Home » Archived » Eclipse Communications Framework (ECF) » Initial provider implementation complete and available
Initial provider implementation complete and available [message #574045] |
Mon, 03 January 2005 00:02  |
ECFers,
The ECF team has checked into the ECF codebase the first complete
provider implementation along with updates to the ECF core plugin
(version 0.2.0) and API documentation. The new provider implementation
is in the (new) plugin:
org.eclipse.ecf.provider
For access to the new plugin source code see the project set files at
the bottom of the page: http://www.eclipse.org/ecf/downloads.html
Also see http://www.eclipse.org/ecf/documentation.html for updated API
javadocs.
Below is a brief description of the characteristics of this plugin, and
some example/test code for using it.
Scott
1) It is a full distributed container implementation of the ECF provider
api. For example, it implements the full ISharedObjectContainer
interface, including all the joinGroup/leaveGroup methods, the event
distribution to the ISharedObjectContainerListeners associated with a
container via addListener, as well as functioning implementations of all
the sharedobject create/add/remove/connect/disconnect container methods.
2) It provides a set of base classes for other provider implementations
(ECF implementations and others). These classes are in the package
org.eclipse.ecf.provider.* in the org.eclipse.ecf.provider plugin.
3) It is implemented with a very simple TCP-based group protocol, but
structured so that other 'group transport' layers may replace the simple
TCP implementation...while reusing all the container classes
themselves. For example, one next step is to finish implementations
that run upon JMS (activemq), XMPP (smack) and Java Groups. This should
now be an easy thing because the base classes in
org.eclipse.ecf.provider can be easily extended by classes that
implement these or other wire protocols.
4) It is based upon a client-server messaging topology...the server does
message reflection to all the connected clients to provider
publish-and-subscribe message delivery. Both the client and a
trivial-but-completely-functional server are in the
org.eclipse.ecf.provider plugin (In case you are wondering, for the
client in the org.eclipse.ecf.provider.generic.TCPClientSOContainer and
org.eclipse.ecf.provider.generic.TCPServerSOContainer classes).
5) Both the server and client container can run as both a java
application and/or as an Eclipse plugin. What this means is that this
server (in particular) can/could run either on any JRE + OSGI
platform...i.e. as a webapp, as a standalone java application, or within
Eclipse. This provides a good deal of flexibility for ECF users, in
that they can have groups hosted by themselves (just as Eclipse users),
by an app server, or by some other shared server.
6) I generated javadocs for the org.eclipse.ecf.provider plugin and they
are available in the appropriate packages here:
http://www.eclipse.org/ecf/org.eclipse.ecf.docs/api/
7) There is now a fair amount of trace code in both the org.eclipse.ecf
and the org.eclispe.ecf.provider plugins. To access the tracing for
these plugins, go to the 'Tracing' tab in the Run/Debug dialog (when
defining a run config for a new RunTime Workbench) and turn on desired
tracing for the org.eclipse.ecf and/or org.eclipse.ecf.provider plugins.
Here is some example/test code that creates a client instance of this
new provider:
ISharedObjectContainer clients[i] =
SharedObjectContainerFactory.makeSharedObjectContainer("org.eclipse.ecf.provider.generic.ContainerInstantiator ");
Here's code for creating a localhost server that listens on port 3282
and has name 'server':
ID serverID =
IDFactory.makeStringID("ecftcp://localhost:3282/server");
Object [] args = new Object [] { new Boolean(false), serverID };
server =
SharedObjectContainerFactory.makeSharedObjectContainer("org.eclipse.ecf.provider.generic.ContainerInstantiator ",args);
Note that neither of these code snippets refers to the provider classes
directly at all (just to the
"org.eclipse.ecf.provider.generic.ContainerInstantiator"). The only
code referenced by such clients is the ECF core code.
There is a small amount of junit test code in the org.eclipse.ecf.test
plugin. See particularly the unit test code in:
ContainerJoinTest
CreateSharedObjectTest
ContainerListenerTest
MultiContainerJoinTest
for examples of doing client-server 'joinGroup/leaveGroup', shared
object creation, removal from container, setting up a container
listener, and a multi-client (i.e. 10 clients joining/leaving a single
server) test.
