Home » Modeling » Epsilon » ANT Script for ETL
ANT Script for ETL [message #481799] Mon, 24 August 2009 07:29 Go to next message
Originally posted by: d.clowes.lboro.ac.uk
Hello all,
I've been trying to get this script (script at bottom) to work for a
couple of days and don't seem to be able to spot what is going wrong. The
error message is:
BUILD FAILED
....ant-builds\ETL_DocModel.xml:63: The following error occurred while
executing this line:
....ant-builds\ETL_DocModel.xml:79: Model 'DocumentStructure' not found
ExecTransformation:
[echo] ../etl/DocXML.etl,DocumentModel,DocumentStructure
[epsilon.etl - DocXML.etl] EXCEPTION: Model 'DocumentStructure' not found
[epsilon.etl - DocXML.etl] at
org.eclipse.epsilon.eol.models.ModelGroup.<init>(ModelGroup.java:40)
org.eclipse.epsilon.eol.models.ModelRepository.getModelByNam e(ModelRepository.java:68)
org.eclipse.epsilon.workflow.tasks.ExecutableModuleTask.popu lateModelRepository(ExecutableModuleTask.java:177)
org.eclipse.epsilon.workflow.tasks.ExecutableModuleTask.exec uteImpl(ExecutableModuleTask.java:106)
org.eclipse.epsilon.workflow.tasks.EpsilonTask.execute(Epsil onTask.java:41)
org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:288)
<?xml version="1.0"?>
<project>
<!-- Source Details -->
<property name="SourceDataDir" value="../data/DocModel" />
<property name="SourceUri" value="DocumentModel" />
<property name="SourcePrefix" value="DocumentModel" />
<property name="SourceMetaModel"
value="../models/meta-models/xml/DocumentModelSchema.ecore" />
<!-- Define files here as order is important in creating the document
Therefore can not use loop of directory. -->
<filelist id="SourceFiles" dir="${SourceDataDir}"
files=" XMF_Prep_Main_Section_1.XML
XMF_Prep_Main_Section_2.XML
XMF_Prep_Main_Section_3.XML
XMF_Prep_Main_Section_4.XML
XMF_Prep_Appendix_Z.XML"/>
<!-- Target Details -->
<property name="TargetFile" value="../models/pop.model" />
<property name="TargetUri" value="DocumentStructure" />
<property name="TargetPrefix" value="DocumentStructure" />
<property name="TargetMetaModel"
value="../models/meta-models/tdl_v3a.ecore" />
<!-- ETL Details -->
<property name="ETLFile" value="../etl/DocXML.etl" />
<!-- ANT Taskdefs for foreach loop -->
<taskdef resource="net/sf/antcontrib/antcontrib.properties"/>
<target name="main">
<!-- Register the meta-models -->
<epsilon.emf.register file="${SourceMetaModel}"/>
<epsilon.emf.register file="${TargetMetaModel}"/>
<!-- Load the target file. Note path to file defined in property
targetFile -->
<epsilon.loadModel name="${TargetPrefix}" type="EMF">
<parameter name="modelFile" file="${TargetFile}"/>
<parameter name="metamodelUri" value="${TargetUri}"/>
<parameter name="readOnLoad" value="true"/>
<parameter name="storeOnDisposal" value="true"/>
</epsilon.loadModel>
<!-- Load each model and execute the transformation -->
<foreach param="SourceFilename" target="ExecTransformation">
<path>
<filelist refid="SourceFiles" />
</path>
</foreach>
</target>
<target name="ExecTransformation">
<epsilon.loadModel name="${SourcePrefix}" type="XML">
<parameter name="modelFile" file="${SourceFilename}"/>
<parameter name="metamodelUri" value="${SourceUri}"/>
<parameter name="storeOnDisposal" value="false"/>
<echo>${ETLFile},${SourcePrefix},${TargetPrefix}</echo>
<epsilon.etl src="${ETLFile}">
<model ref="${SourcePrefix}"/>
<model ref="${TargetPrefix}"/>
</epsilon.etl>
</target>
</project>
Thanks for any help,
Darren
Re: ANT Script for ETL [message #481807 is a reply to message #481799] Mon, 24 August 2009 07:47 Go to previous messageGo to next message
Hi Darren,
The error comes from
which means that there is no DocumentStructure model in the project
repository. I've had a look at your ANT file but can't figure out what
might be going wrong. Could you please try to put together a minimal
example that reproduces the problem (and that you can share) so that I
can have a closer look?
Dimitris
Darren Clowes wrote:
> Hello all,
> The error message is:
> BUILD FAILED
> ExecTransformation:
> <project>
> targetFile -->
> <path>
> </path>
> </foreach>
> </target>
> </epsilon.etl>
> </target>
> </project>
> Darren
Re: ANT Script for ETL [message #481808 is a reply to message #481807] Mon, 24 August 2009 07:56 Go to previous messageGo to next message
This is a cut down version with all the non-essential properties replaced
by their direct text. Is that what you required?
