Problem using AJDT with Eclipse 3.0M6 [message #28971] |
Sat, 20 December 2003 10:04  |
Originally posted by: christian.galsterer.gmx.de
I started with a clean installation of 3.0M6 and installed AJDT with the
update manager.
Unfortunatly the feature is not activated.
The status, found at Help>Software Updates>Manage Configuration>Eclipse
AspectJ Development Tools 1.1.4 says:
No plug-in: "org.eclipse.aspectj" included at runtime.
No plug-in: "org.aspectj.ajde" included at runtime.
No plug-in: "org.eclipse.ajdt.ui" included at runtime.
Any ideas how to activate AJDT with M6?
Thanks in advance.
Yours,
Christian
Re: Problem using AJDT with Eclipse 3.0M6 [message #30018 is a reply to message #29389] |
Tue, 27 January 2004 20:18  |
Originally posted by: vranganath.cox.net
Venkatesh Prasad Ranganath wrote:
> Travis Tripp wrote:
>> Can anybody tell me if AJDT works with M5? I have M6, but am willing to
>> revert. I just would like to know how far back I need to go.
>> Thanks,
>> Travis
>> <user@domain.invalid> wrote in message news:btsqop$l2j$1@eclipse.org...
>>> AJDT doesn't work with M6 yet.
>>> Steve Menard wrote:
>> the
>>>>> update manager.
>>>>> Thanks in advance.
>>>>> Yours,
>>>>> Christian
>>>> Did you ever get an answer to this? I am also trying to get AspectJ to
>>>> work with eclipse, and going back to Eclips 2.1.x is not an option for
>> me.
>>>> Steve
> My experience it did not work after M5 (inclusive).
Well, I tried I20040127 and the features exported by the plugin were
visible in eclipse. However, I do not know if any of them work as I
could not test them as I do not have an aspectJ enabled project ;-)
Venkatesh Prasad Ranganath,
Dept. Computing and Information Science,
Kansas State University, US.
web: http://www.cis.ksu.edu/~rvprasad
Re: Problem using AJDT with Eclipse 3.0M6 [message #573814 is a reply to message #28971] |
Thu, 08 January 2004 14:40  |
> update manager.
> Thanks in advance.
> Yours,
> Christian
work with eclipse, and going back to Eclips 2.1.x is not an option for me.
Steve
Re: Problem using AJDT with Eclipse 3.0M6 [message #573874 is a reply to message #29154] |
Sun, 11 January 2004 19:47  |
>> update manager.
>> Thanks in advance.
>> Yours,
>> Christian
> Steve
Re: Problem using AJDT with Eclipse 3.0M6 [message #573908 is a reply to message #29154] |
Tue, 13 January 2004 01:10  |
>> update manager.
>> Thanks in advance.
>> Yours,
>> Christian
AspectJ works fine with 3.0M4. Hopefully, the differences between M4 and
M6 aren't too great....
dean
dean@aspectprogramming.com
> Steve
Re: Problem using AJDT with Eclipse 3.0M6 [message #573940 is a reply to message #29227] |
Tue, 13 January 2004 14:33  |
Travis
the
> >> update manager.
> >> Thanks in advance.
> >> Yours,
> >> Christian
me.
> > Steve
Re: Problem using AJDT with Eclipse 3.0M6 [message #574021 is a reply to message #29303] |
Tue, 13 January 2004 19:49  |
>Thanks,
>Travis
>the
>>>>update manager.
>>>>Thanks in advance.
>>>>Yours,
>>>>Christian
>me.
>>>Steve
Re: Problem using AJDT with Eclipse 3.0M6 [message #574284 is a reply to message #28971] |
Tue, 27 January 2004 05:30  |
Originally posted by: marcus.edwards.digitalsteps.com
"Christian Galsterer" <christian.galsterer@gmx.de> wrote in message
news:bs1odk$bch$1@eclipse.org...
I know it's a little late in this discussion but for what it's worth here
goes:
If you want/need to be using aspectj/AJDT and Eclipse M5/M6/M7? etc., you
can always use the Ant tasks to compile
your aspects. You obviously don't get some of the nice features of AJDT
(source editor, aspect viewer etc.) but the actual
aspect technology is readily usable. I personally think this is the best
option as you can continue to use AspectJ as
Eclipse develops and until the Eclipse plugins for AspectJ catch up.
Here's the ant build file I'm using with Eclipse M6 as a starting point:
--- 8< --- build.xml
<?xml version="1.0"?>
<project name="scratch" default="compile" basedir=".">
<taskdef
resource="org/aspectj/tools/ant/taskdefs/aspectjTaskdefs.properties ">
<classpath>
<pathelement location="${aspectj-home}/aspectjtools.jar"/>
</classpath>
</taskdef>
<path id="classpath">
<pathelement location="${aspectj-home}/aspectjrt.jar"/>
<fileset dir="${lib}">
<include name="**/*.jar"/>
<include name="**/*.zip"/>
</fileset>
</path>
<target name="compile" depends="check-properties">
<mkdir dir="${dest}"/>
<iajc
destdir="${dest}"
fork="true"
sourceroots="${src}">
<!-- classpath entries -->
<classpath refid="classpath"/>
</iajc>
</target>
<target name="check-properties">
<fail unless="aspectj-home" message="Property 'aspectj-home' must be
defined"/>
<echo>Using aspectj-home=${aspectj-home}</echo>
<echo>Using src=${src}</echo>
<echo>Using dest=${dest}</echo>
</target>
</project>
---8<---
HTH
Re: Problem using AJDT with Eclipse 3.0M6 [message #574316 is a reply to message #29265] |
Tue, 27 January 2004 16:52  |
> and M6 aren't too great....
Actually on Eclipse side they are tremendous. I think that's the problem :-/
Eric
Eric Bodden
ICQ UIN: 12656220
Website: http://www.bodden.de
PGP key available
Re: Problem using AJDT with Eclipse 3.0M6 [message #574357 is a reply to message #29389] |
>> Thanks,
>> Travis
>> the
>>>>> update manager.
>>>>> Thanks in advance.
>>>>> Yours,
>>>>> Christian
>> me.
>>>> Steve
FUDForum. Page generated in 0.58699 seconds
