Home » Eclipse Projects » Eclipse 4 » XWT. Using TableViewer.columns. Why?
XWT. Using TableViewer.columns. Why? [message #527747] Fri, 16 April 2010 07:08 Go to next message
As I understand, "Class.property" should be used when you want to set value of "property". However TableViewer has no property "columns" or method "setColumns()", etc. It seems that it works without wrapping TableViewerColumn-s into "TableViewer.columns", so is there reason to use it in code generation?
Here is code from xwt tests.
<TableViewer xmlns="http://www.eclipse.org/xwt/presentation"
    xmlns:x="http://www.eclipse.org/xwt"
    xmlns:j="clr-namespace:java.lang"
    Name="TableViewer">
	<TableViewer.columns>
		<TableViewerColumn width="80" text="column0"/>
		<TableViewerColumn width="80" text="column1"/>
	</TableViewer.columns>
</TableViewer>
But this also works
<Shell xmlns="http://www.eclipse.org/xwt/presentation" xmlns:x="http://www.eclipse.org/xwt">
	<Shell.layout>
		<FillLayout type="VERTICAL"/>
	</Shell.layout>
	<TableViewer x:Style="BORDER | FULL_SELECTION">
		<TableViewer.table headerVisible="true" linesVisible="true"/>
		<TableViewerColumn width="150" text="Name"/>
		<TableViewerColumn width="150" text="Age"/>
		<TableViewerColumn width="150" text="Image"/>
	</TableViewer>
</Shell>
Re: XWT. Using TableViewer.columns. Why? [message #527748 is a reply to message #527747] Fri, 16 April 2010 07:15 Go to previous messageGo to next message
What I think is strange too here is that this looks like
TableViewerColumn has the properties (name, width) which is doesn't have
in JFace.
I would have expected the attribute is column.width, ... (not sure this
is valid XML) because in Java-Code you write
viewerCol.getColumn().setWidth().
Tom
Am 16.04.10 13:08, schrieb Konstantin Scheglov:
> Name="TableViewer">
> </TableViewer>
> But this also works
> <Shell.layout>
> </Shell.layout>
> </TableViewer>
> </Shell>
Re: XWT. Using TableViewer.columns. Why? [message #527841 is a reply to message #527748] Fri, 16 April 2010 11:22 Go to previous messageGo to next message
XWT's UI Model aligns as much as possible with SWT/JFace "model".
Unfortuately, the API of SWT/JFace is not model-driven. The Java Bean
specification is not totally respected. However, XWT is a 100% model-based
UI solution. We need to connect the SWT/Jface APIs to UI model via an
intermediate model services, which is our UI metamodel. XWT provides a
possibility to extend and overwrite the default UI metamodel.
As for the TableViewerColumn, we have added two additional attributes in the
metaclass of TableViewerColumn to make the declarative simple and
strainghtforward..
"Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
news:hq9gs4$lo$1@build.eclipse.org...
> in JFace.
> Tom
>> Name="TableViewer">
>> </TableViewer>
This is the model-based declaration with a virtual attribute "columns".
>> But this also works
>> <Shell.layout>
>> </Shell.layout>
>> </TableViewer>
>> </Shell>
This is the default mechanism of XWT loader, which takes TableViewerColumn
as child of TableViewer. When XWT loads the resource, JFace API creates the
column in table. But from modeling standpoint, I think it isn't appropriate:
column should not be a child of table.
Yves
Re: XWT. Using TableViewer.columns. Why? [message #527887 is a reply to message #527841] Fri, 16 April 2010 15:09 Go to previous messageGo to next message
Yves YANG wrote on Fri, 16 April 2010 19:22
>> But this also works
>> <Shell.layout>
>> </Shell.layout>
>> </TableViewer>
>> </Shell>
To be honest, I don't understand what you mean.
In both case we create TableViewerColumn-s, which in both cases children of TableViewer (not Table).
I just wonder why special "TableViewer.columns" element is used. For example when we create Composite with children Control-s, we don't wrap children into "Composite.controls" element...
Re: XWT. Using TableViewer.columns. Why? [message #527941 is a reply to message #527887] Sat, 17 April 2010 00:29 Go to previous messageGo to next message
The reason is very simple: I didn't expect the second case works.
I think "TableViewerColumn" is not a contained child of TableViewer. They
are used to define the header and structure of TableViewer. TableViewer
should have a collection or array of TableViewerColumn in order and same
type.
Let's compare the following case in two ways:
Grouped
<TableViewer>
<TableViewer.filters>
<ViewerFilter>
<ViewerFilter.conditions>
<Condition property="age" value="30" operator="GT"/>
</ViewerFilter.conditions>
</ViewerFilter>
<ViewerFilter>
<Condition property="salary" value="50" operator="LT"/>
</ViewerFilter>
</TableViewer.filters>
<TableViewerColumn width="150" text="Name" bindingPath="name"/>
<TableViewerColumn width="150" text="Age" bindingPath="age"/>
</TableViewer>
Flat
<TableViewer>
<ViewerFilter>
</ViewerFilter>
<ViewerFilter>
</ViewerFilter>
</TableViewer>
Which do you prefer?
By writting this, I have checked on the Table. I just noticed Table column
is defined in flat way. It'd better to keep the syntax (or model)
consistance between Table and TableViewer.
Yves
> Konstantin Scheglov,
> Instantiations, Inc.
Re: XWT. Using TableViewer.columns. Why? [message #527946 is a reply to message #527941] Sat, 17 April 2010 04:21 Go to previous message
Yves YANG wrote on Sat, 17 April 2010 08:29
Hm...
Example with logical grouping columns and filters into container elements looks better.
Re: XWT. Using TableViewer.columns. Why? [message #574402 is a reply to message #527747] Fri, 16 April 2010 07:15 Go to previous message
in JFace.
Tom
> Name="TableViewer">
> </TableViewer>
> But this also works
> <Shell.layout>
> </Shell.layout>
> </TableViewer>
> </Shell>
Re: XWT. Using TableViewer.columns. Why? [message #574474 is a reply to message #527748] Fri, 16 April 2010 11:22 Go to previous message
strainghtforward..
> in JFace.
> Tom
>> Name="TableViewer">
>> </TableViewer>
>> But this also works
>> <Shell.layout>
>> </Shell.layout>
>> </TableViewer>
>> </Shell>
Yves
Re: XWT. Using TableViewer.columns. Why? [message #574504 is a reply to message #527841] Fri, 16 April 2010 15:09 Go to previous message
> >> But this also works
> >> <Shell.layout>
> >> </Shell.layout>
> >> </TableViewer>
> >> </Shell>
Re: XWT. Using TableViewer.columns. Why? [message #574578 is a reply to message #574504] Sat, 17 April 2010 00:29 Go to previous message
type.
Grouped
<TableViewer>
<ViewerFilter>
</ViewerFilter>
<ViewerFilter>
</ViewerFilter>
</TableViewer>
Flat
<TableViewer>
<ViewerFilter>
</ViewerFilter>
<ViewerFilter>
</ViewerFilter>
</TableViewer>
Yves
Re: XWT. Using TableViewer.columns. Why? [message #574626 is a reply to message #527941] Sat, 17 April 2010 04:21 Go to previous message
Hm...
Previous Topic:XWT + RCP
Next Topic:Starting an RCP application
Current Time: Fri Jul 18 18:16:24 EDT 2025
Powered by FUDForum. Page generated in 0.05143 seconds
