Home » Modeling » Amalgam » Invoking xpand template options in 1.0M7
Invoking xpand template options in 1.0M7 [message #525166] Fri, 05 June 2009 11:22 Go to next message
I'm a little confused on what my options are in invoking xpand
templates in this build using the OCL/QVTO version of Xpand.
Following a post from Alex in the GMF newsgroup I've had a look
at org.eclipse.gmf.codegen.util.Generator.
What I'm looking for is a way in my dsl project plugin/rcp to right
click on a saved model file and generate 'code text' from a specific
template(s).
In order to do this, do I need a workflow of some kind or must I
manually code this all in java as part of some action? (any examples?)
regards
Steve
Re: Invoking xpand template options in 1.0M7 [message #525167 is a reply to message #525166] Fri, 05 June 2009 11:29 Go to previous messageGo to next message
You'll need an Ant script (easiest way). Here is an example of a QVTO
invocation, followed by several template invocations, as used in the Amalgam
build process:
<project name="amalgam" default="main"
xmlns:zzz="eclipse.org/gmf/2008/xpand">
<tstamp/>
<property name="product" value="dsltk"/> <!-- default is dsltk -->
<target name="main">
<qvto.interpretedTransformation
transformation=" platform:/plugin/org.eclipse.amalgam.releng.builder/transfor
mations/processbuild.qvto">
<targeturidef
targeturi="file:/${basedir}/builder/${product}/${product}.product "/>
<targeturidef
targeturi="file:/${basedir}/builder/${product}/${product}.build "/>
<targeturidef
targeturi="file:/${basedir}/out/build/${product}/${product}.product "/>
<targeturidef
targeturi="file:/${basedir}/out/build/${product}/${product}.build "/>
<configurationproperty name="date" value="${DSTAMP}"/>
<configurationproperty name="time" value="${TSTAMP}"/>
</qvto.interpretedTransformation>
<mkdir dir="${basedir}/out/build/${product}/builder"/>
<zzz:template name="build2properties::Main"
inputURI="file:/${basedir}/out/build/${product}/${product}.build#/ "
templateroot=" platform:/plugin/org.eclipse.amalgam.releng.builder/template s/
,platform:/plugin/org.eclipse.amalgam.releng.builder/transfo rmations/ "
outfile="${basedir}/out/build/${product}/builder/build.properties "/>
<zzz:template name="build2customTargets::Main"
outfile="${basedir}/out/build/${product}/builder/customTargets.xml "/>
<zzz:template name="build2script::Main"
outfile="${basedir}/out/build/${product}/build.xml"/>
<zzz:template name="build2site::Main"
outfile="${basedir}/out/build/${product}/site.xml"/>
<zzz:template name="build2page::Main"
outfile="${basedir}/out/build/${product}/index.php"/>
<zzz:template name="build2promote::Main"
outfile="${basedir}/out/build/${product}/promote.xml"/>
</target>
</project>
On 6/5/09 11:22 AM, in article h0bd7o$41p$1@build.eclipse.org, "Bill Hinge"
<steve.orobec@btopenworld.com> wrote:
> Hi
> template(s).
> regards
> Steve
Rich
Re: Invoking xpand template options in 1.0M7 [message #525168 is a reply to message #525167] Fri, 05 June 2009 11:44 Go to previous messageGo to next message
Thanks Rich for quick response
I'll post back to let you know how I got on
regards
Steve
> build process:
> <tstamp/>
> <targeturidef
> <targeturidef
> <targeturidef
> <targeturidef
> </target>
> </project>
>> Hi
>> template(s).
>> regards
>> Steve
Re: Invoking xpand template options in 1.0M7 [message #525179 is a reply to message #525167] Thu, 25 June 2009 09:49 Go to previous messageGo to next message
Hi Rich
After a bit of fiddling about with other things I've come back to try
this. I've created my UI as described in the book and referencing the
amalgam examples.
Wrt to the ant script, am I correct in assuming that an ant script
replaces the mwe script? Hence if I create my action class to run the
script I just replace the file extension mwe by ant etc?
Secondly , when I run my UI Xpand action against a saved model file I
get the following error.
