Home » Eclipse Projects » DTP » Error while trying to get UDF, Stored Proc from a Oracle database(10g)
Error while trying to get UDF, Stored Proc from a Oracle database(10g) [message #57485] Mon, 27 July 2009 03:35 Go to next message
When I double click UDF, Stored Proc on DSE, SQL scrap book shows wrong
informations like below
CREATE FUNCTION FC_CONS_INFO (
IN V_OWNER VARCHAR2(0),
IN V_TNAME VARCHAR2(0),
IN V_COL VARCHAR2(0))
RETURNS
NOT DETERMINISTIC
NO_SQL
CALLED ON NULL INPUT
Have I got a DTP setting problem?
here is my environment.
DTP : 1.7.0
eclipse : 3.4.2
ORACLE : 10g Enterprise Edition Release 10.2.0.1.0
Re: Error while trying to get UDF, Stored Proc from a Oracle database(10g) [message #258452 is a reply to message #57485] Mon, 27 July 2009 17:25 Go to previous message
> RETURNS NOT DETERMINISTIC
> NO_SQL
> DTP : 1.7.0
> eclipse : 3.4.2
Hi...
The DDL generator must be extended for each different database type. And
in the Oracle case, I'm betting the Oracle enablement project hasn't
been customized to create Oracle-specific DDL.
You might see if the Oracle enablement download is available from the
Oracle site (it's moved, so I can't tell you exactly where it is now) -
it was customized by Oracle themselves, so it's probably more up to date
with DDL generation.
--Fitz
Re: Error while trying to get UDF, Stored Proc from a Oracle database(10g) [message #596154 is a reply to message #57485] Mon, 27 July 2009 17:25 Go to previous message
> NO_SQL
> DTP : 1.7.0
> eclipse : 3.4.2
Hi...
--Fitz
Previous Topic:Error while trying to get tables from a MySQL database
Next Topic:Access Web Services using DTP
Current Time: Mon Nov 03 19:48:11 EST 2025
Powered by FUDForum. Page generated in 0.04349 seconds
