYkCchpGklLEpHCAA/j0QYAAiCIJgAchynHKpIOqFIUB UAA0DG+MntNJ
MoAAVJWwKYZimExDsS0CQABcFr9iYJdEJuniDAEAB1HYtBQFCToAHLY6un+s ACgIlApikkQc
BuHYAE0ThLAAbJsmwAAzjMNQABMEoUVgAA6DsN6GkZCDZAEhZlmYzxUFQ84c BwHQACqKgsqy
e57gAPg+jvMIDp4QxDEYhLFGmaZogAUNiAAGAYBkAAti4L6GnQdBzAATJMWw eeRAAB2S1CNL
4kURTqoYRJEkcgoBpwZhls8VJUlMAAbhuHIACoKors1J+hLCxWVsBC4Foaem mAACgKgqAB66
apKyK8uCSAFmQAWYu4GAaBqynWdYAAZs2l6aOo9D4vEnaJt7RJJtyHASBDdg dr8wgMlDSH1H
x5HoeeuLqABtGwa4AD2PDVIgNY33SGIZhmyG5bfyyRk8UJTbny6SVRzqGQu3 ZHkaR9JglSwE
gUBQAZknDI2U7AA3dNqFn5281HsegAH5vwADqOw7AAcx0HT0DSzaxfPoVhUs 0pvSeeWh8YMU
dR1qqhgDpPkmwRlf57ntf4JgnPE1xpNd/giiu9JQeB4HiAB8nyvlegBqFLOs dVgIaRZGMANE
aIz1Hh/EIABaQOAADuHefcCbqAADycAj0vhDAGIYAUAt1jTB5EJIWAmDzuV/ j4Og8khsHjdt
maUfUd5BSDgPRcc+EbIndtEelBwkbc3lpKIgRQBxsklDwHe/Ah0NSEgWAung eQ8XdwiKiQwC
8R4HxKhhE0hJNycANbwWIfZfHzAAfGngeo8x6xTR+aMsMRCJRoIjDxghPDJP JMdEB+A+46AA
dUbskxPGmOCAeA0iw9h6o0j82EeA7R4FtH6XB7RPAGx9KkOodrbSGgLAa0pG BYItlkH4W8h6
QY3kRMmlCNSSZOw2eYQwBwEWwj+H4WBqa/4SEPAYA5pT2iUDtHXCsxJYI8x2 AWbuDSFgFAMf
iPcvg/R/lkXcTgfQ+CyHoAK9sB0jnAo0HwPcrhEJFgAkbMSXEhzEnYm2AgBJ PDIzXKiF8M5h
AcrTAAGILYZiGtfdYV8pZciUSsMUbMhcYoNgHAIbtvxS0xAAguAksqGjcAFd ZHREqSph0Imi
Xd6w6gAAWAoBZ3krYHwRSadaWLx2FOcMeAZvbJAHzEes8YqZVQNlDNwAehDI oxzhIazJX0WG
lFJK5F0Cj5AATVhgVybcF5gNTQsAlpR0ZjzJIK7N+MzqUNhdmQseI8HBEkdd SiYke2Yq+grI
Qd7gh+SJZJFmqoAH3VZpC08CLUh6PfHvFRobb5Q0hQc56vBnzEkTpSQpXw8a xyleTKQhgFQL
VvHoPKMdcy+GmNAYom0VwHtKghCtZpKAFVKAAPOxlG2sEJFUK0UQABqjWYcI EPrMIhk5AQSi
ehUiqUGgubicgALBO7kuQ03RPIKm7evRZLSeDEkLiS7s0gCwGUIH8UYp8Wy2 j7SS5yHJj3pW
GsJXmUzzILlOdUU4+zgpElgIZOQnlynWDyHhGOh1ICGRYdY8keY8UaXvAdfE yd876kPAkBSH
sgCozXL4ZG8zeicDys8AACAD63prK5fCtQ7rxFfIbgXArY3jPjaiUYxTUyo0 2lOQl1DYR+1l
ijfshCzScEVmJK+YsE3a3ZMzDq7drUoUklAkqpRu1mq+HSOt4wFwKgXkRh0e UsLrO0AgBNsI
8x33sxNJ+M91ozGaSZLO/BCL9RpIRB670vwADvHZBtUpCAEAKN2XXHw6i0AX AsBkoo/MOjzy
QQtr9CHkj1yPD4hAhhIh+OfM0lIgxKW4ydHaD4BAAkoK1E1JzcUwWtr2Q5IW ONJuXlFGfR92
nm0iy5jNztd9O6ZxpXWw0aLsSgg4qi6rn9U4hMxGqU918p111trXVbyJPawr 03AiDsq+42lK
aSfZ1tN7BdhX3ZOkKPno0okNt2m73Rl2bBzS21dP6d1hpbbmxNnnX2xtNy2s tfbfr5uY9Grz
MOc2vrfGuv9PbOaLrLb24XkOdSZsnd7Qm3XV1BpJy+zMqaehxvzfcREnb+16 0UiQcGb7x4gQ
gSAWQrcR0zvviCRiHhVC+E3eIhxBiLAAHkPodd4irFILPHOvN0ba0jmXeFHy lFcE2J4jQwBg
C9jSkFtwPgfBBAA4sPaai9ltyjuXXG9tQY0SEGgNYYAABtDYHAAAOQcLUqvD Pgeqt3byePxf
mNyqESbKW/Ivlpxpk1LkuEEi5JtrNLu7rFC5d8bv7A8qM5k1KkWF2L4XIAAa AtgQ9mcpYh/l
cAhKnMI7IhbB0vwDT25MzALJQHkP/JhrjZNvxExbc36gVaelUQQk3BxuMjvX WJCQDAJJQwwa
XbAU7yV860g71Fy7s1WQsgxC7x8t5XV8rtHOW60G2OFbgKARk0xKXDhBn+ve cIQD4J4N/oae
GALAY3z9ppC9QaPWRkQF33K7hTRrze4ENxKiVNtESCgEV8PSKR1pKOsSQQj+ EY+lEkx2bjwq
TUhPeh5LBiID5icAFAGqECfCgGkmnAJqNIwoxvbLygEinJyLwB3MyCHgBC7g AB1h2qLI6CyA
OgOAOkwgCCnJAEaPHIqlmCcvWFjFMoJC0gOisABgAi7nwMPnKP8vqtqGhPzp ppiPbIFohDHp
yDdsCh3oFraGlJ8K4F/nbv1CEDdCnOxDnq5uiMkCEI2QCLcIgpECwCbC7ppm wwQLOh4nBIdJ
+IWFfF3EoKlKECvi4HrmyQ1AMALgMItClpAkaCvCwP6nBiUL0Koiol/H0gJK 3wcIyJGmwwmr
PHBG/JniEnyFZiGCqD7ryjckLIKqoiuGmIxvdlJgJq3qbCpoVnsntmwJiOzL Oh5utLJO1oKn
WB4oksFAIK3oZK/IexKh2pdK+m7CnGzHWDoCuRWv8P/NsweBGBEhDGymziGG mHdnVnWG/MBw
VMZklKTCeIumzJiRnmmg5A7g8wevfPoN2wdLtLIiwsFoehtltHEnFgAAjgkg kmLAvuoK5q6D
HxzNpOuPnNJBOBPBRt+ttPJOLIbsum6q1QlBWhXBXxmmwrJwvvxrQiED5i7n 6ixrOoIAAAug
tjCNFinJEyKOktON7sqsZOuteSCmhgBiDw1SRNMPHiIhHBHDqoABoOgg7g+g AAVgVAWw1pES
RySiHH6iGLdyVobKcNnLduYuWSUtQySOvpYnPtrt6EmlTvdHaQ+uXPoNUSkS kNRtQQ2l2iFy
tq8SwPvSsCukYvISUNblTJQDQNXLCNSobNyOBPtPnH6ymCEl3FfKbMQPnSBy 3spCEKVgABbB
dhaSeAUCaC5CeBghiEzBhhjhgiLhJhPlJgHH8QMy6jED0ygS+NzSlKyryNtP TklH6ivw/RrN
8weHKnLSlTVMKSmR0kwQ1K0yzNeyWlfTaiEGtS/tlRrNPSii8S2K8McHpTky ZO8LtJRxxr3O
EthvcqQsbzhx/QMnaD0PbQyhhBiOdANAMgNgABRBShNgAAeAdgfgAFDAqIhn pH6vHTrudiFm
ZSyryKbN/DZw2DJwIyTy20AMqNRSnyoMqtKzXmhKoCEicEYShHLylTfNVSVt 6zPNXQ/uMR+q
8oiS0HlHaS9kYz5zoUES4PfUNuAyDsqu7x+w0iDnYvtOL0BiGBEBKDnDoCoh AA5iWTtNkUQt
nxzUAy8o00fyonltLLIT3wdzsPUyuS2tUSTS5tRFTLsULtm0VISUSIat1K7y rNxSS0st/0NS
wUo0EzmUMUlISHZNsG5q+0TOXEjtwzhnYJJNKU3xyEluYy8U3U7UzOX0ukf0 ON10UPtONNjS
DOM0RPttnPTyhzYRz0lyhkmNdu6rCR90ESnPO0mU/OkUgUizp0gHKUhtn1AU wSYuBt2klVAH
OBthuhsuIVRqPgSgRgTyu0SRy1HC8ArgwgoN4hPhNDzgwgzAtt4hUhRBYkHU YzqP/NINoudo
ykmSIqMlZhtx2gABfBfudBmBmhliyh2GyAKPQgaAZgagAAhAhAhgAASgS1Zh 2B1D7nb0HEwV
QyuuYEhBwhxhuFaAWAYLcKsVNUAzn0gq7SozbCEhnhohmgABDhGoCiGA8A5G 2AYgXnJmh081
/VG0VS0NaCHAIAJAHsIwMTQGuKTh9h8xIzC0yNxjMzgAAALgNFLPz1LHLPeh zhwqLMQVF09y
ZSI132LSm2fGiOCtqvu0yiFsVLo14OGUD2Yt4WCOGWgUz04VSUTxkNWJQ2rT lG2rmqQTAU12
oR9UkymwuKbUG2e1ItqQ1WVjSPepduWNXKoW0i8W1zW1b1G1LV5WL1MiIWVl lCwLm272e2pz
qTeHWmtylSXqzLdzAC8WeU5WhVExQM+TdUfWlxkU90jCJTSMKDrTPW62LVmS kRzBihhzLBlB
khkCIww2QuCDFQoCIgal7AAAdAegfWA1BMrXbTXqSDsMF2PV2HjAOAPCsB0H rO6XKWwOXjSB
MhOBQ2u2h1H0qvqw7MiFMhxAABTuHiKCLAmglglgAAfAegeKQBdBdBdgABYh YhZHeMSgAAyA
xkeJZ3eh2xL2BOFzm0+X71Lsp1Xj01JKRJSBbhcX0hwhwBvgAAnAnEPANKYN 4tWUy0CXjXnq
92cLs4J0M1ASC022vvOWNUyX90ktT37VPt0uDWTtJVkYHu7Ug0Y0oYNW84XT C06we4G2UCE3
5CqhZBcSHBxBxEqJAoxgOANwSAtgsAu2WAJs4WeYM0sNLtlzsXG2vWf4VMrW /3A363PXa4HY
IXKz/4oYs4S36YT1D1NLsW0TU1UE22/TPiutjPcCSHbiyBOBPvSByhzByXvA eugAiAhAlE2w
NuFNhYvX8t1W21GYuNcjIYw5DUJYtqQYPNOU85B1MVH1mYXnPYZpTYK4Qy3M Y4UK9YT1O0A2
zZFYq1AuYYRXoZNU+4IyTZOUM5W5AM+EDBchVixHemfAlVhYsHKz5zB4GXAX 84rXcUyti4Wt
YyqtJ39y5z3lTmhzPWmnmZL23ZFzmUv4XXOZXYOUMZstW2pN3ZEki26tgNq2 lVRN2VCVB1Ey
8zXU6Zztzv84Y5V26WnZijM51vfY25dTlyoZ7WmZ5XN4mZhVESnSwUfzpZf3 7YqXb5VPn5q3
a2cMb36ZC4o6A5gPqgA5yVa6KuuaDZmnQZ2y7Z6vIVU4u1S5s5SZ+iGAQASi iYHHOBzBxHjA
NAPMiUCXnCEhwBuj2t00t5YsQ1l030foatrqDxmnWJt2VrdxVmmHzh6wsuDa EypDNQgIooZ5
4ZN5O3/OCCJHVKEBpBqoBCGAWgVgYis6mnm6bWy5FUrYOyo5R6JYaUC1S4tZ 72n625S5/U5u
t0maIZg5FU0vmx+aQ1J2c3ayqXJ5d67KRUqaBq6yxmtSsicRQDRLdytzVk80 75xx/aC5SZKY
xTmZetsscS5Xj7CZK5JWY6P674vuW15U0rAT6mtmuiaibZY2eXW3WvbDRZ+Y XUh1K5GPHqSZ
QaBYIWKweVK5M5Xa8bVaD1HaEtr6oEHZyDZG3AGmzh6B6qa0e3O55nLMcBLh MhPbN5qWvyBu
FG5gMQ7Fw1YkRiyBwBw3qhzniobQRANAAE3i2CGBqhrluB2X5bhsuWM636sc B0NZT6r7gX8L
piHRUu1C7nAr2I66FZE8BX8TX0uDQ2M1Ryv8Ka+7unQaTbVvH7DaI6NSp6sa +VQki4/5qFUE
gcOOMa1s+bitv6g7/1DDJyWwCgFqEWjT9ujClpAF/r2yUjSci2rofFfIdUeD Gq+w/Y1bM7Ca
DboWfcpuMN258Iacba9afZN5M5wZVYPUOS4ZHaJ0wzfklP3FfQa8kiEpkDFC v83zhNIcvte8
2Ju3CFfKmF+iuQI8Vy34MZRy69ASn8/ZA8CbE5Xt47kcD7t1N64cK8s5lUV9 DZD5Ya57k7Bd
H8s5/uByqNg8Rzka35r5oSSZB8jCFszinQ1HdanbMSZZKUjXQbQWY0i8QZK7 XZddIYTcS5U8
TZOWrYHyq4w6eDJdR9EYHWAMZdjUJdC8DSz8ibT1/U2NxUe5n9qVC2vTXDRb DN85n9rRj8Sb
eTsNX7O8PaF53dG8n1XbTcbbd2zyDvUZwcXK7Pua68y3+8tJOvm7uYSd+a3N zaL9Ma+99988
QvOXL5sYt7Ryh6GtoZu7fvq8p5L+IXLaSYS7fZTeKUAUKrC06KP8U5VZjx+9 F7ld2VLYPTAo
34M4N+D4sMGGwiGB4wL6Fdc8vct8Q8Y+BZA8w9acX9e9y8ablyY60byeS26c N9L9/WA8qt7L
qTYarVMV5I1bkVJc6OAK0ylXUi6i72xK+2eJMrQPxzWVlzBbSeLbWd+nj+pO I1CaR+ldo9ed
MyuemdNzP7RUVnaKti5C73UpSJEilr27cc5Uu7d7nyTeRehPIe76Ldb7mbFe 5dD9z+abS8qd
FfI90dGXAe6e09c+zCEhKBLhN5IKR9ncreb4UZRN55U/F5p39a5eNaO+fcA6 +1F6hQeK7/Ef
YeWdjr3JR8yfM9Sa4/J154rdbX78a8T/LuWZnuEdl5trr7g/T8B0j0/fU909 dfpZi618jczy
sw2SXHaUXbKEY40tkTT6A+Fwd7ncytTe02//N6o54xza+d/zC1X5Imi96xyd TiaiAAIBAACw
KCQYAAEAgB+v5/AB9w2IP9/gB/RQAACMRmMwuOR+Px6QSORxWRyKEySQwmUS qWy6VRyXx2Ty
mYySZyybymRSadz+aSugUKYUOjRqZTaj0afUGmSCm0uiTSc1KY1WnVScVeuU mQVirVOw2OyV
mw1GeSSTWCdxuuz+Fx6sVW41uVyiezeK2il1Gm2uoV+2Ry+WWiYWvUO0TPB4 jA0PB0qv3e1U
ii5OWwqT3jJR63YmzZLE5qYXLDaCa6i7arV6DM5fJ7DY1vTayiya91zcXzcR /e5XH4XP5bH8
XfWrhyq/RnfyXmTvIzHHc+b57pXrsV7hYqf83qa3Twvp+PiW3o9+gdbQyWK+ flVJ/1jp6ej4
7C/LZ4b56n0W+xPo7LoKs6b3NsqyctrAEFLawT/uBBkFv+uqzuusjcsOoMCL g2SXLnArlv1B
zCPBCLjve/0Sq486MP2/kFJyvierisDvOM50BxvEzwvzA8eLFAsSQFDkRqOw cjR9CDaKQtCf
M9FsbKBJsnw3KDyu6skgP6ukiQA5MFNzLL5xAsrETKpboyezilIEhYCAKAgA AOBADTiBIDoI
AwCuYip8nyfQAHwex8AAfR9H2hh+H6iyLyW8sayvKcHucqMgRbNLqxxSMUyf C8DU9Kzr01Lk
RLHMdJyEwSFgGAaBgJVwAAJVagn8ftFH2fh+IYiR/oc4ifU6/r6wrFMXO5HT qvU+kmu5UUYq
fClRMTR9ir7Y9hU3LtUVBC8svpGj7VBa6bAiCgMr2xdRuZbqpQTdkF0opUzS w0VqU9NVrJ09
N6W1JF51JIt+0lHd2NJLyys1ZbIWI9d6pxCd+YBCkhxfFGG2VhieLnfeFxpD qjYemtu2Szkt
2BZ8r33aMqYxb19pFl7NVZVtY1hmiBIGhyH1xRVcVyhqKovTtfyTHUpgDk1s wFlV8PqwGKyj
g+oQbEKWsRdeN0wtLT6WuqFIWgqBgRmgDVkATNIih58VrQiJH7XiNaddN76X fOK3vTDX4S2y
X5A9O7tExuo3bd2HX1HMNqrMS7Xg7MmSHuNScHw2nqJvujtdp+r7xokAc1Eu +8Pyl0x61G/q
Tl7MSDSHQ5Y6lNcTC2LY5j+pRNz17NjyVwwd1C7Lx0HVM2/jTcl4Hadleiwe NezX8LiKO+Vw
DWMiv7gLc3b2QDK3q3S5NfrzcOkVG4fuO33dPuxxTwPjTXHL0mdpxPIjeYW2 OrUbCu6fllGA
2LJjt3RoZRw61KsAX+H1fg8GAzCiUv3SJAB2Lpn9wKgYWN0yQGOwWUk5cyi4 kIqdbu815BhH
zMRfEXk/bCW+IIcmxstb4H6rHJepdYzWVHOEg9BRf5UGuOfaYTKGEGX1LWcY 6w3zBkepbMM8
CET/WLPLSrBKJcTmJwHVO7UtpTYhOYRy4GH754HspdFDFEJyYEmKIxCx7UE3 9PnVNBqNcNib
NmIyqsgYBgDp0AUAwBIAAGAOAWAABACQENwIqPYeo9gAD0HiPUAA9h7D3Igo YhijCKLARYwJ
CEWoUv1OE6+EcWIwLEU4lYtkGXVsSRGe6GERnxQkNCzAhabFYADThHYkDOVd KKVqQ9oL+EuL
yk1AtM8H0KphlGWGVsxJhw1iqXt28pUvuxMC/c8TUlktNlDHFMiPIoK+fJKI 4pHiAoAvoE/w
DBQADIQAAbCwABocAHxEQA7IoAH7FwAC41CoYBY8AJBIZFI5JJZNJ5RKZVK5 ZLZdL5hMZlM5
pNZtN5xOZ1O55PZ9P6BQaFQ6JRaNR6RSaVS6ZTadT6hUalU6pVatV6xWa1W6 5Xa9X7BYbFY7
JZbNZ7RabVa7Zbbdb7hcblc7pdbtd7xeb1e75fb9f8BgcFg8JhcNh8RTFxi3 +GMcAATkYtGH
9lQA7cxEIkE84AIKAQA+dEAMq/sTp9RqdVq9Zrddr9hsdls9ptdtt9xud1u9 5vd9v+BweFw+
JxeNx+RyeVy+Zzedz+h0a6xOo/wj19Jln/2wB23+AHD4QAEPIAAJ5wA/PV0v Z7fd7/h8fl8/
p9ft9/x+f1+/5/f8/8AQDAUBwJAsDQPBEEwVBcGJ4Z8Hn+AUJJG0qRm5C4AA 1DQAH3DsGw/E
EQxFEcSRLE0TxRFMVRXFkWxdF8YRjGUZxpGsbRvHEcv+aMeH/CqRQq7wAG7I gAMcDDJn6nch
Q6fYAHedB0AAahaFqAB1GoagAH0eJ5JGAwHgeAALBYFYABYJglgACLHo8ArP IMn0mQ8d0ogA
apZllK5qmm0MupGA8wzGFYWAAFYmicAAJTaj7Pp/OcnHSdcpFsYRZgAbBvmq AB5HqeLuu4Bo
FgcAAVBFQolB9RILgrJE3Tg0EdVlWdaVrW1b1xXNdV3Xle19X9gWDYVh2JYt jWPZC9QeZ8fO
07khQrIhuzGCwLSW7jRHyABrF6XwAGgUBQgAjwCIUCYKTWDYM1gAB3HKc4AH mismgAGAwC/U
ohiEAAD37dibSFbIAGyX5egAa5T3EBQDgNMYMyQCANg8kCDHgcpxyuc94Hsf FtBSLN8BOIIh
35f1HYBbDRl+ZBeAAUpbFAAAEAZN4KA3dALAqC8kgAdJ1XgdpzHdDh7SULYl jCAAghwImSgP
f9k6jqWp6ogAAgUDgkFg0HhEJhULhkNh0PiERiUTikVi0XjEZjUbjkdj0fkE hkUjkklk0nlE
GfoAczbawAeoLEAAEoaBspnE5nU7gb9eYAlzgAEyFQAmwDnlJpVLpkKn1Aaz kAAPEgmAAWBN
IpsNeDia4Ac4EDgAFM2rdntErlsvmMzms3tFxuVzul1u13u9Pl1SqlWrFavG BwWDwmFw2HxG
JxWLxmNx2PyGRyWTymVy2XzGZzWbnbMzz/0D/AD+0mj0sEbupq4WC0dfevAD XXq+ADPTSbAA
QBAIAA6DgaAAzJBGAAdL5cAABAdIcSiUgAZy2XIAYricoAeD4e4AGJmMtkIZ CAAF8kZ177AD
aX68oCkTIAEAWBnBGIiAAfIBFAAYIpWgQBKQdJeFWABwF86ZnGcbgAG+dR6J oLgzgAEwgiI8
byow84AF+ZD2FAWJMAACIPAWAAWhuEYACKGwlgAJAZCmmB8p+WZlFMABiGgY AAGwZqpHgcbt
jCJ40AAIIcQs8gCs5JkmydJ8oSjKUpypKsrSvLEsy1LaTnMY5VAATRhAMAAz DiKCjTJLk1s0
fAAFoIwnAASQ0EoABdCkqyBO2Y5PEk2ISiyAAxB6D02JQeBqFqABIFYeAADG PQtuLNSSnwbY
ADSJw1gAIxKleAAohLEtDpyfRxAAUhClOAARjOOIAByDVKsifBtUyJw2RUSh XABPL5o7U9U1
XVtX1jWaJu2WQ0ieAE7V0WJLzkBKcnGXxPABRYggANAhBChaV0U3BWGoCVID i/wO1oxU3ThO
U6TtPE9ABPk/UBQVCUMxxzGZMBMmkDIADxQgAWpJh+0eYZUFDVJQ0Wb6CBCH QADeNIzAAJYY
OAwZ74gUpJYYAofYuK1ZMxYVVVZV1YVlda6T4UpNAAYR2IE3iDHwfB3gADgd DGAAth6DqNVt
XFdCLXlfBM+d+X9gGBYJg0tnpiBVEqSwAE4XpooKEIXxaMo6jSAAaAtMkvTA UZlHOAGboOA4
AAyD6rBcHQcgAFCsIPes/muEotUHoSDY6AGP4YfOfcDodS8ZxvHcfyHI8lyf Kcry3L8xzLKN
CAGczcaPQPSbVbnz0rkgCAKS84A/WQmEyrBf2O2t30/UoIZPcH+0h/ABznd9 60AAG94bVtaj
h2HMc0NjwPQAAm0opAam4QAgBwAAYGQYAAA4rCo/6kHyVZWgAehmGbAp3niA BXHmn52gEAUj
EQQwAAoDWNoudpzOuZ5DjsTQChSAbgtAqAABwGICgJBK9oBoNAmH/fi+VRY9 xtDOAAPEc46w
ADJGmOooA7CVgxDyIp5wGgNkZHMOg64fxKB1euB0pALAgsBAsBWAoKANAxAA DcEKFh7D6QeM
YbouECjqGwAAdo7n1DWGAOh8g4yViBDYIsowGITuaixFmLUW4uRdi9F+MEYY xOaHMMARCkBE
j1AAJYWAgwAAhbhGOORGh9AAGCH5ZovQfCdAAIIIj+I6i/Das0VwR2ZCTCY4 uOZBB6RHEGFV
WAxgABAjWLAO8b44klH68oRYTGfgyE6qAIYGm3SLIUPkcYAA+BQYuD4TQsFO gdkyZGTYABEy
eOCJ1Xsf2pEblRKqVgAJXSwCNLIicdRjiLWaIIegeQACxECD4ADLiRvqFgEk LAAB2CMTAGQF
ZcCED3GyAAPYUg4HQIGFsQpzwuAyAmY2Osd48x7j7H8gcgZBvrkMACREii0D xHA1wYo1jtg7
