MTJ overwriting build.properties [message #31493] |
Tue, 30 June 2009 12:37  |
I am finding that the latest version of MTJ is always trying to
overwrite my build.properties file. We store a lot of important build
information here so this is not good. Is there a reason for this behaviour?
cheers
Re: MTJ overwriting build.properties [message #31664 is a reply to message #31593] |
Thu, 02 July 2009 08:33  |
David Marques wrote:
> Hi teknokrat,
> Well the solution was designed to work like that. My tip for you is
> creating a build/ folder and putting your ant build.xml and
> build.properties in there :)
> It should solve your problem for now!
> Regards,
> David Marques
Actually we'll be uninstalling MTJ. We have dozens of projects, all set
up to work with our continuous integration system. We have unit tests,
metrics, reports, etc being run via ant, with many custom tasks. MTJ
doesn't add enough value for us to to go through such a restructuring
nightmare.
Re: MTJ overwriting build.properties [message #574244 is a reply to message #31528] |
Thu, 02 July 2009 06:09  |
> Hi teknokrat,
> MTJ stores build configurations for each runtime configuration (device)
> you have on your project inside the build.properties file within the
> project's root. This feature allow developers to select which files are
> packaged on each device package. Did you create this file yourself ??
> Please look at
> http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .mtj.doc.user/html/gettingstarted/gettingstarted.html
yes, and thats the problem. Why doesn't it use its own file instead of
co-opting build.properties which is usually used to setup properties for
Ant?
> Regards,
> David Marques
>> behaviour?
>> cheers
Re: MTJ overwriting build.properties [message #574267 is a reply to message #31563] |
Thu, 02 July 2009 07:13  |
Hi teknokrat,
David Marques
Re: MTJ overwriting build.properties [message #574349 is a reply to message #31593] |
> Hi teknokrat,
> Regards,
> David Marques
nightmare.
FUDForum. Page generated in 0.06746 seconds