Darren
<project>
files=" XMF_Prep_Main_Section_1.XML"/>
file="../models/meta-models/xml/DocumentModelSchema.ecore"/ >
<epsilon.emf.register file="../models/meta-models/tdl_v3a.ecore"/>
targetFile -->
<epsilon.loadModel name="DocumentStructure" type="EMF">
<parameter name="modelFile" file="../models/pop.model"/>
<parameter name="metamodelUri" value="DocumentStructure"/>
<path>
</path>
</foreach>
</target>
<epsilon.loadModel name="DocumentModel" type="XML">
<parameter name="metamodelUri" value="DocumentModel"/>
<epsilon.etl src="../etl/DocXML.etl">
<model ref="DocumentModel"/>
<model ref="DocumentStructure"/>
</epsilon.etl>
</target>
</project>
Re: ANT Script for ETL [message #481809 is a reply to message #481808] Mon, 24 August 2009 07:58 Go to previous messageGo to next message
Hi Darren,
I was actually hoping for a complete project that I can run and
reproduce the problem. If that's too much of a hassle no worries; I'll
try to reproduce this on my own later on today.
Dimitris
> replaced by their direct text. Is that what you required?
> Darren
> <project>
> targetFile -->
> <path>
> </path>
> </foreach>
> </target>
> </epsilon.etl>
> </target>
> </project>
Re: ANT Script for ETL [message #481813 is a reply to message #481809] Mon, 24 August 2009 08:05 Go to previous messageGo to next message
I'll email you a project after lunch.
Darren
Re: ANT Script for ETL [message #481825 is a reply to message #481809] Mon, 24 August 2009 08:55 Go to previous messageGo to next message
I have emailed you acut down project that reproduces the problem.
Darren
Re: ANT Script for ETL [message #481828 is a reply to message #481825] Mon, 24 August 2009 09:06 Go to previous messageGo to next message
Great! Thanks. I'll have a look and get back to you shortly.
Dimitris
> Darren
Re: ANT Script for ETL [message #481845 is a reply to message #481828] Mon, 24 August 2009 10:25 Go to previous messageGo to next message
Hi Darren,
Setting the inheritrefs attribute of the foreach task to "true" (as per
http://ant-contrib.sourceforge.net/tasks/tasks/foreach.html) seems to be
doing the job.
Dimitris
> Cheers,
> Dimitris
>> Darren
Re: ANT Script for ETL [message #482021 is a reply to message #481845] Tue, 25 August 2009 03:28 Go to previous message
Wonderful. Well spotted Dimitris and thank you very much.
Darren
Re: ANT Script for ETL [message #574595 is a reply to message #481799] Mon, 24 August 2009 07:47 Go to previous message
Hi Darren,
Dimitris
> Hello all,
> BUILD FAILED
> ExecTransformation:
> <project>
> targetFile -->
> <path>
> </path>
> </foreach>
> </target>
> </epsilon.etl>
> </target>
> </project>
> Darren
Re: ANT Script for ETL [message #574617 is a reply to message #481807] Mon, 24 August 2009 07:56 Go to previous message
Darren
<project>
targetFile -->
<path>
</path>
</foreach>
</target>
</epsilon.etl>
</target>
</project>
Re: ANT Script for ETL [message #574633 is a reply to message #481808] Mon, 24 August 2009 07:58 Go to previous message
Hi Darren,
Dimitris
> Darren
> <project>
> targetFile -->
> <path>
> </path>
> </foreach>
> </target>
> </epsilon.etl>
> </target>
> </project>
Re: ANT Script for ETL [message #574667 is a reply to message #481809] Mon, 24 August 2009 08:05 Go to previous message
Darren
Re: ANT Script for ETL [message #574680 is a reply to message #481809] Mon, 24 August 2009 08:55 Go to previous message
Darren
Re: ANT Script for ETL [message #574705 is a reply to message #481825] Mon, 24 August 2009 09:06 Go to previous message
Dimitris
> Darren
Re: ANT Script for ETL [message #574724 is a reply to message #481828] Mon, 24 August 2009 10:25 Go to previous message
Hi Darren,
doing the job.
Dimitris
> Cheers,
> Dimitris
>> Darren
Re: ANT Script for ETL [message #574819 is a reply to message #481845] Tue, 25 August 2009 03:28 Go to previous message
Darren
Previous Topic:Operation of includes() operation
Next Topic:Accessing a "guard" field in a model
Current Time: Thu Jul 24 18:48:33 EDT 2025
Powered by FUDForum. Page generated in 0.12586 seconds