CODgqZgCBjmF+HxSAippCtFucQBSTR8RHDaFFrAVBJh9AADuK4uRKBeWcbSc goRaAAB4BahR
cY6jAEos0RKi2yBxPeIMIy+jLS/lXK2V8sZZl1peH2mQAUWhqBqB8grpR5Ii BaEkAAQwTrmI
zLWW7PwZy6ABLwllDaH0RomACiqWX1CxDXNkTA3gagAD8JMNp9x9oLFKHIQQ AAXCZfGEcD1F
YyxnDGIkYKRguM/BSAcfIABwjSOeLUZZBg0CPFQAAJ4KAHz3AAMAN0hAmsyE kEWRSDxdyPAA
I4YyLRSi+hcBIfJ25TWttda+2FsbZWztpbW21tzKOeAALy3gAB3W/AAEq4Vd gXAuKGAtEpyy
kOodTcx2pBXOEEd+78et1QADSuwtkWqiwJXdq2ERCxu5SgAGPeV3Rpbpmlc4 akboAAL3vI6M
05wAEBHsDABCyoInbAIOWAAYYBACAAGWAxUjqAAAyHog8IA/CVj4H6Ssbw/j RCgHg+oC94Dg
heOQRgaoqRPgAH6NI2gUwhKGAOA83gBQG0VAKBI1oBQNAoIEAF+I+xzFfH2O 2Dw+x5j2AAPk
eJ2xWi+VQAMFx4gVhXDCRkUwshQHUGoewHoYkUgNAibwAwB0yAPAVO8DYDkU j7H9Ycco8RvE
wHxU0fY+j0DzHem4YYnr2g7BYhYLQTgwW4z1nvPmfc/Z/0BoHQTlB0jDEZGh 1ImxXBzbjNTQ
cXo6jDEAFIAEemZCACE/gpAFAOwnASPkdwABxoOtadsXgjgqqMpMQKSmig6a NI/g/EF/QBj/
1CIwJtJAZCafHpmoJKB+j6jqAMA2jsQayuUZgAZ8wOAbXNqA646x6ErIcSvY RAti0tIJg8le
ySUj8eUICYMrhWAA0zeMjOy2ebOx+O7aO0yG6yAAcslYzhGLND8PWS4rg/g9 mmSgeI0gABMC
3k8TIuGsAbH4m4hA5xjsMDKIVAhBQehvAAKsO5+pemH0jpPSsrgAaY00/XTr BdQai1IXIcou
A/AADOnYACn66gfSWQUBYFCxgTAVYccw4oND8SaAM3gEwKQFAEPp9Q9Y6gAA aPsaoAAahGbG
FAPwnAABkBsBguY5xk9WDKIOWBBAgh4ZkHMHj+ClbW6XtkhO3N539ITurZuz 93AA2ltQu+kR
A6UF8EdMAlgnrfII6h+I/R8KPHWPC1hGNwch3GJrcu5yh84edzslnPgAdASw Po64lApISG8H
dAgognAXAAPsAKZAGAMoqPodzbNpHo0Loev7qRVDKioCEATqcAJLHcNBAgQw wRuIFpQTYsQx
NxAH3rvgPWZB/0yAAbIsn6BzE1JIRAsRkAABwAZmu8NH/h/F+P8n5fzfn/R+ nPqCYLDQ/cAA
NX8b3XwwBgH+oAP7vwfj/oht6XeO3B+QAvTjYB1QCuYhKhKgAAYQFsDgZAZC ChhwIrzneHfL
0DSnhszgMQNCOhjBAK6gNB1B0gAArgFKKnrCBBgB7I1Bdh7rWACDAHbQBAig ElqAgAFESqmi
BBUh7MfBzALutAdA/qPCMByBLg8I3gIrDgVgWmAgDgIFqMVG4ACAEjeABADm pHUsxsfB+B7r
DseE3B8vFAABqhpm2BwB4DeANg0BDiMhFBSKHACgMjtgZAkqlACADCkQXn4w XikACw7nesJA
AB9B/I6sHv/h+neB9h8ugBnBblUB+B0FqA7AuBCP1RLRLxMRMxNRNxOROknh 1BihHOrhEiBK
8A5G4gCiVhrBcMPg8BLBZCDgWgAAyhCFdAmgXKKhcBHKPBrAVOLA5AkEUiDI 6hlBRhAgABdg
FgrpyAnmAhZhIhIAABNhgBpiDAbtUhFg0nAKpttDAh4hupJBOg4ozkdiDAnA 3ozgvAhiilaB
9ChBOA6BSr3AsKEBxBEBIgADpjvsmgmmCxvuLhKFYBTBkiCAbgAAwAylDBmv tlMg/gumeNjC
FjthpBZlsA+BNjpyCgwBAAAA5ApQHuNo6hshglehKhGkbihCDA1BJBUkXAQM AhiBBEYhfAej
3g/IZiBjthjBKo3BngWEJA1gfqlRBR3x4meAuFthuhCIzyMiBAWk5BEA5qSA VAJF1hzhpIiB
KA+GsRqiDA3yWKogQGpSJyKpVSMCCgbyNyOyPmCiLh3BshegABGg6x8SuynN UhHg8nAARgGR
uiBByBghLv4BGhbgABDhSGsBiAuFsAlBWuWgOuaiLDthnBXTBBABQRyiBgjg qkYhcnxSOhMk
CAgAMqgy3y4y5y6iCAWy8S9FWy+iBR3GsyjAOAwD9B1hWxKhVy7AbjvhOg5A drrhPM8hIymp
JpVBMmxgbAMuNl6CpSKzBSMS7CBAQAjjvg7AxR+gOTmCISrysytgATpCByvy WghyxTYBwzZD
3gSg7KPAfztCwBjBRlnBrFDAxAbDtg4zviCAjg5k/gvgVNQhIgxyOSCTpgjg 1AAA+g0AkAAA
KjATYx4R5AOSkAASlSmTVSoSpAASqE1B+G2BBPPgASakCIZzSy4S5S6TwTVT WS9zXxBT0R4T
1T2AAT3ONzTUUTUzpggFtgBhgBf0KggJLhWzfjxiB0bzUUVCBzVgAS80Wy/C Ch1hlOrAxhVM
ZBaBIgeDRj0CDtQhZg4s8hNgUFYA7gIhiJbBSLGg/pQjg0HRhyi0JUKULR80 MAASoypyqycg
ASdxKhngRlmgWB1hYy5TdCBiZyNpnSPmAiBD0SYyZyaq2ScE909SeDayfgAS gyhiBqAJJBSB
NymTwtWNGBUg5Afl6UThLhKx8BkyUiCAgAtKHAzAsAbJphyS4gqA1R8CETqN GBEygjsBjBRT
DBnqlVe1Speh7znBPToBczwzqTrTsGeVj1JxKhrAURlgZB7D2BARp1CxZhCK PRboCiPQ9gBH
eB+HeCDAAoPBHgmgyG2g9FsA0gcAKCLB6ChBUBIg3AASBiCCZg1BESOAkSqC FB3ILA4S1AUg
+x8AZBnOLBbgTSbVIh+m2BUA/Q2BpgQlmg7AyAhipiCB7r2hOA7lYAAAsD3g yAdGAhzz4z5z
6z7gAT8msT9z+gAT/0A0BoN1C0D0E0F0G0H0YA6UZT2z3i8D0BihByZgeOrA +ggnjCIVkAAB
cBSmGRX0CiCgjk5hWFOAQABUP0Q0RkjTST4VghD1hpbVfGpWVz5BKBrDgAvA ZH1A6zLy0Aqw
jg2AumJrKzYB3CXhUhLkQhV1ViCggSvyOzyiDV7AAV8V9V+Vu1/2A2BiIh+I PBMApV3BbAsA
/gABUgtAZy2iHRQRRAyRSAABMBVRTpSCDADgHICh3hbnmgsBE0fg3hJzyAPs A2jyZgjsng4g
LBlAAAtA3GsAuBGKUg0ntIkB7V0RPXmXm3nXn3oXo3pXptBBTXrLiLjAe3tA AP+P7tktkv+P
+CGP/NjiVu3XztZBiX1AAHQGuAtX3iChgX5DQjRXyHfwMD9wNiOBjA5oXAeP dtzQqG2kAJbB
1oPB3DTsDLoDRAIH4AAA8obHOjSheh7DthijRDehGoqCMB8hPpzgSgUV6AOg TDWgDgIsWAFm
4ABAEMAkACkDRYMVzsQRFvTh6rDh8h3sfBxhtIPBthsGagDgwxoiMBAhSlYA VgevTASAZvTQ
/Q9gB1yYoiBjRMxDRVz1zREPM4ZBtBmQRBrhiInA/gt4h3qYy4zYz40Y041Y 1ouB1hjRogzY
NhLhVJzgMACk3BqhdkdgDgcWsAXutI7BMtKBChW13BQBXgoxBBfXNAzBJgIJ +WtGeDAPflQg
xxjg3BMFQAggHonBghgQRAZAl1ZgKB6OnhFAtIXB4AzhGgAA/gkD7DBB9ByB hQRg2hHmyAxH
6A9AsAaHOhrBbXgA4RogWgx5WBBAmZYB8m2BNAsUETCiBAwBAxogfASoTgJg EmdhRgomLtyk
YhKhXGfgOh6RqhGAvJL5aVShJBUJzpjCIhvBaRSA5hOugBFhVK6gVh+Ong/Z UH6g7GZAzgco
C53oz55SCAlA4IqAyAjAVnOh0GIB8AFOtAIgDiVhjBCD/SaTBA+Af5APTkca LpngdmsBF1I5
lEw5mgAZnyDhAwEghAMH1BPAznmkdnAJQtUgJB+ipBJgqK3h5A4QEhDAnFvh 2BtpUh9gJPTA
HACDRZ35455gAZ65758q2Z+AKZ/OXaAiI5ZZaAr5bXgBDVggyAaDeBZA9D/B IB9GxhTBAjiG
pB+h1rGgqAzH6AlBDRYA8gbmag4ghmsAwBVA9gAANzIiJhvBc54hMPtg7BKk wAgAOk3BehLK
6hGhcEFg4BLrI6OG4at5a5bgtawOr6xgAay6z601962OTZl6UaVAog9QEgog Nz0BBg1oSFMC
BARgpbAA/goIChUAvJz3MBCgABXgriiiBINBVZtgAFWNKbF13AQgCGIBOg7F OBWhuFBPID/U
2tq6daeAAafagahJtaivT6kIDaliBUPAAJH0EAeBKlWAg3Uh0hixog0BGLAi BQHhAhMpzgFB
rrIg6hIZgCCAwhDD3gegChoFBg6zBZiz5ZkFgaTZmZnCB5o6W6XgAaY6Z3gA AabAAAJRIAAB
CAqmxge7L0aAMbNZZ7Oav6w7Q7RlGbS61627071qVb3EjXUh9B0BjwRg0oSA gA0oqA5AogTg
ABxBfsng2BDle0aIXY6GJh/8Vau7O7P6xayazcYa1bTztzYAABkBGxlhfAfz 5A/gaD50tiCh
9Bw6uA4Zbg0hNhdXgAHpJAegrSOAYg0ISA/AjgSiDcI7VcKaWNzcL8MrL8N8 OlzD0BlBID/B
D77lQtXhPAoiihsBUQ2BFBbFMA4hJkbgfAOMA6LaMcSpVaOCB1GaQBY6RaoS cbN8piBAaPkh
Mg7E0GAlHhxh2HeANgMrKh0hoBdwxgDAXqtga6hhjj3gxA/nxg63aqVAQikB lBLHvBChbc+7
FJnAXgJHrAFr+AAB0Bfo3A0BbUshVaSUi7j7k7luYhVbnbocObpgAbq7rhWb sgB9FdGTDdHg
ZM8hKg4G7ht6YlGBgSHpQtKKqCUhtBbIqA7hNpJBBhUqUgWADc0CIINBSbkh Wgk7ABXA61Sh
1hej3gzhCoLBBBQRRAW29CBH1BXg5M8hRAKbABghIJKBdA3j9BcgeTBA99Sj kqKgGB4ZaAig
wbggXAs7ghAgrASGZhIxlhHhgGxhahhE0B9B2sfb5b6b7CB7879qxb/AAcAc BCB8CcDcEcFc
GBG8HARFgcaAq72cb74N0C5j0BjBCj/BFgOOLBCmTPMrDv8ICgTgTOtAB63l U65d4CaAAbFR
jggAQjeBxhvonAHgMwmh+oncRcScTbMr6dvludxAAdyFtzI+rFuesCBWscCl JgHhxEdg1hCl
sAXK/gABAgmCrBsBWtGA8hSIdBRBbFOAIB4ChB0h9ibgKalCB+K+L+Mn1+OO 7ePuXeRI++Sk
TeUCGABFqBzhcKPA1BLrGj7jiA7A1HvAcgTVxCD43Y4Y5Y6D97BiDAGgBipF NK3gRA6BJluA
dvTBjBI+6gDEWgcCALpagB+mlKgBJFkSAB0O17ACIRGJROKRWLReMRmNRuOR 2PR+QSGRSOSS
WTSeUSmVSuWS2XS+YTGZTOaTWbTecTmdTueT2fT+gUGhUOiUWjUekUmlS1Z0 0AEyoAAH1OLg
GrACrAGq1eLP+vROvP+NvCyABaWcAE21RNe21/v64ACwgC4P66XFvXkABi+S tmno+AAfgYC4
IHA0AAUCgYAIdzOUAO6vgECASwPx+AAJVc8hoNAB96EAMF5PLRvrMjNDISTv lTnYACoYBkAC
IV58DBAEgABgrGAID5bEgKKPy7P585l+vV9AB9PB7gBvtVzABqtBzgADllFS dEqw7gAXEENg
AUDMMYkB8QDAMBgAEgTCggB5axWJ8P3Mvd95l8n6foAH4fq7GwZjsmkYDqjw KpEqXB8IQjCU
JwpCsLQvDEMw1DcOQ7D0PxBEMRRHEifnWZBJgANJGIgSpTjaAALgKywJgyCy sHqdzIno6JtF
UKoADwVAegARZRjeAAWAccIACSJ45gAK5AE0AAqhYCQAG2XTWDyTQYgAVpeC iuR6MYDALAUA
B7HadoAHkfrmmCOorgAY4lIOPAegukLonKcR1oIjbMgGBjaA2CTdo8cJeEKA A5kwEIAFeY8k
Re: Menu Contributions [message #534757 is a reply to message #534567] Thu, 20 May 2010 05:09 Go to previous messageGo to next message
Hi Tom,
thank you, for taking the time.
pardon me please, but I cannot decode your attached image.
But I guess the screenshot is about editing the Application.e4xmi, which indeed works out fine.
Maybe we got each other wrong, since I mean adding menus to when editing _ModelComponent_ components.e4xmi
Are we talking at cross-purposes?
Sebastian
Re: Menu Contributions [message #535042 is a reply to message #534757] Fri, 21 May 2010 03:31 Go to previous messageGo to next message
This looks like a "bug" in the model editor (the Menus-item in the Tree
is not making any sense).
You should use the UI-Children and select
Menu/HandledMenuItem/DirectMenuItem in the DropDown.
Tom
Am 20.05.10 11:09, schrieb Sebastian:
> Hi Tom,
> Best regards,
> Sebastian
Re: Menu Contributions [message #535063 is a reply to message #535042] Fri, 21 May 2010 04:18 Go to previous message
Tom, I'm really sorry.
I did not realize the UI Children item, yet.
Looks like I've been "professionally blinkered" (betriebsblind).
Sebastian
Re: Menu Contributions [message #576224 is a reply to message #534370] Tue, 18 May 2010 17:47 Go to previous message
Am 18.05.10 23:18, schrieb Sebastian:
> Hello,
> currently I'm trying to contribute to menus.
> This is, having a "main menu" contribution in Application.e4xmi
> I'd like to contribute via ModelComponent in some plug-ins.
> This seems to be not possible, yet.
> Am I right or did I miss something?
Contributing to the main menu is possible your parent is the main menu
id and you simple contribute a Menu there.
Or did I get your request wrong?
> Secondly, I'm trying to hook a "main menu" contribution to only a
> special perspective, this is in Perspective1 I don't want to have a
> "main menu".
> The only way is to make it invisible?
I'm not sure about this but I guess we have no story for this yet.
> Thirdly, in eclipse 3.x it was easily possible to use the
> org.eclipse.ui.menus extension to define menuContributions, which could
> be accessed via a service.
> How is this to be designed to work in e4, since a menu might not be tied
> to a declared ui element/container?
Not sure what you are referring here. Please note that in e4 you can
always register a Event-handler like described in "Dynamically extending
the workbench model" where you get notified when the model is about to
be renderered and can adjust all things you want to adjust.
The same is true for perspective switches, .... .
Tom
Re: Menu Contributions [message #576243 is a reply to message #534370] Wed, 19 May 2010 08:59 Go to previous message
Sebastian wrote:
> Hello,
As Tom mentioned, this is possible today (or it should be).
> "main menu".
A visible expression can be attached to MenuItems and Menus (or it will
be, once I implement it :-) It's not there yet.
The same pattern that org.eclipse.ui.menus has will be available for
ModelComponents (parentId?before/after=siblingId). It's not there yet,
but I'm working on it.
I'm not sure what you are asking. The main menu and view menu are
rendered by the main rendering engine. There will be a service that
provide an equivalent function to partSite.registerContextMenu(*).
Later,
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Menu Contributions [message #576262 is a reply to message #534535] Wed, 19 May 2010 09:46 Go to previous message
Had a closer look on this today.
The Workbench Model Editor isn't supporting this feature for Model Component, yet - at least as of I20100514-0830.
So I give the XML way another try :)
>be, once I implement it :) It's not there yet.
Great.
This is awesome.
This is exactly what I mean. And, from my point of view, a very utilizing API.
Sebastian
Re: Menu Contributions [message #576275 is a reply to message #534544] Wed, 19 May 2010 09:58 Go to previous message
Which editor are you talking about? Mine (the none visual one) does have
the feature of creating a main menu by using the Context-Menu on the
Window entry in the tree.
Tom
Am 19.05.10 15:46, schrieb Sebastian:
>> will be, once I implement it :) It's not there yet.
> Great.
>> yet, but I'm working on it.
> This is awesome.
> utilizing API.
> Sebastian
Re: Menu Contributions [message #576293 is a reply to message #534551] Wed, 19 May 2010 10:14 Go to previous message
Hi Tom,
Yep, I'm talking on the non-visual one:
Button "Add..." doesn't work and context is not available
Sebastian
Re: Menu Contributions [message #576311 is a reply to message #534554] Wed, 19 May 2010 10:56 Go to previous message
--------------010204050804020600000309
Content-Type: text/plain; charset=UTF-8
Not sure which add you are referring too but because the Main-Menu is
not part of the children-feature I had to find another way to define it
(I'll probably add button also to set it some where in the form)
Here's a screenshot which shows that you can set a main-menu on a window.
