| The very begining fails [message #5681] |
Sun, 27 August 2006 06:08  |
Originally posted by: philippe-briere.neuf.fr
--------------040304070602090401000501
Hi there,
I installed BPEL Designer plugin on Eclipse
(http://www.eclipse.org/bpel/install.php), and I do not succeed in
opening any existing (sample) or new BPEL project.
Following posts are covering my problem :
1. news://news.eclipse.org:119/ebb44n$vvh$1@utils.eclipse.org
Title : Eclipse plugin - can't get it to work
=> Started new project then do 'New BPEL process file'
=> 'creating process from template' flashes in the
dialogue but the dialogue does not close and the bpel is
never created.
2.
news://news.eclipse.org:119/0d27f6a474d375c1b739b55d5bc93551 $1@www.eclipse.org
Title : Example is not working on new version
=> Try opening Sample.process.bpel
=> Error : see attachment
But these problems do not appear to be solved on this forum. Am I right
or did I misss answering posts somewhere ?
Thanks for help.
Phil
name="Err BPEL sample"
Content-Disposition: inline;
filename="Err BPEL sample"
org.eclipse.ui.PartInitException: Error opening editor. Can't read input file.
at org.eclipse.bpel.ui.BPELEditor.init(Unknown Source)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:839)
at org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:583)
at org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:372)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:566)
at org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:214)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2588)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2521)
at org.eclipse.ui.internal.WorkbenchPage.access$10(WorkbenchPag e.java:2513)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2498)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2493)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2470)
at org.eclipse.ui.internal.editors.text.OpenExternalFileAction. run(OpenExternalFileAction.java:132)
at org.eclipse.ui.internal.editors.text.OpenExternalFileAction. run(OpenExternalFileAction.java:100)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:254)
at org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPl uginAction.java:229)
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1085)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3164)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2840)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
--------------040304070602090401000501--
| Re: [solved] Re: The very begining fails [message #5866 is a reply to message #5794] |
Thu, 31 August 2006 15:02   |
Hi James, all,
Nice indeed.
And nice from you sou underlining that :-)
Now I must try to :
- Do the job to draw the formal model my core business process with
it, being a newbie in this stuff myself
- convince my developpers to rely on something modeled in an IDE, giving
they'd rather pray Emacs and GraphVis Gods and hate IDEs...
.... [deep breathe] :-\
Could you tell me where I could post if necessary for functional and not
technical about how to draw my model ?
Phil.
James Moody a écrit :
> Nice, glad it's working. Also good to know someone's running this on
> Unix. :-)
> james
> Philippe Brière wrote:
>> Hi james,
>> Thank's for this tip.
>> Indeed it was related to my JRE.
>> I changed this
>> 1 /usr/bin/gij-wrapper-4.1
>> *+ 2 /usr/lib/jvm/java-gcj/jre/bin/java
>> 3 /usr/lib/jvm/java-1.5.0-sun/jre/bin/java
>> ... for that :
>> * 3 /usr/lib/jvm/java-1.5.0-sun/jre/bin/java
>> ... doing :
>> sudo update-alternatives --config java
>> And everythig seems to go smooth now :-)
>> Thank you again and have a good day.
>> Phil
>>> Hi Philippe,
>>> This error looks to me like a JDK issue. What JDK (vendor and
>>> version) are you using?
>>> james
>>>> Seems that creating an empty simple project beforehand is necessary.
>>>> After that, selecting the projetct in workbench and then file/new,
>>>> gives acces to creating new BPEL Process.
>>>> Note that using of the "neb" button does not the same panel of new
>>>> objects to be created : BPEL process is not reachable that way. Bug ?
