Home » Archived » Riena » Problem getting transaction manager
| Problem getting transaction manager [message #7849] |
Fri, 22 August 2008 18:37  |
Hi Guys,
After Integrate EasyBeans with Eclipse proceed
http://ekkes-corner.blogspot.com/2008/06/easybeans-und-equin ox.html.
Im getting this error on OSGI. Its possible to fix this?
22/08/08 19:15:28 (S) NamingManager.createEnvironmentContext : Cannot
lookup UserTransaction.
javax.naming.NameNotFoundException: javax.transaction.UserTransaction
[Root exception is java.rmi.NotBoundException:
javax.transaction.UserTransaction]
at
org.ow2.carol.jndi.registry.AbsRegistryWrapperContext.lookup (AbsRegistryWrapperContext.java:99)
at org.ow2.carol.jndi.spi.AbsContext.lookup(AbsContext.java:142 )
at org.ow2.carol.jndi.spi.AbsContext.lookup(AbsContext.java:152 )
at javax.naming.InitialContext.lookup(Unknown Source)
at org.ow2.carol.jndi.spi.MultiContext.lookup(MultiContext.java :117)
at
org.ow2.easybeans.naming.NamingManager.createEnvironmentCont ext(NamingManager.java:121)
at
org.ow2.easybeans.deployment.helper.JavaContextHelper.build( JavaContextHelper.java:76)
at
org.ow2.easybeans.container.JContainer3.createBeanFactories( JContainer3.java:425)
at org.ow2.easybeans.container.JContainer3.start(JContainer3.ja va:340)
at
org.ow2.easybeans.osgi.ejbjar.Activator.startContainer(Activ ator.java:147)
at
org.ow2.easybeans.osgi.ejbjar.EmbeddedServiceListener.servic eChanged(EmbeddedServiceListener.java:67)
at
org.eclipse.osgi.framework.internal.core.FilteredServiceList ener.serviceChanged(FilteredServiceListener.java:91)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.d ispatchEvent(BundleContextImpl.java:1248)
at
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:211)
at
org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEv entSynchronous(ListenerQueue.java:141)
at
org.eclipse.osgi.framework.internal.core.Framework.publishSe rviceEventPrivileged(Framework.java:1563)
at
org.eclipse.osgi.framework.internal.core.Framework.publishSe rviceEvent(Framework.java:1538)
at
org.eclipse.osgi.framework.internal.core.ServiceRegistration Impl.register(ServiceRegistrationImpl.java:122)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.c reateServiceRegistration(BundleContextImpl.java:666)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.r egisterService(BundleContextImpl.java:617)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.r egisterService(BundleContextImpl.java:685)
at
org.ow2.easybeans.osgi.core.EZBCoreService.start(EZBCoreServ ice.java:138)
at
org.ow2.easybeans.osgi.core.EZBCoreService.activate(EZBCoreS ervice.java:187)
at
org.eclipse.equinox.internal.ds.model.ServiceComponent.activ ate(ServiceComponent.java:118)
at
org.eclipse.equinox.internal.ds.model.ServiceComponentProp.a ctivate(ServiceComponentProp.java:149)
at
org.eclipse.equinox.internal.ds.model.ServiceComponentProp.b uild(ServiceComponentProp.java:290)
at
org.eclipse.equinox.internal.ds.InstanceProcess.buildCompone nt(InstanceProcess.java:578)
at
org.eclipse.equinox.internal.ds.InstanceProcess.buildCompone nts(InstanceProcess.java:195)
at org.eclipse.equinox.internal.ds.Resolver.getEligible(Resolve r.java:317)
at
org.eclipse.equinox.internal.ds.SCRManager.serviceChanged(SC RManager.java:213)
at
at
at
at
at
at
at
at
at
at
org.ow2.easybeans.osgi.component.EZBComponentServiceFactory. updateMapsAndRegisterService(EZBComponentServiceFactory.java :219)
at
org.ow2.easybeans.osgi.component.EZBComponentServiceFactory. updated(EZBComponentServiceFactory.java:198)
at
org.eclipse.equinox.internal.cm.ManagedServiceFactoryTracker $2.run(ManagedServiceFactoryTracker.java:177)
at
org.eclipse.equinox.internal.cm.SerializedTaskQueue$1.run(Se rializedTaskQueue.java:36)
Caused by: java.rmi.NotBoundException: javax.transaction.UserTransaction
at
org.ow2.carol.jndi.registry.jrmp.ManageableRegistry.lookup(M anageableRegistry.java:126)
at
org.ow2.carol.jndi.registry.AbsRegistryWrapperContext.lookup (AbsRegistryWrapperContext.java:97)
... 47 more
22/08/08 19:15:28 (S) ContextImpl.unbind : CompNamingContext nothing to
unbind
!SESSION 2008-08-22 19:15:21.656
eclipse.buildId=unknown
java.version=1.6.0_07
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=pt_BR
Command-line arguments: -dev
file:C:/dsbi/plataform/osgi_temp/configuration_area/easybean s_launch_config/dev.properties
-os win32 -ws win32 -arch x86 -console -clean -consoleLog
!ENTRY org.eclipse.osgi 4 0 2008-08-22 19:15:28.203
!MESSAGE An unexpected runtime error has occurred.