Tom
Am 19.05.10 16:14, schrieb Sebastian:
> Hi Tom,
> Sebastian
Content-Type: image/tiff;
name="screen.tiff"
filename="screen.tiff"
TU0AKgAF4nKAONyOh/gCDQeEQmFQuGAAAw2IRGJROKRWLReDw+MQaNRuPRyE x2IyKMSSESaR
x+VQyHxqUQyCwuYw6VzWFS2KS+bTadTuJT2fT+gw2gSeDzOPTqi0OGv+lxOn 0qVAGSVWV0iF
TONViKVyP0CvTWwxux0yPWWNyaUP+0WaMgC2xOsVK3Qunzm4RW4yCLTi6ymQ zu726x4OoTS3
YOqRXDUm03XGz6O3u/5Wg1ahZXF0aISLKZmE5+8W/LYzESqy1iuS+6ZrA2e7 aXDQXMU2DaK8
yCtXyT4u/S6j0iY2zc6/Y7WZwXiUfO4nT12L1LWXbIxm/V++4/S8aa2Dtx/c XKzeGZeWxRC9
+Tn9y9efbaTQ8rzUPq+v0cWJZ/1a7v0P9vmzjQtirL8LI7qbv60zHNO4TKtU iMHpK+0EPWtT
roQrz5QxAUCqJAMBr+7ypwSnkPtvDbmQw+sKNQwDsow4a8sm0ESRq+EbP/Ds Jxs5r2w5AD7x
4o0VthBTgQhGjsNI8i2yImCmLDJzwR03kcos1cTRPHr3xbJidtFK0syoy8UR BJ8WyBFMaw1I
UuSCyLcQjBiQs3Mc3TEkc5OKtUkKYtb3zC6CnTbO8z0JNToUPRE7N5RVFxGh yXJwkkNOItjk
0ZGFEw88U10ci84owYhjGe2jdy0jNB04oivSlJT7lqWZZAATRMEsABWliWoA AJXq/qQpdXOO
nrFNbFljsCAK9sVCUh0lScBOU5c1SlC9XyS3tH1QziXrilDIpxNlG0Mmiiqf VsdzMw8b3Gjl
A1XKqUofU91ULZt1SPD86pYm9rW+w7VLamN9x/cS+LDgc9z7hcEPDg1gTS9i 4SjUE8OzdD7v
THzEXndbbt3Nkj3pfjSWNH7zqXYGO0gt9g3SlaRX/Bd2p1kdULBleT046duo 46afz5kjqX/h
FuZuxDiZrSNkX6u6W1C+s4QM0dMxdDq1xnjyqNrF9+sPoNlXbHbKYJbCzXzM uq5NmWK4ywFi
Xk7GTPyuDgaVNNv7RM1pyGmCuUtrrrJAloBAGAAB8KAABAFSh/Nufx+gAf3I LzGKaN2zaHgF
Ca2cdNmDS3l8EMHBts3hlq+ZjC2vZ/wejaFRrfXY2+2PYjuy9desr9fsSg3f hmIw6tDKYFLV
Mc/NTk7/qtt034CjZtpkueLAk3K3aLg7TMae4SvG9Z1DdMer8dtauny5uj3y 05z8lO/Lr3mt
1DnLfA8vh8FOmWb7FUUe72bM3SllPqcozxxX7reY4uNC7dmfLlgauM+Q/h/u ORO8d9rl38st
Sc/5T5jGYvPdg9J7TzXQNiKKf96LP1zr2Li/d2KaGpmmaDB1QDuoOMbgK+5i xV4SPxSm/Y47
cYROcPiyVihzSrHVVVB5A8LkKpBTnCB98OnRE3eiuR0sMW2nQiSgqHUWYet8 SLFImTRSktZi
rD6NSPnvr2Py/R4zdI5PBdCtuMRhIqRLjdHk2SDmdMYekl5jyMTUnuJlAViE F3RSEi0pCEsd
FmwtiAlAk6eoaLuhisQlzmyqObQxBNibnlLLTkBBV87untIZO+pdHZd3fv1W UmBLBBhgjDGY
bRJ61n0raRWsIhYfw+h6AAMMYQwQAAkBKCQAAmxOiiYnK9iSKJfRBZe1yIa6 ZrL8bCx508iz
4KTN9OErMo5TRXao71a6yZryKldNyB0dYRy7lRDiaMO5URtNzNNE0aI6mGJM jkpUHyWUCZ27
k+zBITvhlPI967oXqRkbhEU5jw3cF6YNAOXzOTZv1eY9CU8EH/r6nQiY8k/5 6oCUpF6bTX5I
TVntS856fF6HDbmoyXEiZzzqnyuYokM5+0EaOvNVr3J0G0p80Na8eqUS8m7F s7aD6azbPtGZ
2EbZs0hp4dJEDPacr4Ms7I9EYJ61HKPVeR9HKYTvq8zOgz8aTPna4vl2puVl oNrEo9CxLTFu
LAI4cAdfXFycIO5MgrkB+OSH9YeViJ6pHWdu2OCKBVlv7nTUyk8Jmy0CgZK1 pdPZ9oecyxKf
9EZ3z4oK/pkqJZKoEbJPVpLfmFR2eXFCi0pkyvigNROOK5GKxwKEeFIjw5VF yrefhwEqa1Hv
qvPOFluoaxkjS+xs8hlVsghWmCP1CnnIAb1UZA5mIczSuySGO9IYpt1LHKo0 TqkJtbp7Y+9z
8pyykcqlSMTeUBy6rRGkrss0/WdhgTmitkkdJRv9Dx+TI6gNMuxHN3a9yYVc q/WmlTbZX0Jt
jb11GCLWTxLFemta7LlswXTHe/VbT+P/MKr8+EKLeS4io2JU61kIyFXjGOhs XLmXmQCpXDts
KW3biniBwMvqz28svdSRjJ8G5BhEuKaD78iSYjwlafSU8p4UjXgFTNDzUWNP wn+a9i6nZYpH
HuSKd5LGEzBlFA95yFD6HyPkAA0hpDRAANkbA1wADfG8N0AA6x1DqUiQ8CgF QLAABCCIEYAA
TgoBQAAFoLgXgAAKAYA2BIMnBUCla4dT4BMbP7eVPq9BfjAGTjB8ZUbUNWKY M8ZwzQAB2DqH
KBolNcAABMCgFllcd3nn5OfAeI7+XgyfsTJMIcBLQcZXpjq0r5shbldOfDUq uxUrnsjN53yg
T+h3XPOCSWpYnqbdBwdPIEpZwW651eKMH5LQMnrHOymx22Pa9/MTE7tGhwHh atmWztYU3go0
/U7racB3ThVK8K2lN33LiLh5mdWcOzPA+jzB+K6iUQ9dp29dC0stEti/XHX0 Wrp7iszu655w
rR063g1voxohm9a2q+I+VNfT4VXA9057WtgTJ7MSlVvasydjGddOmaVThuy0 1ZjV3sQs1ebV
UbuYb7dDXuvYAq+gDr/X6vqGB+uR7DYdydir6b6oMvtrNdqO48spzF0VWnY1 WgXRGXVpoF7u
3ozw6mWqRrhQ42jfsqFQzwS0ymNXVSAACBAB/wODQaCweFQp/w2CQOEwd/Qe CxGLRCIxSFxu
GQ+NRyEQcAyCSQaRyCMySHSWPxyKx6BQmXyGNyeBzaYTeSgGcSyQzOcxCSym UT6fT2jSwAzK
kS6kwuT0Snx2pUmqwur0WaRCmzqvUmmz2T12hWUASOyT+p2es0+o0G1Ru2zW kWiFWORWecWO
yS+VzGYSmZQKu3ioUed1SfXPCVzESCeSasSwYj0UWuQKdPq8AFgwlGzZiBM5 jNin0C75Kv4e
W1qMQVfsFeABcLpaABrNdqAB4b0ABDgAAVCkWAAjkYlgAgj8iWcBSO2zaC2L J4zRaqkqpVqY
AFYqlqOWmO9fV0rx4CNvx+vwAMtmMkAMhksQANhstcAONyOIAPR6Hmg4GAYB oAA6DgPAAFAT
hUAAcBuHYABqGYbgAAgBgG1rrIJDTXOwxrJLI8SIrCm7IuolaqqI6inNS8kQ NDFx/vE1i4Q6
9ChrzFkcpbGbJx1GyWQ5FsdxdH7AMEhEhLlGsfRw67IsmuyTKQi6Krm60eyC py/rlJUYSUrq
ry468xS1JciRjIs1RG08mTdIclpTLKgy8wc1JUpaKTmoyGzrJ8jvOsCVJIt6 t0DN9BS21s7y
KnDGGuaxqgAYhhGCABpGiaAAQvDABU8AFPAEiiHH7UoAVKfoABcF4YAAHYeh /BIVQY1DCSpM
qrSKqUNGiZ5nAAXpdF0ABwG8byDhAEQRAAIYjCMAAXhiGLzz3JsaUMoclKyX hfGNOU/xuvdG
XGg5YlgVwAFUVJTgAQpDEKAAWhdaZ5noesgKnarILPRF9RLDzHxXa6FlcVpV AAcRxHCAAoig
KoABAEAQgAfmKvaZZkQrC4ABsGwcvC8ieLRE1+ShJKgT6tcpXIqGTJqtcNX9 b84ZLgAAEYSB
EgAJQjiY4QUhXG9CZZfmBxfbNbX3pTy3wx2XIEcxznMABRFOUAADSMY1AAB4 HAho0PSox+wN
UwyvMKw+XJsuy+LynqZxGmTBTGoqq0K0U55TpemXFDcboyokZKnK+mTPM2x6 KnUe7hbFFw+w
B0HSc9NgDUQKAoC1QafJzzLvf3E6Hw9sL7fhaFrdB+H2fQACgKAsLdNGj8dH K0r3xfQZAu8V
ZVa3e6FfnBbSqE2bdvbU9rmjxeVsiheWyG0Zfl8ROj43oxhoUOS8hWonGABQ FGSwADUM47AA
CIHgjonFZb6vC2vlebZqk3tb3vPQsbKWSKbKy/RhHqIWWK1Zo7l+DuH7P4eY QIVYsjuD7H46
sLIUgwPqRJAN3C1iskOS830niolQqbAEARUAAkME2H9CcAEJz2D/hQQ0iao0 iNmSS40xLIXm
w2eM/Aurm2SGrLq48kTAi9Oxfk9Z+L62iufSm4h+77lCEZdu9RR0QHHJ2eA7 9Q7oIMp0JpC8
oUXitkXJi3QszLk7P0LKVc6BTkZv7NcdI6yu0muMdmYmAERktJId/AJprvma FzeQ9d+ZMYlL
UUPG5XJi0jRojq2J+q+VCN9I+VlESdylvELg3duqfHZw6eOi12xoi2x6UMQm H7ZU0pQe0lgx
znXcxUKeDMICDFGCMEMJIAAdA9BuXGMsYakk4uwic2eLEgiBDpHUOgAAeg+h zAANMag0SOKc
VOqYjYLQWAvXaIQRgAALgWAwjyAKiVGBICUD4AAWQsBeAAF8LwZIiJGdhEou ySB6n/AAKcVQ
owACtFewcdo7R2PqIMBMCYFAABTCgFadIVguAAAWAsBjfoiN6oJEiJ0lZYKg X4c9WxPR/Nym
LIOBMFHRPMjuS5wk8nDQWTvGiUlL4mUunGRhRcVqTvZkUUdPZ02StmlUa+FN Qm8JCTqilwZI
R1DtHUAACoE3MzCIMPgfI+AADhHEN8AAGwNAbogApAiZFEUtnkScdQ6x0sUd TVsDIHI61jUa
rdNMck0w1pzJx9RUpNUkSaOkdMyoSKiAkBECamwBqijJSwkAtxcG3ai1M44S KtgcA6aIdg7B
1sIHGfyg1hQPgeBAm1xrYk7ObINSEgonxPicIOGAMAY4RqiGwNg/AxhjH0BK CUEwAAeA9nRR
dGrfY+ECGaMsZQABdi6FwACgVA5qGYZSyKaqqaD0IWbZIGYNQa1wKwn5zlZC QD6vEAASAjJu
jAF6bMgwCQFAKIOPcew9iDhACGEMAAbw6B0AAAYAwBzyMzj6kyxJohdC8GHg N9sF7gElF0Lk
W4ABJCSEgzUFgLQWgACEEK+wWJ1QpPWAAS4mBNAAFMKWfjKVZtBCcE80AOwe A8K+zGnbRzpO
8cSHUOgbwAK+GYU8JoTwpX3DgHWeJ5SyB2DrLwZgzLjiKEVhMGoNAcH9nwE0 JwRQAAIAQAk2
gtxfnoMKtWULay8v9SbIGsTAcFM2hlW9fYdw9ByUmMUYRLMtAIWALkYbiQeB BQoH0PIgAABI
CMEog4Owgg2AAH8PYggABGCJZKcmk5jZrgNJbBUug4AAGEMVSxJc7qTFyMc0 Q1TdTtDQF0AA
shUi1AABoDAGgAC/GGL4AAdQ+TOGOLwZYAAC6/pRS1fUPZiMDfydhkZIw4B4 a2M4aOPRaCpF
6+YCL6W6DXGybsK4YQngAGSL2aQBwDZ4b/RRxKY3gw0c6nnWYwzZhzl3t4X0 0tfgFjGRosUO
zJF+ishrf1F3tPQiXAWOkdJFDCGJrYTwn3wjfHAN2tR7L+b2E0JYUoAATAlM vdw6Mp9LTFbV
SeYuACQB/EDkSqg9wACIEOJVIEktLmYiE2E0QdA7hoAAMMYe071gJy4BkDFb gsBWgmFEJwV8
i1JiyQ/NoABUCpE+94UQlzaC117mSGvHpIWmTRSkwEBZITDeceUJYUgdM7CO aANj5COBlDZ0
gc45xyAAFmK0YpHBci7FkAATQnxIgAFcKbaYdg+tbHwPflQkhGNXrJcORhCx qDWV+FwMQTQA
C3FexkDQGbK9cexEyT3H6eSuip1hIiI+wSGwXjRURdhVCxn4HsQmmxXCiNmC sFALn/Q2kKoo
kAaQ6TsHrfFqglhWofgKJ8U3VBECR0ENsZVAz0YIJh6kgwcA+hmAAPfw4ABM iLxPaLS0FYiN
vnEaGmNSEp752S5pTqnyEUhQ2ROF29yXvLi2uBoj+yxyYcKimiGb4MMOo88+ QiSekbQ7HAMp
oiC96b4gvAALo9I2E3Ozc66/UvAjWRqlMiau6LioozMqGPOSrA2hm9EpgScQ 46ahglccA6Wr
oKFBcu5Am5m6UJbBClEUZA0TWo2+qXwZkiOxmmCkS5ELYJQkcKOp8/1AXAUW 1Aspm98j8Rsr
1AOniXE5hBsvAIYd2AACcHMvsGqH0GmJYBWAMwuFmA22m4E0qUG92MMxk9GI 0MYBuCG90RiI
cCQCK0MGKGQz2HeHeHc18AKAMNEGQGAGlCjDiKsX0mQcmDSDYDCAAHOHQcmB eVYAADcDazkB
YBWOKAIAKhEdSPYGoGqN2EkEmEcAAGiUyAAAwAy1kEwEo6iAsnAS+pKu+jwS KCcCgOa3Ev8C
cCayCC8C6tg/EKMYEjcZW/aZSNqFmAAEmEtFSoC+kIGQuVEB8B8CCAAB0ByQ gBAA+tCAcAaA
cIOHkHmQAHCHCq0GKGM7uGEGGGAumIOoMoQDYDQ03DyOSp2pwhwyMeAIcEkE uEavuDUv0ZPE
kck1e1iIO9ac0JGo86YQ2IK/kX64CJYHgHiHeawDktgP0YW9XFyIWAiAgfSF aFEwev5EIpG6
WSaHEHIYWA8A4A+PKHQHUcmH2dUAAA4A0QQulJWH6H8VTHSq02qAkfMAhKMl KpqHaHcoGpCI
m8QvkA+A4tDJCXIuGqJFxFtJAS0TnIguklUIS/ohSg0IGDODigmF6GCWGDuD eD4AADKC8a3C
MI2GuG0GsAACaCwywBqBiQoFME6XQIMDiDya2+45UEwEe6iS4SEGQGW7uFSF e4uGWGcPgsGs
KFiFMFyMevEdWD0ECmcF5LWN+Aea/EmamCmCe6QEKD8EUwCIiE6FEEyZuEkE MJYCSCM8sEaE
MEoKEHaHeoGCSCgCA4iAAAOAOzwsHKMDCC6DKAACqCkCy3M6ZCBChBSKQDcD m5xEmHLGMIWC
oCg6QCsCoPBKsOqZhK4kaJSFQFU4uGMGQ7ur8mUiXLgDGDSOUCCOaR+SEEME S0dFJEQDuDqD
2VUBcVaMwF8F+NmE4E6EwAAB/GyAADODMDXO9C5JYI4hOImC8C9OkIMFAFCO 4hIQwGAF+2mE
6E6xHGwViDKDNPvPSiOKAGytoAAFiYKABD/ECg+INJwH3HkVQIOmomo3qIkh QAiAksKCaCiN
ABMBQBTPRBnShK2I4EkEam6F2FwuWB8CBOIDaDe02YjKqIGHBTIAAEiEgEeU mGCUsCKCQslO
zINK4+pClA+JKFuFyGAjU9WjuX0EqEmwmF3UCtiaTBZPoxiJWKjKCawDUl4C MCO0lToX3Ac9
EI2D2Dyv0yWuOBiBkBmQKA6QQReVWWmVhG0rs9KJoDyDyDiYuyayeAABmBku 3M6AAFIFK6iA
JE+nbGIIfCUozDZACgRQxOtGOleK2TmZGrqZAD4D+DuuYoEAAD4D20Ed+OeJ G6ArcJsE+FEt
YCCB8CEAABCBABGIOB8CIY+0Y0cCICCyxCoRc+sUbWJVMIGDyD+yIHYHasyE AD2EClgg7J0A
usqMwGsGyUkDCDSC+AAFgFPGcAyAuAyqvJeNoF6weDKC6DPUHNOXSFeFSAAD MDA5wAUvZA7X
kbbUlUMbKbYL0VEDoD6DaAAF8GCF2ABPBOkEADyEO3vQ0PqG2UkCsC+CcAAG OF2U1JSjTTqi
4Q6SyJsHAHGq0FwF2NuDMC/QrR3DhZOjWZQcCLWE+FGxGBeBcBkAABiBeBpC fXdJWYBJ8iSj
cL/bbbQHw+6YcvsB6B5OID6D0EGU3FAuQF2FsQSBMwuAwAu1lbNB6o2T3DWs U0rB2I2EGEKD
wABbg5UEIEIlxPMelXhCxFuI4DyD4DYAAHcHcHaAADwDu0EGmGkGe8AFeFQA AG2G4GyaoE6F
g4wBJSfCqTajOd6OgKQNyU0GgGgPgC2Cy5wfilDB1AKIG7jO6FUFaFDY6DJV WAUAQvdcNesi
bBXCCdkECEOv0HKHNO6E2EndatOhQB8COwuXsQAGCFzDHHEAeIOEKEWDyAAv Yy4DkDYD8AAF
4GBGcPWVSCQCGNAVq8eJU/8IE1MU0C8DHaAdOGMABWvUpV+3YdA9Sc+h/WPA XLpCDXfRhUkM
iHSHWmUCaCynQXqHkn6FFZkBSBKaDXkMQgOrwI4DaDyDEAAviXuE6ElY4gQ/ aFEFUxGEOEeD
+AAGyGQsy+mzNbdWCI4DmEBPu+4vkEsEReek2cK3Sp9BqdxV63UhmkRDbH85 DLA4+g1iWic5
JC0ky5A6TZPjBcObARWLC9C7Ah261g6iK2K3wgGh5glAmercTH9SlAqhoeU3 +zKixgoK+h4q
CMCIctRkaZQLMjFV5BLgKknkFg9cKbpiwUAlG/zi2oxVOxsRRPOMYW0WrT0w CZLksRjUmi4u
9SmjtAsVwlQTUg4/HBNkxCWTcihbRV+jKhzes5DCJK1ToBMHBYeHICUtYJKA 4FsngG2BCcm5
pcLC2lBlBWHjzKwI2B0CKWmMwBgBiVaDKDKngwzW+GkGnDGYaNBSIMwGMF9d Ucfm2f9eSaES
yZSvxYuGaGc166GPBQED0YoH2ILJwPYC2C+CoAAFKFCFZEEhEAGAKJGEUEZZ w6e4vVgu2EgE
bNmc3Xbjdj06So0I4CiCkWeFGFFdaDcDea2wyCOAAC6C3EjGNCpGQ/KcrOKE QEXX4FsFw72J
eAooOAADZUY0eCMskAYAWQJf+mqIrIoJuo9GsQqQsP6HrhQFyuUAAEoEslxX vGoIECVNyAAD
uDnLfVwhEPHa07CidFEXaEW0EF1YmAAGMF6V+IMGQGU7uDkDzZcC4CvYQDQD JZcAIhIc0gRk
nTnUjAYIGEoE3TSFeFmFWAADmDgfKsOQxjTZGYGVKPYEGEO0EDoDhWaCqCYP BlIv+IUEmE3F
SBkBeu2B0BsB6AAG6G+G2AADgDy5wAmAkoQPUPZYyF6Fi1II2FcFmYOEkE0m 6BSBMaCHIHKP
4BuBo7OD4DpbzBkI2EwE+lwHMHRO6ANEGmWDlX4g+qoqsDEDWdeEiEPQcEgE xNdLjQqBCA/X
Gp7mJCeIcBGBrcJkyKM+hO6jwlYcTWrACJfIpkeIiDWDsngF4F/M2BgBaWmF SE8FiJYEgEuE
WxAE8EmY4QmaoExskIMFwF9GcYqPYCYCNgGI8SUFCFQtYrOmUHHueABuce6F cFHb9C0DkD1c
/JqamFIE7daoiomqwq1xjO6BkBbbLvsIEFCFOtYFoFvdpHs02I2AsAqnCBQB IOKMAHsHwXuG
aGiPgB/bq19VyEiErFSFKFQn4F+Fu1JndmrgnB4IUFaFjdaHiHkHgIOHeHhI 0GYGauPOOzwB
8B4ViKkBiBdU6Bh0SiCcHsS9VCLH6IeGUPevIEmm6Ab0zZmCm6QukGSGU1IQ c7OOXP0gwSEE
UEaXgGoGpDGxxcgBYmyoqIW4c4hUzXABDXGBoBm0UmFnpkIMnZ0DCDCoeIME 6E8n5RG5yGEy