>>>> From now I try to reproduce this "at home succes" at my office
>>>> (same Ubuntu environement) and I get an error at creation of BPEL
>>>> process
>>>> java.lang.ClassNotFoundException: java.text.Bidi
>>>> at java.lang.ClassLoader.findClass(libgcj.so.7)
>>>> at java.lang.ClassLoader.loadClass(libgcj.so.7)
>>>> at
>>>> org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:364)
>>>> at
>>>> org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:352)
>>>> at
>>>> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:83)
>>>> at
>>>> org.eclipse.draw2d.text.BidiProcessor.process(BidiProcessor.java:190)
>>>> at org.eclipse.draw2d.text.BlockFlow.validate(BlockFlow.java:298)
>>>> at org.eclipse.draw2d.text.FlowPage.validate(FlowPage.java:150)
>>>> at
>>>> org.eclipse.draw2d.text.FlowPage.getPreferredSize(FlowPage.java:87)
>>>> at org.eclipse.draw2d.text.FlowPage.getMinimumSize(FlowPage.java:56)
>>>> at
>>>> org.eclipse.draw2d.BorderLayout.calculateMinimumSize(BorderLayout.java:94)
>>>> at
>>>> org.eclipse.draw2d.AbstractHintLayout.getMinimumSize(AbstractHintLayout.java:68)
>>>> at org.eclipse.draw2d.Figure.getMinimumSize(Figure.java:707)
>>>> at
>>>> org.eclipse.draw2d.StackLayout.calculateMinimumSize(StackLayout.java:44)
>>>> at
>>>> at
>>>> org.eclipse.draw2d.ToolbarLayout.calculateChildrenSize(ToolbarLayout.java:95)
>>>> at
>>>> org.eclipse.draw2d.ToolbarLayout.calculateMinimumSize(ToolbarLayout.java:131)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> org.eclipse.draw2d.ViewportLayout.calculatePreferredSize(ViewportLayout.java:65)
>>>> at
>>>> org.eclipse.draw2d.AbstractLayout.getPreferredSize(AbstractLayout.java:93)
>>>> at
>>>> org.eclipse.draw2d.AbstractHintLayout.getPreferredSize(AbstractHintLayout.java:85)
>>>> at org.eclipse.draw2d.Figure.getPreferredSize(Figure.java:735)
>>>> at
>>>> org.eclipse.draw2d.StackLayout.calculatePreferredSize(StackLayout.java:71)
>>>> at
>>>> at
>>>> at
>>>> org.eclipse.draw2d.FigureCanvas.computeSize(FigureCanvas.java:142)
>>>> at org.eclipse.swt.layout.FillData.computeSize(FillData.java:26)
>>>> at
>>>> org.eclipse.swt.layout.FillLayout.computeChildSize(FillLayout.java:148)
>>>> at
>>>> org.eclipse.swt.layout.FillLayout.computeSize(FillLayout.java:119)
>>>> at org.eclipse.swt.widgets.Composite.computeSize(Composite.java:210)
>>>> at org.eclipse.swt.layout.FormData.computeSize(FormData.java:116)
>>>> at org.eclipse.swt.layout.FormData.getWidth(FormData.java:146)
>>>> at
>>>> org.eclipse.swt.layout.FormData.getRightAttachment(FormData.java:247)
>>>> at
>>>> org.eclipse.swt.layout.FormLayout.computeWidth(FormLayout.java:264)
>>>> at org.eclipse.swt.layout.FormLayout.layout(FormLayout.java:330)
>>>> at
>>>> org.eclipse.swt.layout.FormLayout.computeSize(FormLayout.java:239)
>>>> at org.eclipse.swt.widgets.Control.pack(Control.java:926)
>>>> at
>>>> org.eclipse.bpel.common.ui.palette.GraphicalEditorWithPalette.createPartControl(Unknown
>>>> Source)
>>>> at
>>>> org.eclipse.bpel.common.ui.tray.GraphicalEditorWithPaletteAndTray.createPartControl(Unknown
>>>> Source)
>>>> at org.eclipse.bpel.ui.BPELEditor.createPartControl(Unknown Source)
>>>> at
>>>> org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:598)
>>>> at
>>>> org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:372)
>>>> at
>>>> org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:566)
>>>> at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:290)
>>>> at
>>>> org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:142)
>>>> at
>>>> org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:271)
>>>> at
>>>> org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:66)
>>>> at
>>>> org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:395)
>>>> at
>>>> org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1149)
>>>> at
>>>> org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1098)
>>>> at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1314)
>>>> at org.eclipse.ui.internal.PartStack.add(PartStack.java:456)
>>>> at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:104)
>>>> at org.eclipse.ui.internal.PartStack.add(PartStack.java:442)
>>>> at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:113)
>>>> at
>>>> org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:61)
>>>> at
>>>> org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:218)
>>>> at
