Home » Eclipse Projects » Eclipse 4 » XWT. Composite with XWT UI.
XWT. Composite with XWT UI. [message #532832] Tue, 11 May 2010 06:52 Go to next message
How to create normal SWT Composite with UI created in XWT?
Also same Composite should be used for handling events.
So, I've tried to use x:Class in XWT file, but this causes infinite recursion.
public class Composite_1 extends Composite {
	public Composite_1(Composite parent, int style) {
		super(parent, style);
		setLayout(new FillLayout());
		// load XWT
		String name = Composite_1.class.getSimpleName() + IConstants.XWT_EXTENSION_SUFFIX;
		try {
			URL url = Composite_1.class.getResource(name);
			XWT.load(this, url);
		} catch (Throwable e) {
			throw new Error("Unable to load " + name, e);
<Composite xmlns="http://www.eclipse.org/xwt/presentation" xmlns:x="http://www.eclipse.org/xwt" x:Class="test.Composite_1">
	<Composite.layout>
		<RowLayout/>
	</Composite.layout>
	<Button text="Double click me!"/>
</Composite>
I think that reason is that XWT creates each time new instance of Composite_1, which tries to load XWT file, etc.
Is it possible to avoid x:Class instance, if given "parent" container is already instance of this class?
I'm aware of this discussion, but I want standalone SWT Composite, not just way to use nested XWT files. I.e. just keep XWT as internal details. Is this wrong idea? Which features of XWT I will lose by doing so? Something important in databinding?
Re: XWT. Composite with XWT UI. [message #532994 is a reply to message #532832] Tue, 11 May 2010 15:06 Go to previous messageGo to next message
"Konstantin Scheglov" <Konstantin.Scheglov@gmail.com> wrote in message
news:hsbctv$1qs$1@build.eclipse.org...
> recursion.
> // load XWT
> try {
> <Composite.layout>
> <RowLayout/>
> </Composite.layout>
> </Composite>
Yes, each time, the XWT Loader will create an instance for each
specification of x:Class.
To prevent the creation, you can use the loadWithOptions() with the option
IXWTLoader.CLASS_PROPERTY
URL url = UserComposite.class.getResource(name);
Map<String, Object> options = new HashMap<String, Object>();
options.put(IXWTLoader.CLASS_PROPERTY, this);
options.put(IXWTLoader.CONTAINER_PROPERTY, this);
XWT.loadWithOptions(url, options);
In this case, you should remove the x:Class attribute in the XWT file.
We do it in inverse order. If the current element type is compatible with
x:Class, we reuse the x:Class instance, instead of creating a new one.
> I'm aware of
> http://www.mail-archive.com/e4-dev@eclipse.org/msg02099.html , but I want
Franckly speaking, I have never considered this way to use XWT. My
understanding is this solution provides a solution to define a SWT composite
in XWT, which can be used in standard SWT programming API. But programming
approach is not really the focus of XWT.
> databinding?
I don't know exactly. XWT is not designed to work in this way.
Best regards
Yves YANG
> Konstantin Scheglov,
> Instantiations, Inc.
Re: XWT. Composite with XWT UI. [message #532995 is a reply to message #532994] Tue, 11 May 2010 15:10 Go to previous messageGo to next message
>> databinding?
For sure, we lost the flexibility.
Best regards
Yves YANG
Re: XWT. Composite with XWT UI. [message #533062 is a reply to message #532994] Wed, 12 May 2010 03:25 Go to previous messageGo to next message
OK, thank you.
It seems to work in general, but there is one problem with using such Composite in XWT itself.
For <p:MyComposite> it creates not MyComposite class, but Composite, becase <Composite> is used as root element in XWT file. As I can see, existing of XWT file is checked before checking if type of Metaclass is Widget.
So, when I use this Composite in Java SWT code, I can for example set properties defined in MyComposite.
	public void setText(String text) {
		Button button = (Button) XWT.findElementByName(m_control, "button");
		button.setText(text);
But XWT creates wrong/incompatible type, so fails to set property value.
java.lang.IllegalArgumentException: object is not an instance of declaring class
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.eclipse.e4.xwt.javabean.metadata.properties.BeanProperty.setValue(BeanProperty.java:85)
	at org.eclipse.e4.xwt.javabean.ResourceLoader.initSegmentAttribute(ResourceLoader.java:1645)
	at org.eclipse.e4.xwt.javabean.ResourceLoader.initAttribute(ResourceLoader.java:1414)
	at org.eclipse.e4.xwt.javabean.ResourceLoader.init(ResourceLoader.java:1080)
	at org.eclipse.e4.xwt.javabean.ResourceLoader.doCreate(ResourceLoader.java:634)
	at com.instantiations.designer.xwt.parser.XWTParser$4$1.doCreate(XWTParser.java:177)
Re: XWT. Composite with XWT UI. [message #575839 is a reply to message #532994] Tue, 11 May 2010 15:10 Go to previous messageGo to next message
>> databinding?
Best regards
Yves YANG
Re: XWT. Composite with XWT UI. [message #575875 is a reply to message #532994] Wed, 12 May 2010 03:25 Go to previous message
OK, thank you.
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.e4.xwt.javabean.metadata.properties.BeanProperty .setValue(BeanProperty.java:85)
at org.eclipse.e4.xwt.javabean.ResourceLoader.initSegmentAttrib ute(ResourceLoader.java:1645)
at org.eclipse.e4.xwt.javabean.ResourceLoader.initAttribute(Res ourceLoader.java:1414)
at org.eclipse.e4.xwt.javabean.ResourceLoader.init(ResourceLoad er.java:1080)
at org.eclipse.e4.xwt.javabean.ResourceLoader.doCreate(Resource Loader.java:634)
at com.instantiations.designer.xwt.parser.XWTParser$4$1.doCreat e(XWTParser.java:177)
Previous Topic:XWT. Composite with XWT UI.
Next Topic:Annotatoin @UIEventHandler and @EventHandler
Current Time: Sat Jul 26 02:04:39 EDT 2025
Powered by FUDForum. Page generated in 0.13405 seconds