+E8E6E2AAB8B/OIDCDHOdv4KdVmFOxMPqUhqnrQIHR7UHOQzwQt2+IKPUVSq qqtZ1zgIFSBS
aMuCuC21VaLi7lZlUVqGnFXWgDsfL2iViEKEQEQP68QAAvFR8IM4mAAAY58m WDvWaGGGEzqE
IETNcBbEspM/RSjjSKAJtygF73vAhj8LWGiGkU0EEEBf0hIhFX8tMeoVGILw HVhbCD4D9iIH
yH14Ro/ApbPFzkSAAD6D2fKGaGY16D2D7X5UcCSfkJPrb5wdXbTjYIMD2D1U wyY5WERtYBiu
2ulZCv8IivgqthecRlcffrWJy2Hev7USKD+EFfo8Q5UEaEVw2JLKCVS56zwd VR9KAVSJsCAC
MxgD8D00ECECBP0g2Tg3Ts1WL8XkQIW0bWb7hGeEWfCJLs46VLtLwDGDXEiF cFLdoAwAtYfS
Hu/ciHuHyJ1zAx6DaDpPuFuFcNmAgAbfhgrWFiZ9rau//UIp/IfsKDsD8l4G GGNHjSAFaFLb
8BWBSwv70AA1NDHZ88sGIFzdU3E3sosjEMHlMLT53GqsO18AMhE8P6hlYbNk nKUcPOEnQDPs
EdYCYYekAQ69Rl+NZCvbWQyf4euKIG0G2PwIAZDQWAAoU8qgAIhAJwBDYaBQ KAwA/H4/QA/o
xDo1G45HQDHYbH4+/5DDpJJZBKZLH4bJ5RGpdMI3LI7LkKhj0AHw+XwAEGgU fKqFGpFQ6NK5
pQqLQ5jDj2fjcAH0+XyAEejU4AAHWwAzGYxgAajaXwAdzmgAATyaVwAAgDIr eALfSQA/7tdb
vdpJe43d77cZABAJEgGBAEAJ4+7li6JdIdjqHjrpk46zWcyAAazgXgAuVoyg ADweEcfHJjkJ
VgJBkNRj6TdFquFYAEMiz8AGEuGmAMEBAA3W+2gAWDASou/oslUcogANxqPZ QUiyQQAdDgfQ
AOxuQgBEIljH2+otTZNKvJR5rHWs2GgADAZSiAFkq2GAAyGA5jPR+5XM6IkL zv+9DJNSxbWP
Iyj+QVBaPI+Ng6rICQJgmABaFwV4AFMTZZAAFASBYozUNa/S6o4pcSwC9KVD ePYyAAex7nqA
BNkeU7SsAj7DlGViskSSC0GuYx1PKux/LxIyWpal0TwE6pBDWAB7nwe4AEoQ 5PSS1MUpTBEB
NYmUSpBFIAy2vjVybG80vQvyPL6lMRvK/bztalkRTW/0TKVM8DJexk6tK1yZ pZJc/QbEk2zh
Q08UTBjX0PNqjwJPLJpo08US5ME9pnLdMMWk6Ty+kKWLckQBMOua+n8kiMSM jFVrvI0zLxLM
w0ulzz1lBia1zN83V1ONftNNFa0zXk2V280SzpR7/T+/lbzdW6YqbTlhpM1t qpqyFQTFPs8V
1bJ/0dYSmRVYFk3REL/U409s00yM90ZAFfxTTlt2YxlqWJYL93Hb1CwVMdO3 NPKGhQbr8l8H
IzqMIRjkyABsBIcmC3vctG3PSGNUBWkFB4JAZ10HeRgADQNAyACbkMABoGgZ 4ACiKApO6iFd
GGXZmY5XlM0BJmB3wjhiGMYAAD0Po6AAF4XBhGZMlAxB7sVY6Gi+Ma2FATpU pmw4AAQBIDAA
MgzLIaRpvaQxBka7IdB9XyhYFjtFKbnyOEqSyghaFumB8HrqCkKokgAVBSww dR2HOAAvi+LU
Zk0UiEhCEaj6nM6aUYpa4j+QI8AAXxgl0jYuC0zg1jSNrugJsDEoufsjHQdP EG4bptgAdx3n
cjYJAiCQABIEYTAADAL5QAQBo+A4DgKAB9n6fQAEqS5JgAUhSuYjQgh+IYAE EPhD328l3QKk
B7HrGQ/EKPIAGUZjMI0YZdGWjYCgMiRYlsVoAEORRCgAMQvBmf6FyADljVJK UyvJ8KjyWE7J
6FMLhxgwBeDGAALwWQxJxfAr1eShy6DmHQOUAASwphFemJxrQIgOvATEtVFI sBav4GUM8Y4A
BEB/KCeEfgAAlBWCAZkMwbwABUCgQQkA+R7GKI0NcbQ1XEhqCsZ0WAwXggVA wXItwAB+j8SM
PsfJ4yhDrHWOloohA5kFEwKgAAgREB7AAEMHoSAAA2BmDkAAgBEOcCGEAIgA Afg5hIOweEYg
whqcYKYTKGAGgMAaiFMq+1urlBMDcDq/JKFDGyMccSd11KCJetJWRfA3B4YY NUa5ux0DqHQA
AXosBivBeGSmHZ3CqE9A4BsDwABQCWjQRoAhESNj8H3DlOR5H5m+AC1wRYkX vDEGPFIVYoBZ
lGHO7AAARwpNtFWKMWIAATgjBUXgkiplSkNIokiTRGxRioSwMkZZYBMCSE+l xVREx+kWI0qQ
rRhosT1VmAAdLhwABGCYD8gomo0AwBcDJXsCW3SVbiQ0AwB5jRXI0NkbY2QA B8D+HYACEwKA
AEwJMrJIJgEWIpPZfi03xUOWI5RaywhSCnFCAAXQvBbgACaEsKAAAtBYC6rW Xphx9vMeWPqJ
Db6XEqEYI97w1Bqm7DoHJzgLAVguYyt4vhWyJS9IkchI0wIcrVUSuE9CrGwh kM4RoTQnGn1a
AAMMYcUhPieKyD0H1BAwBhgnSylaXSNjRGgM4AApxSCja6AgBBG6hmKl68oB gCwGHHSNPWlB
Da3KmMOPQeo9CJ1DZo8ojQ97RHDC5T8FwMQYrkXSwFBanBSihaeKwVLWhSio a0AoBwDpwIhL
iPYeQ8gABbCwWwKgVi2BacUv+hrBbVr1r4RwWQtRdKyTtc9SKg0tidE4xAXV 3S2lcLeRJVCm
10EuAHFe85hxTCmFKRMfxH1XXWUi0BfpDg/h9c4M0Zr8Q7B4D4ACu53F3kdH gO8eEuBPiaAA
NIaR7R4jxwOBcDDKAwhhYYDYGwOAAB9D4HUAF+n4iGEMIwAAMgYg0Re+QAAc g5unAQ8gAAkB
ICXI2JESOJBsDYGsAANIaHTi/GAL0AAxhjjENCA4B4AAyhlDTHEGsdCQCyFm hgZIySwDVGsN
QAADgGyLB8D47gZSBEpyJkZ6lMxyjlHGfYDAGgABhDAi4HANwdKIr4iNeUGx ACDv/aIewABE
iGEcroMwaQwv9PeAAHOdD9BDCTQQPgeA/gAexgIhw7dMAAEYJARWC2zAAAvh IAAcA2xlBeCw
F98k+IKLonMoQfRBk5z8AARwhhIq6HYO0dkNBHP8lJloDwHJbhKCOEvTQkhF gAFYKNDAGALR
VGaM9nIkRMFBE8JWmY5BzQgDqH0OQABzjoHMAAD4HQPlaMKAAT4ljmFbN8f+ Dak0+qhYAUhU
8x90ESDuICIDwoqi5ptuQDwIAACxFULknQ9yqjQGiy8KoXdjG5GaAAA0vQAD kHKOEAAoxUzx
GkNU9o8x6DzwADqHoagyFRAVyuGgjxCUdQk2EL+TZOsRG0NcAAihIP8EuI9L A0xrDRAAJES2
yRPiXFMbwwSWRijIGEAATInxKz+jCdkG50GT5uHEOSTIgg9veI0MEYovzOi8 FsADoHQgJgSo
+E4JTMwoBNCqRsOoe3TvrhmBLmMibdBo5SADOZ0FVEWE70cAAuBdTRVUkYKI Ti2BeC2i5OSY
YCqI8rzVY6n0ktzIc+XkgTgpncC+F2AAXfIznIbrodemud4LGlYLULKA4yhA AC4FlqS5EfHM
ObNYphU0zqd0IenIwAA8B1QTv3KgFALI2JcTetx9fRABVSqwnxRYKCcEwKYA AqhTcYPDCAAB
LbVAAM4aD8fh8kPvm4SIjxOgAAYAy3QhhExsHx/eIIUwtozE49IdQdKVIJ4K CJ4LILDQ4pJS
yl5Xpji65RilQAAPwQAOIxAnjQAQ4TA/R16EAK4LSOAOgOI7DuIggMIMr7YM 4MqIAZQZaVrg
AWhDIT6bbvQCp2odwdoqwSZlbaIZK74iQGwGjOoNoNQO7+D+QjYXIXaaIWoW 5/ASQR5p5bwZ
QZTIwSwTRtQc4c5igGYGIG4AAPIO5/jLgCCTjtAaiwQTBGgAAbgbijB5AA4A AHoHh7QKwKgz
gOiUTcAc6EAD4DwETfKXATibatylcQcBkQrebeQjQcoc7jQKILCPYTwS42YF gFRpgWYW4VYA
AXYX4WoAAa4bDLQLYK6CYMALbJodIdRxAJ4K6ggX4W5l4BIBD5gSYTARMCgq oOgN424jQSUW
gqQqiNoIJwMKjEh17cYKgKILiCgLRhiRwdYdhIYQgRRzipxl4D0PgAAJgJL7 YRQRw24WAVJo
h4Q/ImgZ4aJ+ISgTMWo4A4QC4CxlCIUZIKoKKn4jQPQQB04GIF4GwAAKwKIz gwAZAZY+oSAS
plYQIPTEgFAEwFYjYToUTqY3o9wLQNEQjOy5hNB8Ly4hyswSwTptQWIW42Yf 4jIK4KQzgMoL
x04vpUAj4WgXIVwAASYTTToWYVTsgHYIyqwUaQ5DoEZECh4uLeMQxb5i5n4h wOIPiABGBGQT
IRq9pQooow4UoVr94RQSQQQAAagYbcYjQ5CHISQTkWoWAWwhCswLIKQMAAAN AL4qJJoOwQh0
7+5KgSQQgrIlwRoSx/gfIqY5oGYHYAAS4T4oKU5xAI4ILYwPANwtAAxmrAby a5cBaDEoZPUB
S+ht5fBbiR61pRUipgBbZqY1jPApTy5RyAheJE0jRQMyo/syKBUi5jBdQyRL c1LVZjkjRcRI
iq4/hMhLTVk0Ax8lghqzDdAw4AQwa75rkjZ1qLCogioiyrwi5WBYAvxaCT5T CskosyCrAoyh
jVTzTVs3JniDI8038RBBsoRYpaJjLzSR01opgkZeE9o1c2c7qlk3BZ8zc7Bc EobzhM09Ex09
0QxOA1BdxnZBa6rzcy8zRjBf01ZBM3S+dBZEoKocQ4wa4fKJgkAXgHjQ4oYI gYieIkAFIA8h
gVoEDs5uM+s3ZEzV0/j1AlAH4JULiljLDLQatG5mBmSz5XQYAXEHcos+Eoko U+5ZISQSzEgV
4WA2YTASwrIFAEoFq3YkAMIMxxgTwTTpJRbfCiw3YNANKCZmIKgAANoNZpFC RnlFc1STYhzA
xIdLyCYNgNbb4SQSbZIQYQTToQQQi/4QoQYRB3oEib6LKYU7JAqDYygj5wyE DQrQ4PYPTSYI
QIB7QeoeRKixY+QWpDAWIWcmAcAcIb5XQEAD4EItIJpmbtw+IiA3wBYBoBRz oYIXYAAQgQ0r
ATQSxLAC4CbNxYSFkoQmkZxIYPYQSjgbSi4lIYAW4zBz1WLUKKoGwGoGqXAU j94S4TTqYUQT
KNADoDjc9XxyZjcyoaga4aQsIOSCamQ2YfgfJIz0iJ5flJ6b75561BAkgY4Z g+oOwPsCYXQW
BogfQfCHIB4B0MQmBAJbIMYN0ZIPQOY24EYD4hgYwZQ+oOgPx04Y4XY9of6e 0B4kCOxzgAaX
wPwOplckahhXiU7cYQYRa/4SoRaeIR4S9P4HIGkv74azgZYaAzBo4QaLCLSK wj4PwQ7DwIQH
gIwAAIAHZ7S5RedCE+VBQjYFIHTc7VShwawYtUBWtAk7hN02ifpYQN4PTJtZ rZUb7FcIS4IK
osgjQbAbbnAMINgLKHQIoJgAAbwcIbwAATwSdLIhwRwSsWr6IqoPEEE/FNAj QScpoAAYjpwA
AVITybYoYUVxzdQUgTY3AWwzCLScxZBTIWIWsmAW4XcFwTASBLA84UoVSeIZ IZiGYSQRTBS1
c14lJCybYQ4RkrFHozAAri1Bs9ilKvlAwjQ4AbiNIQy/5CZCgRwRDqah4jrL A3YVrgzi4cjN
bldVwFQFJEALIKyn6RKRZJMFQzAWAWZ/EOCHsWABIAAWwzyfaHIJ4Jg+LOcv 4UQUieIZwaJn
IEwEghgLgLIzgCgCcGdkwAF8Z/AWAWUmAFAE4FIAAOIN7D0xhsB8LB4eIAAV QVhGwbAbLHYe
Qea4ACoCgC0fgKoghpS1IRwSEWtG7LQOIODDwawayJgYwZDIyWqSYKgKQtgE AEFUgjQZYZYz
FTZDAGQGTFAKQKFMRGDP4QwRErAAyiIAFOKIAUIg1uob4boAAGgGkfYKoKgt gBIBV9IjQqZ5
x6g5gZ4Z7iYBOMCEIJgJoAAUWKojQTATRLCtwYoYjp4UAT794HiuxxIMCvdr Jc0/4jxfQhoV
4VohGNLiYiB5VS6Y4w63K3SyifYi2SojS84wk46tweQeK4BJMiNS4GAGZkIK AKdMVw12MzeV
WVQRQQlngaQaNcgVQWAWAqT6RBh5BsAKsAT2ppQAAOwPi/9rZelQuY4owV4W QW82aSlrszol
QPIOxpDrbNZ4q8TfBfgt4w+NcNzYIDaOoQZlcvZ5xOFFUixAZBYQIP4nIZwZ pnIMYMsimLbD
QjV3Z5QCwCwC4jb+4noNYNCC6MBIYDYDg/IJIJNugcIcFUAHIHIHiOLRgP4P y/K/ZlMaIAAG
AGDFDz0fgK4J6w99IVoVkFwkoPwPyjgyxnOHdUgvRKIe7P4dWmLimKAVQVKb eJ5sAYAYIXzn
OV9QAEoAAK4K1uIdGoojYKgKduIjQZDKyNLrzcgD7ggJwJqnYVQVaNGgTdQT i9rf1A65VFuQ
o9AQQQo25KRKgQ4QbEi+ohoI4Jg6maS/4IAHx7QmigQ6gPQO47AIAHo7iswM oNTQ4E4EwhgM
RqrgoWmW4WgWqaIVBHaw6xLyhXRZ2aC1RdQQAQqNmT+CoPoOwtDmoCA0VHel oMQNQsmNdVwO
INrb9S4RwSTEgbZ2eCwUA2cdqKoYoZLIwPRzaVQWSKR1oiwXMVoAARoSLZIR 4RLW7LqRYEgE
J4BHJZuys1FAZSEoJPwmk4pUw3hmoPIQAOCbgE4FBpIFzVIM4NaCYSYR5iDt xmYrw0D/TYwY
AWx+Lip5VcQ9oZIZosDSuXB5wNYOJhgO1sAAAIoIKOAWoXabYS4TgSmAgUym 54rd4lgR4SjT
qzS4AP0L9xQZCKQPIP6MoX4WgsEiKJTHYNAN6C4JgJQJxxILiC4aYadcgRgS NP9baW4TISMJ
4hwV0moAENrwAHDOoXIXSm4ToULBQWQVVWOMNVwcAcmLANQNyCYKAJ1MWuR7 R4WcCx63QTwU
MDDsTIWvA278GCtPS/4PIOoQI7IHKgky2QZgSApbBMJXFNBVASEHA+QWkmAJ QJCnYNKH4ADl
b5gkCswMgNNuOwWBmwoMrgtThCoWybYVIUZDixFV0TzLQZYZyGeuQ7ioZ5wN oOMigOYN59II
nAojY2o249aJlgTJILAKz/ewUhgCgCWEWv8ZIerFQPgPUrBk2cAbQbQbBpIF 7DWnDQARQ7Ab
IbLnGa77gKr77ApGYTfBiwpDnLFNd2Uyki+sJzSMsvYnoQ4QgSw/QT4UPcQU YUrBQToTJrQE
qb1o4IxplUVUgFrVAAAJOtr2oFjFEkYhqCRmZ+Z5QNQM+70vYquOgSQAGNcW QR6mYjWZRG3c
9ywVwVWngksNXYJ0xxgOoOQ7AFaqqGgRXNI++cAPgPNP4jR2SjDJiJ5vh7Wf 8Cb6J5wdsGoA
AFIFDVPIRDCpZ/gSARrBTvgAAEpD82u6Zfuyal5Zae684AHPiOgLoLJFwLQK iC5Hw24CwCuf
Y9Y3a843wQ4QPBgXHBDZQWJx4ToS0kQu4QAQxpEuSGgQN5ghwQAQ5pGDTLTd w4YKozj8B3AS
wTIoIVoUzsj9a3YLoMnFbld9IOYOCNlS4RYRzl4bYbjnAVoU+nnawbgbyjFK g+IJwJZmYLIK
8tIYjsYAHIrGgMwMO7wKwKYzgSwTbToayUp54Rxx4mjnQ24VwWSNANgM7DwL wK/RYjUZB7QP
YOtngGoGEv5Ql5s8zehX41oS4TzQYXgYKm4QAPR7z8Ad4AAPYQKMoQQPTQdp CPZJPmb1YKoM
JwIRgQvBgGYFrOoG4Iohncp/AE9QKDTVlplAGZAkAgBzP5oADsdzsAB/OiIA AAAMNh8PiAAW
q7VwAT6mTIAaDAcMNkCUTiLAC7YK1ACBPUMeDwdwAPKBOYAQx7R4AII7IsOk B4QxvAD4fD3A
CQQSakENPCFoDUa7RAAUCYWABYKhcADUa1QUqrUMwNyAABWJxbpNniVntVrA D/tlvtsTt1wu
kgtNqu9outvt15vF8htzvcgf9+v1xieGw9swUTuGHxd2AOGpMRiWLu+XteTn mPztviOVumRu
10ueZz+Dzd/yWg1OpzWEwNrxuqwGvvG12kO0+lhoCAUPAfDAAEAwE4oHAoAA YEAdnfr7foAf
b5ffU6wAfr86b9f9uf3fxHjt3lwm62vmuvp226x2yxm22+4+VJ92C8Vn92I/ ey2rSJ4vMBPk
9T4PG+0DwSz0DNMvT4wW3a2tDBr6rYvz+rUxq0ww2bOw5BEKwo/UQtUvL/sq yMAQAvbxQ/Cz
3rhAr6QZBUHs7FcbwhGzWMxFi4hea4RAAcQtI2pIPFMM4AFwISzLqJBfFLIc irPJElGmFRuw
JEjfReusJxo/rdIkIQmh1Li1mqapqAAaprGqAAoigKLigKA0ZroXpamM1kYx KwaJPYpI0DaM
AAG2bhtAAXRbGC5gAuXDq1jGNAugAThMFJGC1PCfgACMJIfgAEoSBKABLkoU EKwxHDRr2AoC
uQeJ5HaAAxjKL4AHkeR4gABIEgUABFkSRwABSFAWKCfB9PrFzX1avQDOOAAB AItzguee56Hy
ABommZyikmkhxHGj62WkA4AA6DgOrOcZyHGAB9H1bi2A8DoPgAOA2DqAAXha GNfAXdNOgAfx
9oefZ909A9BQyyiziIJYdzQhpfFpPhGkqhheF8XQAEiRRL1GEwSAAJYoiMAA vi2MYACuKMnS
7PuK2ghpfmKXYAEEQ4+gAXhZmIABZFqi5JExYuKiiJwqAAN4zX62xZlyi5IE qRgAF6WRigAM
A1C1k4iicAAqigLMMxBAx/bWAAdCOGAAF8WRjgABQEgYABVFhKRYFsVgAB2G wfAAV5alXXwE
WCOw3D4AAeBzUSkjINyzBcFm4G0bZsgAaatgAFQT2SlREgACwKAvDsZIc4IA DaOwyAAGoYhy
ABgGJnRBDyRQAD6Qw7IwSpTIafwBLeThSkqoJ7qINoyJnTbIrm9FoQwFYeyF ivsroaZhG5PD
ZzFGrV0kyrajiPg1gAEQPhGABvnEbwAJaeAAE6SVNKSkSbnad5118sAADmXN ibEiKMs4exCB
0AAPcoYABHCEEomhhz+gADGGQMMAAphOEXLqIsSQhQADOGiMwAAdw3uNFIKo r47SDuABw4MM
DLTmHEMEMsZwyAADMGeMkAAaQxFAPcKYrwABTirgMEwJAUFjAnBWAAHoOggE OMgWooQ+IAjc
GwAAZo0BltxGAx8NQZw2uABuqI76HHpPaWcaphxSRvDge8IMRAfgAATAkBRY QhhJIRJANQao
0gACMEiIcAABwDgIAAEwJTY1EObGmNSQAFwLAYAAIQP7uwCSZAAMIYovyMCi E2AADgGwPAAH
dC0CwFnUDhHCOAACdk7glBGqZWavR4DxfoPQeg8wABSCeFUAATQlBPS2W4dI 6x0AAD2H4O7B
m2AaAyBtroXnYAjBEyZ1Q+ZtTKD878d48B3gAAwBeSgPwfRRHKOYcgAAYgvB mv4F4MiiiSJI
m5Ni918jxn03VuwABzDnHOv4FzcA2hsDih0YgxVHChFEJ5xwPAesrC8y4ew9 h6tODg+mTJyA
KAUAqAABFIQADoHTQF5ZRAxBiDKAAHIOWKFJE4pgAAyRkw4AiBECQAAjhHCR BUY6fBxjiXMS
ASolxOQzeKMYYsGBRChE+4CiAAAuheDCfVmx7SziTEisWcE4TJkPm0twBYC2 8KwOWdxTx2zp