Re: Initial provider implementation complete and available [message #574092 is a reply to message #574045] |
Mon, 03 January 2005 06:48   |
scott,
when i checked out the code it comes up with a syntax error
in org.eclipse.ecf.provider.comm.tcp.Client! probably because
the projects where imported with jdk1.5 settings and you use
the "enum" as an identifier. in jdk1.5 it is a keyword!
cheers
/eike
Scott Lewis wrote:
> ECFers,
> javadocs.
> Scott
> new provider:
> ID serverID =
> server =
> ContainerJoinTest
> server) test.
Re: Initial provider implementation complete and available [message #574122 is a reply to message #574092] |
Mon, 03 January 2005 10:27   |
Hi Eike,
Thanks. I've fixed this variable name and checked it in. You should be
able to do an update and get the fix. Thanks!
Scott
Eike Stepper wrote:
> scott,
> cheers
> /eike
> Scott Lewis wrote:
>> ECFers,
>> implementation is in the (new) plugin:
>> javadocs.
>> and some example/test code for using it.
>> Thanks,
>> Scott
>> provider api. For example, it implements the full
>> ISharedObjectContainer interface, including all the
>> joinGroup/leaveGroup methods, the event distribution to the
>> ISharedObjectContainerListeners associated with a container via
>> addListener, as well as functioning implementations of all the
>> implementations (ECF implementations and others). These classes are
>> in the package org.eclipse.ecf.provider.* in the
>> simple TCP implementation...while reusing all the container classes
>> should now be an easy thing because the base classes in
>> does message reflection to all the connected clients to provider
>> and org.eclipse.ecf.provider.generic.TCPServerSOContainer classes).
>> within Eclipse. This provides a good deal of flexibility for ECF
>> users, in that they can have groups hosted by themselves (just as
>> Eclipse users), by an app server, or by some other shared server.
>> they are available in the appropriate packages here:
>> org.eclipse.ecf and the org.eclispe.ecf.provider plugins. To access
>> the tracing for these plugins, go to the 'Tracing' tab in the
>> Run/Debug dialog (when defining a run config for a new RunTime
>> Workbench) and turn on desired tracing for the org.eclipse.ecf and/or
>> new provider:
>> ID serverID =
>> serverID };
>> server =
>> classes directly at all (just to the
>> ContainerJoinTest
>> server) test.
Re: Initial provider implementation complete and available [message #574150 is a reply to message #574045] |
Tue, 04 January 2005 11:55   |
Minor typo: the <title> text in the header of the ECF downloads page
(http://www.eclipse.org/ecf/downloads.html) should be corrected to
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<title>eclipse communication framework downloads</title>
<link rel="stylesheet" href="../default_style.css" type="text/css">
</head>
instead of
<head>
<title>eclipse communication goundation downloads</title>
</head>
Li-Te
Scott Lewis wrote:
> ECFers,
> javadocs.
> Scott
> new provider:
> ID serverID =
> server =
> ContainerJoinTest
> server) test.
Re: Initial provider implementation complete and available [message #574162 is a reply to message #574150] |
Tue, 04 January 2005 13:11   |
Hi Li-Te,
Fixed...thanks!
Scott
> <head>
> </head>
> instead of
> <head>
> </head>
> Li-Te
> Scott Lewis wrote:
>> ECFers,
>> javadocs.
>> Thanks,
>> Scott
>> new provider:
>> ID serverID =
>> serverID };
>> server =
>> ContainerJoinTest
>> server) test.
Re: Initial provider implementation complete and available [message #574173 is a reply to message #574045] |
Tue, 04 January 2005 13:25  |
<head>
</head>
instead of
<head>
</head>
Li-Te
Scott Lewis wrote:
> ECFers,
> javadocs.
> Scott
> new provider:
> ID serverID =
> server =
> ContainerJoinTest
> server) test.
Current Time: Wed Jul 23 04:52:44 EDT 2025
Powered by FUDForum. Page generated in 0.32478 seconds
