Home » Archived » Service Component Architecture (SCA) Tools » Re: [stp-dev] STP-SCA Tools not drawing wire lines when reference target uses component URI instead
Re: [stp-dev] STP-SCA Tools not drawing wire lines when reference target uses component URI instead [message #575966] Tue, 01 September 2009 02:17
Hi Luciano,
Seems like a bug indeed.
Can you open a ubg entry in the SCA bugzilla? [0]
Vincent Zurczak.
[0] :
https://bugs.eclipse.org/bugs/buglist.cgi?query_format=speci fic&order=relevance+desc&bug_status=__all__&prod uct=SCA&content=sca
Luciano Resende a écrit :
> Looks like the algorithm used to draw the wiring lines between
> service/reference only works if the reference specify the target
> service in the form of Component/Service URI. Note that, when the
> component only have one service, a Component URI is also valid, but it
> looks like the SCA tools does not recognize it and thus no wiring
> lines are drawn. Please see below my test composite :
> <composite xmlns="http://www.osoa.org/xmlns/sca/1.0"
> xmlns:s="http://sample"
> xmlns:t="http://tuscany.apache.org/xmlns/sca/1.0" name="rest"
> targetNamespace="http://sample">
> <component name="ExpertRegistryComponent">
> <implementation.java
> class="org.apache.tuscany.sample.expertise.ExpertRegistryImpl "/>
> <service name="ExpertRegistry">
> <interface.java
> interface="org.apache.tuscany.sample.expertise.ExpertRegistry "/>
> </service>
> </component>
> <component name="RestExpertiseLocatorComponent">
> class="org.apache.tuscany.sample.expertise.RestfulExpertiseLocator "/>
> <service name="Servlet">
> <t:binding.http uri="http://localhost:8200/experts"/>
> </service>
> <reference name="experts" target="ExpertRegistryComponent"/>
> </component>
> </composite
Vincent Zurczak
EBM WebSourcing
+33 (0) 4 38 12 91 72
Previous Topic:Missing 'Generate Java Skeleton' function
Next Topic:Re: [stp-dev] STP-SCA Tools not drawing wire lines when reference target uses component URI instead
Current Time: Sun Jul 20 21:49:12 EDT 2025
Powered by FUDForum. Page generated in 0.04831 seconds