l1Oac85xyGFHXHqPUelIKRNrH8AAB9NwABrDfQd8j2o+I1UCiOwwjxEukGeM 9cAoBTioikgO
wKGTxBgCyFgAAMAYzyDiHeZqzbJ2CS2jsAArRYC1QKhtmbNT5WqLgGwNZBB5 DzrqcB4pk3iv
fLYrE5ADAGgNeHXkE4J1TBmDUGxGZ7kLoBjW+NVyXyJCDEA40ZwzoSF1A8B5 fIkRKFILSK8V
zhxQigqOBxdgABRikFSAAfh3KkAAm0ddeazBAiAD1CG6wABBiDdIC+eIAK50 XCyFmJVIQEgA
FWKoWRZxACADzFq/NOwkgAD4HoP97L2gAC8GBsA46ggAEKIN3d/mAitFcKoj AoJQhBCAEMAA
dg633kNIgwpbh8D2isUkNwcCCDdG694Rsgp2AwneK4WDhxKCUEjRIMTLwqtg U2baq6X2aFwE
KIfC4xhjtcAOAZdJbA/B8EFkOd5SZFhEAAHgOoewAA+B6EEs+Z805rAAEDN4 ABijHaEIIQ2F
xXirwWA0BgDjtHbAAEgJpOw+B4wuDwHVETRZUqtaIvRDxAs9AAMMYowi9iKE GI0AANAYg1AA
MoZkOA8CAd+KATQon1PsLONwb42wABiDQoYU4n8UAXAq6gY4y0+B7EDg8XQs BfSvVgAAaTng
3h1uQLQVYuAAAOAcA87TC7nKAQchaKaEzOGJADbc4GyE7h7EFQe4YKQACHEK 1gJrKQADXGuN
Z2ouW6byiyVcJYABfi0hwc45ZzSHgEAKc8fY+jr7fDoH0oAEAHARhLCeBY+R 7SJCsyoQofXd
g3BqmfhB1wphc32IJ3tmQVg0ABr+DAehAL9F4LFoVG2diJca52QAtRWsfHyP dblbQACWE5Hs
Zoz4SCWEcJ0s8h07lJH5thhZ1whhMB5usQKxQbg0TPJk54TAqYuDMGN9Mwgp TOrzNpZgUArs
qDUGgoATgltNOCQ8PIfqD5dkQHoO2Y7SZSyie89NzY0t1AXIgUQpJQibE6JZ 0uvQACA40ACa
ypik55UcIIQuDxXisFztMBYEDtD+WYEcJjgw+h5hBo6KPWpXrTH4PphhnA8h 9DhXqvYAA6Bw
zYWkRAjRAkcGiM0AApBPuHAUApvF7TpjBGHscQAhMHh5DvhcI4RQm+frycPg x0i2niEUIzC4
yhlt0E2JpKU5JpD+H6dMIwRwcAADcG2ZoRwjTE0in/KSPWKiCEIv0cg5V4gj PqAABkILnOBq
FwAogngrGnA1r7m1i3AhAkJ5AkvRAABHhGPFPkHlFuBdBdhbM0uGH6hMHhGS omjCiGhnBnoc
A4A6ElBHBFpQl/p3hYhaL1hSBSqjhVBTmdDQhDBEr7h2B2h1AABKhJCvjtq8 hehgCUBDBEGf
BcBZhlFqNxhCBDg8N+BgmPlGE+MugFrIlqCJL2q8hpBqISA2g4smhahYmuAH gHPPQMrDO+ts
jQkTkwP6kdDHA/BCKDwMhDhABJmVgzk6A3g1HfhqhrpABWBXhTgABYhUhgCa BGM2AKgKiqFc
IgCQL+HfoqsQA/o9ikxMwBBkmhBQhOBWgAANAMF2h+v0InAiAWvbA3sLokGm hjhlNOM1klBR
hPBXgAASAQgVEJCGhtBuE2AwAyApsEBSmdJJJpBBhDl+hoBpoSBbw1F5B8FP OCDnhCBEwrBh
hiJPBZBVmhBnhom6A5A8ElBcBXwogEgEMDgpAtghHPlkFlIrBHBDCkBuhvlF Azg3mwBdhZIu
nirckSDYopkaP7CJL5gAAigogbF9A1nfgqgnCsNwiHg3g8KVgEADsDhCA9Cb jZg7hALkAJqO
gAA9A4hCL2PtAdgkomhPhKHDgTARxgLAw6sqrdQ7KsQ4DOg6hAH0nbBeDijm i9xVq8vtoche
nvOEFmAggnrOA1pmgrgnFLSLHWg8GXAEgDlghDg9sli0iVqDihCiBHBAhMEO ywgAI3nvBUhO
hYjmABOAgBniyomXSBpAg/nkw7LXD6D8k0CHj0LnydNtLlu+jxSDkRLBjfLm jWrVkQkVQ5Ga
NvkUDPjUHxjISbkXkVTJtskKlWrJEvNJCITITMTFSeGKjew7kGC+kui0y5ni uCDkACgEE7gD
AEk7gBlpjEPWlPB9OeF5B7lmGFFPP0K8jwjwEDDzD8DaDGo2zTI+LCkfTUDH D9kxlVo+D7j7
rQm0O+TQIpTpEwyEPtznTVE/HxEHFAzUzEjAzMtKEdjSTGEXTGFJS+D1zntt u9jZzNzNP7T1
z7NtTHLAz5Tzzyi9zODXEuvAjHspi1hrhsk2AtB9E6BcgkJgAUgMsXBrhzhe i90L0M0NqdBc
HDhTADiLnQFkz8TTEPzPlXDDzyD4C/GECiBvhvn4hwBxJXB0B0KAyFi6g/BA s2Byp0iUhABB
pRANAOCzlpE7gMAMAMgAAQAPgQPIARmTABB/Mvw7T5zKEQhPhRCNwZiLxNik qxwughggmVA0
gzA3C3vRFRE5QFAwJqJCpDi0HWAkgmFRLftCBUhTMFzTkI0GUDD5FYDkBphq lwA3qMq+g0ox
grgrCsHll6z/u+TRUAQpHim1jphchdhbgABJhLliqwnEJEAxAwqVghAgsXAQ gQnsLlCG0aH4
hfhgNjhOhPCkIGIrMul0g2g0g5KdAiKerbJnEMS/TQjBvqHBmKheBZIMAEAF jlmmAlGTgkGx
gwguKVg5g9oxgLPGA6g2s2TB0A1LDQT6iGhaBdxeBMBOHkhaBWUOBMBPI9hV BWxF1Li1AyAw
klAtAolcjbBShWqnrTMUBXBR1PAuAzxkL2lPBUBOS3zzDdBuBvFFAwA2Gzhi BbhnzxgABMhQ
w/14oIg6g3MHgtgrlLBUhWnhBNhQyzhchWNOVhgpAvMJpagABKBGCkAQAQAQ s0g/CZxUUknF
mfHUi4Stk7hnhoPgAWAVgXAAR+qqg0gxrkBjhkk+SZgUCcAeM0KvgABbmtHC NoAABNBHNXDE
j5zzDBkMAEAMq8gTW3T3E0BtW5IFhzLSI0AA0trSA6A/U2UokhAUAS2sNUoF WXRHgJI7gAAo
Atqeg9g6sLhgxvoAhunN2xivikg+HfCgudlhBBI90XD1j+hLBOslhixRPghN HDi6yRPZhoBp
FwF70pgtAqisBxv/AABQBSKjgkAiAmAAA6g3r7jzRsjmDnL4TgkahrBspABh XIhlhmwo0HE4
AVR6BKBHKjyN0sj3hmhooug+hBQrIWCEAhAgM0A7A4s2AIgHqc1xTt2iLn28 j51zI3ktRtix
AJ37gABFBCBIERjaxnGfBwqhGuguqqgiQIShnig5g8PZp0p1gugsqqgfgex5 BiBjlHBQBRuk
KbuIBDhCHdgIAHvPAyNbgAJdK60zidgylKKZvwwKhImsHLAXv3A1Hn0CHyr3 hthvNaBIhJli
sA2N4DAjmyAprMDgCHhbhdCUBXhYG/gLpyJAhFX+TilqABmEuEDqNsLuNQBr E3gAW3ATplA9
I6Jbn6A3g3qNJNBJhJCN2uBjBjKmBRqngdgdqIguguFDKKuKg5A5oxiksBiz AlgmPqhbhbiU
BShSoDAbAbP2gw1TgAJ9Jwg8A8IFDZhFBFFixJiqP0jpgxgyV/CQBJhKikPs OU43r0BRFVY5
qIgtgu5P17o2TwCGhCBBMLzXwvY8gAAJX8B/jwsMTiRWDuK1iQDnDnjgK3JN SrB3B2lavilg
ozr2P0yTg/verQLRUtjzQnhZ3bhPKHGeCGATLhkSBtBsIsg/A9MHgwAwsmtE Pqm020320U54
ESDBC016BZT1VXzH1BD6v3g1AAB5raYqDnrcTOgBS5gAAGaEgALfrgZnmFFm JUo8A4A4mo24
VyX2Z4i3sQo6LGPgAsgtFLAaAayHik3sJxUkDSqtGsBgBf0OApAppgAuAusm jRDIhBhBLqL8
hAtLqBGAqKqLgtAtxkKQpEBUBThYCzhBBB6coSBDhDCSAVAUxX2uBLhMI9hb hcCUAqAqLMY7
KqpTiEA1A1qVnluKqOqPgmAlpia0mxl0NCjpgqyp5fAAAcAbuspNB3h3iXp7 NDgj1pg1g0vZ
6MVj0C7Ci4QesxiWpwg9A8Whi16EtrK3izt3mVA7A6L7gegdooik7KIS7Ls2 7NAABUBWHhBT
BToDaoomi2BrBrk4AygxElO3IlLWEvVBToi6r+MLxNhKBHmRjDqLCiOmlPBV hYL1hPBRqjuc
PN4qyCRhBuHNg1A5CCINLIVunUBkBmG6A+BBr7hcBWmdOZNlioA5A8vZhX0/ aFtBzBT+VKjS
i0jY2zLcjONwzYNkg+oE4vXAvG77gAXahvnHAfgbgAAsgrgvAAAkwAgsAvpi OXmuJMlI5eAA
Jjpkhghi0OB0h1B0s8BktOAWAVWmg9A5ML2uHewrStMDg8A5I6cKpPZRX+BW BSBaGDRVwBBl
mhNzHfhchXlHOZAyA2lLFSYwITHGm0WVvFRohoQhhFikD7CJQx8klvckiDH/ BahcS3hBg+iG
AcgbNICeApAtKegxgwA0gAAlP5izhxByJXAxg0mwATb9FflgikqABygAZMoH BFSzzpydXPzr
i9lgE7hshthrneA/nf7FCaBBibgV6pbRIhhShTlVaoxX7VhrhpgAbXn0gnOu Czh1h18NNNJP
dPcNBjBkoMcPWmg7cVDPhFBH0jB8l6CEvTGDVjIMoVXbpQAAU+8ZQ2OIZ3C9 BGSyl5ODneA9
pCDuK8tvgrgsMJgw8x6+v6dfjXGIP759xPhCpmhoPfxegR4wLzJSggAfs0Ac HBIFh7FuYjSG
AlOUBCBAmsAkgjGxjBODjrhOhPnkhPhRikBbBXtOHVizlliiAnApIog2g1F+ pFGmhZnDPghT
qHBUhSNpCJgzg2LMK6JeJoF2ikh7B7qLnM9CBTBRQPAKnT2neKm6oABIhGqn j8v8FvISA5A6
gzAAMjxHgHAGtrNJzHtKzOi/74CQBXhaHhBPBRSzhUBQVPOuOphbhXk+XkpA A4A6qVhWhS0O
A1A4isA9g7SVAYAW6SCQBCBFwrRN8sX+CkhC+xL4dYhCA/Ml4pjOmmKI7X02 AmgkwFbRqHBN
hPo9hdBZyBFqjxhshtE2FCGzhUBRPNpJANAAAyA1RkARAQmTXGnSEHBdhfS3 hCuaeaBT+bQ2
KdAn8BJLI9gMAKpKA7A+8yBBg/Gseo+Zm/E+BThWKnhwBxnvJundkFEVv8Vx kH0DrV0bn4gs
AyN9gUATImgFm7izhyBziPteUnhNBHnhBeBg1PBEhIixBKhGqHACABJECkgv A0olBBA9NQAX
gVp3gJAIgJ6M7CbDNKO8oxoGOKhPhL17S9gABQhSpQhFhICAIUAMldNcAOBx N0AFUxkoACkT
CsAAsFAwAReLuNzOIABgKhgAJ1IKkAAGMHxEnMAPh8vgAIw/JWMReUSp8y2X n+ZP9/zOLqBV
JgAJ9TpsAMBXMoAAIAgKfU+oT6e1GqVOTTOp1StVetV2uRev1STVmngGyViu 2mL2eMWGfW62
2Cu1a4VC4XeZ1+r24A3qS1G+2W82/ASazXG7X/EWKoVm61u84+1W3A5PH36S 2y2ZPOV/N4u1
6HFaO+yYBgOnAQCgQAAYEgbWgkDgACAYCgCez1+Pl9gB8vZ8gB9cAAPt9PwA P7lcmecmMc3c
c/o5uz1PrXPOVirdjs1Ht9HOd+1dTpU/od60eC/5/GWHK5D0+X5eTNd3u+e6 5L0fLAaL9Oyz
7/vMqr7MbAr9qlAzEvssieswwcFv0w0Bv4+6vQguDcwStMNPs/69sI70QMm9 kBLUq48GuOAA
F4fBcAAWwmilA4ACUWZXAAIgECQABEhSR65RpDcQyEsEHvi0UkvAtwjikH8i qeaxrGqABqym
AAoCeKIAALLsaFwWBgyDCjsyPCqogUBbZj0Pw7AAYhimGnwaBmGqXkUSIAHu ergqiep7HoAB
DESQQAGgaRmpeRBJoeFKJHieR4gALAtieAAUBOFIAEeRhLyGrT2Sg+EEmwbJ rAAQ5EkCAB4n
ieAAAYBgGgAMQvjMAAhiEI1PyRUdRQWqhvHAbYADkOw3AAGYZBoAA/j5VdYg clbiH03kiJmA
wDtuBDZAAeZ6nkABAkGP4AGaZxmAARxFEkAARA+ErusPXlfIwI4oCDURcleY Dkn8foAC6Mwr
yxGSFieLQADyQKVAsCwL2KNI7wvITDRMqJcF8WYAEwTqZFeUsXk+UyhFOVRS 1EMQvDKAAsik
L8lK0VRZFIABWlgVQAFUTxZYCNAqp8URLlXGhwnGbwAC4M+gGGW1EvAVJY5q UBTE4ABdleYQ
AH6feAAEAinB2I4Z3UQpLWSF87DIN4uAAFoWBfiI8OSfqemWaJjAAPRAjqAB blXrQBKZEjTb
AABLk7doMcWABemAXQADgNO+lKVRQgAIogCSAAcBoHUYF7npal0WIAEsRJO1 BIVQrEqYFA4k
wTdlX/aG12wAHoceAQoq/WQ72jQjsQEVhAD4QgAMelAAIQmh3Yo14mFYUBaA A2jvW5dlhORG
koRAAG2bps8ORpPp8P5Ebme58JcRRASBDkCKiS5P0YY5kmIABQkwkj1KgPoh k3C9F+Ltvwrx
egAAoBICpS3BOHE6owTgoRMgAY0Mc1oBzZsxLSAQAgAzaGrAAAODoABtDcGw QtSrAQsBhAAG
kMobSqQcg8AkBYCAADiHGOEAAnBQCab8LgWgABSieaIBoDAGzwvxPGYt1iUB vjhIUIYRaqwJ
gSAmqgQQjiqHKH8AANYcQyNbH6wAPweVCgcA2B4nwpxVijAAL8YMBwgg+CGp MKwXQADFGQ1o
UQpBPAACYEoJwAAnhMRmconohxFqFHAOEb6ihIAAAaAwB4ABxjlI4IQQ65QV gpBYAANwayVQ
aiURc1RrB6LgAAJsT0PhqDUGmcwnoQwghFAAFYKgWShihKMMkZcFgjhGc2FA JwVDuEYEmJVI
A1hrpUDmHFNwJASAmNEGkNkYSZiVEnD4phThjDIfwKMUgoAAA7B0D1pIWmYD 2HwPYAAcw6LI
gwbMS4lmrPrJcNAaAzgACaE2p4GYM1mBjDGGcAA2RskGEiJGLSsSLCLEXJGL h0wABsDXQYmY
kRJqeNPB4ZAxxigAFIKNy4Ogdg8AAFoLceHgPwNAWcP4ew8qwVibg5o9acAA Aqw4AA/B9nIj
GwAm5wSeRdJm4IpwBlswhNObSDgAB1jrHVTQixMx6VXWaIUQyNDzv9NAmeY5 UR6DyXCGYMUL
AXAvbiHIPDc0um3PcaIfVcwACNESIcAA0xpDSn6J6P4CwHLSlLS5XqwC1meY pV4qIqBViwib
S0tJ+h/mPFSKkUwAKPjIS5UopdTTSwMKcAepYCQFAJi2csflPlpzuC6GAMAA ASgmBOaOyBbi
2JmROYQQ4hBAAAGeM9RM8G5g9B+vkqRPR90/J8JARwiY8pxluFdhIVgrBbO6 IUQgfrfXAAAI
AQFWwWgtBgAAew9h6sBC60ABF6wACmFKjgmYhBCB9AAM67l3qtguvET4TgnG zi2FvEEJ4TkZ
hfC/GGDsHh8j6HuAASYk5IjDGImInhPXZWzESIhIC/2ABWCwFCMTAAmBLkHY FaVn6kAAjQB1
zgN3nIeRoxda5jxECLEGSse+DRBiBuchMmdEx/D/qMRgKAU3Nh0DncMHSTyZ hPyMAAOuSQAA
9yWAAVIrBTs2FezkPIdQ9pGJ8acp0RokAVAoBZ1WM0IKixkT6KShcc4NEKH/ HpjaugAjYzUV
4tEcCsFEK+mxZxtDdG09UOgagACjE3ZcC2ZyBjNs0H4QgfAAC1FWi+DhrBpj Wr4HQPYcgACs
FHoCSdgjImJXmmVa+YExlyL2VwpxTSnUdWaIdiYIwRLxDqHEPRrTbKbEnc4S 4mhKAAD4HZQo
gRD5fFwK1MVbwADBGJAcQ4j1ChTCc0AGQMFmCmFWzUCgEwKAADwG/ShWRjDM TkIcRghAACrF
A6UQwjre64XiF4LE2CMDJGZSEPohG5i3FYL+p0HteBrxUBvFgcw1tzKiJsUZ QhpDTGeAASQi
ihYVR6I/dw1xtKnCeEtGamFNBwDtwgQQfK8OdpQTMKYXQlvIC9QYJIRZBmKH GOQcAAAyBrjw
GMMFBgQghBIT5wRJgFJpAACcEhEj0FcMc7Qx7v6wlPlPGIlwWQupbBuDVz4b w2Nzyu5cVgrh
UMKDtdqz5M8xAAAyBjFmjSQDDGKv0RgkN3BQCbMYGQMVmWMZqBPcWUA4aUJn 3cgRNyXB8Dvj
czdjBRAAFEKV8oqRSsbAWrIzq6u8ErfWwoPG7iohaC4EwAAYAv0GCNzZAuPs YnvV+IURFMzj
D6XUIuCY/cgnFH0b04zuyrzdAAEkJwNwAB+D1VsIoRPTHgjGcgTooSZdlyyK 0U0BLaEXuT7Y
KAVghAADMGRZATglhWAALQW4rb2ioj+KYUQti4zWl0BcC5IAnBMmMZEpwAgB kmBUBQBiAAtE
hsDMDWYIAsI+AAt4Ty1czWIwGmGouCDuDQAA7MgOAaAakqYqXkMILw1Y1aKo G6HAhODIDUl0
DeDWpm/QFYJCEtBYxyUCCUCkpQDQDERWE2FCUYFuFgbyg6NgJmEMEY16JYJc ECD2i0Jm3ZCG
8/CNCQKgCgCwSeDKDChgCWCOaAFGFQKEZusuFgFSwoLYGyG2GoAADUbYvaFA /gAuAsA0AADC
DOxAv0BkAADiDY7UKg2kcgECgAZ0FGFyp0AoJADsD4oMBEBAmoAiAgiuHWHa HQoqDMb6CQCi
c+EeEOh8EoE0EWpSCsteB8BylssQMsP7AcsMQKHAHGIUC2DMxADQDGWQBIBE moqOcGIoVmBY
BNDmESEkXKFk/SRoCwCkC8eqDKTcQO9gK2seVEDyEKDevIHuncEgEKKMLSFW ZoAAEiEuEUjy
FuljFOIUCyDKkGDTFctgBEtnFmJNFqAABcBOWYK4D+EWb6HuJwEWD4UYKzHh HkJwEVHsQMFE
FYKME0+kTeFk4q7WQtGMO9GSLsza1Wd6MgRKsGsUQ5Iatw1Usk+zAbAcK5GO MUrjItI61OMv
IyLFJCQXIWQ+MHIaSC9cSKRBIeXqRIMsVCLCLOQnI4MC7ahkS4W0S4AQNgAG AMNYpsp6OOOF
HmOEHw9sH4H0YA90i6yCd+KzKmOmPqV6zvIlImNC1S+zIWQQtpK8P8QUMFKJ ImQaLQOoPEsi
MK1WP66oSGPodWQYshJktyiSKkxk6mLqOvBAiXL7KzKwPIq+xjK1LbJYQvIx L9KvMPJUsRMD
AcOqV5JbLsK3JWcIOeQEEiGkIMKiHwHmHeIGADBYHKAPD+Fq2wLUCWFaZ6A2 HyCOAABuH+mM
AQAaAiKoDgBgBRLosTMGiZKylIIuCUCq++SgqCSqGtDIoQfECcCcUsQm0ytA LUFqFcF86rMN
JJLCs+ACAKi6CqCuxA1oFKFGZyLMNY40Xq4m4qGeGiUSC+C6jCGSGUpCEGEK u0CwUoaSCyDF
N/MLN2KiGyG0IMEOEQt6EWEUSADoDsDiAAEoEkU8DiDkhgC0CyZgloV2sKMY rBIdP6M4vWNg
HeHiHY7cAxDaHqHmwarmN6GEGIX6GIGMTEHIHKHIJ8jQA4nKByB8AAB+B4Xy qUNusAtMHOHO
HMAAAiAe3GHyHu9tQxK2smpaCgCyIcJm+ejEyGK0FsFYgOEcErG0GAGGgOFI E6yyACH8NYDC
