Home » Archived » DSDP - Mobile Tools for Java (MTJ) » How to use preprocessor?
How to use preprocessor? [message #33205] Thu, 23 July 2009 15:13 Go to next message
I've added this code in me j2me application
//#define SIEMENS
//#ifdef SIEMENS
import com.siemens.mp.io.file.FileConnection;
import com.siemens.mp.io.file.FileSystemRegistry;
//#else
import javax.microedition.io.file.FileConnection;
import javax.microedition.io.file.FileSystemRegistry;
//#endif
However, in Eclipse I have error
"The import javax.microedition.io.file.FileSystemRegistry collides with
another import statement"
So, how can I use preprocessor in Eclipse? Should I install and configure
Antenna for this?
PS I've switched on preprocessor support in project properties via Mobile
Tools for Java->Enable Preprocessing but this not help ;(
Re: How to use preprocessor? [message #33251 is a reply to message #33205] Thu, 23 July 2009 16:13 Go to previous messageGo to next message
Hi Andrey,
Please take a look at our documentation
( http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .mtj.doc.user/html/gettingstarted/gettingstarted.html).
If still you have no success please send us another message!
David Marques
Andrey wrote:
> Hi
> //#define SIEMENS
> //#ifdef SIEMENS
> //#else
> //#endif
> Antenna for this?
Re: How to use preprocessor? [message #33285 is a reply to message #33205] Thu, 23 July 2009 17:15 Go to previous messageGo to next message
Check the "Configuring Preprocessor Support" section on
http://help.eclipse.org/galileo/topic/org.eclipse.mtj.doc.us er/html/gettingstarted/prepare_workbench.html
maybe this is a problem of workspace configuration.
Diego
Re: How to use preprocessor? [message #33390 is a reply to message #33285] Fri, 24 July 2009 17:37 Go to previous message
Hello, Diego!
Seems it helped (MTJ generates different code cause preprocessor
settings), thanks!
However, in Eclipse IDE editor I still have errors (and Quick Fixes
advices too) but Problems tab is empty.
So, last question is how to avoid errors in IDE editor?
Re: How to use preprocessor? [message #575309 is a reply to message #33205] Thu, 23 July 2009 16:13 Go to previous message
Hi Andrey,
David Marques
Andrey wrote:
> Hi
> //#define SIEMENS
> //#ifdef SIEMENS
> //#else
> //#endif
> Antenna for this?
Re: How to use preprocessor? [message #575328 is a reply to message #33205] Thu, 23 July 2009 17:15 Go to previous message
Diego
Re: How to use preprocessor? [message #575396 is a reply to message #33285] Fri, 24 July 2009 17:37 Go to previous message
Hello, Diego!
settings), thanks!
Previous Topic:MTJ downloads as P2 repositories
Next Topic:Build state machine has not been initialized
Current Time: Sun Jul 20 21:05:49 EDT 2025
Powered by FUDForum. Page generated in 0.04522 seconds