>>>> org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:210)
>>>> at
>>>> org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:821)
>>>> at
>>>> org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:721)
>>>> at
>>>> org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:679)
>>>> at
>>>> org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2586)
>>>> at
>>>> org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2521)
>>>> at
>>>> org.eclipse.ui.internal.WorkbenchPage.access$10(WorkbenchPage.java:2513)
>>>> at
>>>> org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.java:2497)
>>>> at
>>>> org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:67)
>>>> at
>>>> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2504)
>>>> at
>>>> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2478)
>>>> at org.eclipse.ui.ide.IDE.openEditor(IDE.java:388)
>>>> at org.eclipse.ui.ide.IDE.openEditor(IDE.java:350)
>>>> at
>>>> org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:275)
>>>> at
>>>> org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:139)
>>>> at
>>>> org.eclipse.jdt.internal.ui.actions.OpenActionUtil.open(OpenActionUtil.java:49)
>>>> at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:190)
>>>> at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:175)
>>>> at
>>>> org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchRun(SelectionDispatchAction.java:267)
>>>> at
>>>> org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(SelectionDispatchAction.java:244)
>>>> at
>>>> org.eclipse.jdt.internal.ui.packageview.PackageExplorerActionGroup.handleOpen(PackageExplorerActionGroup.java:307)
>>>> at
>>>> org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$4.open(PackageExplorerPart.java:652)
>>>> at
>>>> org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:818)
>>>> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
>>>> at org.eclipse.core.runtime.Platform.run(Platform.java:844)
>>>> at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:45)
>>>> at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:150)
>>>> at
>>>> org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:813)
>>>> at
>>>> org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1071)
>>>> at
>>>> org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1169)
>>>> at
>>>> org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:248)
>>>> at
>>>> org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:243)
>>>> at
>>>> org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:283)
>>>> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:62)
>>>> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1087)
>>>> at
>>>> org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3150)
>>>> at
>>>> org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:2840)
>>>> at
>>>> org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:1914)
>>>> at
>>>> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:419)
>>>> at
>>>> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
>>>> at
>>>> org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplication.java:95)
>>>> at
>>>> org.eclipse.core.internal.runtime.PlatformActivator$1.run(PlatformActivator.java:78)
>>>> at
>>>> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:92)
>>>> at
>>>> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:68)
>>>> at
>>>> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
>>>> at
>>>> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:177)
>>>> at java.lang.reflect.Method.invoke(libgcj.so.7)
>>>> at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336)
>>>> at org.eclipse.core.launcher.Main.basicRun(Main.java:281)
>>>> at org.eclipse.core.launcher.Main.run(Main.java:978)
>>>> Any help would be greatly welcomed.
>>>> Phil
>>>> Philius a écrit :
>>>>> Hi there,
>>>>> never created.
>>>>> 2.
>>>>> right or did I misss answering posts somewhere ?
>>>>> Thanks for help.
>>>>> Phil
>>>>> input file.
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>>>>> at
>>>>> at
| Re: [solved] Re: The very begining fails [message #5951 is a reply to message #5902] |
Fri, 15 September 2006 02:19  |
Originally posted by: rthummala.gmail.com
I too am facing the same problems. Where in eclipse should I change these
settings. I tried giving various JRE versions for the project but still it
does not work.
-Raghu
FUDForum. Page generated in 0.05351 seconds