DUusDJDe+GeY1ari1UxgQGGUGgpCD8EGy+z8Y2GcGoGWUEEUUKSgCaCUUsDW DG1BL2KeF4GI
FuXUElE0FoFQgIDmD8hgC+C4hZNyTsXoMAKdR0CY+MFiFKgIAcAaWkGO3UAA DsD/QWF8Fggs
NWNuJmCiC8R4Dm7CAAB4BuSeEGEavouSN6ECDwucJmG2G+hODEDUYSGCFqUT IOdYJMGgGon4
saZrQISACuDCkGFUE6Z6GIGWTEGcGgUSDXBsJCZILWi6DIC20RP9SYK0AaA8 NYdlFlXaO6ds
0KHkHDSWoozSOlLDMqLQDuEE1ABAA8eODSDCWQDxYGAApwvOBSBOIkHsT2ne 4aU2EtG0fA0K
EqEWasJmECEVCWJck2EbOATJK2PkEyFA2KGQGWbyE+EqsuLSEoE4SAF8GCF4 AAZA/gomJmGk
Gs4qDSDgjCFSFAFgAAA2A0xZMjQ4K6AGAKg8DcDoVvRSAAEqEcKMQEJM/4Kc fUvOCSCiCI5k
oMC2juSJaZLHA4PHWeK0kaaQEQEaxuAkisAAznE0Kip+N6DcDnApKIEAD4q2 AwAsJAJnNWZy
F2F4ReB4B3RyC2CuZgGMGSTkFGFKnICQCMIckKRnCTbihuHC52t4uciq3GHE HIh0EPT+AABU
BUk+DaDQRXbYNCPYxStIhssYyywAiCViVmEQEKEYJCh6u2USCUCS9MCW+JU2 myEukiGuGwVO
DYDURWUwBUpsYADackJ8EnGwL+KcGQGSpCFIFK8iB0B0pRQmjwxyncDqDvQW qUNgEaEYUYMU
n0USE6E6h8BkBkbIDCDCZYGumadMEsUYArgIAAD6D9UAOeyElAlCJ8EeEgJk 7aGSGQbyFLPE
ABfIecCwCybbbVLnJkEED+voAXhIJ8quUCApgKp8OQ969sWqOCtSOQJnOgqU Nnfcg+NYHYqi
qphMqwD4EE9FaashL5LINFiIvWhsFkFa/UpIcuBKBOmoCrg2UvdWJ9ecVOFU FOyyG4duJmDs
D0pmBYBhADZPjLXrLqLUFMFQFdiJFHjciVMsLUkcIUnEZqIqIsNsNgxSJKza yEN0jGN8Hwwb
hIAUAACoCtAOYfjPJJjfkYKoruUKGgGen4DeDiDoAABynO82FgFcZyFQFOZq A8A8BAAAEWEa
XbJHCSEMt6t+USD80kbcBabivMvOC+DACwABiQ0SFEaJCAEPlYu4D/lgbebi JnQSWQHAHAke
DSDShgVzNe7YNQVhhLbclADe0QziTuTyBEBE6KDi4YAAHDc+/ADJAoCmCk/M RDOMfXSXGTJS
pbMnIyEUEYq2fUwapi9FMSJnnQ5imeYmB3RwJ9n4AADoDjn+B1RyGWGYs0k0 VWEYw0AABYBW
BcQNOMH6H4d3N7JjIYZjnjg+EOEa3dmy5Sq3TeMWGwG2VODkDyRWE8Es8iAw /qJ8GeGkn4D3
WCAAFAEyZq0agWGUGcGSu7PqAAFkFSFqS4qe02liDsD7kuFME67PESAkq9Mm zbo8P7niPfJu
LA1igaEFZCAABCA+BEhaDKRWxSyCOQCoC09MqGAAHYHaHW0qFVOq2gDKDcjw ToBtDoDTkvV+
1q16NsNmDqDcpmx+H+YACkC2CaAAC9P0h2FEKEE8EuZqAuAoAyJ8GSGabyD+ EK16FoFVZzOg
FWFiyyFwF3qOE6EojcJmnw2MEITdhiAAEgEObOaM52DODghZaugmk7ooJaOC COCiCAXE+SAA
Bsc8J8CuDAUtschZCsxBsOYACgCuR4kCxADVtyQSNyKmuThkQBjNL/OuLXLC dY6OAAEEEMbm
HoHmUCESEKXaGU36AAEGEM0oEYESJlmJoqH4i7OMDWDehYoDr2DcDS1Bu9vQ EO0pjyWLsKJ8
EcEkrxrcD0eFLKJns0bzPo0omey+CAB9bFK+L+EgEkq3CI3IDrgSKeC4C+Ut PcZYCICJsZkb
a1nfLXOwLYERH4N8JuWaD7d+NxI/MOJMRkecy6UKCCB+R4NConS9D+UGu0Es Ei8jYLrIKyGm
Gq4qDwD4hgEIEDZKBiBe+MFqFwRwFPaKpEE+Y2LkEYEeXLAgGgiEFCY2/4g9 I0OKuU40EWEe
u0GJRYysFIReAStJA+THyun4DqDy0QFO/fSLEVQziLvGMhA8LixlU6CaCmnR bm3GBqBmBweq
DObms+DADQRmvKvOjQjUEcEOKNKiJ8ESEc0pxMD+Dzx+Ix1f1iJwjLd+LgCk C0++6ADYRqCM
RmGsGxzgDeDoDG8lW4I6AuiQJmvss0DwD64Qj8iDARswEEEOJUhwh0v9BYLg EqE1G0FudI/O
FapCLMJMFcFoZqFwF0Y3VIkqC2hWbQByYUEB2CiMjUFo2aAAFmFUTEW0tN0m sJIP0hIzKxFI
a2H8OR2H3uCg/Kee17IUN0a6AAIqNmALJ6KiHmHmXCB4CLACFPaMAABIA+tm T3X3FLkd4Ro3
xCKeD2ENQXfSrqEGgmLSFaFosuEkExE0GGFrzg90OQCGCi+MCiCY/MDoDWy+ x8OuJ6a5SsXE
EabmfWwaEQD3AYIwEB6o88wa2X60LkJ6DwEKRWHKHOHG0SEo/VN/X/5ZQ1Mp ITIbLUOi6mpa
QD5dg95cMPFDI+LuL5TdpMLf8B0p0fvFJf5dK8RHA4MlLzL7JX8FiH7yKqQc L+MrJuMCxSNO
cKg86uhEKcOhouOQH2WtKYqA914Yi6OhKoSSQ1LTMWO5MEQNFD8qSgLJFC9a PT7wPV4UP4Ob
9lkb8m+yPzZN9b91iEVFjbxt+QzXLP8MQKibxrLfkXMUPj+BJdeTLJ4K1ROs Owsetw6h+9Lv
0jo1LZMpdiPiQm6iIuEWGXzgE4DllwKiHUHSHSR6GIq2E+G+U8FmIAWCUAIJ BCaqFsADCITS
ADuPD0AAsFwvBYtBDIjlQADqNhfF5BIZFI5CAYJJpJKYu/5HLJETSuRJVIzG ZDGADxOQADwg
DwA/aAAHo83oADWazYAFyulzI5RF1kq15IZdKKfMwBV4LLq3IgDWgGBAEAHQ 6nGAHw+HyABA
HxKAH4+35WJVKHzdwAej6cgA2242gAmUungAGQuHZnXIJiqdWgA/65T8jIJN WlhUQAO80AA6
HBAACyWikAE6m1IAHg8XaADIZTAAEejUsAA+Hs/k6xjsXuotjLpWZCBgOBgA +30+wA53Q5wA
iEYgwA3W829/FxGIreeDmfMKGA0AAL4QA+ny+pTLN9wJR6erBAyHQtF3n8wA eT4dgAyGUx5G
tFUXYAGia5nAADgNg2woKg4ABPlIToAFOVZRgAVhTFiAAEgIBaCt49rgNzD6 VoKc52HI1g1C
8ABHEMSoABCEIPgAKIsiZDyQB0G4dgAPY5uhDqQGyb5qgAOI7DaABSE0VcCg +DKsn+AYAHqe
R7va3w4D4ho0jANwABOEgUpOlgkCqIIADeM46AAJAhxqbRumwAAzjiL4AFkU 8AAaBYHQCaxm
pwQA5wYSqNguCoMAATBPkkABvnEbgAESP9GMU3ynqIeQADoPykkmRZNAAAwC AQ1g3i2ABNEc
UQAFoXRXgAA9YzWIMakGRw+gAIwgCQAAbhjHSLMlG0bN8GwkBdYdkvaZJbmg rr2K7DjGWgkk
fvqQk1BA2wADMLw1gAYBiqmPxDIiCYIgmABBj6RAABYE6PkiTJGAAbhvMASZ E1AixBEW7i1H
wABDD4RbH2HaBNFC2ZkGWYzSEm06VGCYxegAPhBjwABVE/C4MgxJyuFyXpag AQ5GugXZZmIA
ACLDEVoWskQ2DoMoAAHlxIkUS7FpKyiCqAuYoCygYjCGJIADaM44Ja88RWVp 6RnAcRv0iRxC
AACQJXSQg/ESxqCEAQruHSdR0AALgsTrHAeouR183q6YACqKYsgAIAeCEABj mUYskFOUAACO
IqBicJYoIuRRHEKABwnEcIAEEPpDAACYJAoABxnJx5EEbxYVBSFajDMN9o4P pwAHUdh08gQo
/4MlhGEOSIAF+YWKlsW5ZgADGPryO4/Z8kZLExRhrmwa6jDTLoThPMLIH9M4 4jUi5IkfFqvr
GZJlYcUpTQmHQcx0LAri4AB7nueyHDzQVYgOABFkUSGDIIaJowITxPE2AAZB kGYABfC+Tcfk
AyOB1aWP6BAABCiGYKAuBwABwDgaoJAR7BSLCMEeJNmzNwADKGSfwU4pUJg5 B0DoAAVgsKna
g6YkQhBAvAAZDEi49IaAAAoBUCpcICHGPMXctcAy5kWAJENWCsgCgGOJEMAg AB2DrHWACGID
IZw1D0IAQLPDEvzhXFkkhXFzgQAAKkUwpgACjFCKEi7N0okWH8UE3pKQvhiJ uEIIoRUPLTjf
CtaxuGnCjFMKtakW1gyCK0P4uIABFPwAAA4BxPgEAJASyyIhJyslfMeZAmbQ AAD5LUUIeamR
9j7LWHEOh+AESni2zFEJdS6CLEQ4saA0ECA6B22wDwHkYyUIs+1wISAlloHw +kNQaCblpYC/
wGgAAihGaOO8d47gAAXImAAFYK1kCIEQIIAEsUCB8D5NoFgLFkD2nIAAMQYg tAAlOqQUIoBU
kXEOIiK83AAAjBGCQ0AWAugAGaM0ZYABcC5ZJLwTonEJxDOILoXRCYaDzXdN aXQhhDxXh8ok
wYAAIgQAiAAZwzp/iHES1cBtIwABDCEEYAAKXQAAHIOMcRJyTBPCaFGQSHC6 EsQ6VZnxJiuC
MEcIeYCVQ+B6m1HskIVQsBOSIHAOoAAdA4bYRapFSg5VMqdVCSSUQ2JoABSN PgXgtmvBOCUF
AAGyOrkvNEC6iGmNfJTKpap1REuKAAPKT4AA5huPwVo9ZBAHyNZYAVKIVQuG jBqDMGwAAtWE
cYOIcAABSiqQmOMcpZxPiWjQBUCh8RljPGUAAQIh3XCwFM7qJRaB9JVCuF8K oAA2BmSOEUIK
vCLm8McpaVcupB27trTaShXynmVACWMQgjFcS3M+GILgaJKlaGmNZAgcA7PT IsLEVAulQniD
mHspJPYwPSPw3tvoohUGEA2BlBdohGlduAbAS7BXasVOvPgSAiDZj9H49Aiw yxnDIAAIAQ4e
wACxFOU2045BzOPDOG8MQAAVAoBY/sF8yW9srAVhcAECHoCKEE/Idg7onhgD ROkNoaA4gABq
DEG6dhbKvFWLAjYbGlAACSEQJpFxBCKO5e0PIchAM2iJe0VArY0GXFaAANAZ Eug3BuDwuEoQ
ADmHOiYEgIwTxapqTOnixCCDeG+dQco5izg4Btk48IBV6jdGyTgPjpAshXn2 FMKE6SwljDWG
4MNXQGk+rAzUE4JkwtkbNWkiiTg8h9dIA8njSA0pqGSw2yAqBPgAA1egAAhB AQWIKJESgii0
ScJwHN10eYNljDQGxOp4TiB4Do65dDlxsDYSGCI7EUAGANAAJESa7S7sBDqH TH7PgvhgcOF0
LrNQiBDl+iC3mzLd1wJmIkRbwDylrD6HrT1fLfbbCgFUH5HNRAAB6DomRkpM GQLmGAMoVKHg
wnMF4hp5TzCbE8ozKRZxMiVFLhm/QtxciwAAKgVcaBQid4BJTKVjw0hsRSFA JwWAABQCaFYn
YDwJAAy8YADwHQQxFVJZQboAA1BtTqE0JQU3/hd3iPhKo3hwKQBkDCxJan0h WC2rwNgaT8BH
xssNYW0NtU7t7tu3oAiUB6ECl0ZYzb/B6DrNpu9tCCiPEs1ffwspzBfIaFgK WeT0iLEg64tS
VQ+h308RbsHYh89k7MSMKoXY7BiC89MJARaaEsegFEK4QAAA2Bpk4LgWQzQQ HDyGPwmXMDks
eKETiFwLAVScNUbCBA6B3uYG0NTGQjhDxuNAaQzNciVcWEUIZAwvhauocAcQ 5FIBlDW3WSAC
gACvFOxXo0SxXi032JoT0GuY2JEQIAShjx/U4Z6V63RdDKtNN/JYAE7vECtu smcNDGQeg4bz
KE82CKXpfBUdUeo9iihMCwD4AAmxIinAACQEOV0bFXMcAGQPRIth8EQmoe8w X3iANmV4lAVw
Wr9QSYTK9YYAWRP5D4T4VBnYVj6YOQNAPIAAHz7A4rKAcYcyl4FIEp0IiwQY R4iLsZgQPAR7
HED6DoZw/gvZyZXwHAAAYoZQYJdQR47gNYMhpYJoIblBYQkT+bLStrUit5ZT 5Zp4q6TCVUHo
6raD5UJT5JnroL5K4T48Jq2zZ75Bay9sJL5C3IpxD0IcJj45H7oDoampH5Ss La9i3K9rowsc
NQlAATowAEN4ysOB+YoAfon6/LDIoIfr4qS7vB0sMx17LB0qLAl0JCtJ04kD 40LUQkID+kQc
RyVkRQqkSkRsQY9A3yQMK75RD628SsRLc7LKLkH8RkSDZolUQ75kJsU0KjLA 9iPkUUT4rg9I
9L+ET8UkVcU8XMJ8SI3UQ0UyuMR5K0YEIT5sUp4MWMDoYIYYAALAKY0YlQeQ dqJ4VQbJRgYo
dpwAiwHYCY14KwE5LoBwCaHIlTIYVwAAPoICqMIjZ0LgrBag9B4IJ4LII6mr hw0Yy8c6QQWI
VIpsMcYiXSoxaKvsIcUwBIBR9y9oewepKoZQZi/wF4FoGKIp90M50qioSQSh goYwZBlYIAH5
MwO4Op4DlgtcYYf7+Mf8S0HwiwnjXA8g8x84tYMYMxU4QjHJSIRY6AMgMTwY GIF4GsCqIMTk
SUXESEJgrQaIaZAgQIQpXEN4sYKYKLdiZBEIZwZ5P4VgVwVTfglgP6ogAEiI GSLEsiLsIMXU
WCvsM5m4sYBYB6SIRoSBgoWYWzrAiwWQVAppPb2S/EO6PyNAUbSQAAOANgvg JAISX440O5ZK
VSnImYAQAokwLIMTlAJoJIJ4AALYKo14CwDTi5p44wuYdgc4d46oege4eI0A MLlEnR2YFQE4
FsPS/SLYXIYAWifkrAvIODUYlAawbYaRM4O56a84xAcodBEwP4PA6AHgGxMw f8PoAiwRRIUC
DQUwVRVZAwDzfkO4SQRQTCjAB0cguhcg/ALQKyfYFIEhZAyAlgY4ZsGIXAXY hLC72QNwM5QQ
e8hhpAPIM4AD3pCYBIAz2UVkssHjLIHIJUicZKLYYwWsBEUL48eMWI3QPYQw /AD4Doz4MoLp
6YfQfhgIJIKgIaRawAWIUwW82QAASQTYRxuA6gSQQ5nYiwQgRp4D/JgIQgPR r1AwrCIAuAfo
5AUAU4TgAC/gZIAEjR/QsYsaJA4hYIsYAAKQLiX62Ro4NAMIpId4eM0oQIRL AQDCtYhwOB4E
9jjDl7whqgIQH6OwkQeIeQeCRYBpPi/YZ9I4PIP5QQNIMpI4KgJ7iAp41NOA dwdwdhFwEAEY
n6/BjQV4jYTYUBnYRIQa9YGwGQHMldAtA0VNBYi4cIcZqjsCoACRdC0APioF TAgoZoaKz4UA
URB9URdIKQJ61ococpExkQhKSCSIQYP5dplrNBhhhwUwVBVYIwIhXgJgJJw5 ngRgSCoAcSly
/4PZq5rJdKyil4Ran6lIFD79PRI5njaEujrAeoeoooEoEjK4BKVAXwYIqYbA bZONcwExpANT
E584esdAQLAQ8gtYFFbbcQHb81N01ICkcYAAEwEzK4TATT4YbAbJ5ANIM5I7 P6stMqUgpIiw
R4RiDS9rR6/wU4VA04HIHCEwK4KqdL/JKoPIPaptJpSIRFFoiwaQaRZwT4UF IgGIGMsbYzPK
9oSgSh+QbobpSFailIFR0LWJ5AdqJpxFZiDZKIZYZS/wVCEIAAHCEhuSFFTc RQ3inAlwQyFz
WyKQiyGgoqG6HIuIuYtJKtH1HyISIi06U6SM6KJaJqJ6KKKYooO4Pp4CFlCS mwrVv0d8JYkw
CwChy4dQdJ1YYAX4XwAAbVhoi9hDK4IAIJvIc4c4cw+oO4/AkQLoMDPIIIIg mVrUVBg0HY9U
QS3QxgUIUYVNrtU4usgTnwmadZvQY0ZgZYZhP6rxUI4aSsNi4cPy2qS1MqNs O9lAAAeIeNOC
w8iYHIHjvkO0lh08L8i160TogoRgRRyYaIaAZ46oCF8NJAS1IiNQ5IcxEwSI SC9YcIcKx4iz
M4AFz5moIAIAmR+Bq6egPQPbH4FiiCch9IMgMh8t2p/CMgiwRQRV/KWQAF0S lAYwYxvqcle7
RSMAPIPA7gEIECfD4p6AWgWjgAWQWbgA+ZTK9qlT74KIKDdgGAF5/16V2oYJ 20/wT9Il5VOA
iyBxDYIV0Js6sMYsXRqDoIxwRwSBrx85KoPYPDYJYMXwi4K4LSmgOANxNQHJ HOJ4LeKQN5NR
HDJy9oe4fNe6RKoAaYak4FuLUo1gMDwYHoHbb8Y798XL+l6ogjsBdsjhvo34 QgPqoAFqiAYQ
Y4X70J2aAY5C+bd7Bt/giITgSrSYCtgoZgZ6f4QYRKK4VoUjgAAqIkOSyAVY 076TI4BYBRDY
UATBiMlSVkx2IK3kgqSq3ySwQ4RzH4zoz4LwLAm91Q8GTRgQRp1y+IAAVwUo hIAyI4AAagbB
Z1UAAAdyZ4AAGIF0sYJgJSpQQb4IAAJoI8zA1whoiwaobM4APAP6poOINZQQ IQHylEJqztI4
QQRBXAV4UtFCIZKK04Z4aj0AV4WTI+TTNAJ4JimgYgYwYQAAcrKa0APCoEth BgU5/QWAWcc7
5YKwKLiEhle4WoXM24PoOyK4GAFssYa4bYah96+oAAex9AAAOQNgO7FAGUFo AoA6JYUAUlIg
VwWMrgAYARKL4oljMiEwOINsCI9uJ0R2OgmYaoa4aJkoRR1zXtEgnweAeE0r ZJXgNwNaps0O
Vx8wfChwREnQAGMupNdKSOnJKIMgMJ6YHxvAAAa+b4AEuJdqZyaAF+aAAAJY JTG4QyeQAAJQ
JCpQMgMAhoSQSxempoOoOJXAr0OAeYetOAQYQp4AbVd9pwAAnqjYQ0DyGwCo ioSYSrT2poOg
OVvi3oMAMblALoLYm6kwgcYL98Xl2MswrtbDH9fZHYPBdsZCQYp4KYLBvIOZ LAzIHNEcQqmA
gh1JEwQQQzAQdAdFzN6Q69eQPgPKbSv6HNMs+JC4VRCU/wTbI4p9uZAIaaf4 RoR5yeqCaGYg
4gnijYRIQo2d8Li48Np4ZhlaDBxeCd35/YGMoIPoPJr2TgUoVB/QVoV6d+UR DdVpC+VcdyPa
nUJ0KUU4rTF6NATwUU74UO7giQCg74iwXQXzrCDKoASIRZ/QEwEjCI9IRoSS K5gBHYOtUwgv
FPFbUFlfF4kBtJXgMDlRwIIkzD5x2ohISASRdouQ5DKrK4MYMB6bQ50gT4TR V6zRRCJCJYXA
XjgAS4TMEjDSHQ5GvkzANYMxNSBA9Yk2hQK4L0etfp0IQAPC9ceJqQ6gNIN6 fen5jMw6mmIO
VUSW1z+SN6Pg9glCI4sZhL4YVQVyMl80556AHYHDvgPYORq434ej8QAAJ4LR M3LA04EYED90
s+OXTz5NTQ6oP4RY/Gkx9Opb4YlQV4Wyd4SlFgAAXwWCz4iwAYAwkwTU6iMP Q2yfRIAAHgHB
MwPwORyZD4QoSBf7UAQgO5elGfY6swdY5mnCJYbIbga2rRKoKbiZIgM+lYfo fU2cSfUPB8RM
JMWEduVEXsXBDseHTuOMd12e3F1ER8LGVeVsRj50LkVve3dEovduJt6fT7/3 d/fi392EYXgk
gG4d65EK9r5ffDba4I9bc6TCBETDvHiZnlv0WkQkX5aEQMSMUHeO2CFkZCTH fslfjcSqPEQM
