Home » Archived » XML Schema Definition (XSD) » Moving components from one XSD schema to another
Moving components from one XSD schema to another [message #25573] Thu, 31 July 2003 05:48 Go to next message
I need to take a pre-existing XSD, and prune off lots of bits and pieces
that are not relevant for a certain flavor of XML that needs to be
validated. The reason this needs to be done is that the sheer size of the
original XSD (>800kb) makes it unfeasible to validate against.
I have already figured out how to remove parts of a schema (using
ECoreUtil.remove() ), however I am not sure how to re-write the changed
schema back to a file. The re-write I need to do is a bit different to a
plain old write. If the schema I am working on includes/imports another
schema, I also need to write the updated reference schema.
I would very much like to be able to merge the references schemas into a
single smaller main schema. I need to be able to tell all of the
XSDConcreteComponents that they know belong to a different schema, without
breaking the references to them. I also need to update the underlying DOM
representation of these refered schemas.
How do I go about this merging task? What methods do I need to call on
these referred components?
Hayden Marchant
Re: Moving components from one XSD schema to another [message #25612 is a reply to message #25573] Thu, 31 July 2003 07:53 Go to previous message
Hayden,
Given any EObject "x" contained by a resource, (that includes any
XSDConcreteComponent), you can save it back to it's original location like
this
Resource resource = x.eResource();
resource.save(null);
or you can save it to a stream like this
resource.save(System.out, null);
If you want to save your whole set of related schemas to a new location, you
can call resource.setURI() for each resource to change it's location. You'll
also need to change the import/includes to use the new names.
You can only merge included schemas into a single schema since imports imply a
different namespace and each different target namespace will require a
different schema document to be defined. If you want something to be
contained by a particular schema you would add it to the list returned by
xsdSchema.getContents(); adding it to a new container will remove it from its
old container automatically.
> Hayden Marchant
Re: Moving components from one XSD schema to another [message #575061 is a reply to message #25573] Thu, 31 July 2003 07:53 Go to previous message
Hayden,
this
> Hayden Marchant
Previous Topic:Moving components from one XSD schema to another
Next Topic:Generating Java Classes from XSD
Current Time: Fri Nov 07 15:59:16 EST 2025
Powered by FUDForum. Page generated in 0.03976 seconds
