Web Project doesn't Build/Publish Correctly [message #573285] |
Mon, 23 August 2010 17:20  |
We have a large web app with multiple Maven projects. Command-line seems to work fine, but with Eclipse+IAM, the project seems to deploy correctly only about 50% of the time.
First, I'm not convinced that the Publish on the Server window is working correctly. I've been using winmerge to validate publishing and I've noticed frequent problems. (Plz, point me in the right direction on this one). It seems like if I do a Clean-Publish, then it should nail it each and every time and it doesn't.
However, about 25% of the time, it appears that the build has failed or jammed somehow. Closing and reopening the project seems to kick it back into motion and also gets the webapp to publish correctly.
Any pointers on how to debug would be greatly appreciated. I'm on a project with 20+ developers that all have this issue.
--Kurt
Re: Web Project doesn't Build/Publish Correctly [message #573336 is a reply to message #573285] |
Mon, 23 August 2010 18:04   |
There are a lot of improvements to WTP deployment in 0.12, available at
http://q4e.googlecode.com/svn/trunk/updatesite-dev/
If you still have issues with that build, please let us know what
appserver and version are you using, and what issues do you have.
I have used it successfully with jetty, tomcat, jboss and websphere,
having overlayed wars, EARs,...
> --Kurt
Re: Web Project doesn't Build/Publish Correctly [message #631457 is a reply to message #573336] |
Thu, 07 October 2010 11:01  |
Hi Carlos,
I still can't seem to install the developer version:
I run into these MD5 errors:
Quote: |
An error occurred while collecting items to be installed
session context was:(profile=epp.package.jee, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
Problems downloading artifact: osgi.bundle,javax.xml,1.3.4.v200902170245.
MD5 hash is not as expected. Expected: 5906e465e1d260a8284ff6d0cb2b4ac2 and found e1c050883ffe3d7f18da374d591e3297.
Problems downloading artifact: osgi.bundle,org.apache.commons.codec,1.3.0.v20080530-1600.
MD5 hash is not as expected. Expected: 463eaee3a15b2aa436a71a01295ac64d and found 5c508c23e8bfa04e92093c49ab10fa94.
Problems downloading artifact: osgi.bundle,org.apache.commons.collections,3.2.0.v2008030618 11.
MD5 hash is not as expected. Expected: e0ef92afcfb63905fa6b5fcbce31aaaf and found eae0208c9a0ec23538b65f6c45cd840b.
Problems downloading artifact: osgi.bundle,org.apache.commons.lang,2.3.0.v200803061910.
MD5 hash is not as expected. Expected: 75424cbbd383dc7e3479eee6089612e5 and found c9f7ce1d04eb55945ce1161b0064509c.
Is there a way around these?
--Kurt
FUDForum. Page generated in 0.04532 seconds