!STACK 0
java.lang.IllegalStateException: Cannot remove java:comp/UserTransaction
object
at
org.ow2.easybeans.deployment.helper.JavaContextHelper.build( JavaContextHelper.java:99)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by: javax.naming.NameNotFoundException: UserTransaction
at
org.ow2.easybeans.naming.context.ContextImpl.unbind(ContextI mpl.java:309)
at
org.ow2.easybeans.deployment.helper.JavaContextHelper.build( JavaContextHelper.java:97)
... 40 more
!ENTRY br.com.cgsys.easybeans.demo 4 0 2008-08-22 19:15:28.203
!MESSAGE
!STACK 0
object
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 40 more
| Re: Problem getting transaction manager [message #8866 is a reply to message #8846] |
Mon, 25 August 2008 08:49   |
Hi! Christian campo,
I am from Brazil, my project is a system for accounting and finances, an
environment for interactive visual analysis, with objective of decision
support. He Is back-end sits on top of existing information systems,
legacy infrastructure, and proprietary sources and data feeds.
I want to use Riena and EJB in this project , I need help to decide which
the best solution: EasyBeans embedded in the OSGi environment or solution
based on JBoss.
I am thankful for any help and a basic example "if possible", something
as, very basic application contains a stateless bean, demonstrate:
Riena-Client -> Riena Server -> EJB (EasyBeans or JBoss).
| Re: Problem getting transaction manager [message #8886 is a reply to message #8866] |
Mon, 25 August 2008 09:00   |
> which the best solution: EasyBeans embedded in the OSGi environment or
> solution based on JBoss.
Hi Jose,
as I said I havnt used EasyBeans, so I cant give you an example on how to use it neither without Riena or with Riena.
There are multiple samples UI, remote Services, security about the pieces in Riena that we already have. None of them
currently is linked to EasyBeans. Maybe there are others like Ekke who has experience with Easybeans and Riena.
Maybe there is someone who has used it with JBoss too.
christian campo
| Re: Problem getting transaction manager [message #8906 is a reply to message #8866] |
Mon, 25 August 2008 10:02  |
Originally posted by: ekkehard.gentz-software.de
hi missias,
....think I can help you
but this week I'm on vacation
ekke
| Re: Problem getting transaction manager [message #573466 is a reply to message #7849] |
Sat, 23 August 2008 05:08  |
hi missias,
the stacktrace isn't enough to see what went wrong.
at the moment I'm on vacation and have not much time to look into it.
but I'll place soon a new blog entry about integration of Easybeans
1.1.0 + Riena M3 (or upcoming M4) + Eclipse / Equinox 3.4
this works great, but there are some pitfalls to watch.
ekke
Missias schrieb:
> Hi Guys,
> I�m getting this error on OSGI. It�s possible to fix this?
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 47 more
> unbind
> !STACK 0
> object
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 40 more
> !MESSAGE !STACK 0
> object
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 40 more
| Re: Problem getting transaction manager [message #573637 is a reply to message #7916] |
Mon, 25 August 2008 04:46  |
Missias schrieb:
> Ekkes,
> You can send me some basic example of integration Riena Client + Riena
> Service + EasyBeans, can be very simple. Thank you!
So hopefully Ekke can help you. Apparently you are looking for help how to use EasyBeans in the OSGi environment. Are
you using Riena at all yet ?
I have not used EasyBeans myself so I cant help you on that topic, sorry.
christian campo
| Re: Problem getting transaction manager [message #573657 is a reply to message #8846] |
based on JBoss.
| Re: Problem getting transaction manager [message #573677 is a reply to message #8866] |
Hi Jose,
christian campo
| Re: Problem getting transaction manager [message #573698 is a reply to message #8866] |
hi missias,
ekke
Current Time: Thu Nov 06 11:51:34 EST 2025
Powered by FUDForum. Page generated in 0.05480 seconds
