Home » Eclipse Projects » Eclipse 4 » open Application.e4xmi and the window keeps flashing
open Application.e4xmi and the window keeps flashing [message #526162] Thu, 08 April 2010 23:49 Go to next message
Originally posted by: n.n.nnn
I downloaded eclipse-e4-SDK-incubation-1.0M4-linux-gtk.tar.gz, unpacked
then ran eclipse. I created a new e4 project with the wizard and then
double-clicked on Application.e4xmi and a form window opens but then
the focus keeps shifting between the Eclipse workbench and a pop-up
that never quite materializes on the Gnome panel.
Using IBM Java sr7 on Ubuntu 9.10. I tried with and without
export GDK_NATIVE_WINDOWS=true and I tried with the default
OpenJDK 1.6.0_0 that comes on Ubuntu.
I can report this in the morning on BugZilla if that's the consensus
or is there anything you all can recommend I look at or try?
Dilton
Re: open Application.e4xmi and the window keeps flashing [message #526286 is a reply to message #526162] Fri, 09 April 2010 09:37 Go to previous messageGo to next message
I think it is a bug of e4 Visual Designer in Linux. There is a known issue
with Windows Manager that doesn't support the advanced features of SWT such
as transparent of Shell.
Please report in BugZilla and give the detail information about the your OS,
Windows Manager as well.
Best regards
Yves YANG
"Dilton" <n@n.nnn> wrote in message news:hpm852$6lf$1@build.eclipse.org...
> Dilton
Re: open Application.e4xmi and the window keeps flashing [message #526298 is a reply to message #526162] Fri, 09 April 2010 10:19 Go to previous messageGo to next message
I experience the same behavior, also running Ubuntu/GTK.
HTH,
Simon
Re: open Application.e4xmi and the window keeps flashing [message #526307 is a reply to message #526286] Fri, 09 April 2010 11:02 Go to previous message
>> Hi,
>> Using IBM Java sr7 on Ubuntu 9.10. I tried with and without export
>> GDK_NATIVE_WINDOWS=true and I tried with the default OpenJDK 1.6.0_0
>> I can report this in the morning on BugZilla if that's the consensus or
>> Dilton
> issue with Windows Manager that doesn't support the advanced features of
> SWT such as transparent of Shell.
> OS, Windows Manager as well.
> Best regards
> Yves YANG
Here's the number:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=308659
Thanks Yves, and Simon for the report,
Dilton
Re: open Application.e4xmi and the window keeps flashing [message #573650 is a reply to message #526162] Fri, 09 April 2010 09:37 Go to previous message
Best regards
Yves YANG
> Dilton
Re: open Application.e4xmi and the window keeps flashing [message #573688 is a reply to message #526162] Fri, 09 April 2010 10:19 Go to previous message
HTH,
Simon
Re: open Application.e4xmi and the window keeps flashing [message #573748 is a reply to message #526286] Fri, 09 April 2010 11:02 Go to previous message
>> Hi,
>> Dilton
> Best regards
> Yves YANG
Here's the number:
Dilton
Previous Topic:DI Question
Next Topic:Show View request
Current Time: Sat Jul 26 10:18:44 EDT 2025
Powered by FUDForum. Page generated in 0.03816 seconds