IOException: Unable to resolve plug-in
"platform/plugin/..../templates/demo.ant"
I checked and the ant file does live in the plugins directory at
..../templates/demo.ant. I'm presumably not setting some path somewhere
but not sure where I should do this (I have exported all my UI dirs in
plugin.xml and checked the templates directory in build)
regards
Steve
> build process:
> <tstamp/>
> <targeturidef
> <targeturidef
> <targeturidef
> <targeturidef
> </target>
> </project>
>> Hi
>> template(s).
>> regards
>> Steve
Re: Invoking xpand template options in 1.0M7 [message #525180 is a reply to message #525179] Thu, 25 June 2009 10:00 Go to previous messageGo to next message
If you're going to invoke an Ant script programmatically using an action,
you should look into the AntRunner API provided by the platform. Or, stick
to using launch invocation UI. Just be sure to run using the workbench JVM,
and not a new one, in order to have easy access to all the ant libs.
You can also look into the GMF codebase to see how Xpand is invoked
programmatically from our UI contributions for running the code generator.
Best,
Rich
On 6/25/09 9:49 AM, in article 4A438066.1070005@btopenworld.com, "Bill
Hinge" <steve.orobec@btopenworld.com> wrote:
> Hi Rich
> amalgam examples.
> regards
> Steve
>> build process:
>> <?xml version="1.0" encoding="UTF-8"?>
>> <tstamp/>
>> <targeturidef
>> <targeturidef
>> <targeturidef
>> <targeturidef
>> </target>
>> </project>
>>> Hi
>>> template(s).
>>> regards
>>> Steve
Rich
Re: Invoking xpand template options in 1.0M7 [message #525181 is a reply to message #525180] Thu, 25 June 2009 10:20 Go to previous message
Thanks Rich
getting there slowly but surely
steve
> Best,
> Rich
>> Hi Rich
>> amalgam examples.
>> regards
>> Steve
>>> build process:
>>> <tstamp/>
>>> <targeturidef
>>> <targeturidef
>>> <targeturidef
>>> <targeturidef
>>> </target>
>>> </project>
>>>> Hi
>>>> template(s).
>>>> regards
>>>> Steve
Re: Invoking xpand template options in 1.0M7 [message #574581 is a reply to message #525166] Fri, 05 June 2009 11:29 Go to previous message
build process:
<tstamp/>
<targeturidef
<targeturidef
<targeturidef
<targeturidef
</target>
</project>
> Hi
> template(s).
> regards
> Steve
Rich
Re: Invoking xpand template options in 1.0M7 [message #574598 is a reply to message #525167] Fri, 05 June 2009 11:44 Go to previous message
regards
Steve
> build process:
> <tstamp/>
> <targeturidef
> <targeturidef
> <targeturidef
> <targeturidef
> </target>
> </project>
>> Hi
>> template(s).
>> regards
>> Steve
Re: Invoking xpand template options in 1.0M7 [message #577183 is a reply to message #525167] Thu, 25 June 2009 09:49 Go to previous message
Hi Rich
amalgam examples.
regards
Steve
> build process:
> <tstamp/>
> <targeturidef
> <targeturidef
> <targeturidef
> <targeturidef
> </target>
> </project>
>> Hi
>> template(s).
>> regards
>> Steve
Re: Invoking xpand template options in 1.0M7 [message #577193 is a reply to message #525179] Thu, 25 June 2009 10:00 Go to previous message
Best,
Rich
> Hi Rich
> amalgam examples.
> regards
> Steve
>> build process:
>> <tstamp/>
>> <targeturidef
>> <targeturidef
>> <targeturidef
>> <targeturidef
>> </target>
>> </project>
>>> Hi
>>> template(s).
>>> regards
>>> Steve
Rich
Re: Invoking xpand template options in 1.0M7 [message #577218 is a reply to message #525180] Thu, 25 June 2009 10:20 Go to previous message
Thanks Rich
steve
> Best,
> Rich
>> Hi Rich
>> amalgam examples.
>> regards
>> Steve
>>> build process:
>>> <tstamp/>
>>> <targeturidef
>>> <targeturidef
>>> <targeturidef
>>> <targeturidef
>>> </target>
>>> </project>
>>>> Hi
>>>> template(s).
>>>> regards
>>>> Steve
Previous Topic:Questions about linked EMF & GMF Editors
Next Topic:Amalgam Galileo 1.0 FR
Current Time: Wed Jul 23 01:56:06 EDT 2025
Powered by FUDForum. Page generated in 0.09870 seconds