TXf0omXPkEWfcSLflMLPkXg3nEVCuEWstHcm1kW/TsTMQHk6O/hcYwymovcn dkgJqCPEKUJE
Vq3j+cW10ggoPQWohIMG0g6saQdRKSu+HNOSRYCY+I34UAUBB4Q2aVS+3EpG OA6vj43YkFKW
1aLfHLBoUAUYwiQXQwhMiynHh8o0VXdcXwlmthIYQFHI7o74JwJg0YGIGCZL RQn15U1IZ4aD
0AWIWkc6lql4D4EAz4SwShUB9A5BZMQ+ofeAlIMwNKfenBKIo5LptauoeQov o8IMI8SfkveI
rWUaSIbYbxOJ3hRFwoiou48wi1lodZ1QsgdJswEr9uks/VMo3/lvCHmxS0OA CIChPnvLSYT9
VoAAWGYQi4Z4aRP9LpXAMoMU/sZydIeYeNe/T0xvhPPJaqSwXAYB3XvIwggB JIhMAACgwAhE
IAMJhkNh0PiERAAPCAQACbUCXABhLhkABQJBViUjkgGA4FACNSqIABDHpIAA qE4rAAEAgDAA
HBQGADfcDeAAcDQcAD/fsLfT7fkRnQHAFJfAAdrtdlBDYeAD3er5AD+fr+kg ApT7ADsd7oAA
dDQgAD9fb9hoFAs4AoGAlFhL5er6ACLSiFABYKhatIYENFf7/sMIxWKxcRx0 QhcIHZNGmPzG
ZsLDWTJhuRiWNkeTzWkhJ9RB4AAfDtsMZbNAAAOTbLfawABAHBGrDOHhiUTq QADcbzbACQQq
VhqFR6AAD4fNRQR4Q940OghyVTqRACtWKpsIe1oAT6VUuMhWTc7rcoAN52Nc 1Ad3d7wdwAFo
sF4AQZ96q5qcyJVleU4AFgWhWAAUpOlahrSEU5AAGKZBhgABcLqkdyqigJgp AANw0jksR9KW
hhrGyar3DsNKJgcix/RgrJ8HsAAvi2MIAC8LAxKepKHscybsR/ICFuwxx/oW 2b0SEhkmIY0y
HHEcZwAARhIkSAAJS0ABADywDQgAkyUGAYZfQMWZXAAe01tlNoQhCEQADALw xyyCAKKLGJkm
YY4AFMVJRgAIwhpgJYkCchpGklLEpHCAA/j0QYAAiCIJgAchynHKpIOqFIUB UAA0DG+MntNJ
MoAAVJWwKYZimExDsS0CQABcFr9iYJdEJuniDAEAB1HYtBQFCToAHLY6un+s ACgIlApikkQc
BuHYAE0ThLAAbJsmwAAzjMNQABMEoUVgAA6DsN6GkZCDZAEhZlmYzxUFQ84c BwHQACqKgsqy
e57gAPg+jvMIDp4QxDEYhLFGmaZogAUNiAAGAYBkAAti4L6GnQdBzAATJMWw eeRAAB2S1CNL
4kURTqoYRJEkcgoBpwZhls8VJUlMAAbhuHIACoKors1J+hLCxWVsBC4Foaem mAACgKgqAB66
apKyK8uCSAFmQAWYu4GAaBqynWdYAAZs2l6aOo9D4vEnaJt7RJJtyHASBDdg dr8wgMlDSH1H
x5HoeeuLqABtGwa4AD2PDVIgNY33SGIZhmyG5bfyyRk8UJTbny6SVRzqGQu3 ZHkaR9JglSwE
gUBQAZknDI2U7AA3dNqFn5281HsegAH5vwADqOw7AAcx0HT0DSzaxfPoVhUs 0pvSeeWh8YMU
dR1qqhgDpPkmwRlf57ntf4JgnPE1xpNd/giiu9JQeB4HiAB8nyvlegBqFLOs dVgIaRZGMANE
aIz1Hh/EIABaQOAADuHefcCbqAADycAj0vhDAGIYAUAt1jTB5EJIWAmDzuV/ j4Og8khsHjdt
maUfUd5BSDgPRcc+EbIndtEelBwkbc3lpKIgRQBxsklDwHe/Ah0NSEgWAung eQ8XdwiKiQwC
8R4HxKhhE0hJNycANbwWIfZfHzAAfGngeo8x6xTR+aMsMRCJRoIjDxghPDJP JMdEB+A+46AA
dUbskxPGmOCAeA0iw9h6o0j82EeA7R4FtH6XB7RPAGx9KkOodrbSGgLAa0pG BYItlkH4W8h6
QY3kRMmlCNSSZOw2eYQwBwEWwj+H4WBqa/4SEPAYA5pT2iUDtHXCsxJYI8x2 AWbuDSFgFAMf
iPcvg/R/lkXcTgfQ+CyHoAK9sB0jnAo0HwPcrhEJFgAkbMSXEhzEnYm2AgBJ PDIzXKiF8M5h
AcrTAAGILYZiGtfdYV8pZciUSsMUbMhcYoNgHAIbtvxS0xAAguAksqGjcAFd ZHREqSph0Imi
Xd6w6gAAWAoBZ3krYHwRSadaWLx2FOcMeAZvbJAHzEes8YqZVQNlDNwAehDI oxzhIazJX0WG
lFJK5F0Cj5AATVhgVybcF5gNTQsAlpR0ZjzJIK7N+MzqUNhdmQseI8HBEkdd SiYke2Yq+grI
Qd7gh+SJZJFmqoAH3VZpC08CLUh6PfHvFRobb5Q0hQc56vBnzEkTpSQpXw8a xyleTKQhgFQL
VvHoPKMdcy+GmNAYom0VwHtKghCtZpKAFVKAAPOxlG2sEJFUK0UQABqjWYcI EPrMIhk5AQSi
ehUiqUGgubicgALBO7kuQ03RPIKm7evRZLSeDEkLiS7s0gCwGUIH8UYp8Wy2 j7SS5yHJj3pW
GsJXmUzzILlOdUU4+zgpElgIZOQnlynWDyHhGOh1ICGRYdY8keY8UaXvAdfE yd876kPAkBSH
sgCozXL4ZG8zeicDys8AACAD63prK5fCtQ7rxFfIbgXArY3jPjaiUYxTUyo0 2lOQl1DYR+1l
ijfshCzScEVmJK+YsE3a3ZMzDq7drUoUklAkqpRu1mq+HSOt4wFwKgXkRh0e UsLrO0AgBNsI
8x33sxNJ+M91ozGaSZLO/BCL9RpIRB670vwADvHZBtUpCAEAKN2XXHw6i0AX AsBkoo/MOjzy
QQtr9CHkj1yPD4hAhhIh+OfM0lIgxKW4ydHaD4BAAkoK1E1JzcUwWtr2Q5IW ONJuXlFGfR92
nm0iy5jNztd9O6ZxpXWw0aLsSgg4qi6rn9U4hMxGqU918p111trXVbyJPawr 03AiDsq+42lK
aSfZ1tN7BdhX3ZOkKPno0okNt2m73Rl2bBzS21dP6d1hpbbmxNnnX2xtNy2s tfbfr5uY9Grz
MOc2vrfGuv9PbOaLrLb24XkOdSZsnd7Qm3XV1BpJy+zMqaehxvzfcREnb+16 0UiQcGb7x4gQ
gSAWQrcR0zvviCRiHhVC+E3eIhxBiLAAHkPodd4irFILPHOvN0ba0jmXeFHy lFcE2J4jQwBg
C9jSkFtwPgfBBAA4sPaai9ltyjuXXG9tQY0SEGgNYYAABtDYHAAAOQcLUqvD Pgeqt3byePxf
mNyqESbKW/Ivlpxpk1LkuEEi5JtrNLu7rFC5d8bv7A8qM5k1KkWF2L4XIAAa AtgQ9mcpYh/l
cAhKnMI7IhbB0vwDT25MzALJQHkP/JhrjZNvxExbc36gVaelUQQk3BxuMjvX WJCQDAJJQwwa
XbAU7yV860g71Fy7s1WQsgxC7x8t5XV8rtHOW60G2OFbgKARk0xKXDhBn+ve cIQD4J4N/oae
GALAY3z9ppC9QaPWRkQF33K7hTRrze4ENxKiVNtESCgEV8PSKR1pKOsSQQj+ EY+lEkx2bjwq
TUhPeh5LBiID5icAFAGqECfCgGkmnAJqNIwoxvbLygEinJyLwB3MyCHgBC7g AB1h2qLI6CyA
OgOAOkwgCCnJAEaPHIqlmCcvWFjFMoJC0gOisABgAi7nwMPnKP8vqtqGhPzp ppiPbIFohDHp
yDdsCh3oFraGlJ8K4F/nbv1CEDdCnOxDnq5uiMkCEI2QCLcIgpECwCbC7ppm wwQLOh4nBIdJ
+IWFfF3EoKlKECvi4HrmyQ1AMALgMItClpAkaCvCwP6nBiUL0Koiol/H0gJK 3wcIyJGmwwmr
PHBG/JniEnyFZiGCqD7ryjckLIKqoiuGmIxvdlJgJq3qbCpoVnsntmwJiOzL Oh5utLJO1oKn
WB4oksFAIK3oZK/IexKh2pdK+m7CnGzHWDoCuRWv8P/NsweBGBEhDGymziGG mHdnVnWG/MBw
VMZklKTCeIumzJiRnmmg5A7g8wevfPoN2wdLtLIiwsFoehtltHEnFgAAjgkg kmLAvuoK5q6D
HxzNpOuPnNJBOBPBRt+ttPJOLIbsum6q1QlBWhXBXxmmwrJwvvxrQiED5i7n 6ixrOoIAAAug
tjCNFinJEyKOktON7sqsZOuteSCmhgBiDw1SRNMPHiIhHBHDqoABoOgg7g+g AAVgVAWw1pES
RySiHH6iGLdyVobKcNnLduYuWSUtQySOvpYnPtrt6EmlTvdHaQ+uXPoNUSkS kNRtQQ2l2iFy
tq8SwPvSsCukYvISUNblTJQDQNXLCNSobNyOBPtPnH6ymCEl3FfKbMQPnSBy 3spCEKVgABbB
dhaSeAUCaC5CeBghiEzBhhjhgiLhJhPlJgHH8QMy6jED0ygS+NzSlKyryNtP TklH6ivw/RrN
8weHKnLSlTVMKSmR0kwQ1K0yzNeyWlfTaiEGtS/tlRrNPSii8S2K8McHpTky ZO8LtJRxxr3O
EthvcqQsbzhx/QMnaD0PbQyhhBiOdANAMgNgABRBShNgAAeAdgfgAFDAqIhn pH6vHTrudiFm
ZSyryKbN/DZw2DJwIyTy20AMqNRSnyoMqtKzXmhKoCEicEYShHLylTfNVSVt 6zPNXQ/uMR+q
8oiS0HlHaS9kYz5zoUES4PfUNuAyDsqu7x+w0iDnYvtOL0BiGBEBKDnDoCoh AA5iWTtNkUQt
nxzUAy8o00fyonltLLIT3wdzsPUyuS2tUSTS5tRFTLsULtm0VISUSIat1K7y rNxSS0st/0NS
wUo0EzmUMUlISHZNsG5q+0TOXEjtwzhnYJJNKU3xyEluYy8U3U7UzOX0ukf0 ON10UPtONNjS
DOM0RPttnPTyhzYRz0lyhkmNdu6rCR90ESnPO0mU/OkUgUizp0gHKUhtn1AU wSYuBt2klVAH
OBthuhsuIVRqPgSgRgTyu0SRy1HC8ArgwgoN4hPhNDzgwgzAtt4hUhRBYkHU YzqP/NINoudo
ykmSIqMlZhtx2gABfBfudBmBmhliyh2GyAKPQgaAZgagAAhAhAhgAASgS1Zh 2B1D7nb0HEwV
QyuuYEhBwhxhuFaAWAYLcKsVNUAzn0gq7SozbCEhnhohmgABDhGoCiGA8A5G 2AYgXnJmh081
/VG0VS0NaCHAIAJAHsIwMTQGuKTh9h8xIzC0yNxjMzgAAALgNFLPz1LHLPeh zhwqLMQVF09y
ZSI132LSm2fGiOCtqvu0yiFsVLo14OGUD2Yt4WCOGWgUz04VSUTxkNWJQ2rT lG2rmqQTAU12
oR9UkymwuKbUG2e1ItqQ1WVjSPepduWNXKoW0i8W1zW1b1G1LV5WL1MiIWVl lCwLm272e2pz
qTeHWmtylSXqzLdzAC8WeU5WhVExQM+TdUfWlxkU90jCJTSMKDrTPW62LVmS kRzBihhzLBlB
khkCIww2QuCDFQoCIgal7AAAdAegfWA1BMrXbTXqSDsMF2PV2HjAOAPCsB0H rO6XKWwOXjSB
MhOBQ2u2h1H0qvqw7MiFMhxAABTuHiKCLAmglglgAAfAegeKQBdBdBdgABYh YhZHeMSgAAyA
xkeJZ3eh2xL2BOFzm0+X71Lsp1Xj01JKRJSBbhcX0hwhwBvgAAnAnEPANKYN 4tWUy0CXjXnq
92cLs4J0M1ASC022vvOWNUyX90ktT37VPt0uDWTtJVkYHu7Ug0Y0oYNW84XT C06we4G2UCE3
5CqhZBcSHBxBxEqJAoxgOANwSAtgsAu2WAJs4WeYM0sNLtlzsXG2vWf4VMrW /3A363PXa4HY
IXKz/4oYs4S36YT1D1NLsW0TU1UE22/TPiutjPcCSHbiyBOBPvSByhzByXvA eugAiAhAlE2w
NuFNhYvX8t1W21GYuNcjIYw5DUJYtqQYPNOU85B1MVH1mYXnPYZpTYK4Qy3M Y4UK9YT1O0A2
zZFYq1AuYYRXoZNU+4IyTZOUM5W5AM+EDBchVixHemfAlVhYsHKz5zB4GXAX 84rXcUyti4Wt
YyqtJ39y5z3lTmhzPWmnmZL23ZFzmUv4XXOZXYOUMZstW2pN3ZEki26tgNq2 lVRN2VCVB1Ey
8zXU6Zztzv84Y5V26WnZijM51vfY25dTlyoZ7WmZ5XN4mZhVESnSwUfzpZf3 7YqXb5VPn5q3
a2cMb36ZC4o6A5gPqgA5yVa6KuuaDZmnQZ2y7Z6vIVU4u1S5s5SZ+iGAQASi iYHHOBzBxHjA
NAPMiUCXnCEhwBuj2t00t5YsQ1l030foatrqDxmnWJt2VrdxVmmHzh6wsuDa EypDNQgIooZ5
4ZN5O3/OCCJHVKEBpBqoBCGAWgVgYis6mnm6bWy5FUrYOyo5R6JYaUC1S4tZ 72n625S5/U5u
t0maIZg5FU0vmx+aQ1J2c3ayqXJ5d67KRUqaBq6yxmtSsicRQDRLdytzVk80 75xx/aC5SZKY
xTmZetsscS5Xj7CZK5JWY6P674vuW15U0rAT6mtmuiaibZY2eXW3WvbDRZ+Y XUh1K5GPHqSZ
QaBYIWKweVK5M5Xa8bVaD1HaEtr6oEHZyDZG3AGmzh6B6qa0e3O55nLMcBLh MhPbN5qWvyBu
FG5gMQ7Fw1YkRiyBwBw3qhzniobQRANAAE3i2CGBqhrluB2X5bhsuWM636sc B0NZT6r7gX8L
piHRUu1C7nAr2I66FZE8BX8TX0uDQ2M1Ryv8Ka+7unQaTbVvH7DaI6NSp6sa +VQki4/5qFUE
gcOOMa1s+bitv6g7/1DDJyWwCgFqEWjT9ujClpAF/r2yUjSci2rofFfIdUeD Gq+w/Y1bM7Ca
DboWfcpuMN258Iacba9afZN5M5wZVYPUOS4ZHaJ0wzfklP3FfQa8kiEpkDFC v83zhNIcvte8
2Ju3CFfKmF+iuQI8Vy34MZRy69ASn8/ZA8CbE5Xt47kcD7t1N64cK8s5lUV9 DZD5Ya57k7Bd
H8s5/uByqNg8Rzka35r5oSSZB8jCFszinQ1HdanbMSZZKUjXQbQWY0i8QZK7 XZddIYTcS5U8
TZOWrYHyq4w6eDJdR9EYHWAMZdjUJdC8DSz8ibT1/U2NxUe5n9qVC2vTXDRb DN85n9rRj8Sb
eTsNX7O8PaF53dG8n1XbTcbbd2zyDvUZwcXK7Pua68y3+8tJOvm7uYSd+a3N zaL9Ma+99988
QvOXL5sYt7Ryh6GtoZu7fvq8p5L+IXLaSYS7fZTeKUAUKrC06KP8U5VZjx+9 F7ld2VLYPTAo
34M4N+D4sMGGwiGB4wL6Fdc8vct8Q8Y+BZA8w9acX9e9y8ablyY60byeS26c N9L9/WA8qt7L
qTYarVMV5I1bkVJc6OAK0ylXUi6i72xK+2eJMrQPxzWVlzBbSeLbWd+nj+pO I1CaR+ldo9ed
MyuemdNzP7RUVnaKti5C73UpSJEilr27cc5Uu7d7nyTeRehPIe76Ldb7mbFe 5dD9z+abS8qd
FfI90dGXAe6e09c+zCEhKBLhN5IKR9ncreb4UZRN55U/F5p39a5eNaO+fcA6 +1F6hQeK7/Ef
YeWdjr3JR8yfM9Sa4/J154rdbX78a8T/LuWZnuEdl5trr7g/T8B0j0/fU909 dfpZi618jczy
sw2SXHaUXbKEY40tkTT6A+Fwd7ncytTe02//N6o54xza+d/zC1X5Imi96xyd TiaiAAIBAACw
KCQYAAEAgB+v5/AB9w2IP9/gB/RQAACMRmMwuOR+Px6QSORxWRyKEySQwmUS qWy6VRyXx2Ty
mYySZyybymRSadz+aSugUKYUOjRqZTaj0afUGmSCm0uiTSc1KY1WnVScVeuU mQVirVOw2OyV
mw1GeSSTWCdxuuz+Fx6sVW41uVyiezeK2il1Gm2uoV+2Ry+WWiYWvUO0TPB4 jA0PB0qv3e1U
ii5OWwqT3jJR63YmzZLE5qYXLDaCa6i7arV6DM5fJ7DY1vTayiya91zcXzcR /e5XH4XP5bH8
XfWrhyq/RnfyXmTvIzHHc+b57pXrsV7hYqf83qa3Twvp+PiW3o9+gdbQyWK+ flVJ/1jp6ej4
7C/LZ4b56n0W+xPo7LoKs6b3NsqyctrAEFLawT/uBBkFv+uqzuusjcsOoMCL g2SXLnArlv1B
zCPBCLjve/0Sq486MP2/kFJyvierisDvOM50BxvEzwvzA8eLFAsSQFDkRqOw cjR9CDaKQtCf
M9FsbKBJsnw3KDyu6skgP6ukiQA5MFNzLL5xAsrETKpboyezilIEhYCAKAgA AOBADTiBIDoI
AwCuYip8nyfQAHwex8AAfR9H2hh+H6iyLyW8sayvKcHucqMgRbNLqxxSMUyf C8DU9Kzr01Lk
RLHMdJyEwSFgGAaBgJVwAAJVagn8ftFH2fh+IYiR/oc4ifU6/r6wrFMXO5HT qvU+kmu5UUYq
fClRMTR9ir7Y9hU3LtUVBC8svpGj7VBa6bAiCgMr2xdRuZbqpQTdkF0opUzS w0VqU9NVrJ09
N6W1JF51JIt+0lHd2NJLyys1ZbIWI9d6pxCd+YBCkhxfFGG2VhieLnfeFxpD qjYemtu2Szkt
2BZ8r33aMqYxb19pFl7NVZVtY1hmiBIGhyH1xRVcVyhqKovTtfyTHUpgDk1s wFlV8PqwGKyj
g+oQbEKWsRdeN0wtLT6WuqFIWgqBgRmgDVkATNIih58VrQiJH7XiNaddN76X fOK3vTDX4S2y
X5A9O7tExuo3bd2HX1HMNqrMS7Xg7MmSHuNScHw2nqJvujtdp+r7xokAc1Eu +8Pyl0x61G/q
Tl7MSDSHQ5Y6lNcTC2LY5j+pRNz17NjyVwwd1C7Lx0HVM2/jTcl4Hadleiwe NezX8LiKO+Vw
DWMiv7gLc3b2QDK3q3S5NfrzcOkVG4fuO33dPuxxTwPjTXHL0mdpxPIjeYW2 OrUbCu6fllGA
2LJjt3RoZRw61KsAX+H1fg8GAzCiUv3SJAB2Lpn9wKgYWN0yQGOwWUk5cyi4 kIqdbu815BhH
zMRfEXk/bCW+IIcmxstb4H6rHJepdYzWVHOEg9BRf5UGuOfaYTKGEGX1LWcY 6w3zBkepbMM8
CET/WLPLSrBKJcTmJwHVO7UtpTYhOYRy4GH754HspdFDFEJyYEmKIxCx7UE3 9PnVNBqNcNib
NmIyqsgYBgDp0AUAwBIAAGAOAWAABACQENwIqPYeo9gAD0HiPUAA9h7D3Igo YhijCKLARYwJ
CEWoUv1OE6+EcWIwLEU4lYtkGXVsSRGe6GERnxQkNCzAhabFYADThHYkDOVd KKVqQ9oL+EuL
yk1AtM8H0KphlGWGVsxJhw1iqXt28pUvuxMC/c8TUlktNlDHFMiPIoK+fJKI 4pHiAoAvoE/w
DBQADIQAAbCwABocAHxEQA7IoAH7FwAC41CoYBY8AJBIZFI5JJZNJ5RKZVK5 ZLZdL5hMZlM5
pNZtN5xOZ1O55PZ9P6BQaFQ6JRaNR6RSaVS6ZTadT6hUalU6pVatV6xWa1W6 5Xa9X7BYbFY7
JZbNZ7RabVa7Zbbdb7hcblc7pdbtd7xeb1e75fb9f8BgcFg8JhcNh8RTFxi3 +GMcAATkYtGH
9lQA7cxEIkE84AIKAQA+dEAMq/sTp9RqdVq9Zrddr9hsdls9ptdtt9xud1u9 5vd9v+BweFw+
JxeNx+RyeVy+Zzedz+h0a6xOo/wj19Jln/2wB23+AHD4QAEPIAAJ5wA/PV0v Z7fd7/h8fl8/
