Home » Archived » EPF » XML Export
XML Export [message #28002] Tue, 30 January 2007 01:36 Go to next message
When we do a XML export and try to use that XML as an Input to another
tool, we are not able to see the relationship between the Activity and the
Task descriptors below that.
When we tried to analyze the XML we found that the relation ship between
the Activity, Task and other elements are not properly established.
I am not sure, if I am missing something.....did someone have come across
this issue??
Re: XML Export [message #28041 is a reply to message #28002] Tue, 30 January 2007 16:36 Go to previous message
Are you exporting whole method library or as plugin? In either case, you
should see Activity and TaskDescriptor relationships should be established
as this. You should see taskdescriptor as one of the breakdownelement of
an activity if that's what your process authors.
<BreakdownElement xsi:type="uma:Activity" name="act1" ....>
<SuperActivity>_oTu5sLCAEduSh9wCUoXvKw</SuperActivity>
- <BreakdownElement xsi:type="uma:TaskDescriptor" name="taskdesc1" ....>
<SuperActivity>_xuu0gbCAEduSh9wCUoXvKw</SuperActivity>
</BreakdownElement>
</BreakdownElement>
Activity and Task are never related and you won't see that relationships.
What are the "other elements" are you talking about.
Re: XML Export [message #575597 is a reply to message #28002] Tue, 30 January 2007 16:36 Go to previous message
</BreakdownElement>
</BreakdownElement>
Previous Topic:XML Export
Next Topic:inline insertion
Current Time: Tue Sep 23 17:15:49 EDT 2025
Powered by FUDForum. Page generated in 0.03163 seconds
