| Software update [message #54469] | Mon, 12 December 2005 02:25  |  |
| Eclipse User  |  |  |  |  | OSGi platforms (Equinox) should be a good platform for dealing with software
 updates. Some service could look for updates (automaticaly/"manualy"
 triggered),
 download them and then replace the outdated bundle.
 My question is: How "deep" can the software update work? Are their
 possibilites
 that the software update service can also update itself or the complete
 platform
 without restarting the JVM?
| Re: Software update [message #54787 is a reply to message #54469] | Mon, 12 December 2005 18:18   |  |
| Eclipse User  |  |  |  |  | Originally posted by: jeff_nospam_mcaffer.ca.ibm.com
 the update can go pretty deep.  The Eclipse Update Manager for example
 allows you to lay down new versions of any bundle (including the framework
 itself).  In some cases the updates could be activated dynamicially (without
 restarting).  However, in general, the bundle being updated needs to be
 first stopped, then updated, the restarted.  When you update the bundle, any
 bundles that depend on it must also be stopped and started.
 So you see that, for exapml,e updating the runtime bundle would likely shut
 down all/most of Eclipse.  Note also that it requires all the bundles
 involved to be clean (unregister listeners etc).
 You can also update the so-called "root files" (eclipse.exe, config.ini,
 startup.jar) if you use install handlers.
 Jeff
 "Stefan Liebig" <Stefan.Liebig@compeople.de> wrote in message
 news:7e4625f46c3802a20f1249df62e21e87$1@www.eclipse.org...
 > software
 > triggered),
 > possibilites
 > platform
| Re: Software update [message #54974 is a reply to message #54787] | Thu, 15 December 2005 08:51   |  |
| Eclipse User  |  |  |  |  | Sounds pretty good. But how does the magic work that code which is currently running (update service?) replaces itself (file locks,..)?
 > Jeff
 >>software
 >>triggered),
 >>possibilites
 >>platform
| Re: Software update [message #57588 is a reply to message #54974] | Mon, 23 January 2006 23:00  |  |
 Updating bundles is ok since you are actually laying down a completetly new
 JAR beside the old one.  Then you either restart the framework or recycle
 the bundle.
 Updating the root files is more complicated.  Right now updating things like
 eclipse.exe and startup.jar is harder because they are shared and typically
 locked and do not have version numbers.  We have been talking about a)
 making stratup.jar into a versioned file (perhaps in the plugins dir) and b)
 a way of updating eclipse.exe by putting a copy beside the old one and then
 swapping on restart.
 Jeff
 news:dnrsdu$p3q$1@news.eclipse.org...
 framework
 (without
 any
 shut
 > > Jeff
 > >>software
 > >>triggered),
 > >>possibilites
 > >>platform
FUDForum. Page generated in 0.03116 seconds