p9ft9/x+f1+/5/f8/8AQDAUBwJAsDQPBEEwVBcGJ4Z8Hn+AUJJG0qRm5C4AA 1DQAH3DsGw/E
EQxFEcSRLE0TxRFMVRXFkWxdF8YRjGUZxpGsbRvHEcv+aMeH/CqRQq7wAG7I gAMcDDJn6nch
Q6fYAHedB0AAahaFqAB1GoagAH0eJ5JGAwHgeAALBYFYABYJglgACLHo8ArP IMn0mQ8d0ogA
apZllK5qmm0MupGA8wzGFYWAAFYmicAAJTaj7Pp/OcnHSdcpFsYRZgAbBvmq AB5HqeLuu4Bo
FgcAAVBFQolB9RILgrJE3Tg0EdVlWdaVrW1b1xXNdV3Xle19X9gWDYVh2JYt jWPZC9QeZ8fO
07khQrIhuzGCwLSW7jRHyABrF6XwAGgUBQgAjwCIUCYKTWDYM1gAB3HKc4AH mismgAGAwC/U
ohiEAAD37dibSFbIAGyX5egAa5T3EBQDgNMYMyQCANg8kCDHgcpxyuc94Hsf FtBSLN8BOIIh
35f1HYBbDRl+ZBeAAUpbFAAAEAZN4KA3dALAqC8kgAdJ1XgdpzHdDh7SULYl jCAAghwImSgP
f9k6jqWp6ogAAgUDgkFg0HhEJhULhkNh0PiERiUTikVi0XjEZjUbjkdj0fkE hkUjkklk0nlE
GfoAczbawAeoLEAAEoaBspnE5nU7gb9eYAlzgAEyFQAmwDnlJpVLpkKn1Aaz kAAPEgmAAWBN
IpsNeDia4Ac4EDgAFM2rdntErlsvmMzms3tFxuVzul1u13u9Pl1SqlWrFavG BwWDwmFw2HxG
JxWLxmNx2PyGRyWTymVy2XzGZzWbnbMzz/0D/AD+0mj0sEbupq4WC0dfevAD XXq+ADPTSbAA
QBAIAA6DgaAAzJBGAAdL5cAABAdIcSiUgAZy2XIAYricoAeD4e4AGJmMtkIZ CAAF8kZ177AD
aX68oCkTIAEAWBnBGIiAAfIBFAAYIpWgQBKQdJeFWABwF86ZnGcbgAG+dR6J oLgzgAEwgiI8
byow84AF+ZD2FAWJMAACIPAWAAWhuEYACKGwlgAJAZCmmB8p+WZlFMABiGgY AAGwZqpHgcbt
jCJ40AAIIcQs8gCs5JkmydJ8oSjKUpypKsrSvLEsy1LaTnMY5VAATRhAMAAz DiKCjTJLk1s0
fAAFoIwnAASQ0EoABdCkqyBO2Y5PEk2ISiyAAxB6D02JQeBqFqABIFYeAADG PQtuLNSSnwbY
ADSJw1gAIxKleAAohLEtDpyfRxAAUhClOAARjOOIAByDVKsifBtUyJw2RUSh XABPL5o7U9U1
XVtX1jWaJu2WQ0ieAE7V0WJLzkBKcnGXxPABRYggANAhBChaV0U3BWGoCVID i/wO1oxU3ThO
U6TtPE9ABPk/UBQVCUMxxzGZMBMmkDIADxQgAWpJh+0eYZUFDVJQ0Wb6CBCH QADeNIzAAJYY
OAwZ74gUpJYYAofYuK1ZMxYVVVZV1YVlda6T4UpNAAYR2IE3iDHwfB3gADgd DGAAth6DqNVt
XFdCLXlfBM+d+X9gGBYJg0tnpiBVEqSwAE4XpooKEIXxaMo6jSAAaAtMkvTA UZlHOAGboOA4
AAyD6rBcHQcgAFCsIPes/muEotUHoSDY6AGP4YfOfcDodS8ZxvHcfyHI8lyf Kcry3L8xzLKN
CAGczcaPQPSbVbnz0rkgCAKS84A/WQmEyrBf2O2t30/UoIZPcH+0h/ABznd9 60AAG94bVtaj
h2HMc0NjwPQAAm0opAam4QAgBwAAYGQYAAA4rCo/6kHyVZWgAehmGbAp3niA BXHmn52gEAUj
EQQwAAoDWNoudpzOuZ5DjsTQChSAbgtAqAABwGICgJBK9oBoNAmH/fi+VRY9 xtDOAAPEc46w
ADJGmOooA7CVgxDyIp5wGgNkZHMOg64fxKB1euB0pALAgsBAsBWAoKANAxAA DcEKFh7D6QeM
YbouECjqGwAAdo7n1DWGAOh8g4yViBDYIsowGITuaixFmLUW4uRdi9F+MEYY xOaHMMARCkBE
j1AAJYWAgwAAhbhGOORGh9AAGCH5ZovQfCdAAIIIj+I6i/Das0VwR2ZCTCY4 uOZBB6RHEGFV
WAxgABAjWLAO8b44klH68oRYTGfgyE6qAIYGm3SLIUPkcYAA+BQYuD4TQsFO gdkyZGTYABEy
eOCJ1Xsf2pEblRKqVgAJXSwCNLIicdRjiLWaIIegeQACxECD4ADLiRvqFgEk LAAB2CMTAGQF
ZcCED3GyAAPYUg4HQIGFsQpzwuAyAmY2Osd48x7j7H8gcgZBvrkMACREii0D xHA1wYo1jtg7
CODgqZgCBjmF+HxSAippCtFucQBSTR8RHDaFFrAVBJh9AADuK4uRKBeWcbSc goRaAAB4BahR
cY6jAEos0RKi2yBxPeIMIy+jLS/lXK2V8sZZl1peH2mQAUWhqBqB8grpR5Ii BaEkAAQwTrmI
zLWW7PwZy6ABLwllDaH0RomACiqWX1CxDXNkTA3gagAD8JMNp9x9oLFKHIQQ AAXCZfGEcD1F
YyxnDGIkYKRguM/BSAcfIABwjSOeLUZZBg0CPFQAAJ4KAHz3AAMAN0hAmsyE kEWRSDxdyPAA
I4YyLRSi+hcBIfJ25TWttda+2FsbZWztpbW21tzKOeAALy3gAB3W/AAEq4Vd gXAuKGAtEpyy
kOodTcx2pBXOEEd+78et1QADSuwtkWqiwJXdq2ERCxu5SgAGPeV3Rpbpmlc4 akboAAL3vI6M
05wAEBHsDABCyoInbAIOWAAYYBACAAGWAxUjqAAAyHog8IA/CVj4H6Ssbw/j RCgHg+oC94Dg
heOQRgaoqRPgAH6NI2gUwhKGAOA83gBQG0VAKBI1oBQNAoIEAF+I+xzFfH2O 2Dw+x5j2AAPk
eJ2xWi+VQAMFx4gVhXDCRkUwshQHUGoewHoYkUgNAibwAwB0yAPAVO8DYDkU j7H9Ycco8RvE
wHxU0fY+j0DzHem4YYnr2g7BYhYLQTgwW4z1nvPmfc/Z/0BoHQTlB0jDEZGh 1ImxXBzbjNTQ
cXo6jDEAFIAEemZCACE/gpAFAOwnASPkdwABxoOtadsXgjgqqMpMQKSmig6a NI/g/EF/QBj/
1CIwJtJAZCafHpmoJKB+j6jqAMA2jsQayuUZgAZ8wOAbXNqA646x6ErIcSvY RAti0tIJg8le
ySUj8eUICYMrhWAA0zeMjOy2ebOx+O7aO0yG6yAAcslYzhGLND8PWS4rg/g9 mmSgeI0gABMC
3k8TIuGsAbH4m4hA5xjsMDKIVAhBQehvAAKsO5+pemH0jpPSsrgAaY00/XTr BdQai1IXIcou
A/AADOnYACn66gfSWQUBYFCxgTAVYccw4oND8SaAM3gEwKQFAEPp9Q9Y6gAA aPsaoAAahGbG
FAPwnAABkBsBguY5xk9WDKIOWBBAgh4ZkHMHj+ClbW6XtkhO3N539ITurZuz 93AA2ltQu+kR
A6UF8EdMAlgnrfII6h+I/R8KPHWPC1hGNwch3GJrcu5yh84edzslnPgAdASw Po64lApISG8H
dAgognAXAAPsAKZAGAMoqPodzbNpHo0Loev7qRVDKioCEATqcAJLHcNBAgQw wRuIFpQTYsQx
NxAH3rvgPWZB/0yAAbIsn6BzE1JIRAsRkAABwAZmu8NH/h/F+P8n5fzfn/R+ nPqCYLDQ/cAA
NX8b3XwwBgH+oAP7vwfj/oht6XeO3B+QAvTjYB1QCuYhKhKgAAYQFsDgZAZC ChhwIrzneHfL
0DSnhszgMQNCOhjBAK6gNB1B0gAArgFKKnrCBBgB7I1Bdh7rWACDAHbQBAig ElqAgAFESqmi
BBUh7MfBzALutAdA/qPCMByBLg8I3gIrDgVgWmAgDgIFqMVG4ACAEjeABADm pHUsxsfB+B7r
DseE3B8vFAABqhpm2BwB4DeANg0BDiMhFBSKHACgMjtgZAkqlACADCkQXn4w XikACw7nesJA
AB9B/I6sHv/h+neB9h8ugBnBblUB+B0FqA7AuBCP1RLRLxMRMxNRNxOROknh 1BihHOrhEiBK
8A5G4gCiVhrBcMPg8BLBZCDgWgAAyhCFdAmgXKKhcBHKPBrAVOLA5AkEUiDI 6hlBRhAgABdg
FgrpyAnmAhZhIhIAABNhgBpiDAbtUhFg0nAKpttDAh4hupJBOg4ozkdiDAnA 3ozgvAhiilaB
9ChBOA6BSr3AsKEBxBEBIgADpjvsmgmmCxvuLhKFYBTBkiCAbgAAwAylDBmv tlMg/gumeNjC
FjthpBZlsA+BNjpyCgwBAAAA5ApQHuNo6hshglehKhGkbihCDA1BJBUkXAQM AhiBBEYhfAej
3g/IZiBjthjBKo3BngWEJA1gfqlRBR3x4meAuFthuhCIzyMiBAWk5BEA5qSA VAJF1hzhpIiB
KA+GsRqiDA3yWKogQGpSJyKpVSMCCgbyNyOyPmCiLh3BshegABGg6x8SuynN UhHg8nAARgGR
uiBByBghLv4BGhbgABDhSGsBiAuFsAlBWuWgOuaiLDthnBXTBBABQRyiBgjg qkYhcnxSOhMk
CAgAMqgy3y4y5y6iCAWy8S9FWy+iBR3GsyjAOAwD9B1hWxKhVy7AbjvhOg5A drrhPM8hIymp
JpVBMmxgbAMuNl6CpSKzBSMS7CBAQAjjvg7AxR+gOTmCISrysytgATpCByvy WghyxTYBwzZD
3gSg7KPAfztCwBjBRlnBrFDAxAbDtg4zviCAjg5k/gvgVNQhIgxyOSCTpgjg 1AAA+g0AkAAA
KjATYx4R5AOSkAASlSmTVSoSpAASqE1B+G2BBPPgASakCIZzSy4S5S6TwTVT WS9zXxBT0R4T
1T2AAT3ONzTUUTUzpggFtgBhgBf0KggJLhWzfjxiB0bzUUVCBzVgAS80Wy/C Ch1hlOrAxhVM
ZBaBIgeDRj0CDtQhZg4s8hNgUFYA7gIhiJbBSLGg/pQjg0HRhyi0JUKULR80 MAASoypyqycg
ASdxKhngRlmgWB1hYy5TdCBiZyNpnSPmAiBD0SYyZyaq2ScE909SeDayfgAS gyhiBqAJJBSB
NymTwtWNGBUg5Afl6UThLhKx8BkyUiCAgAtKHAzAsAbJphyS4gqA1R8CETqN GBEygjsBjBRT
DBnqlVe1Speh7znBPToBczwzqTrTsGeVj1JxKhrAURlgZB7D2BARp1CxZhCK PRboCiPQ9gBH
eB+HeCDAAoPBHgmgyG2g9FsA0gcAKCLB6ChBUBIg3AASBiCCZg1BESOAkSqC FB3ILA4S1AUg
+x8AZBnOLBbgTSbVIh+m2BUA/Q2BpgQlmg7AyAhipiCB7r2hOA7lYAAAsD3g yAdGAhzz4z5z
6z7gAT8msT9z+gAT/0A0BoN1C0D0E0F0G0H0YA6UZT2z3i8D0BihByZgeOrA +ggnjCIVkAAB
cBSmGRX0CiCgjk5hWFOAQABUP0Q0RkjTST4VghD1hpbVfGpWVz5BKBrDgAvA ZH1A6zLy0Aqw
jg2AumJrKzYB3CXhUhLkQhV1ViCggSvyOzyiDV7AAV8V9V+Vu1/2A2BiIh+I PBMApV3BbAsA
/gABUgtAZy2iHRQRRAyRSAABMBVRTpSCDADgHICh3hbnmgsBE0fg3hJzyAPs A2jyZgjsng4g
LBlAAAtA3GsAuBGKUg0ntIkB7V0RPXmXm3nXn3oXo3pXptBBTXrLiLjAe3tA AP+P7tktkv+P
+CGP/NjiVu3XztZBiX1AAHQGuAtX3iChgX5DQjRXyHfwMD9wNiOBjA5oXAeP dtzQqG2kAJbB
1oPB3DTsDLoDRAIH4AAA8obHOjSheh7DthijRDehGoqCMB8hPpzgSgUV6AOg TDWgDgIsWAFm
4ABAEMAkACkDRYMVzsQRFvTh6rDh8h3sfBxhtIPBthsGagDgwxoiMBAhSlYA VgevTASAZvTQ
/Q9gB1yYoiBjRMxDRVz1zREPM4ZBtBmQRBrhiInA/gt4h3qYy4zYz40Y041Y 1ouB1hjRogzY
NhLhVJzgMACk3BqhdkdgDgcWsAXutI7BMtKBChW13BQBXgoxBBfXNAzBJgIJ +WtGeDAPflQg
xxjg3BMFQAggHonBghgQRAZAl1ZgKB6OnhFAtIXB4AzhGgAA/gkD7DBB9ByB hQRg2hHmyAxH
6A9AsAaHOhrBbXgA4RogWgx5WBBAmZYB8m2BNAsUETCiBAwBAxogfASoTgJg EmdhRgomLtyk
YhKhXGfgOh6RqhGAvJL5aVShJBUJzpjCIhvBaRSA5hOugBFhVK6gVh+Ong/Z UH6g7GZAzgco
C53oz55SCAlA4IqAyAjAVnOh0GIB8AFOtAIgDiVhjBCD/SaTBA+Af5APTkca LpngdmsBF1I5
lEw5mgAZnyDhAwEghAMH1BPAznmkdnAJQtUgJB+ipBJgqK3h5A4QEhDAnFvh 2BtpUh9gJPTA
HACDRZ35455gAZ65758q2Z+AKZ/OXaAiI5ZZaAr5bXgBDVggyAaDeBZA9D/B IB9GxhTBAjiG
pB+h1rGgqAzH6AlBDRYA8gbmag4ghmsAwBVA9gAANzIiJhvBc54hMPtg7BKk wAgAOk3BehLK
6hGhcEFg4BLrI6OG4at5a5bgtawOr6xgAay6z601962OTZl6UaVAog9QEgog Nz0BBg1oSFMC
BARgpbAA/goIChUAvJz3MBCgABXgriiiBINBVZtgAFWNKbF13AQgCGIBOg7F OBWhuFBPID/U
2tq6daeAAafagahJtaivT6kIDaliBUPAAJH0EAeBKlWAg3Uh0hixog0BGLAi BQHhAhMpzgFB
rrIg6hIZgCCAwhDD3gegChoFBg6zBZiz5ZkFgaTZmZnCB5o6W6XgAaY6Z3gA AabAAAJRIAAB
CAqmxge7L0aAMbNZZ7Oav6w7Q7RlGbS61627071qVb3EjXUh9B0BjwRg0oSA gA0oqA5AogTg
ABxBfsng2BDle0aIXY6GJh/8Vau7O7P6xayazcYa1bTztzYAABkBGxlhfAfz 5A/gaD50tiCh
9Bw6uA4Zbg0hNhdXgAHpJAegrSOAYg0ISA/AjgSiDcI7VcKaWNzcL8MrL8N8 OlzD0BlBID/B
D77lQtXhPAoiihsBUQ2BFBbFMA4hJkbgfAOMA6LaMcSpVaOCB1GaQBY6RaoS cbN8piBAaPkh
Mg7E0GAlHhxh2HeANgMrKh0hoBdwxgDAXqtga6hhjj3gxA/nxg63aqVAQikB lBLHvBChbc+7
FJnAXgJHrAFr+AAB0Bfo3A0BbUshVaSUi7j7k7luYhVbnbocObpgAbq7rhWb sgB9FdGTDdHg
ZM8hKg4G7ht6YlGBgSHpQtKKqCUhtBbIqA7hNpJBBhUqUgWADc0CIINBSbkh Wgk7ABXA61Sh
1hej3gzhCoLBBBQRRAW29CBH1BXg5M8hRAKbABghIJKBdA3j9BcgeTBA99Sj kqKgGB4ZaAig
wbggXAs7ghAgrASGZhIxlhHhgGxhahhE0B9B2sfb5b6b7CB7879qxb/AAcAc BCB8CcDcEcFc
GBG8HARFgcaAq72cb74N0C5j0BjBCj/BFgOOLBCmTPMrDv8ICgTgTOtAB63l U65d4CaAAbFR
jggAQjeBxhvonAHgMwmh+oncRcScTbMr6dvludxAAdyFtzI+rFuesCBWscCl JgHhxEdg1hCl
sAXK/gABAgmCrBsBWtGA8hSIdBRBbFOAIB4ChB0h9ibgKalCB+K+L+Mn1+OO 7ePuXeRI++Sk
TeUCGABFqBzhcKPA1BLrGj7jiA7A1HvAcgTVxCD43Y4Y5Y6D97BiDAGgBipF NK3gRA6BJluA
dvTBjBI+6gDEWgcCALpagB+mlKgBJFkSAB0O17ACIRGJROKRWLReMRmNRuOR 2PR+QSGRSOSS
WTSeUSmVSuWS2XS+YTGZTOaTWbTecTmdTueT2fT+gUGhUOiUWjUekUmlS1Z0 0AEyoAAH1OLg
GrACrAGq1eLP+vROvP+NvCyABaWcAE21RNe21/v64ACwgC4P66XFvXkABi+S tmno+AAfgYC4
IHA0AAUCgYAIdzOUAO6vgECASwPx+AAJVc8hoNAB96EAMF5PLRvrMjNDISTv lTnYACoYBkAC
IV58DBAEgABgrGAID5bEgKKPy7P585l+vV9AB9PB7gBvtVzABqtBzgADllFS dEqw7gAXEENg
AUDMMYkB8QDAMBgAEgTCggB5axWJ8P3Mvd95l8n6foAH4fq7GwZjsmkYDqjw KpEqXB8IQjCU
JwpCsLQvDEMw1DcOQ7D0PxBEMRRHEifnWZBJgANJGIgSpTjaAALgKywJgyCy sHqdzIno6JtF
UKoADwVAegARZRjeAAWAccIACSJ45gAK5AE0AAqhYCQAG2XTWDyTQYgAVpeC iuR6MYDALAUA
B7HadoAHkfrmmCOorgAY4lIOPAegukLonKcR1oIjbMgGBjaA2CTdo8cJeEKA A5kwEIAFeY8k
Re: Menu Contributions [message #576342 is a reply to message #534567] Thu, 20 May 2010 05:09 Go to previous message
Hi Tom,
thank you, for taking the time.
pardon me please, but I cannot decode your attached image.
But I guess the screenshot is about editing the Application.e4xmi, which indeed works out fine.
Maybe we got each other wrong, since I mean adding menus to when editing _ModelComponent_ components.e4xmi
Are we talking at cross-purposes?
Sebastian
Re: Menu Contributions [message #576438 is a reply to message #576342] Fri, 21 May 2010 03:31 Go to previous message
This looks like a "bug" in the model editor (the Menus-item in the Tree
is not making any sense).
You should use the UI-Children and select
Menu/HandledMenuItem/DirectMenuItem in the DropDown.
Tom
Am 20.05.10 11:09, schrieb Sebastian:
> Hi Tom,
> Best regards,
> Sebastian
Re: Menu Contributions [message #576449 is a reply to message #535042] Fri, 21 May 2010 04:18 Go to previous message
Tom, I'm really sorry.
I did not realize the UI Children item, yet.
Looks like I've been "professionally blinkered" (betriebsblind).
Sebastian
Previous Topic:e4 deltas.xml
Next Topic:e4 deltas.xml
Current Time: Sat Jul 26 10:50:55 EDT 2025
Powered by FUDForum. Page generated in 0.29713 seconds
