| DTP 0.9RC2 "Error loading driver instance data" [message #13499] |
Mon, 08 May 2006 18:45  |
I am unsuccessfully attempting to create a driver definition for Sybase
12.x on Win2K using DTP 0.9RC2. The following error appears in the log:
org.eclipse.datatools.connectivity
!MESSAGE Error loading driver instance data.
!STACK 1
org.eclipse.core.runtime.CoreException: Error loading driver instance data.
at
org.eclipse.datatools.connectivity.drivers.XMLFileManager.lo adPropertySets(XMLFileManager.java:228)
SAXParseException: Invalid encoding name "UTF8".
at
org.eclipse.datatools.connectivity.drivers.XMLFileManager.lo adPropertySets(XMLFileManager.java:207)
Any help is appreciated.
- Ron
| Re: DTP 0.9RC2 "Error loading driver instance data" [message #13685 is a reply to message #13664] |
Tue, 09 May 2006 16:25   |
Originally posted by: jograham.sybase.com
Hi Ron,
Yes, you could remove the "encoding" attribute, and that might help. We've
been talking among ourselves, trying to get this to repro on the dev
machines. No luck yet (and I did add Xerces into the mix), but the latest
theory has to do with the JVM. Seems to be failing on IBM JVM but not on Sun
JVM. Which one are you using?
John Graham
Eclipse Data Tools Platform PMC Chair
"R. Gavlin" <rgavlin@yahoo.com> wrote in message
news:022b40cfe585557abe12ca872ada6768$1@www.eclipse.org...
> John,
> Please see my comments in the bug.
> Is there a way to workaround this problem by manually editing
> driverStorage.xml?
> - Ron
> John Graham wrote:
>> Hi Ron,
>> I think this is the same issues as found in:
>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=140280
>> We'll be looking into this. BTW, what locale is your machine setting?
>> Regards,
>> John Graham
>> news:8c0cdb8b5431220a078ade699b02d974$1@www.eclipse.org...
>>> !STACK 1
>>> data.
>>> at
>>> at
>>> - Ron
| Re: DTP 0.9RC2 "Error loading driver instance data" [message #574421 is a reply to message #13499] |
Tue, 09 May 2006 09:56  |
Hi Ron,
John Graham
> !STACK 1
> data.
> at
> at
> - Ron
| Re: DTP 0.9RC2 "Error loading driver instance data" [message #574524 is a reply to message #13583] |
Tue, 09 May 2006 12:11  |
John,
driverStorage.xml?
- Ron
John Graham wrote:
> Hi Ron,
> Regards,
> John Graham
>> !STACK 1
>> data.
>> at
>> at
>> - Ron
| Re: DTP 0.9RC2 "Error loading driver instance data" [message #574573 is a reply to message #13664] |
Hi Ron,
John Graham
> John,
> driverStorage.xml?
> - Ron
> John Graham wrote:
>> Hi Ron,
>> Regards,
>> John Graham
>>> !STACK 1
>>> data.
>>> at
>>> at
>>> - Ron
FUDForum. Page generated in 0.05038 seconds
