Home » Eclipse Projects » OSEE » Importing from Word
Importing from Word [message #14568] Fri, 01 May 2009 11:44 Go to next message
Sorry if I've missed this in the help but I have gone and looked!
The FAQ says that OSEE can import from a Word XML by heading to generate
artifacts. I can't find a BLAM to carry out this action and it doesn't
seem to be in the import options.
How does one do this please?
Re: Importing from Word [message #14655 is a reply to message #14568] Thu, 07 May 2009 15:15 Go to previous message
You can import a wordMl document by dragging and dropping a file from your
desktop onto a folder or any other artifact in Artifact Explorer. After
the drop occurs, the Artifact Import Wizard should open. Select Word
Outline or Whole Word Document import method, and the type of artifact you
want to create (Software Requirement, etc...). Click finish if you
selected Whole Word Document, this should import the doc onto OSEE. If you
selected Word Outline, click next and select the outline handler -
probably general outlien documents should work. Click finish.
This same process can be used to import excel xml docs, or any other
native document. Just make sure you select the appropriate import method.
See the following for more information regarding word ml format:
http://wiki.eclipse.org/OSEE/FAQ#Can_I_import_existing_Micro soft_Word.28c.29_documents_into_OSEE.3F
Re: Importing from Word [message #573539 is a reply to message #14568] Thu, 07 May 2009 15:15 Go to previous message
Previous Topic:Can I start the app server in Eclipse?
Next Topic:Can I start the app server in Eclipse?
Current Time: Thu Nov 27 06:17:11 EST 2025
Powered by FUDForum. Page generated in 0.04282 seconds
