Home » Eclipse Projects » Eclipse 4 » Starting an RCP application
Starting an RCP application [message #527997] Sun, 18 April 2010 08:23 Go to next message
I have been using "self hosting" e4. I tried to get an RCP app to run,
however i get this error:
!ENTRY org.eclipse.osgi 4 0 2010-04-18 14:17:16.910
!MESSAGE Application error
!STACK 1
org.eclipse.core.runtime.AssertionFailedException: null
argument:applicationXMI argument missing
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:85)
at
org.eclipse.e4.ui.workbench.swt.internal.E4Application.loadA pplicationModel(E4Application.java:185)
at
org.eclipse.e4.ui.workbench.swt.internal.E4Application.creat eE4Workbench(E4Application.java:129)
at org.eclipse.ui.internal.Workbench$3.run(Workbench.java:525)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:518)
Are RCP apps supposed to run out of the box or do I always need the
application XMI?
Wim Jongman
Re: Starting an RCP application [message #527998 is a reply to message #527997] Sun, 18 April 2010 08:40 Go to previous messageGo to next message
You currently need at least a minimal Application XMI which holds a Window.
Tom
Am 18.04.10 14:23, schrieb Wim Jongman:
> !STACK 1
> at
> at
> at
> at
> application XMI?
> Regards,
> Wim Jongman
Re: Starting an RCP application [message #527999 is a reply to message #527998] Sun, 18 April 2010 08:56 Go to previous message
One more thing which is probably important:
a) You want to write a native e4-RCP-Application
b) You want to write a RCP-Application using the compat layer
You don't need a Application XMI in case of b) but then you need to
launch the correct product (I've asked a question on e4-dev just today
asking how to run an inner instance on the compat-layer).
Tom
Am 18.04.10 14:40, schrieb Tom Schindl:
> Tom
>> Hi,
>> !STACK 1
>> at
>> at
>> at
>> at
>> application XMI?
>> Regards,
>> Wim Jongman
Re: Starting an RCP application [message #574709 is a reply to message #527997] Sun, 18 April 2010 08:40 Go to previous message
Tom
> !STACK 1
> at
> at
> at
> at
> application XMI?
> Regards,
> Wim Jongman
Re: Starting an RCP application [message #574728 is a reply to message #527998] Sun, 18 April 2010 08:56 Go to previous message
Tom
> Tom
>> Hi,
>> !STACK 1
>> at
>> at
>> at
>> at
>> application XMI?
>> Regards,
>> Wim Jongman
Previous Topic:Starting an RCP application
Next Topic:About XWT.registerMetaclass(DecoratedText.class)
Current Time: Sun Jul 27 11:10:40 EDT 2025
Powered by FUDForum. Page generated in 0.04206 seconds
