Home » Eclipse Projects » OSEE » Artifact import wizard - Add to Selected Artifact greyed out
Artifact import wizard - Add to Selected Artifact greyed out [message #16138] Mon, 29 June 2009 04:49 Go to next message
I am using OSEE Version: 0.7.0 RC 2009-02-19 08:49
With an artifact selected in Artifact Explorer, when I use the
right-click->Import to run the Artifact Import Wizard, the Add to Selected
Artifact radio button is greyed out and has ":null" on the end. Is this a
bug or have I messed something up in setup?
Re: Artifact import wizard - Add to Selected Artifact greyed out [message #16993 is a reply to message #16138] Fri, 24 July 2009 06:55 Go to previous messageGo to next message
The "Add to Selected Artifact" option is only available when a document is
dropped onto a node of the Artifact Explorer from Windows Explorer. This
may be the design intent but it is not intuitive to me that you cannot
select an artifact and then use right-click Import.
Re: Artifact import wizard - Add to Selected Artifact greyed out [message #479914 is a reply to message #16993] Thu, 13 August 2009 01:03 Go to previous message
The first use case specified in this thread is a valid use case that is
intended to work. This bug is addressed by
https://bugs.eclipse.org/bugs/show_bug.cgi?id=286475.
Re: Artifact import wizard - Add to Selected Artifact greyed out [message #574742 is a reply to message #16138] Fri, 24 July 2009 06:55 Go to previous message
Re: Artifact import wizard - Add to Selected Artifact greyed out [message #574995 is a reply to message #16993] Thu, 13 August 2009 01:03 Go to previous message
Previous Topic:Can I change icons in Artifact Explorer?
Next Topic:OSEE pronunciation
Current Time: Thu Sep 04 12:55:16 EDT 2025
Powered by FUDForum. Page generated in 1.90401 seconds
